Siemens Simatic PDM v6.0 SP2
Başlatan aslan_korhan, 28 Eylül 2006, 01:12:13
aslan_korhan
Siemens Simatic PDM v6.0 SP2 Multilanguage
SIMATIC PDM (Process Device Manager) is a universal cross-manufacturer tool for configuration, parameter assignment commissioning, diagnostics and maintenance of intelligent process devices and automation components. With SIMATIC PDM, you can use one software program to configure a number of field devices by different manufacturers using a single user interface. Process device data can be easily set, changed, checked for plausibility, managed and simulated. In addition, you can monitor selected process values, alarms and status signals of devices online.
The core functions are:
* Setting and changing device parameters
* Comparison of setpoint and actual parameter assignment
* Plausibility check on entries
* Simulation
* Diagnostics
* Management
* Commissioning function, e.g. measuring circuit testing of process device data
* LifeList
* Protocoll Functions
SIMATIC PDM is the most efficient product of its kind on the market as regards device integration. This offers security, and saves investment, training and subsequent costs.
You can use SIMATIC PDM in two ways:
* As an integrated tool in STEP 7 and thus as an integral part of the engineering system of SIMATIC PCS 7.
* Independent of system suppliers to a PC/PG under the Windows 95/98/ME/NT/2000 /XP operating systems.
Major Advantages at a Glance
* Simple, operating system-independent integration of field devices based on a device descriptions (e.g. EDD or HART DD)
* Similar visualization of all field devices
* Provides basic functions (e.g. export, data comparison, printing) for all field devices
* Various communications possibilities (e.g. PROFIBUS DP/PA, HART, Modbus)
* No configuration knowledge required for parameter assignment and diagnostics of field devices via the LifeList.
* Type-independent and cross-manufacturer field device parameter assignment and diagnostics
* Support of comprehensive field device-specific functions (simulation, measuring circuit test, character tics curve definition, calibration functions, documentation etc.) which can form the overall characteristics of field device manufacturers
* All field device parameters can be changed smoothly online, without having to stop the PROFIBUS master.
* Over 1,000 integrated field devices from more than 150 manufacturers worldwide (version 07/2003).
* Installed large base with more than 4,000 systems worldwide (version 07/2003).
FULL ISO
http://rapidshare.de/files/34678397/sismpd6a.rar           - 247.47 MB
http://rapidshare.de/files/34679429/sismpd6b.rar           - 186.85 MB
http://rapidshare.de/files/34216247/tbepdm.rar              - 101.8 MB
MANUAL.ADDON
http://rapidshare.de/files/34216111/tbepma.rar              - 58.9 MB
CATALOG.ADDON
http://rapidshare.de/files/34216585/tbepdc.rar               - 188.9 MB
Şifre : www.devilived.com
