SMS / GPRS İle Araç Takip Güvenlik Sistemi
Başlatan armys2000, 21 Mayıs 2008, 23:56:13
armys2000
Arkadaşlar şema ve pcb demo programı vs dokümanı www.endofcode.com sitesinde bulabilirsiniz. son hali bu. Hatalar vs varsa arkadaşlar düzeltsin.
[code]
' AGS5V5.BAS
' 20.07.2007 Tarihli Modem Kartının 03.02.2008 12:46 Tarihli 18F452 Kodu
'-ampasmwin -oq -c -p18F452
' 03.02.2008 12:46
'************************   KONFİGÜRASYON    ***********************************
INCLUDE "modedefs.bas"                           ' File Include
DEFINE OSC 20                                 ' OSC Speed  Set 20 Mhz
adcon1  = 7
'************************      ATAMALAR      ***********************************
          'ISI1            VAR            PORTA.0         ' 1:24LC512 SCL I/O
         'ISI2            VAR            PORTA.1         ' 1:24LC512 SDA I/O
         'M2_SCL            VAR            PORTA.2         ' 2:24LC512 SCL I/O
         'M2_SDA            VAR            PORTA.3         ' 2:24LC512 SDA I/O
         'M3_SCL           VAR            PORTA.4         ' 3:24LC512 SCL I/O
         'M3_SDA            VAR            PORTA.5         ' 3:24LC512 SDA I/O
         Tmp1            VAR            PORTA.0         ' 1:24LC512 SCL I/O
         Tmp2            VAR            PORTA.1         ' 1:24LC512 SDA I/O
         GPRS_LED          VAR            PORTA.2         ' 2:24LC512 SCL I/O
         GPS_LED            VAR            PORTA.3         ' 2:24LC512 SDA I/O
         NC1              VAR            PORTA.4         ' 3:24LC512 SCL I/O
         NC2               VAR            PORTA.5         ' 3:24LC512 SDA I/O
'         ACIL            VAR            PORTB.0         ' ACIL TETIK INPUT
'         SUPHE            VAR            PORTB.1         ' ALARM TETIK INPUT
'         ALARM            VAR            PORTB.2         ' RS485 RECEIVER & TRANSMITTER ENABLE/DISABLE OUTPUT
'         AKU              VAR            PORTB.3         ' Programmer Port B3 I/O (INPUT) & AKU
'         Gprs_Det         VAR            PORTB.4         ' RS485 TX DATA OUTPUT
'         KONTAK            VAR            PORTB.5         ' RS485 RX DATA INPUT
'         TEMPIN            VAR            PORTB.6         ' Programmer Port B6 I/O (INPUT) & KONTAK
'         PGM_B7             VAR            PORTB.7         ' Programmer Port B7 I/O (INPUT) &
         PGM_B6            VAR            PORTB.6         ' Programmer Port B6 I/O (INPUT) & KONTAK
         'G24_CTS            VAR            PORTC.0         ' G24 CTS SIGNAL INPUT
         'G24_RTS            VAR            PORTC.1         ' G24 RTS SIGNAL OUTPUT
         'MCU_TXD          VAR            PORTC.2         ' MCU TX DATA OUTPUT
         'MCU_RXD            VAR            PORTC.3         ' MCU RX DATA INPUT
         'MCU_IN           VAR            PORTC.4         ' MCU IN INPUT
         'MCU_OUT         VAR            PORTC.5         ' MCU OUT OUTPUT
         'G24_TXD          VAR            PORTC.6         ' G24 TX DATA OUTPUT
         'G24_RXD          VAR            PORTC.7         ' G24 RX DATA INPUT
         G24_AUIN            VAR            PORTC.0         ' G24 CTS SIGNAL INPUT
         G24_SPWR            VAR            PORTC.1         ' G24 RTS SIGNAL OUTPUT
         G24_LED             VAR            PORTC.2         ' MCU TX DATA OUTPUT
         G24_RI            VAR            PORTC.3         ' MCU RX DATA INPUT
         G24_CTS           VAR            PORTC.4         ' MCU IN INPUT
         G24_RTS            VAR            PORTC.5         ' MCU OUT OUTPUT
'          GPS_RST            VAR            PORTD.0         ' GPS RESET OUTPUT
'         PIO_CTS            VAR            PORTD.1         ' GPS TX DATA OUTPUT
'         PIO_RTS            VAR            PORTD.2         ' GPS RX DATA INPUT
'         PIO_TXD            VAR            PORTD.3         ' G24 HARDWARE ON/OF OUTPUT
'         PIO_RXD          VAR            PORTD.4         ' G24 SOFTWARE ON/OF OUTPUT
'         ROLE             VAR            PORTD.5         ' CLOCK SCL I/O
'         GPS_RXD              VAR            PORTD.6         ' CLOCK SDA I/O
'         GPS_TXD          VAR            PORTD.7         ' G24 SOUND IN OUTPUT
         CAM_TXD            VAR            PORTD.1         ' CAMERA TX DATA OUTPUT
         CAM_RXD            VAR            PORTD.2         ' CAMERA RX DATA INPUT
         PIO_RXD          VAR            PORTD.4         ' G24 SOFTWARE ON/OF INPUT
         SYS_LED            VAR            PORTE.0         ' SYSTEM INDICATOR LED OUTPUT
         M1_SDA           VAR            PORTE.1         ' I2C Serial Data
         M1_SCL           VAR            PORTE.2         ' I2C Serial Clock
'************************   TRIS REGISTERS   ***********************************
           TRISA.0 = 1
           TRISA.1 = 1
           TRISA.2 = 0
           TRISA.3 = 0
           TRISA.4 = 1
           TRISA.0 = 1
           TRISB= %11111111
           TRISC= %10011000
           TRISD= %01010100
           TRISE.0 = 0
           TRISE.1 = 0
           TRISE.2 = 0
'*****************************     DEĞİŞKENLER    *****************************
         ' SYSTEM KAMERA Bilgileri
         Prmtr         VAR         BYTE[6]
         cSync         VAR         BYTE
         cAck         VAR         BYTE
         cNak         VAR         BYTE
         cAckCnt         VAR         WORD
         cNakCnt         VAR         WORD
         ColorType      VAR         BYTE
         PreviewRes      VAR         BYTE
         JpegRes         VAR         BYTE
         ResimType      VAR         BYTE
         ' SYSTEM ISI 1 Bilgileri  İçin
         R_Temp           VAR           WORD
         Cold_Bit       VAR          R_Temp.Bit11
         Polarite          VAR        BYTE
         Dummy          VAR        BYTE
         TempC          VAR        WORD
         Kusurat          VAR          WORD
         'Real_Cold      CON          1
         'Deg            CON          223
         DrmTemp1      VAR          BYTE
         'SYSTEM Zaman Bilgileri Paketler İçin
         sysSaat         VAR         BYTE[2]
         sysDakika      VAR         BYTE[2]
         sysSaniye      VAR         BYTE[2]
         sysHafta      VAR         BYTE[2]
         sysAy         VAR         BYTE[2]
         sysGun         VAR         BYTE[2]
         sysYil         VAR         BYTE[2]
         'PIO Veri Paketler İçin
         datAcil         VAR         BYTE
         datSuphe      VAR         BYTE
         datAlarm      VAR         BYTE
         datAku         VAR         BYTE
         datKontak      VAR         BYTE
         datRole         VAR         BYTE
         datMdmSPwr      VAR         BYTE
         datMdmHPwr      VAR         BYTE
         'Modem Ekran Bİlgisi Paketler İçin
         mdmBat         VAR         BYTE
         mdmSin         VAR         BYTE
         mdmReg         VAR         BYTE
         mdmMsg         VAR         BYTE
         mdmRom         VAR         BYTE
         mdmSmsFull      VAR         BYTE
         mdmGprs         VAR         BYTE
         mdmSim         VAR         BYTE
         mdmData         VAR         BYTE
          ErrModem      VAR         BYTE
         ' GPS Verisi Paketler İçin
         gpsTarih      VAR         BYTE[6]
         gpsGun          VAR         BYTE[2]
         gpsAy          VAR         BYTE[2]
         gpsYil          VAR         BYTE[2]
         gpsSaat          VAR         BYTE[2]
         gpsDakika       VAR         BYTE[2]
         gpsSaniye       VAR         BYTE[2]
         gpsStatu       VAR         BYTE
         gpsKuzey       VAR         BYTE[10]
         gpsDogu          VAR         BYTE[11]
         gpsHiz          VAR         BYTE[7]
         gpsSapma       VAR         BYTE[6]
         gpsData         VAR         BYTE
         gpsTmp1         VAR         BYTE
         gpsTmp2         VAR         BYTE
         ErrGPS         VAR         BYTE
         gpsCHS         VAR         BYTE
         ' SYSTEM Parametre Kayıtları
         ApnName         VAR         BYTE[10]
         ApnUser         VAR         BYTE[8]
         ApnPass         VAR         BYTE[8]
         KonsolID      VAR         BYTE[5]
