Digchip üzerinden bazı yeni malzemeler...(bilgi amaçlı)
Başlatan sitenindelisi, 12 Nisan 2007, 00:03:13
sitenindelisi
Alıntı yapılan: "digchip mail ile"
Below you will find the list of new components appeared on March 2007
» Analog & Mixed-Signal Processing
MCP6S28: Programmable Gain Amplifier
ISL55014:MMIC Silicon Bipolar Broadband Amplifier...
ISL55191:Single and dual high speed operational...
INA270:Current-shunt monitors with voltage ...
TSH173:Single supply triple video buffer and filter...
TSH344:340MHz single-supply triple video buffer...
LMH6733:High-performance CMOS analog-to-digital converter...
TS3022:Rail-to-Rail 1.8V High-Speed Micropower Comparator...
LMH7322:High-performance CMOS analog-to-digital converter...
NUF6001MU:6 line EMI filter array for wireless applications...
CAT5126:Digital programmable potentiometer. The wiper position...
TS12A4517:Single pole/single throw (SPST), low-voltage...
STG5682Low voltage dual SPDTswitch with negative rail capacitance...
» Automotive
ATA6603:LIN and Microcontroller System-In-Package...
ATA6662:LIN Transceiver...
» Communication
DS26519:Single-chip 16-port framer and line interface unit...
ATR7040:5.8 GHz WDCT Power Amplifier...
ATR2820:Low IF WDCT 5.8 GHz Transceiver...
VSC8239:9.953 Gbps to 11.32 Gbps Dual XFP Signal Conditioner...
DS26518:Single-chip 8-port framer and line interface unit...
CMX865A:Multi-standard modem for use in Wireless Local Loop...
HMC543LC4B:4-bit digital phase shifter...
AT86RF230:Low-power 2.4 GHz transceiver specially designed...
LX5514:Next generation 2.4GHz wireless LAN power amplifier...
» Data Conversion
ADC12C170:High-performance CMOS analog-to-digital converter...
ADC14V155:High-performance CMOS analog-to-digital converter...
AD7982:18-bit, successive approximation, analog-to-digital...
» Discrete
UJA1069:Fail-safe System Basis Chip (SBC) replaces basic discrete...
KDV142EL:For antenna switches in mobile applications....
BZX84J:General-purpose Zener diodes in a SOD323F (SC-90) very small...
USCD012:Schottky Barrier Rectifiers...
15LJQ100:15A 100V Hi-Rel Schottky Discrete Diode in a SMD-0.5 package...
22CGQ045:35A 45V Hi-Rel Schottky Common Cathode Diode in a TO-254AA package...
IR3510M:Hot-Swap N+1 Redundant XPhase Control IC...
STTH120R04TV:Ultrafast recovery diode...
STTH30R04:Ultrafast recovery diode...
PMD9010D:The PMD9010D comprises two NPN transistors and a high-speed switching...
S2000AF:High voltage NPN Power transistor for standard Definition CRT display...
EIB3439-4P:8 Volt Internally Matched Power FETs (MFETs)...
ZXMP2120FF:200V P-channel enhancement mode MOSFET in the SOT2...
ISL83204A:60V/2.5A Peak, High Frequency Full Bridge FET Driver...
ISL6130:Power Sequencing Controllers...
STRH13N20SY3:Power MOSFETs for Aerospace...
STRH10N25ESY3:Power MOSFETs for Aerospace...
STB9NK90Z:N-CHANNEL 900V 1.1 OHM 8A TO-220 TO-220FP TO-247 D2PAK...
STB140NF55:N-CHANNEL 55V - 0.0065Ohm - 80A TO-220/D2PAK STripFET TM II Power MOSF...
» Interface and Interconnect
DS8007:Multiprotocol dual smart card interface is a low-cost,...
MAX13487E:+5V, half-duplex, ±15kV ESD-protected RS-485/R...
NCV7708A:Fully protected Hex Half Bridge Driver designed...
DS15BA101:High-speed differential buffer for cable driving,...
