128x64 glcd resim gonderme sorunu
Başlatan mesmert, 09 Mayıs 2007, 13:56:59
mesmert
Slm arkadaşlar aşağıdaki kodu pic yardımıyla 128x64 grafik ekrana gönderecem ama picte max 255 kadar gönderebiliyoruz benim sormak istediğim 255 ten sonra nasıl bir yol izlemeliyimki aşağıdaki resmi glcd atmak için.
dt 	0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0xE0,0x60,0x60,0x60,0x70,0x30,0x30,0x38,0x1C,0x1C,0x9C,0x9C,0xCC,0xCC,0xCC,0xCC,0xC4,0xC4,0xC4,0xC4,0xC4,0xC6,0xC6,0xC6,0xE6,0xE6,0xE6,0xE6,0xE6,0xE6,0xE6,0xE6,0xE6,0xE6,0xC6,0xC6,0xC6,0xC4,0xC4,0xC4,0xC4,0xC4,0xC4,0xCC,0xCC,0xCC,0x8C,0x9C,0x1C,0x1C,0x18,0x38,0x30,0x70,0x70,0x60,0x60,0x60,0xC0,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
	dt 	0x00,0x00,0x00,0x80,0xE0,0xF0,0x78,0x3C,0x1C,0x8C,0x87,0x87,0xC7,0xF7,0xF1,0xF9,0xF8,0xFC,0xFC,0xFC,0xFC,0xFE,0xFF,0xFF,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7E,0x7C,0x7C,0x7C,0x7C,0x78,0xF9,0xF1,0xF1,0xE7,0x87,0x87,0x8E,0x1C,0x1C,0x78,0xF0,0xF0,0x80,0x00,0x00,0x00
	dt 	0x00,0xF0,0xFF,0x0F,0x07,0x00,0xF0,0xFC,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0x1F,0x1C,0x1C,0x9C,0xDC,0xFC,0x3C,0x1C,0x1C,0x1C,0x1C,0x9C,0xFC,0xFC,0xFC,0x1C,0x0C,0x00,0x00,0xC0,0xF0,0xF8,0xFC,0xFF,0x1F,0x1F,0x1F,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x9C,0xFC,0xFC,0xFF,0xFF,0xFF,0xE3,0x80,0x80,0x80,0x80,0x00,0x0C,0x1C,0x1C,0x3C,0xFC,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xF8,0x00,0x07,0x0F,0x1F,0xFC,0x00
	dt 	0x00,0x07,0x3F,0xF8,0xF0,0x80,0x83,0x0F,0x1F,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x9F,0x87,0x83,0x80,0x80,0xE0,0xF8,0xFF,0x9F,0x8F,0x83,0x80,0x80,0x80,0xF8,0xFC,0x9F,0x87,0x81,0x80,0x80,0x80,0xF0,0xFC,0xFF,0x87,0x83,0x81,0x80,0x80,0x80,0x80,0x8E,0x8E,0x8E,0xFE,0xFE,0xFE,0x9F,0x8F,0x8F,0x8F,0x8F,0x8F,0x8F,0x8F,0x8F,0x8F,0x87,0x87,0x80,0xC0,0xE0,0xF0,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x1F,0x0F,0x87,0x80,0xF0,0xF8,0x3E,0x1F,0x00
	dt 	0x00,0x00,0x00,0x00,0x01,0x07,0x07,0x0F,0x1C,0x1C,0x38,0x30,0x70,0xF3,0xC7,0xC7,0xCF,0x8F,0x0F,0x1F,0x1F,0x1F,0x1F,0x3F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x3F,0x3F,0x1F,0x1F,0x1F,0x1F,0x8F,0x8F,0xCF,0xC7,0xE3,0x71,0x30,0x38,0x18,0x1C,0x0E,0x0F,0x07,0x03,0x00,0x00,0x00,0x00
	dt 	0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x03,0x03,0x03,0x07,0x06,0x0E,0x0E,0x0C,0x1C,0x1C,0x1C,0x1C,0x1C,0x19,0x19,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x19,0x19,0x18,0x1C,0x1C,0x1C,0x1C,0x1C,0x0E,0x0E,0x06,0x06,0x07,0x03,0x03,0x03,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
CLR
iki yolla yapabilirsin, birincisi hex değerleri 255'lik parçalar halinde table'lar oluşturarak , ikincisi ise tüm bu hex değerleri her hangi bir eeprom'a yaz ve oradan pic ile oku ve glcd'ye yaz (bu ikinci yöntemle bir çok resmi glcd'de gösterebilirsin)
mp3dragon
Alıntı Yapzamanında yaptığım bir program. Karakterleri ve resimleri epromdan okuyor. Umarım işine yarar.
http://rapidshare.com/files/29970756/GLCD.rar.html
@mesmert, eemkutay haklı.
Daha önce verdiğim kod harici eepromdan karakter ve resim yüklemek amacıyla yazılmıştır. Harici bir hafıza kullanırsan daha esnek bir uygulama yapabilirsin.
mesmert
Bana görede mantıklı olan harici EEPROM daha basit çözüm olur diye düşünüyorum