         usrAdmin       VAR       BYTE[8]
         pasAdmin       VAR       BYTE[4]
         telMerkez      VAR       BYTE[15]
         ipServer      VAR         BYTE[12]
         prtServer       VAR       BYTE[5]
         telAcil1       VAR       BYTE[15]
         cagAcil1       VAR       BYTE
         telAcil2       VAR       BYTE[15]
         cagAcil2       VAR       BYTE
         msgAlarm       VAR       BYTE[40]
         ' Kontrolü Yapılacaklar
         kntAcil        VAR       BYTE
         kntSuphe      VAR         BYTE
         kntAlarm       VAR       BYTE
         kntKontak         VAR       BYTE
         kntAku         VAR       BYTE
         kntBloke       VAR       BYTE
         kntKamera      VAR         BYTE
         kntTakip       VAR       BYTE
         kntYer         VAR       BYTE
         kntMrkzBilgi   VAR         BYTE
         kntSysReset      VAR         BYTE
         ' SYSTEM Güvenlik Birimi
         usrKontrol      VAR       BYTE[8]
         pasKontrol      VAR       BYTE[4]
         usrType         VAR         BYTE
         ' SYSTEM Ana Birimi
         wr            VAR       BYTE
         Sender         VAR         BYTE
          KnslRstDeg      VAR         WORD
         strComp         VAR         BYTE
         addr         VAR         BYTE
         GprsPacType     VAR         BYTE
         SysCalType     VAR       BYTE
         EtkenCalType    VAR         BYTE
         RegGeneral      VAR         BYTE[256]
         ' SYSTEM G24 GPS Birimi
         i            VAR         BYTE
         j            VAR         BYTE
         VirSay         VAR         BYTE
         ' SYSTEM G24 GPRS Birimi
         GWR            VAR         BYTE
         Deger         VAR         BYTE
         WhoIs         VAR         BYTE
         GpKomut         VAR         BYTE
         G24SAYAC      VAR         WORD
         GpTaWait      VAR         WORD
         TmpGpWait      VAR         WORD
         G24ADDR         VAR         WORD
         G24TMP1         VAR         BYTE
         G24TMP2         VAR         BYTE
         G24TMP3         VAR         BYTE
          G24VERI         VAR         BYTE[350]
           GprsMesaj      VAR         BYTE[160]
         MipData1      VAR         BYTE[64]
         MipData2       VAR         BYTE[32]
         ' SYSTEM G24 SMS SOS Birimi
         telEtkin      VAR         BYTE[15]
         SosType         VAR         BYTE
         SmsPacType      VAR         BYTE[2]
         TxMesajType     VAR         BYTE
         ' SYSTEM G24 SMS MESAJ Birimi
         MsgIndex      VAR         BYTE
         SmsMesaj      VAR         BYTE[160]
         SmTaWait      VAR         WORD
         ' SYSTEM I2C Birimi
          MemAddrH      VAR         BYTE
          MemAddrL      VAR         BYTE
          MemAddr         VAR         WORD
          MemData         VAR         BYTE
          MemVeri         VAR         BYTE[52]
         ' SYSTEM FLAGLAR
         FlagMsgVar      VAR         BYTE
         FlgAcil          VAR         BYTE
         FlgSuphe      VAR         BYTE
         FlgAlarm      VAR         BYTE
         FlgAku           VAR         BYTE
         FlgKontak       VAR         BYTE
         FlgTakip       VAR         BYTE
         FlgYer        VAR         BYTE
         FlgBloke      VAR         BYTE
           FlgMsgVar      VAR         BYTE
         FlgGsmReg      VAR         BYTE
         FlgGprsReg      VAR         BYTE
         FlgGprsRom      VAR         BYTE
         FlgGprsNet        VAR         BYTE
         FlgGprsPing      VAR         BYTE
           FlgCalType      VAR         BYTE
           FlgGprsCom      VAR         BYTE
           FlgSosDurum      VAR         BYTE
         FlgGpTakip      VAR         BYTE
         FlgGpYer       VAR         BYTE
         FlgSmTakip      VAR         BYTE
         FlgSmsYer      VAR         BYTE
         FlgMipCall      VAR         BYTE
         FlgMipCallErr   VAR         BYTE
         FlgMipOpen      VAR         BYTE
         FlgMipOpenErr   VAR         BYTE
         FlgMipStat      VAR         BYTE
         FlgBaglanti     VAR         BYTE
         FlgPingSend      VAR         BYTE
         FlgPingRec      VAR         BYTE
         FlgPingErr      VAR         BYTE
          FlgRING          VAR         BYTE
         FlgKntkGitK      VAR         BYTE
         FlgKntkGitA      VAR         BYTE
         'FlgGecVeri      VAR         BYTE
         FlgGpNoTxD      VAR         BYTE
         'SYSTEM SAYAÇLARI
         SayGsmSin      VAR         BYTE
         SayGsmReg      VAR         BYTE
         SayGprsReg      VAR         BYTE
         SayLink         VAR         BYTE
         SayG24Cev      VAR         BYTE
         SayModemRst      VAR         WORD
             SayPing       VAR         WORD
         SayPingErr      VAR         WORD
         SaySmTakip      VAR         WORD
         SayGpTakip      VAR         WORD
         SayMipOpen      VAR         WORD
         SayPingWait      VAR         WORD
         SayBaglanti      VAR         WORD
         SaySoket      VAR         WORD
         SayMipCall      VAR         WORD
'*****************************     SABİTLER    ********************************
         CR            CON         13
         LF            CON         10
         CTRLZ         CON         $1A
         XON             CON        $11
           XOFF            CON        $13
         ENQ            CON         $05
         ACK            CON         $06
         NAK            CON        $15
         DLE            CON          $10
         STX            CON         $02
         ETX            CON         $03
         BEL            CON         $07
         SOH            CON        $01
         EOT            CON         $04
         ESC            CON         $1B
         G24_BAUD      CON         84
         GPS_BAUD      CON         84
         MAX_BAUD      CON         16416
         MCU_BAUD      CON         84
         CAM_BAUD      CON         84
         Bek10         CON         10
         Bek100         CON         100
         Bek200         CON         200
         Bek300         CON         300
         Bek500         CON         500
         Bek1000         CON         1000
         Bek1500         CON         1500
         Bek2000         CON         2000
         Bek3000         CON         3000
         Bek5000         CON         5000
         ART            CON         "+"
         BOL            CON         "/"
         ESTR         CON         "="
         DOLAR         CON         "$"
         BOSLUK         CON         " "
          VI            CON         ","
           SIF            CON         "0"
           BIR            CON         "1"
           IKI            CON         "2"
           UC            CON         "3"
           DOT            CON         "4"
           BES            CON         "5"
           ALT            CON         "6"
           YED            CON         "7"
           SEK            CON         "8"
           DOK            CON         "9"
           AA            CON         "A"
           BB            CON         "B"
           CC            CON         "C"
           DD            CON         "D"
           EE            CON         "E"
           FF            CON         "F"
           GG            CON         "G"
           HH            CON         "H"
           II            CON         "I"
           JJ            CON         "J"
           KK            CON         "K"
           LL            CON         "L"
           MM            CON         "M"
           NN            CON         "N"
           OO            CON         "O"
           PP            CON         "P"
           RR            CON         "R"
           SS            CON         "S"
           TT            CON         "T"
           UU            CON         "T"
           WW            CON         "W"
           XX            CON         "X"
           VV            CON         "V"
           YY            CON         "Y"
           ZZ            CON         "Z"
'********************    İLK ATAMALAR    **********************************
EEPROM 0,  ["00"]                        ' System Saat