DS40MB200:Dual signal conditioning 2:1 multiplexer and 1:2...
AT83C5136:USB C51-based Microcontroller with 32K Bytes ROM, 1280 bytes RAM,...
AT90USB162:USB Microcontroller....
ISP1110:Universal Serial Bus (USB) transceiver that supports...
ISL54200:Dual 2:1 multiplexer IC is a single supply part...
AT83C5135:USB C51-based Microcontroller with 16K Bytes ROM, 1280 bytes RAM,...
STUSB02E:USB TRANSCEIVER...
» Logic
74LVC3G34:High-performance, low-power, low-voltage, Si-gate...
74HC154:High-speed Si-gate CMOS device and is pin...
» Memory
FM24C512:512Kbit Ferroelectric Nonvolatile RAM...
M65KA512AB:512 Mbit (4 Banks x 8M x 16) , 133 MHz Clock Rate, Bare Die, 1.8V...
STK17TA8:1Mb nvSRAM + RTC...
FM24C512:512K bit Ferroelectric Nonvolatile RAM...
FM25256:512K bit Ferroelectric Nonvolatile RAM...
» Microcontrollers
FM25L256:256K bit Ferroelectric Nonvolatile RAM...
EM78P419N:8-bit microprocessors designed and developed with...
AT32UC3A1512:32-bit Flash Microcontroller based on AVR32 UC core featuring 512K...
VRS51L3074:FRAM-enhanced, high performance, 8051-based...
MM908E621:Integrated single-package solution that...
PIC18F85J90:LCD PIC18F Microcontroller with 32K bytes of Flash and 2048 bytes...
PIC24FJ64GA004:PIC24 16-bit Microcontroller, 64 KB Flash Memory, 8 KB RAM,...
HT82A832R:8-bit high performance RISC-like microcontroller...
PIC18F85J11:General Purpose PIC18 J-series Microcontroller providing 10 MIPS...
PIC18F97J60:Feature rich PIC18 Microcontroller with an integrated 10Mbps Ethernet...
» Microprocessors
SAM7XC512:Flash microcontroller with integrated Ethernet,...
» Multimedia
ZL30123:SONET/SDH Line Card Synchronizer is a highly integrated...
HT82V739:Integrated class AB mono speaker driver...
TPA3120D2:25-W (per channel) efficient, Class-D audio power...
LOG114:Specifically designed for measuring low-level and wide dynamic range currents...
STA516B:Audio Power Amplifier...
TS4997:2x1 W differential input stereo audio amplifier with programmable 3D...
CS4350:192 kHz Stereo DAC with Integrated PLL...
» Optoelectronics
EM6126:controller and driver for character monochrome TN and STN...
A8500:Multi-output WLED driver for medium display backlightin...
CAT4004:Four matched low dropout current sources to drive...
TPS61051:The 2-MHz switching frequency allows the use of small and low profile...
HT16565:Direct drive to VFD panels to implement a 24 hour...
OC100HG:10kV Opto-coupler...
» Power Management
CRS180G60:18kV CRT Power Supply...
XC61F:Highly precise, low power consumption voltage detector...
AIC1187:Ultra low dropout and high performance linear regulator...
MAX8662:Power-management ICs (PMICs) are efficient, compact...
MAX8731A:SMBus programmable multi-chemistry battery charger...
DS2792:User-programmable fuel gauge solution for Li-Ion...
MAX9775:Combine a high-efficiency Class D, stereo/mono audio...
IRPP3624-12A:12 Amp Single Phase Synchronous Buck POWER+ Chipset Reference Design..
ZXHF5000:Next generation of DBS IF integration for multiple output LNBs ...
ISL59837:Revolutionary device that allows true singlesupply operation of video amplifiers...
TPS65053:Integrated Power Management IC for applications power...
VN330SP-32-E:Intelligent Power Switches for Industrial...
L6563A:Advanced transition-mode PFC controller...
LTC4264:Integrated Powered Device (PD) interface controller...
MAX8677A:Integrated 1-cell Li+ charger and Smart Power...
