Pic Assembly Gecikme Yardım
Başlatan GamzeDemir, 17 Mart 2008, 15:06:41
GamzeDemir
Merhaba Arkadaslar
Ben assembly den pek anlamam ama su an asm ile yazılmıs bi programa gecikme vermem lazım ama gecikme komutu diye bişey yok sanırım Embarassed Yani bi bakabilirmisin burada ki gecikme ayarı ne ile yapılmıs nereyi değiştirirsem istediğim kadar gecikme elde edebilirim lütfen yardım edin
Alıntı YapLIST P=16F84A
; C=80
; N=0
; R=DEC
INCLUDE "P16F84A.INC"
;* BIT CONST
C EQU 0
Z EQU 2
W EQU 0
F EQU 1
RP0 EQU 5
TOIF EQU 2
TOIE EQU 5
GIE EQU 7
RD EQU 0
WR EQU 1
EEIF EQU 4
;* USERS REG
TMR_SUR EQU D'12' ;
KLV_BRK_TMR EQU D'13' ;
TEST EQU D'14' ;
SON_TEMP EQU D'36' ;25
TON_D0 EQU 0 ;PORTB
TON_D1 EQU 1 ;PORTB
TON_D2 EQU 2 ;PORTB
TON_D3 EQU 3 ;PORTB
TON_EA EQU 4 ;PORTB
TX_OUT EQU 5 ;PORTB
TUS1 EQU 2 ;PORTA
TUS2 EQU 3 ;PORTA
TX_ON_LED EQU 0 ;PORTA
TX_OFF_LED EQU 1 ;PORTA
DTMF_ON_SUR EQU D'200' ;CONSTANT
DTMF_OFF_SUR EQU D'100' ;CONSTANT
INT_SUR EQU D'227' ;CONSTANT
DTMF_SIFIR EQU 00101010B
DTMF_BIR EQU 00100001B
DTMF_IKI EQU 00100010B
DTMF_UC EQU 00100011B
DTMF_DORT EQU 00100100B
DTMF_BES EQU 00100101B
DTMF_ALTI EQU 00100110B
DTMF_YEDI EQU 00100111B
DTMF_SEKIZ EQU 00101000B
DTMF_DOKUZ EQU 00101001B
DTMF_YILDIZ EQU 00101011B
DTMF_DIYEZ EQU 00101100B
DTMF_A EQU 00101101B
DTMF_B EQU 00101110B
DTMF_C EQU 00101111B
DTMF_D EQU 00100000B
ORG 00
GOTO START
ORG 04
INT;
MOVLW INT_SUR
MOVWF TMR0
BSF TEST,C ;992 uSN
BCF INTCON,TOIF
RETFIE
; START ROUTINE *;
START;
MOVLW B'00000000'
MOVWF PORTA
MOVLW B'00000000'
MOVWF PORTB
BSF STATUS,RP0
MOVLW B'11111100'
MOVWF TRISA
MOVLW B'11000000'
MOVWF TRISB
MOVLW B'00000100' ;1/32
MOVWF OPTION_REG
BCF STATUS,RP0
CLRF PORTA
CLRF PORTB
CLRF TMR0
BCF INTCON,TOIF ;TIMER INT ENABLE
BSF INTCON,TOIE
BSF INTCON,GIE
TUS_BIRAK:
MOVLW D'20'
CALL DELAY
NOP
BTFSS PORTA,TUS1
GOTO TUS_BIRAK
BTFSS PORTA,TUS2
GOTO TUS_BIRAK
MOVLW D'20'
CALL DELAY
BTFSS PORTA,TUS1
GOTO TUS_BIRAK
BTFSS PORTA,TUS2
GOTO TUS_BIRAK
KLV_TARA;
BTFSS PORTA,TUS1
GOTO TUS1_BAK
NOP
NOP
NOP
NOP
NOP
BTFSS PORTA,TUS2
GOTO TUS2_BAK
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
GOTO KLV_TARA
TUS1_BAK;
BTFSC PORTA,TX_ON_LED
GOTO TUS_BIRAK
BSF PORTB,TX_OUT
BSF PORTA,TX_ON_LED
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
MOVLW DTMF_YILDIZ
CALL DTMF_ON
CALL DTMF_OFF
MOVLW DTMF_SIFIR
CALL DTMF_ON
CALL DTMF_OFF
MOVLW DTMF_BIR
CALL DTMF_ON
CALL DTMF_OFF
GOTO TUS_BIRAK
TUS2_BAK;
BTFSS PORTA,TX_ON_LED
GOTO TUS_BIRAK
BCF PORTA,TX_ON_LED
BSF PORTB,TX_OUT
BSF PORTA,TX_OFF_LED
MOVLW DTMF_YILDIZ
CALL DTMF_ON
CALL DTMF_OFF
MOVLW DTMF_DIYEZ
CALL DTMF_ON
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
MOVLW DTMF_YILDIZ
CALL DTMF_ON
CALL DTMF_OFF
MOVLW DTMF_DIYEZ
CALL DTMF_ON