EEPROM 2,  ["00"]                        ' System Dakika
EEPROM 4,  ["00"]                        ' System Saniye
EEPROM 6,  ["00"]                        ' System Gün
EEPROM 8,  ["00"]                        ' System Ay
EEPROM 10, ["00"]                        ' System Yil
EEPROM 12, ["0"]                         ' PIO datAcil
EEPROM 13, ["0"]                         ' PIO datSuphe
EEPROM 14, ["0"]                         ' PIO datAlarm
EEPROM 15, ["0"]                         ' PIO datKontak
EEPROM 16, ["0"]                         ' PIO datAku
EEPROM 17, ["0"]                         ' PIO datRole
EEPROM 18, ["0"]                         ' PIO datMdmSPwr
EEPROM 19, ["0"]                         ' PIO datMdmHPwr
EEPROM 20, ["0"]                         ' G24 ErrModem
EEPROM 21, ["0"]                         ' G24 mdmBat
EEPROM 22, ["0"]                         ' G24 mdmSin
EEPROM 23, ["0"]                         ' G24 mdmReg
EEPROM 24, ["0"]                         ' G24 mdmMsg
EEPROM 25, ["0"]                         ' G24 mdmRom
EEPROM 26, ["0"]                         ' G24 mdmSmsFull
EEPROM 27, ["0"]                         ' G24 mdmGprs
EEPROM 28, ["0"]                         ' G24 mdmSim
EEPROM 29, ["0"]                         ' GPS ErrGPS
EEPROM 30, ["0"]                         ' GPS gpsStatu
EEPROM 31, ["00"]                        ' GPS gpsSaat
EEPROM 33, ["00"]                        ' GPS gpsDakika
EEPROM 35, ["00"]                        ' GPS gpsSaniye
EEPROM 37, ["00"]                        ' GPS gpsGun
EEPROM 39, ["00"]                        ' GPS gpsAy
EEPROM 41, ["00"]                        ' GPS gpsYil
EEPROM 43, ["0000.00000"]                ' GPS gpsKuzey
EEPROM 53, ["00000.00000"]               ' GPS gpsDogu
EEPROM 64, ["000.000"]                   ' GPS gpsHiz
EEPROM 71, ["000.00"]                    ' GPS gpsSapma
EEPROM 77, ["O+"]                        ' ISI 1 Sensör Verisi
EEPROM 79, [49,57]                       ' ISI 1 Sensör Verisi
EEPROM 81, ["000000000"]                 ' RESERVE
' SYSTEM TARAFINDAN KONTROLÜ YAPILACAK İŞLEMLER  , 1 = Yapılsın , 0 = Yapılmasın
EEPROM 90, ["1"]                         ' Kontrol Acil
EEPROM 91, ["1"]                         ' Kontrol Suphe
EEPROM 92, ["1"]                         ' Kontrol Alarm
EEPROM 93, ["2"]                         ' Kontrol Kontak
EEPROM 94, ["1"]                         ' Kontrol Akü
EEPROM 95, ["1"]                         ' Kontrol Bloke
EEPROM 96, ["1"]                         ' Kontrol Kamera
EEPROM 97, ["1"]                         ' Kontrol Takip
EEPROM 98, ["1"]                         ' Kontrol Yer
EEPROM 99, ["1"]                         ' Kontrol Merkeze Bilgi
EEPROM 100,["3"]                         ' Kontrol System Reset
EEPROM 101,["1"]                         ' RESERVE
EEPROM 103, ["2"]                        ' Konsol Kontak Aralığı 4 = 60 Dakika
EEPROM 104, ["1"]                        ' Konsol Reset Aralığı, KnslRstDeg
EEPROM 105, [0]                          ' Memory Adres High
EEPROM 106, [0]                          ' Memory Adres Low
EEPROM 107, ["7"]                        ' GPRS Takipte Aralığı
EEPROM 108, ["1"]                        ' GPRS Takipte Kontak Kontrolü
EEPROM 109, ["1"]                        ' GPRS Takip
' SYSTEM PARAMETRE KAYITLARI YERİ
EEPROM 110,["internet??"]                ' Network APN Name
EEPROM 120,["pppppp??"]                  ' Network APN Username
EEPROM 130,["uuuuuu??"]                  ' Network APN Password
EEPROM 142,["12345678"]                  ' User Username
EEPROM 150,["1234"]                      ' User Password
EEPROM 154,["00001"]                     ' Konsol ID
EEPROM 159,["905326220881"]              ' Merkez Telefon Numarası
EEPROM 171,[255]
EEPROM 172,[255]
EEPROM 173,[255]
EEPROM 174,["905327030602"]              ' Acil Telefon Numarası 1
EEPROM 186,[255]
EEPROM 187,[255]
EEPROM 188,[255]
EEPROM 189,["1"]                         ' Acil Telefon Numarası 1 Çağrı Tipi 1 = SMS , 0 = Çağrı
EEPROM 190,["905428387054"]              ' Acil Telefon Numarası 2
EEPROM 202,[255]
EEPROM 203,[255]
EEPROM 204,[255]
EEPROM 205,["0"]                         ' Acil Telefon Numarası 2 Çağrı Tipi 1 = SMS , 0 = Çağrı
EEPROM 206,["06 TJP 22 Plakali Aracta!"] ' Acil Ve Alarm Durum Mesajı Max 25 Karakter
EEPROM 231,["088248008143"]              ' Server IP
'EEPROM 231,["088248010126"]             ' Server IP
'EEPROM 231,["078161058027"]             ' Server IP
EEPROM 243,["48100"]                     ' Server Port
EEPROM 248,["0"]                         ' RESERVE
EEPROM 249,["0"]                         ' RESERVE
EEPROM 250,["0"]                         ' RESERVE
EEPROM 251,["0"]                         ' RESERVE
EEPROM 252,["0"]                         ' RESERVE
EEPROM 253,["0"]                         ' RESERVE
EEPROM 254,["0"]                         ' RESERVE
EEPROM 255,["1"]                         ' Çalışma Şekli
High G24_SPWR
'Low G24_SPWR
Low ROLE
For addr=1 TO 3
   High SYS_LED
   High GPRS_LED
   High GPS_LED
   'High ROLE
   Pause 1000
   Low SYS_LED
   Low GPRS_LED
   Low GPS_LED
   Low ROLE
   Pause 1000
   SerOut2 PIO_TXD,MAX_BAUD,["Q",CR,LF]
Next addr
Low SYS_LED
Low GPRS_LED
Low GPS_LED
MemAddr = 0
SayModemRst = 0
'olee:
'IF PORTB.2=0 Then
'High ROLE
'EndIF
'IF PORTB.5=0 Then
'Low ROLE
'EndIF
'IF ROLE=0 Then
'Low PORTE.0
'EndIF
'IF ROLE=1 Then
'High PORTE.0
'EndIF
'GoTo olee
'****************                KAMERA MODÜLÜ              ********************
'******************************************************************** 07.10.2007
'InitKamera :       cSync[0]=$AA0D
'               cSync[1]=$0000
'               cSync[2]=$0000
'   InitKameraL1 :
'               SerOut2 ACIL,CAM_BAUD,[HEX4 cSync(0),HEX4 cSync(1),HEX4 cSync(2)]
'               SerIn2 SUPHE,CAM_BAUD,1000,cAckYok,[HEX4 cAck(0),HEX4 cAck(1),HEX4 cAck(2)]
'               SerIn2 SUPHE,CAM_BAUD,1000,cSyncYok,[HEX4 cSync(0),HEX4 cSync(1),HEX4 cSync(2)]
'    cAckYok      : GoTo InitKameraL1
'    cSyncYok     :
'****************                   PREMAIN                  ********************
'******************************************************************** 02.05.2007
PreMain        :  GoTo SysInit
 SysInitOk    :  GoTo G24Init
 G24InitOK    :  GoTo GpsInit
 GpsInitOK    :
                 GoTo Main
'****************                   MAIN                  ********************
MAIN :
                      GoSub GpsVeriOku     ' GPS KONUM VE ZAMAN BİLGİSİNİ AL
                      GoSub SaatOku        ' SYSTEM ZAMAN BİLGİSİSİNİ AL
                      GoSub PioVeriOku     ' ÇEVRESEL GİRİŞ BİLGİLERİNİ AL
                      GoSub ModemEkranOku  ' G24 EKRAN BİLGİLERİNİ AL
                      'GoSub IsiOku       ' TEMP 1 DE BAĞLI SICAKLIK SENSÖRÜ
                      GoSub NormlVeriYaz   ' VERİ PAKETİNİ HAFIZAYA YAZ
                      GoSub GsRgKnt        ' GSM REGISTER KONTROLÜ
                      GoSub GpRgKnt        ' GPRS REGISTER KONTROLÜ
                      GoTo GpRoKnt         ' GSM ROAMING KONTROLÜ
     GpRoKntOK      : GoTo SmsKnt          ' GSM GELEN SMS VARMI KONTROLÜ
     SmsKntOK       : GoTo SmKmtIc         ' SMS KOMUT VARSA ICRA EDİLMESİ
     SmKmtIcOK      : GoTo GPBLK           ' GPRS BLOK
     GPBLKOK        : GoTo GpKoIc          ' GPRS GELEN KOMUT VARSA İCRA EDİLMESİ
     GpKoIcOK       : GoTo SosKontrol      ' ACİL VEYA ALARM DURUMU VARSA GEREKENİ YAP
     SosKontrolOK   : GoTo SmTakipDur      ' SMS ÜZERİNDEN TAKİP VARMI
     SmTakipDurOK   : GoTo SmYerSorma      ' SMS ÜZERİNDEN YER BİLGİSİ İSTENMİŞ Mİ
     SmYerSormaOK   : GoTo KontakKont      ' KONTAK KONTROL TAKİPTEN ÖNCE
     KontakKontOK   : GoTo GpTakipDur      ' GPRS ÜZERİNDEN TAKİP VARMI
     GpTakipDurOK   : GoTo GpYerSor        ' GPRS ÜZERİNDEN YER BİLGİSİ İSTENMİŞ Mİ
     GpYerSOK       : 'GoTo GpGecVeri       ' GPRS ÜZERİNDEN GEÇMİŞ VERİ İSTENMİŞ Mİ
     'GpGecVeriOK    :
                      GoTo G24Rst          ' G24 RESET DURUMU GELMİŞ Mİ
     G24RstOk  :
     'SerOut2 PIO_TXD,MAX_BAUD,["20",HEX2 sysYil,".",HEX2 sysAy,".",HEX2 sysGun,"  ", HEX2 sysSaat,":",HEX2 sysDakika,":",HEX2 sysSaniye,13,10]
GoTo MAIN
