LCD saatte 12-24 sorunu yardım lütfen..
Başlatan mcguiverali, 05 Mart 2008, 23:49:27
mcguiverali
Öncelikle yeniden herkese merhabalar..
Sorum sudur bu kodun 24 lük saat düzenine göre calışması gerekiyor fakat 12 lik calışıyor ben bi turlu cözemedim birde sizin görüşlerinize sunayım dedim yardımcı olursanız sevinirim..
2. sorum ise acaba adım adım debug edcek ve herhangi bi registerin(örn. bu kodda SAAT değiskeni) degerini anlık gösterebilecek bi program varmıdır..
Şimdiden teşekkür ederim saygılarımla..
DEFINE LCD_DREG    PORTB
 DEFINE LCD_DBIT    0
 DEFINE LCD_RSREG   PORTB
 DEFINE LCD_RSBIT   4
 DEFINE LCD_EREG    PORTB
 DEFINE LCD_EBIT    5
 DEFINE LCD_BITS    4
 DEFINE LCD_LINES   2
 SAAT VAR BYTE
 DSAAT VAR BYTE
 DAKIKA VAR BYTE
 SANIYE VAR BYTE
 TMR0_SAY VAR BYTE
 GUNCELLE VAR BYTE
 I VAR BYTE
 PAUSE 100
 SAAT=0
 DAKIKA=0
 SANIYE=0
 TMR0_SAY=0
 GUNCELLE=1
 OPTION_REG=%01010101
 INTCON=%10100000
 ON INTERRUPT GOTO TMR0_KESME
 TRISB=%00000000
 TRISA=%11111111
 ANADONGU:
 IF PORTA.0=1 THEN DAK_AZALT
 IF PORTA.1=1 THEN DAK_ARTTIR
 IF PORTA.3=1 THEN SAAT_AZALT
 IF PORTA.2=1 THEN SAAT_ARTTIR
 KONTROL:
 IF GUNCELLE=1 THEN
 LCDOUT $FE,1
 DSAAT=SAAT
 IF(SAAT//12)=0 THEN
 DSAAT=DSAAT+12
 ENDIF
 IF SAAT<12 THEN
 LCDOUT DEC2 DSAAT,":",DEC2 DAKIKA,":", DEC2 SANIYE
 LCDOUT$FE,$C0,"SABAH"
 ELSE
 LCDOUT DEC2 (DSAAT-12),":",DEC2 DAKIKA,":", DEC2 SANIYE
 LCDOUT$FE,$C0,"OGLE"
 ENDIF
 GUNCELLE=0
 ENDIF
 GOTO ANADONGU:
 DAK_ARTTIR:
 DAKIKA=DAKIKA+1
 IF DAKIKA>=60 THEN
 DAKIKA=0
 SAAT=SAAT+1
 IF SAAT >=24 THEN
 SAAT=0
 ENDIF
 ENDIF
 GOTO ARK_SONDUR
 DAK_AZALT:
 DAKIKA=DAKIKA-1
 IF DAKIKA>=60 THEN
 DAKIKA=59
 SAAT=SAAT-1
 IF SAAT>=24 THEN
 SAAT=23
 ENDIF
 ENDIF
 GOTO ARK_SONDUR
 SAAT_AZALT:
 SAAT=SAAT-1
 IF SAAT<=0 THEN
 SAAT=24
 ENDIF
 GOTO ARK_SONDUR:
 SAAT_ARTTIR:
 SAAT=SAAT+1
 IF SAAT>=24 THEN
 SAAT=0
 ENDIF
 ARK_SONDUR:
 FOR I=1 TO 25
 PAUSE 10
 NEXT I
 GUNCELLE=1
 GOTO KONTROL
 DISABLE
 TMR0_KESME:
 TMR0_SAY=TMR0_SAY+1
 IF TMR0_SAY < 61 THEN KESME_SONU:
 TMR0_SAY=0
 SANIYE=SANIYE+1
 IF SANIYE>=60 THEN
 SANIYE=0
 DAKIKA=DAKIKA+1
 IF DAKIKA>=60 THEN
 DAKIKA=0
 SAAT=SAAT+1
 IF SAAT >=24 THEN
 SAAT=0
 ENDIF
 ENDIF
 ENDIF
 GUNCELLE=1
 KESME_SONU:
 INTCON.2=0
 RESUME
 ENABLE
 END
Düşünmeden öğrenmek beyhude, öğrenmeden düşünmek, tehlikelidir.....
mucitotomasyon
kod inceleme icin proteus kullan  tektek komutları ilerletirin
birde 24 saat diye gösterecem ama 12 gözüküyo dion attrıtıgın sayacı kadar arttırman lazım basic den anlasam  sorununu bulurdum
kadirbas
Esasında Basic kullanmadığım için ben de bilmiyorum ama kodu incelediğimde hatayı farkettiğimi düşünüyorum.
DSAAT=SAAT
 IF(SAAT//12)=0 THEN
 DSAAT=DSAAT+12
 ENDIF
 IF SAAT<12 THEN
 ELSE
 ENDIF
 GUNCELLE=0
Bu kısımdan benim anladığım, saatin 12lik saat düzenine göre gösterilmeye çalışıldığı ve hatta buna ek olarak "SABAH"  ya da "OGLE" ibaresinin de eklenmek istendiği. Basic bilen arkadaşlar da değerlendirirler gerçi.
Sanırım bu kodu hazır kullandığınız ve çok üzerine durmadığınız için farkedemediniz.
İyi çalışmalar...
mcguiverali
Alıntı yapılan: "kadirbas"
 LCDOUT$FE,$C0,"OGLE" '
quote]
DSAAT-12 yerine DSAAT yazınca düzeldi fakat ufak bi sorun daha var şimdide saat gece 00 oldugunda 12 .oglen 12 oldugunda ise 24 gösteriyor..yardımlarınızı bekliyorum..
mcguiverali
Alıntı yapılan: "mucitotomasyon"kod inceleme icin proteus kullan  tektek komutları ilerletirin
PROTEUS da registerlerin degerlerini görebiliyormuyuz peki?
mcguiverali
saat sorunun cözdüm..birkaçda ekleme yaptım ..bu benim bitirme ödevim olacak .tamamen bitirdigimde komple proje olarak siteye sunarım saygılar..
