birazcık yardım
Başlatan mirzeydin, 05 Nisan 2003, 01:55:30
mirzeydin
arkadaşlar kusura bakmayın ama sizden bir ricam var aşağıdaki asembler ile yaılmış olan programı hex haline bir türlü çeviremedi çevirebilen arkadaşlar
lütfen yardımcı olurmusunuz. TEŞEKKÜRLER
#case
#include <16F84.H>
// Configure PIC to use: HS clock, no Watchdog Timer,
// no code protection, enable Power Up Timer
#fuses HS,NOWDT,NOPROTECT,PUT
// Tell compiler clock is 10MHz.  This is required for delay_ms()
// and for all serial I/O (such as printf(...).  These functions
// use software delay loops, so the compiler needs to know the
// processor speed.
#use DELAY(clock=10000000)
// Declare that we'll manually establish the data direction of
// each I/O pin on port B.
#use fast_io(B)
// Standard definitions for the irx2_1 board
#define RS232_XMT       PIN_B1  // (output) RS232 serial transmit
#define RED_LED         PIN_B2  // (output) Red LED (low true)
#define IR_LED          PIN_B3  // (output) Infrared LED (low true)
#define IR_SENSOR       PIN_B4  // (input) IR sensor (Sharp IS1U30)
#define RS232_RCV       PIN_B5  // (input) RS232 serial receive
// Macros to simplify I/O operations
#define RED_LED_ON      output_low(RED_LED)
#define RED_LED_OFF     output_high(RED_LED)
#define IR_LED_ON       output_low(IR_LED)
#define IR_LED_OFF      output_high(IR_LED)
#define IR_RECEIVED   (!input(IR_SENSOR))
// Default tri-state port direction bits: all PORT B bits are
// output except for IR_SENSOR (bit 4) and RC232_RCV (bit 5).
#define IRX_B_TRIS      0b00110000
// Inform printf() and friends of the desired baud rate
// and which pins to use for serial I/O.
#use rs232(baud=9600, xmit=RS232_XMT, rcv=RS232_RCV)
void main() {
 // since we've declared #use fast_io(B) (above), we MUST
 // include a call to set_tris_b() at startup.
 set_tris_b(IRX_B_TRIS);
 RED_LED_ON;                    // reality check at startup
 delay_ms(200);
 RED_LED_OFF;
 while (1) {
   RED_LED_ON;                  // turn on the led
   printf("Hello, world.\r\n"); // print to serial port
   RED_LED_OFF;                 // turn off the led
   delay_ms(500);               // do nothing for half a second
AlundrA
merhaba bu neyazıkki assembly değil  :D  C kodu ccs picc ile compile ettim mail adresiniz olsaydı gönderecektim ama yok
yapabilirim!
mirzeydin
özür dilerim mailimi yazmayı unutmuşum mailim aşağıda gönderirseniz sevinirim
mirzeydin@hotmail.com
mirzeydin
teşekkürler dostum mailini aldım
muratyamak10
dotmatrix kayan yazı programı yapmak istiyorum pic asm ile yanlız bir noktada takılıyorum tarama, ve seri veri gönderme yardımcı olurmusunuz lütfen