'******************************************************************** 29.04.2007
'****************               ISI   OKUMA                 ********************
'******************************************************************** 24.10.2007
IsiOku   : addr = 0
BolumTemp1 : OWOut Tmp1, 1, [$CC, $44]
   LoopTemp1 : IF addr >=10 Then
                  addr = 0
                  DrmTemp1 = NN ' TEMP NO
                  Write 77,DrmTemp1
                  Return
               EndIF
               OWIn Tmp1, 4, [strComp]
               IF  strComp = 0 Then
                   addr =  addr + 1
                   GoTo LoopTemp1
               EndIF
            OWOut Tmp1, 1, [$CC, $BE]
            OWIn  Tmp1, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]
            IF Cold_Bit = 1 Then
            'IF Cold_Bit = Real_Cold Then
                  Polarite  = "-"
                   Dummy  = 625 * ~R_Temp+1
                   TempC  = Div32 10
                  'LCDOut $fe,1,"Sns1= ",Polarite,DEC TempC,".",DEC2 Kusurat,Deg,"C "
            Else
                   Polarite  = "+"
                   Dummy = 625 * R_Temp
                   TempC = Div32 10
                    TempC  = (R_Temp & $0FF0) >> 4
                   Kusurat = ((R_Temp.Lowbyte & $0F) * 625)
            EndIF
               DrmTemp1 = OO  ' TEMP OK
            Write 77,DrmTemp1
            Write 78,Polarite
            Write 79,TempC
            Write 80,Kusurat
Return
'****************                MODEM ME READY             ********************
'******************************************************************** 27.04.2007
MeReady : High SYS_LED
         IF WhoIs = DOK  Then
            WhoIs = SIF
            G24ADDR = 0
            Low G24_RTS
            While  G24ADDR < 350
                SerIn2 G24_RXD,G24_BAUD,1500,G24ERR,[G24VERI(G24ADDR)]
                G24ADDR = G24ADDR + 1
            Wend
           GoTo G24ERR
         EndIF
         G24ADDR = 0
         Low G24_RTS
         While  G24ADDR < 350
                SerIn2 G24_RXD,G24_BAUD,300,G24ERR,[G24VERI(G24ADDR)]
         Wend
         GoTo G24ERR
         G24ERR:
         Low SYS_LED
         High G24_RTS  'MeBusy
         For G24ADDR = 0 TO 349
            IF G24VERI[G24ADDR] = "+"  Then
           IF G24VERI[(G24ADDR + 1)] = "M"  Then
           IF G24VERI[(G24ADDR + 2)] = "I"  Then
           IF G24VERI[(G24ADDR + 3)] = "P"  Then
           IF G24VERI[(G24ADDR + 4)] = "R"  Then
           IF G24VERI[(G24ADDR + 5)] = "T"  Then
           IF G24VERI[(G24ADDR + 6)] = "C"  Then
           IF G24VERI[(G24ADDR + 7)] = "P"  Then
           IF G24VERI[(G24ADDR + 8)] = ":"  Then
           IF G24VERI[(G24ADDR + 9)] = " "  Then
           IF G24VERI[(G24ADDR + 10)] = "1"  Then
           IF G24VERI[(G24ADDR + 11)] = ","  Then
           IF G24VERI[(G24ADDR + 12)] = "0"  Then
           IF G24VERI[(G24ADDR + 13)] = ","  Then
                For G24SAYAC = 0 TO 63
                  MipData1[G24SAYAC] = G24VERI[((G24ADDR + G24SAYAC ) + 14)]
              Next G24SAYAC
              GoTo MipVar
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
        Next G24ADDR
         GoTo MipYok
MipVar:         FlgGprsCom = BIR
               For addr = 0 TO 63
               IF MipData1[addr]= SIF Then MipData1[addr]= $0
               IF MipData1[addr]= BIR Then MipData1[addr]= $1
               IF MipData1[addr]= IKI Then MipData1[addr]= $2
               IF MipData1[addr]= UC  Then MipData1[addr]= $3
               IF MipData1[addr]= DOT Then MipData1[addr]= $4
               IF MipData1[addr]= BES Then MipData1[addr]= $5
               IF MipData1[addr]= ALT Then MipData1[addr]= $6
               IF MipData1[addr]= YED Then MipData1[addr]= $7
               IF MipData1[addr]= SEK Then MipData1[addr]= $8
               IF MipData1[addr]= DOK Then MipData1[addr]= $9
               IF MipData1[addr]= "A" Then MipData1[addr]= $A
               IF MipData1[addr]= "B" Then MipData1[addr]= $B
               IF MipData1[addr]= "C" Then MipData1[addr]= $C
               IF MipData1[addr]= "D" Then MipData1[addr]= $D
               IF MipData1[addr]= "E" Then MipData1[addr]= $E
               IF MipData1[addr]= "F" Then MipData1[addr]= $F
               Next addr
               For addr = 0 TO 31
                G24TMP1        = MipData1[(addr*2)] << 4
                G24TMP2        = MipData1[((addr*2)+1)] << 4
                G24TMP2        = G24TMP2 >> 4
                G24TMP3        = G24TMP1 | G24TMP2
                  MipData2[addr] = G24TMP3
            Next addr
            Return
MipYok :       For G24ADDR = 0 TO 349
                      IF G24VERI[G24ADDR] = "R"  Then
                         IF G24VERI[(G24ADDR + 1)] = "I"  Then
                            IF G24VERI[(G24ADDR + 2)] = "N"  Then
                               IF G24VERI[(G24ADDR + 3)] = "G"  Then
                                   FlgRING = BIR
                                   SerOut2 G24_TXD,G24_BAUD,["ATA",CR,LF]
                               EndIF
                            EndIF
                         EndIF
                      EndIF
            Next G24ADDR
Return
'******************************************************************** 21.04.2007
'*****************************************************************************OK
'****************           SYSTEM INITILAZE RUTİNİ         ********************
'******************************************************************** 07.01.2007
SysInit    : sysSaat[0]          = SIF     ' Sistem Saati Okuma Okuma
            sysSaat[1]          = SIF
            sysDakika[0]      = SIF
          sysDakika[1]      = SIF
          sysSaniye[0]      = SIF
          sysSaniye[1]      = SIF
          sysAy[0]         = SIF
          sysAy[1]         = SIF
          sysGun[0]         = SIF
          sysGun[1]         = SIF
          sysYil[0]         = SIF
          sysYil[1]         = SIF
            SayG24Cev         = 0        ' Modem Initilaze
            MsgIndex          = 1        ' G24 Mesaj Kontrol Mesaj Index Numarası
            FlgGsmReg         = SIF      ' G24 Gsm Register Kontrolü
            SayGsmReg         = 0
            FlgGprsReg        = SIF      ' G24 Gprs Register Kontrolü
            SayGprsReg        = 0
            FlgMipCall        = SIF      ' G24 MIPCALL Bayrağı SIF ise MIPCAL Yok
            SayMipCall        = 0
            FlgRING         = SIF     ' RING i SIFIRLA
            Sender            = SIF     ' GPRS Paketlerini Hazırlarken Kimden ( Takip,Yer,Kontak,Reset,Acl/Alr) Geldiği
            FlgSmTakip        = SIF     ' Çalışma Şekli Ne Olursa Olsun SMS li Takip İptal
            FlgMsgVar         = SIF
            FlgSosDurum       = SIF
            FlgMipCall          = SIF
          FlgMipOpen        = SIF
          FlgBaglanti       = SIF
          FlgPingSend       = SIF
          FlgPingRec        = SIF
          FlgPingErr        = SIF
            FlgMipCallErr     = SIF
          FlgMipOpenErr     = SIF
          GpKomut          = $FF
          SayGprsReg        = 0
          SayGsmReg          = 0
          SayPing           = 0
            SayMipCall        = 0
            SayMipOpen        = 0
            SayBaglanti       = 0
              SayPingErr        = 0
              SayG24Cev         = 0
          MsgIndex          = 1
          FlgGprsNet          = 0
          TxMesajType       = SIF
           FlgKntkGitK      = SIF ' 24.10.2007
           FlgKntkGitA      = SIF ' 24.10.2007
GoTo SysInitOk
'***********                      MODEM INITILAZE                    ***********
'***********   Modemin Açılması Ve Mesaj Formatının Set Edilmesi     ***********
G24Init        : High SYS_LED
                SerOut2 PIO_TXD,MAX_BAUD,["MINIT",13,10]
                GoSub G24AcSoft
G24Loop       :
              Pause Bek300
             GoSub BuffDel
              SerOut2 G24_TXD,G24_BAUD,["AT",CR,LF]
              GoSub MeReady
                      IF G24VERI[G24ADDR] = "O"  Then
                         IF G24VERI[(G24ADDR + 1)] = "K"  Then
                            SerOut2 PIO_TXD,MAX_BAUD,["MATOK",13,10]
                            SayG24Cev = 0