MAX8840:Ultra-low-noise, low-dropout (LDO) linear...
AAT3697:Battery Manager is a highly integrated single-cell lithium...
MCP73812:Tiny 500mA charge management controller in SOT23....
XC9120:PWM, PWM/PFM auto/external switching controller...
KAB3403T:Monolithic step-up DC/DC converter...
AIC1594:Step-down monolithic PWM converters for deliver...
TL3577:Easy-to-use devices that incorporate all...
PM6670:Complete DDR2/3 memory power supply controller...
ST1S06:Synchronous rectification with inhibit, 1.5A, 1.5 MHz fixed or...
NCV8843:1.5 a buck regulator IC operation at a fixed frequency...
NCP5389:Two or three phase buck controller which combines...
TPS2062-1:Power-distribution switches are intended for applications...
MLX10803:General purpose LED driver for high power LEDs...
MAX8790:High-efficiency driver for white-light-emitting diode...
SP7616:Wide 4.5V to 30V operating range...
ISL6236A:Dual step-down, switch-mode power-supply (SMPS) controller...
AIC1848:Micropower charge pump DC/DC converter...
ISL9105:600mA, 1.6MHz step-down regulator that is ideal for power...
ISL8502:Synchronous buck controller with internal MOSFETs...
A8697:Constant off-time current mode step-down regulator...
LM5574:Easy to use SIMPLE SWITCHER® buck regulator which...
DS16EV5110:2.25 Gbps multi-channel equalizer optimized for...
XC6221:Precise, low noise, high speed, low dropout Regulator...
KIC3210T-030:150mA CMOS High Performance LDO Regulator...
ADM6710:Low voltage, high accuracy süpervisory...
STM6315:Open Drain Microprocessor Reset...
» RF & Microwaves
TGC4405:First new multi-function circuit (MFC)...
TGA4040-SM:This packaged part is a wide-band, medium power amplifier for 17-35 GHz...
TGA2520:This product is a high power amplifier designed for customers...
TGA2602-SM:High IP3 dual pHEMT discrete low noise...
CMX998:A Cartesian Loop improves the efficiency and linearity of transmitters...
CMX7032:Highly integrated, half-duplex, AIS baseband signalling processor...
PD64004AH:Four-port, mixed-signal, high-voltage Power over Ethernet...
TDA7529:RF front-end for AM/FM DSP car-radio with IF sampling...
HMC591:High dynamic range GaAs PHEMT...
HMC-C033:x2 active broadband frequency multiplier ...
TEA5766UK:Single chip electronically tuned FM stereo radio...
MLX12115:ISO compliant 13.56MHz RFID transceiver integrated...
ATA5577:Read/Write LF RFID IDIC® 100 to 150 kHz...
HMC253LC4:Non-reflective SP8T switch in...
» Sensors
SSD1921:Image processor for car AVs,...
MLX90316:CMOS Hall sensor that gives the angular position ...
MLX90242:CMOS Linear Hall Effect sensor IC. It possesses ...
ACS760:Hall-effect current monitor no external sense resistor required...
TPS31:Offer both absolute and gage pressure measurement...
MLX90614:Infra Red thermometer for non contact temperature ...
MCP6S21:Designs with multiple signals Designs that need to be calibrated over...
DS3600:Secure süpervisor with 64 bytes of SRAM for application...
» Timing Circuits
LM95214:11-bit digital temperature sensor with a 2-wire System...
LMK03000:Precision clock conditioner...
PI6C10807:1.5V/1.8V/2.5V, 250MHz, 1:10 Networking Clock Buffer...
PI6C10808:1.8V/2.5V, 250MHz, Low Skew 1:6 Crystal to LVCMOS Clock Buffer...
ISL14011:Low Jitter Clock Generators for Set-Top Box...
EM1564:Very low power crystal oscillator...
EM7604:Advanced low power CMOS circuit...
DS32B35:Accurate real-time clock (RTC) is a temperature-compensate...
DS3501:7-bit, nonvolatile (NV) digital potentiometer...
M41T82:Serial RTC with Battery Switchover...