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
CALL DTMF_OFF
MOVLW DTMF_YILDIZ
CALL DTMF_ON
CALL DTMF_OFF
MOVLW DTMF_DIYEZ
CALL DTMF_ON
CALL DTMF_OFF
BCF PORTB,TX_OUT
BCF PORTA,TX_OFF_LED
GOTO TUS_BIRAK
DTMF_ON;
MOVWF PORTB
NOP
NOP
BSF PORTB,TON_EA
MOVLW DTMF_ON_SUR
CALL DELAY
BCF PORTB,TON_EA
RETURN
DTMF_OFF;
MOVLW DTMF_OFF_SUR
DELAY;
MOVWF TMR_SUR
DELAY_1;
BCF TEST,C
DELAY_2;
BTFSS TEST,C
GOTO DELAY_2
DECFSZ TMR_SUR,F
GOTO DELAY_1
RETURN
END
Sanırım gecikme kısmı surası
Alıntı YapDELAY;
MOVWF TMR_SUR
DELAY_1;
BCF TEST,C
DELAY_2;
BTFSS TEST,C
GOTO DELAY_2
DECFSZ TMR_SUR,F
GOTO DELAY_1
RETURN
Mesela ben CALL DELAY desem ne kadarlık gecikme saglamıs olurum bi fikri olan var mı   :cry:   :(
mucitotomasyon
asm de
gecikme  programı dedigin yer gecikmesinin basit bir hesabı var
internet te  bakarsan  bir cok kaynak bulursun bi zaman lar biliyodum asm bırakınca unttum
pioneer5900
dostum bu gecikme biraz yanlış gibi geldi bana bak bu döngü 1sn lik gecikme yapıyor.
GECIKME
 MOVLW  D'2'
 MOVWF  SAYAC1
DON1
 MOVLW  D'200'
 MOVWF  SAYAC2
DON2
 MOVLW  D'250'
 MOVWF  SAYAC3
DON3
DECFSZ  SAYAC3,F
 GOTO  DON3
 DECFSZ  SAYAC2,F
 GOTO  DON2
 DECFSZ  SAYAC1,F
 GOTO  DON1
RETURN
CALL   GECIKME yazarsan sayac1,sayac2,sayac3 e bağlı olarak bunların çarpımı olan 2*200*250=100000 adet makine saykılı gecikme olmuş oluyor buda 4 MHZ dış osilatörü olan bir pic için 1/4=1MHZ frekans ile
bir saykıl 1\1mhz=1usn oluyor.bunuda döngü sayısıyla çarparsan 1 sn gecikme sağlamış oluyorsun.(aslında call ve return komutu ilede 4 saykıl harcanıyor yani tam döngün 100004 oluyor 4saykıl ise 4usn lik bir gecikme sağlar .bunun için 250 yerine 249 yazarsan tam denk gelir.
Zorsa yaparız imkansız ise zaman alır....
pioneer5900
bu 249 meselesini yanlış hesapladık.. bu arada bayan olduğunuza dikkat etmedim kuusra bakmayınız kolay gelsin.
GamzeDemir
Alıntı yapılan: "pioneer5900"bu 249 meselesini yanlış hesapladık.. bu arada bayan olduğunuza dikkat etmedim kuusra bakmayınız kolay gelsin.
Rica ederim sorun değil sağol un yardımlarınız için gercekten çok yardımcı oldunuz inanın ;)
pioneer5900
bu arada birşeyi söylemeyi unuttuk sayac1,sayac2,sayac3 değişkenleri bir hafıza adresini göstermesi gerekiyor.pogramın başına eklenmeli
sayac1   equ   0x10
sayac2   equ   0x11
sayac3   equ   0x12
kolay gelsin.
kostebek
Alıntı yapılan: "pioneer5900"bu arada birşeyi söylemeyi unuttuk sayac1,sayac2,sayac3 değişkenleri bir hafıza adresini göstermesi gerekiyor.pogramın başına eklenmeli
sayac1   equ   0x10
sayac2   equ   0x11
sayac3   equ   0x12
kolay gelsin.
0x10 dan başlarsa çoğu pic de çalışmaz çok kullanılan 877 ve 628 için h'20' ideal ;)
pioneer5900
örnek olsun diye yazmıştım pic ten hiç anlamam yazmışsın o yüzden ..bilgi için teşekkürler..