                            GoTo G24AtOk
                         EndIF
                      EndIF
              Next G24ADDR
              IF SayG24Cev > 15 Then
                  High SYS_LED
                  SayG24Cev = 0
                 GoSub G24KapaSoft
                 GoTo G24Init
              Else
                 SayG24Cev = SayG24Cev + 1
                 GoTo G24Loop
              EndIF
G24AtOk    :     Low SYS_LED
                SerOut2 G24_TXD,G24_BAUD,["AT+CBAUD=5",CR,LF]
                Pause Bek100
                'SerOut2 G24_TXD,G24_BAUD,["AT+MAPATH=1,1",CR,LF]
                'Pause Bek100
                'SerOut2 G24_TXD,G24_BAUD,["AT+MADIGITAL=0",CR,LF]
                'Pause Bek100
                'SerOut2 G24_TXD,G24_BAUD,["AT+MMICG=28",CR,LF]
                'Pause Bek100
                'SerOut2 G24_TXD,G24_BAUD,["AT+MAMUT=1,0",CR,LF]
                'Pause Bek100
                'SerOut2 G24_TXD,G24_BAUD,["AT+MAFEAT=4,1",CR,LF]
                'Pause Bek100
                SerOut2 G24_TXD,G24_BAUD,["AT+IPR=5",CR,LF]
                Pause Bek100
                SerOut2 G24_TXD,G24_BAUD,["AT+CMGF=1",CR,LF]
                Pause Bek100
                SerOut2 G24_TXD,G24_BAUD,["AT+CPMS=",34,"SM",34,CR,LF]
                Pause Bek100
                SerOut2 G24_TXD,G24_BAUD,["AT+CMGD=1,4",CR,LF]
                Pause Bek100
                SerOut2 G24_TXD,G24_BAUD,["ATE1",CR,LF]
                Pause Bek100
              SerOut2 G24_TXD,G24_BAUD,["AT&K3",CR,LF]
              Pause Bek100
              GoSub BuffDel
GoTo G24InitOk
'***********                  uBLOX GPS INITILAZE                    ***********
'***********              GPS NMEA Mesaj Ve Port Ayarı               ***********
GpsInit : 'SerOut2 PIO_TXD,MAX_BAUD,["GPS INIT",13,10]
         gpsCHS = $5A
         'SerOut2 GPS_TXD,GPS_BAUD,["$PUBX,40,GGA,0,0,0,0*",HEX2 gpsCHS ,CR,LF]
         SerOut2 GPS_TXD,GPS_BAUD,[DOLAR,PP,UU,BB,XX,VI,DOT,SIF,VI,_
                 GG,GG,AA,VI,SIF,VI,SIF,VI,SIF,VI,gpsCHS ,CR,LF]
         Pause Bek200
         gpsCHS = $5C
         'SerOut2 GPS_TXD,GPS_BAUD,["$PUBX,40,GLL,0,0,0,0*",HEX2 gpsCHS ,CR,LF]
                 GG,LL,LL,VI,SIF,VI,SIF,VI,SIF,VI,gpsCHS ,CR,LF]
         Pause Bek200
         gpsCHS = $4E
         'SerOut2 GPS_TXD,GPS_BAUD,["$PUBX,40,GSA,0,0,0,0*",HEX2 gpsCHS ,CR,LF]
                 GG,SS,AA,VI,SIF,VI,SIF,VI,SIF,VI,gpsCHS ,CR,LF]
         Pause Bek200
         gpsCHS = $59
         'SerOut2 GPS_TXD,GPS_BAUD,["$PUBX,40,GSV,0,0,0,0*",HEX2 gpsCHS ,CR,LF]
                 GG,SS,VV,VI,SIF,VI,SIF,VI,SIF,VI,gpsCHS ,CR,LF]
         Pause Bek200
         gpsCHS = $5E
         'SerOut2 GPS_TXD,GPS_BAUD,["$PUBX,40,VTG,0,0,0,0*",HEX2 gpsCHS ,CR,LF]
                 VV,TT,GG,VI,SIF,VI,SIF,VI,SIF,VI,gpsCHS ,CR,LF]
         Pause Bek200
         gpsCHS = $44
         'SerOut2 GPS_TXD,GPS_BAUD,["$PUBX,40,ZDA,0,0,0,0*",HEX2 gpsCHS ,CR,LF]
                 ZZ,DD,AA,VI,SIF,VI,SIF,VI,SIF,VI,gpsCHS ,CR,LF]
         'Pause Bek200
         'gpsCHS = $25
         'SerOut2 GPS_TXD,GPS_BAUD,["$PUBX,41,1,0007,0003,19200,",gpsCHS ,CR,LF]
         'SerOut2 GPS_TXD,GPS_BAUD,[DOLAR,PP,UU,BB,XX,VI,DOT,BIR,VI,BIR,VI,SIF,_
         'SIF,SIF,YED,VI,SIF,SIF,SIF,UC,VI,BIR,DOK,IKI,SIF,SIF,VI,gpsCHS ,CR,LF]
GoTo GpsInitOk
'*****                      VERİLERİN TOPLANMASI                    ************
'*****                       TARİH VE SAAT BİLGİSİ                  ************
SaatOku:    sysSaat[0]   = gpsSaat[0]
           sysSaat[1]   = gpsSaat[1]
           sysDakika[0] = gpsDakika[0]
           sysDakika[1] = gpsDakika[1]
           sysSaniye[0] = gpsSaniye[0]
           sysSaniye[1] = gpsSaniye[1]
           sysGun[0]    = gpsGun[0]
           sysGun[1]    = gpsGun[1]
           sysAy[0]     = gpsAy[0]
           sysAy[1]     = gpsAy[1]
           sysYil[0]    = gpsYil[0]
           sysYil[1]    = gpsYil[1]
           Write 0,sysSaat[0]:Write 1,sysSaat[1]
           Write 2,sysDakika[0]:Write 3,sysDakika[1]
           Write 4,sysSaniye[0]:Write 5,sysSaniye[1]
           Write 6,sysGun[0]:Write 7,sysGun[1]
           Write 8,sysAy[0]:Write 9,sysAy[1]
           Write 10,sysYil[0]:Write 11,sysYil[1]
           SerOut2 PIO_TXD,MAX_BAUD,["SYS TIME : ",STR sysSaat\2,":",STR sysDakika\2,":",STR sysSaniye\2,"  ", STR sysGun\2 ,".",STR sysAy\2,".","20",STR sysYil\2,13,10]
Return
'*****                  ÇEVRESEL GİRİŞ/ÇIKIŞ BİLGİLERİ               ***********
PioVeriOku   : IF ACIL = 1 Then
              datAcil =BIR
            Else
                 datAcil =SIF
            EndIF
            IF SUPHE = 1 Then
              datSuphe =BIR
            Else
                 datSuphe =SIF
            EndIF
            IF ALARM = 1 Then
              datAlarm =BIR
            Else
                 datAlarm =SIF
            EndIF
            IF KONTAK = 1 Then
              datKontak =BIR
            Else
                 datKontak =SIF
            EndIF
            IF AKU = 1 Then
              datAku =BIR
            Else
                 datAku =SIF
            EndIF
            IF ROLE = 1 Then
              datRole =BIR
            Else
                 datRole =SIF
            EndIF
            IF G24_SPWR = 1 Then
              datMdmSPwr =BIR
            Else
                 datMdmSPwr =SIF
            EndIF
            'IF G24_HPWR = 1 Then
            '  datMdmHPwr =BIR
            'Else
                 datMdmHPwr =SIF
            'EndIF
            Write 12,datAcil
            Write 13,datSuphe
            Write 14,datAlarm
            Write 15,datKontak
            Write 16,datAku
            Write 17,datRole
            Write 18,datMdmSPwr
              Write 19,datMdmHPwr
              SerOut2 PIO_TXD,MAX_BAUD,["PIO : ",datAcil,":",datSuphe,":",datAlarm,":",datKontak,":",datAku,":",datRole,":",datMdmSPwr,":",datMdmHPwr,CR,LF]
Return
'***********                    MODEM STATU KONTROL                  ***********
'***********                Modem Durumunun Sorgulanması             ***********
ModemEkranOku :    mdmBat          =  ZZ
               mdmSin           =  ZZ
               mdmReg          =  ZZ
               mdmMsg          =  ZZ
               mdmRom          =  ZZ
               mdmSmsFull       =  ZZ
               mdmGprs          =  ZZ
               mdmSim          =  ZZ
                  ErrModem       =  ZZ
                  'WhoIs = BIR
                  GoSub BuffDel
                  GoSub MdmEkrON
                   GoSub MeReady
                         IF G24VERI[(G24ADDR + 1)] = "C"  Then
                               IF G24VERI[(G24ADDR + 3)] = "E"  Then
                                  IF G24VERI[(G24ADDR + 4)] = "V"  Then
                                  mdmBat     = G24VERI[(G24ADDR + 9)]
                                  mdmSin     = G24VERI[(G24ADDR + 23)]
                                  mdmReg     = G24VERI[(G24ADDR + 37)]
                                  mdmMsg     = G24VERI[(G24ADDR + 51)]
                                  mdmRom     = G24VERI[(G24ADDR + 79)]
                                  mdmSmsFull = G24VERI[(G24ADDR + 107)]
                                  mdmGprs    = G24VERI[(G24ADDR + 121)]
                                  mdmSim     = G24VERI[(G24ADDR + 136)]
                                        GoTo ModemStatuOk
                                 EndIF
                               EndIF
                            EndIF
                         EndIF
                      EndIF
                   Next G24ADDR
                    IF SayG24Cev > 20 Then
                       SayG24Cev = 0
                       GoSub G24KapaSoft
                       GoTo SysInit
                    Else
                       PauseUs 1
                       GoTo ModemEkranOku
                    EndIF
                   GoTo ModemStatuEr
ModemStatuOk: ErrModem   =  NN
           Write 20,ErrModem
           Write 21,mdmBat
           Write 22,mdmSin
           Write 23,mdmReg
           Write 24,mdmMsg
           Write 25,mdmRom
           Write 26,mdmSmsFull
           Write 27,mdmGprs
           Write 28,mdmSim
             SerOut2 PIO_TXD,MAX_BAUD,["MS OK:",mdmBat,":",mdmSin,":",mdmReg,":",mdmMsg,":",mdmRom,":",mdmSmsFull,":",mdmGprs,":",mdmSim,CR,LF]
