AWG American Wire Gauge
Başlatan bunalmis, 02 Kasım 2006, 01:45:34
   In the US at least, wire is graded according to the American Wire Gauge (AWG) standard. You can see from the photo above that different wire gauges are considerably different in size. We recommend the following:
   AWG 30 - for wiring of very low current electronic signals over short distances where there is absolutely no mechanical movement of the wire. Resistance is 4/1000'
   AWG 22 - is excellent for all kinds of hook-up wiring. Not too small to break all the time, and not too heavy to restrict movement. Useful when the current doesn't exceed an amp or two. Very commonly used in long runs of low current twisted pair cable. Resistance is 16.20/1000'.
   AWG 18 - quite heavy wire for high current use - up to 10A perhaps. Resistance is 6.3/1000'
   AWG 16 - very heavy duty wire for high current use - beyond 10A. Resistance is 4/1000'
AWG ile tel çapı arasındaki matematiksel bağıntıyı nihayet buldum.
D = 0.127 x 92^((36-n)/39)
Burada n, AWG değerimiz. D ise mm cinsinden telimizin çapı.
Örneğin 10 AWG kaç mm ?
D = 0.127 x 92^((36-10)/39)
D = 0.127 x 92^(26/39)
D = 0.127 x 20.379
D = 2.588 mm
Daha fazla bilgi için  http://en.wikipedia.org/wiki/American_wire_gauge
Aşağıdaki link ise online hesaplama yapıyor.
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=util_awg_calc