             WhoIs = BIR
             GoSub BuffDel
           GoSub MdmEkrOF
             GoSub MeReady
Return
ModemStatuEr: ErrModem   =  EE
             SerOut2 PIO_TXD,MAX_BAUD,["MS ER:",mdmBat,":",mdmSin,":",mdmReg,":",mdmMsg,":",mdmRom,":",mdmSmsFull,":",mdmGprs,":",mdmSim,CR,LF]
             WhoIs = BIR
             GoSub BuffDel
           GoSub MdmEkrOF
             GoSub MeReady
Return
'******************************************************************** 05.05.2007
'*****                 uBLOX GPS VERİLERİNİN ALINMASI               ************
'*****   Konum Bilgisi, Hız Bilgisi Sapma Bilgisi Ve Zaman Bilgisi  ************
GpsVeriOku : For addr=0 TO 64
            RegGeneral[addr] = SIF
          Next addr
          For addr=0 TO 9
            gpsKuzey[addr] = SIF
          Next addr
          For addr=0 TO 10
            gpsDogu[addr] = SIF
          Next addr
          For addr=0 TO 6
            gpsHiz[addr] = SIF
          Next addr
          For addr=0 TO 5
            gpsSapma[addr] = SIF
          Next addr
          gpsGun[0]     = SIF
          gpsGun[1]     = SIF
          gpsAy[0]      = SIF
          gpsAy[1]      = SIF
          gpsYil[0]     = SIF
          gpsYil[1]     = SIF
          gpsSaat[0]    = SIF
          gpsSaat[1]    = SIF
          gpsDakika[0]  = SIF
          gpsDakika[1]  = SIF
          gpsSaniye[0]  = SIF
          gpsSaniye[1]  = SIF
          ErrGPS     = EE
          SerIn2 GPS_RXD,GPS_BAUD,3000,GpsErr1,[wait("$GPRMC,")]
          i = 0
   Loop1 :    SerIn2 GPS_RXD,GPS_BAUD,[gpsData]
          IF (gpsData = "*") OR (i >=200) Then
             GoTo gpsDataOk
          Else
             RegGeneral[i]=gpsData
             i = i + 1
             GoTo Loop1
          EndIF
   gpsDataOk : IF RegGeneral[1] = "V" Then
               gpsStatu = VV
               GoTo gpsAntYok
            EndIF
            IF (RegGeneral[10] = "V") Then
               gpsStatu = TT
               GoTo gpsOlcYok
            EndIF
            IF RegGeneral[10] = "A" Then
               gpsStatu = AA
               GoTo gpsOlcVar
            EndIF
            IF (RegGeneral[1] = SIF) OR (RegGeneral[6] = SIF)  Then
               gpsStatu = DOK
               GoTo GpsErr1
            EndIF
   gpsAntYok :   GoTo GpsErr1
   gpsOlcYok :   gpsSaat[0]   = RegGeneral[0]
            gpsSaat[1]   = RegGeneral[1]
            gpsDakika[0]   = RegGeneral[2]
            gpsDakika[1]   = RegGeneral[3]
                gpsSaniye[0]   = RegGeneral[4]
            gpsSaniye[1]   = RegGeneral[5]
            gpsGun[0]   = RegGeneral[18]
            gpsGun[1]   = RegGeneral[19]
            gpsAy[0]  = RegGeneral[20]
            gpsAy[1]   = RegGeneral[21]
            gpsYil[0]   = RegGeneral[22]
            gpsYil[1]   = RegGeneral[23]
            GoTo GpsErr1
gpsOlcVar     : gpsSaat[0]   = RegGeneral[0]
            VirSay = 0
            i = 0
            j = 0
   Kuzey1 :    IF    (RegGeneral[i] = VI) OR ( i >= 200) Then
                 VirSay = VirSay + 1
                     IF  VirSay = 2 Then
   Kuzey2 :               IF    (RegGeneral[(i+1)] = VI) OR ( i >= 200) Then
                           GoTo gpsKuzeyOk
                        Else
                           gpsKuzey[j] = RegGeneral[(i+1)]
                             i =  i + 1
                             j = j + 1
                             GoTo Kuzey2
                         EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Kuzey1
   gpsKuzeyOk : VirSay = 0
             i = 0
             j = 0
   Dogu1      :  IF    (RegGeneral[i] = VI) OR ( i >= 200) Then
                 VirSay = VirSay + 1
                     IF  VirSay = 4 Then
   Dogu2      :          IF    (RegGeneral[(i+1)] = VI) OR ( i >= 200) Then
                        GoTo gpsDoguOk
                     Else
                        gpsDogu[j] = RegGeneral[(i+1)]
                          i =  i + 1
                          j = j + 1
                          GoTo Dogu2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Dogu1
   gpsDoguOk : VirSay = 0
            i = 0
            j = 0
   Hiz1       :  IF    (RegGeneral[i] = VI) OR ( i >= 200) Then
                 VirSay = VirSay + 1
                     IF  VirSay = 6 Then
   Hiz2      :          IF    (RegGeneral[(i+1)] = VI) OR ( i >= 200) Then
                        GoTo gpsHizOk
                     Else
                        gpsHiz[j] = RegGeneral[(i+1)]
                          i =  i + 1
                          j = j + 1
                          GoTo Hiz2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Hiz1
   gpsHizOk   : VirSay = 0
             i = 0
             j = 0
   Sapma1      :  IF    (RegGeneral[i] = VI) OR ( i >= 200) Then
                 VirSay = VirSay + 1
                     IF  VirSay = 7 Then
   Sapma2      :          IF    (RegGeneral[(i+1)] = VI) OR ( i >= 200) Then
                        GoTo gpsSapmaOk
                     Else
                        gpsSapma[j] = RegGeneral[(i+1)]
                          i =  i + 1
                          j = j + 1
                          GoTo Sapma2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Sapma1
   gpsSapmaOk : VirSay = 0
             i = 0
             j = 0
   Tarih1     : IF    (RegGeneral[i] = VI) OR ( i >= 200) Then
                 VirSay = VirSay + 1
                     IF  VirSay = 8 Then
   Tarih2      :          IF    (RegGeneral[(i+1)] = VI) OR ( i >= 200) Then
                        GoTo gpsTarihOk
                     Else
                        gpsTarih[j] = RegGeneral[(i+1)]
                          i =  i + 1
                          j = j + 1
                          GoTo Tarih2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Tarih1
gpsTarihOk    : gpsGun[0]   = gpsTarih[0]
            gpsGun[1]   = gpsTarih[1]
            gpsAy[0]  = gpsTarih[2]
            gpsAy[1]   = gpsTarih[3]
            gpsYil[0]   = gpsTarih[4]
            gpsYil[1]   = gpsTarih[5]
gpsVeriOk:
GpsVeriAlOk :  Low GPS_LED
           ErrGPS = NN
         Write 29,ErrGPS
         Write 30,gpsStatu
         Write 31,gpsSaat[0]  :Write 32,gpsSaat[1]
         Write 33,gpsDakika[0]:Write 34,gpsDakika[1]
         Write 35,gpsSaniye[0]:Write 36,gpsSaniye[1]
         Write 37,gpsGun[0]   :Write 38,gpsGun[1]
         Write 39,gpsAy[0]    :Write 40,gpsAy[1]
         Write 41,gpsYil[0]   :Write 42,gpsYil[1]
         Write 43,gpsKuzey[0]:Write 44,gpsKuzey[1]:Write 4
armys2000
Sanırım bir sorun oldu code tam olarak görüntülenmedi
[code]
' AGS5V5.BAS
' 03.02.2008 12:46
adcon1  = 7
           TRISA.0 = 1
           TRISA.1 = 1
           TRISA.2 = 0
           TRISA.3 = 0
           TRISA.4 = 1
           TRISA.0 = 1
           TRISB= %11111111
           TRISC= %10011000
           TRISD= %01010100
           TRISE.0 = 0
           TRISE.1 = 0
           TRISE.2 = 0
         Prmtr         VAR         BYTE[6]
         cSync         VAR         BYTE
         cAck         VAR         BYTE
         cNak         VAR         BYTE
         cAckCnt         VAR         WORD
         cNakCnt         VAR         WORD
         ColorType      VAR         BYTE
         PreviewRes      VAR         BYTE
         JpegRes         VAR         BYTE
         ResimType      VAR         BYTE
         R_Temp           VAR           WORD
         Polarite          VAR        BYTE
         Dummy          VAR        BYTE
         TempC          VAR        WORD
         Kusurat          VAR          WORD
         'Real_Cold      CON          1
         'Deg            CON          223
         DrmTemp1      VAR          BYTE
         sysSaat         VAR         BYTE[2]
         sysAy         VAR         BYTE[2]
         sysGun         VAR         BYTE[2]
         sysYil         VAR         BYTE[2]
         datAcil         VAR         BYTE
         datSuphe      VAR         BYTE
         datAlarm      VAR         BYTE
         datAku         VAR         BYTE
         datKontak      VAR         BYTE
         datRole         VAR         BYTE
         datMdmSPwr      VAR         BYTE
         datMdmHPwr      VAR         BYTE
         mdmBat         VAR         BYTE
         mdmSin         VAR         BYTE
         mdmReg         VAR         BYTE
         mdmMsg         VAR         BYTE
         mdmRom         VAR         BYTE
         mdmSmsFull      VAR         BYTE
         mdmGprs         VAR         BYTE
         mdmSim         VAR         BYTE
         mdmData         VAR         BYTE
          ErrModem      VAR         BYTE
         gpsGun          VAR         BYTE[2]
         gpsAy          VAR         BYTE[2]
         gpsYil          VAR         BYTE[2]
         gpsSaat          VAR         BYTE[2]
         gpsStatu       VAR         BYTE
         gpsHiz          VAR         BYTE[7]
         gpsData         VAR         BYTE
         gpsTmp1         VAR         BYTE
         gpsTmp2         VAR         BYTE
         ErrGPS         VAR         BYTE
         gpsCHS         VAR         BYTE
         ApnUser         VAR         BYTE[8]
         ApnPass         VAR         BYTE[8]
         cagAcil1       VAR       BYTE
         cagAcil2       VAR       BYTE
         kntAcil        VAR       BYTE
         kntSuphe      VAR         BYTE
         kntAlarm       VAR       BYTE
         kntKontak         VAR       BYTE
         kntAku         VAR       BYTE
         kntBloke       VAR       BYTE
         kntKamera      VAR         BYTE
         kntTakip       VAR       BYTE
         kntYer         VAR       BYTE
         usrType         VAR         BYTE
         ' SYSTEM Ana Birimi
         wr            VAR       BYTE
         Sender         VAR         BYTE
          KnslRstDeg      VAR         WORD
         strComp         VAR         BYTE
         addr         VAR         BYTE
         SysCalType     VAR       BYTE
         i            VAR         BYTE
         j            VAR         BYTE
         VirSay         VAR         BYTE
         GWR            VAR         BYTE
         Deger         VAR         BYTE
         WhoIs         VAR         BYTE
         GpKomut         VAR         BYTE
         G24SAYAC      VAR         WORD
         GpTaWait      VAR         WORD
         TmpGpWait      VAR         WORD
         G24ADDR         VAR         WORD
         G24TMP1         VAR         BYTE
         G24TMP2         VAR         BYTE
         G24TMP3         VAR         BYTE
         SosType         VAR         BYTE
         MsgIndex      VAR         BYTE
         SmTaWait      VAR         WORD
         ' SYSTEM I2C Birimi
          MemAddrH      VAR         BYTE
          MemAddrL      VAR         BYTE
          MemAddr         VAR         WORD
          MemData         VAR         BYTE
         ' SYSTEM FLAGLAR
         FlagMsgVar      VAR         BYTE
         FlgAcil          VAR         BYTE
         FlgSuphe      VAR         BYTE
         FlgAlarm      VAR         BYTE
         FlgAku           VAR         BYTE
         FlgKontak       VAR         BYTE
         FlgTakip       VAR         BYTE
         FlgYer        VAR         BYTE
         FlgBloke      VAR         BYTE
           FlgMsgVar      VAR         BYTE
         FlgGsmReg      VAR         BYTE
         FlgGprsReg      VAR         BYTE
         FlgGprsRom      VAR         BYTE
         FlgGprsNet        VAR         BYTE
           FlgCalType      VAR         BYTE
           FlgGprsCom      VAR         BYTE
         FlgGpTakip      VAR         BYTE
         FlgGpYer       VAR         BYTE
         FlgSmTakip      VAR         BYTE
         FlgSmsYer      VAR         BYTE
         FlgMipCall      VAR         BYTE
         FlgMipOpen      VAR         BYTE
         FlgMipStat      VAR         BYTE
         FlgPingRec      VAR         BYTE
         FlgPingErr      VAR         BYTE
          FlgRING          VAR         BYTE
         FlgGpNoTxD      VAR         BYTE
         'SYSTEM SAYAÇLARI
         SayGsmSin      VAR         BYTE
         SayGsmReg      VAR         BYTE
         SayGprsReg      VAR         BYTE
         SayLink         VAR         BYTE
         SayG24Cev      VAR         BYTE
             SayPing       VAR         WORD
         SayPingErr      VAR         WORD
         SaySmTakip      VAR         WORD
         SayGpTakip      VAR         WORD
         SayMipOpen      VAR         WORD
         SaySoket      VAR         WORD
         SayMipCall      VAR         WORD
         CR            CON         13
         LF            CON         10
         CTRLZ         CON         $1A
         XON             CON        $11
           XOFF            CON        $13
         ENQ            CON         $05
         ACK            CON         $06
         NAK            CON        $15
         DLE            CON          $10
         STX            CON         $02
         ETX            CON         $03
         BEL            CON         $07
         SOH            CON        $01
         EOT            CON         $04
         ESC            CON         $1B
         G24_BAUD      CON         84
         GPS_BAUD      CON         84
         MAX_BAUD      CON         16416
         MCU_BAUD      CON         84
         CAM_BAUD      CON         84
         Bek10         CON         10
         Bek100         CON         100
         Bek200         CON         200
         Bek300         CON         300
         Bek500         CON         500
         Bek1000         CON         1000
         Bek1500         CON         1500
         Bek2000         CON         2000
         Bek3000         CON         3000
         Bek5000         CON         5000
         ART            CON         "+"
         BOL            CON         "/"
         ESTR         CON         "="
         DOLAR         CON         "$"
         BOSLUK         CON         " "
          VI            CON         ","
           SIF            CON         "0"
           BIR            CON         "1"
           IKI            CON         "2"
           UC            CON         "3"
           DOT            CON         "4"
           BES            CON         "5"
           ALT            CON         "6"
           YED            CON         "7"
           SEK            CON         "8"
           DOK            CON         "9"
           AA            CON         "A"
           BB            CON         "B"
           CC            CON         "C"
           DD            CON         "D"
           EE            CON         "E"
           FF            CON         "F"
           GG            CON         "G"
           HH            CON         "H"
           II            CON         "I"
           JJ            CON         "J"
           KK            CON         "K"
           LL            CON         "L"
           MM            CON         "M"
           NN            CON         "N"
           OO            CON         "O"
           PP            CON         "P"
           RR            CON         "R"
           SS            CON         "S"
           TT            CON         "T"
           UU            CON         "T"
           WW            CON         "W"
           XX            CON         "X"
           VV            CON         "V"
           YY            CON         "Y"
           ZZ            CON         "Z"
'************************    İLK ATAMALAR    **********************************
EEPROM 171,[255]
EEPROM 172,[255]
EEPROM 173,[255]
EEPROM 186,[255]
EEPROM 187,[255]
EEPROM 188,[255]
EEPROM 202,[255]
EEPROM 203,[255]
EEPROM 204,[255]
High G24_SPWR
'Low G24_SPWR
Low ROLE
For addr=1 TO 3
   High SYS_LED
   High GPRS_LED
   High GPS_LED
   'High ROLE
   Pause 1000
   Low SYS_LED
   Low GPRS_LED
   Low GPS_LED
   Low ROLE
   Pause 1000
Next addr
Low SYS_LED
Low GPRS_LED
Low GPS_LED
MemAddr = 0
SayModemRst = 0
'olee:
'IF PORTB.2=0 Then
'High ROLE
'EndIF
'IF PORTB.5=0 Then
'Low ROLE
'EndIF
'IF ROLE=0 Then
'Low PORTE.0
'EndIF
'IF ROLE=1 Then
'High PORTE.0
'EndIF
'GoTo olee
'               cSync[1]=$0000
'               cSync[2]=$0000
'   InitKameraL1 :
'    cSyncYok     :
 GpsInitOK    :
                 GoTo Main
MAIN :
     'GpGecVeriOK    :
     G24RstOk  :
GoTo MAIN
IsiOku   : addr = 0
                  addr = 0
                  Write 77,DrmTemp1
                  Return
               EndIF
               IF  strComp = 0 Then
                   addr =  addr + 1
                   GoTo LoopTemp1
               EndIF
                  Polarite  = "-"
                   TempC  = Div32 10
            Else
                   Polarite  = "+"
                   TempC = Div32 10
            EndIF
            Write 77,DrmTemp1
            Write 78,Polarite
            Write 79,TempC
            Write 80,Kusurat
Return
         IF WhoIs = DOK  Then
            WhoIs = SIF
            G24ADDR = 0
            Low G24_RTS
            While  G24ADDR < 350
            Wend
           GoTo G24ERR
         EndIF
         G24ADDR = 0
         Low G24_RTS
         While  G24ADDR < 350
         Wend
         GoTo G24ERR
         G24ERR:
         Low SYS_LED
              Next G24SAYAC
              GoTo MipVar
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
        Next G24ADDR
         GoTo MipYok
               For addr = 0 TO 63
               Next addr
               For addr = 0 TO 31
            Next addr
            Return
                                   FlgRING = BIR
                               EndIF
                            EndIF
                         EndIF
                      EndIF
            Next G24ADDR
Return
            sysSaat[1]          = SIF
            sysDakika[0]      = SIF
          sysDakika[1]      = SIF
          sysSaniye[0]      = SIF
          sysSaniye[1]      = SIF
          sysAy[0]         = SIF
          sysAy[1]         = SIF
          sysGun[0]         = SIF
          sysGun[1]         = SIF
          sysYil[0]         = SIF
          sysYil[1]         = SIF
            SayGsmReg         = 0
            SayGprsReg        = 0
            SayMipCall        = 0
            FlgMsgVar         = SIF
            FlgSosDurum       = SIF
            FlgMipCall          = SIF
          FlgMipOpen        = SIF
          FlgBaglanti       = SIF
          FlgPingSend       = SIF
          FlgPingRec        = SIF
          FlgPingErr        = SIF
            FlgMipCallErr     = SIF
          FlgMipOpenErr     = SIF
          GpKomut          = $FF
          SayGprsReg        = 0
          SayGsmReg          = 0
          SayPing           = 0
            SayMipCall        = 0
            SayMipOpen        = 0
            SayBaglanti       = 0
              SayPingErr        = 0
              SayG24Cev         = 0
          MsgIndex          = 1
          FlgGprsNet          = 0
          TxMesajType       = SIF
GoTo SysInitOk
                GoSub G24AcSoft
G24Loop       :
              Pause Bek300
             GoSub BuffDel
              GoSub MeReady
                            SayG24Cev = 0
                            GoTo G24AtOk
                         EndIF
                      EndIF
              Next G24ADDR
                  High SYS_LED
                  SayG24Cev = 0
                 GoSub G24KapaSoft
                 GoTo G24Init
              Else
                 GoTo G24Loop
              EndIF
                Pause Bek100
                'Pause Bek100
                'Pause Bek100
                'Pause Bek100
                'Pause Bek100
                'Pause Bek100
                Pause Bek100
                Pause Bek100
                Pause Bek100
                Pause Bek100
                Pause Bek100
              Pause Bek100
              GoSub BuffDel
GoTo G24InitOk
         gpsCHS = $5A
         Pause Bek200
         gpsCHS = $5C
         Pause Bek200
         gpsCHS = $4E
         Pause Bek200
         gpsCHS = $59
         Pause Bek200
         gpsCHS = $5E
         Pause Bek200
         gpsCHS = $44
         'Pause Bek200
         'gpsCHS = $25
GoTo GpsInitOk
           sysAy[0]     = gpsAy[0]
           sysAy[1]     = gpsAy[1]
Return
              datAcil =BIR
            Else
                 datAcil =SIF
            EndIF
            IF SUPHE = 1 Then
              datSuphe =BIR
            Else
                 datSuphe =SIF
            EndIF
            IF ALARM = 1 Then
              datAlarm =BIR
            Else
                 datAlarm =SIF
            EndIF
            IF KONTAK = 1 Then
              datKontak =BIR
            Else
                 datKontak =SIF
            EndIF
            IF AKU = 1 Then
              datAku =BIR
            Else
                 datAku =SIF
            EndIF
            IF ROLE = 1 Then
              datRole =BIR
            Else
                 datRole =SIF
            EndIF
              datMdmSPwr =BIR
            Else
                 datMdmSPwr =SIF
            EndIF
            '  datMdmHPwr =BIR
            'Else
                 datMdmHPwr =SIF
            'EndIF
            Write 12,datAcil
            Write 13,datSuphe
            Write 14,datAlarm
            Write 15,datKontak
            Write 16,datAku
            Write 17,datRole
            Write 18,datMdmSPwr
              Write 19,datMdmHPwr
Return
               mdmSin           =  ZZ
               mdmReg          =  ZZ
               mdmMsg          =  ZZ
               mdmRom          =  ZZ
               mdmSmsFull       =  ZZ
               mdmGprs          =  ZZ
               mdmSim          =  ZZ
                  ErrModem       =  ZZ
                  'WhoIs = BIR
                  GoSub BuffDel
                  GoSub MdmEkrON
                   GoSub MeReady
                                        GoTo ModemStatuOk
                                 EndIF
                               EndIF
                            EndIF
                         EndIF
                      EndIF
                   Next G24ADDR
                       SayG24Cev = 0
                       GoSub G24KapaSoft
                       GoTo SysInit
                    Else
                       PauseUs 1
                       GoTo ModemEkranOku
                    EndIF
                   GoTo ModemStatuEr
           Write 20,ErrModem
           Write 21,mdmBat
           Write 22,mdmSin
           Write 23,mdmReg
           Write 24,mdmMsg
           Write 25,mdmRom
           Write 26,mdmSmsFull
           Write 27,mdmGprs
           Write 28,mdmSim
             WhoIs = BIR
             GoSub BuffDel
           GoSub MdmEkrOF
             GoSub MeReady
Return
             WhoIs = BIR
             GoSub BuffDel
           GoSub MdmEkrOF
             GoSub MeReady
Return
          Next addr
          For addr=0 TO 9
          Next addr
          For addr=0 TO 10
            gpsDogu[addr] = SIF
          Next addr
          For addr=0 TO 6
            gpsHiz[addr] = SIF
          Next addr
          For addr=0 TO 5
          Next addr
          gpsGun[0]     = SIF
          gpsGun[1]     = SIF
          gpsAy[0]      = SIF
          gpsAy[1]      = SIF
          gpsYil[0]     = SIF
          gpsYil[1]     = SIF
          gpsSaat[0]    = SIF
          gpsSaat[1]    = SIF
          gpsDakika[0]  = SIF
          gpsDakika[1]  = SIF
          gpsSaniye[0]  = SIF
          gpsSaniye[1]  = SIF
          ErrGPS     = EE
          i = 0
             GoTo gpsDataOk
          Else
             i = i + 1
             GoTo Loop1
          EndIF
               gpsStatu = VV
               GoTo gpsAntYok
            EndIF
               gpsStatu = TT
               GoTo gpsOlcYok
            EndIF
               gpsStatu = AA
               GoTo gpsOlcVar
            EndIF
               gpsStatu = DOK
               GoTo GpsErr1
            EndIF
            GoTo GpsErr1
            VirSay = 0
            i = 0
            j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 2 Then
                           GoTo gpsKuzeyOk
                        Else
                             i =  i + 1
                             j = j + 1
                             GoTo Kuzey2
                         EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Kuzey1
             i = 0
             j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 4 Then
                        GoTo gpsDoguOk
                     Else
                          i =  i + 1
                          j = j + 1
                          GoTo Dogu2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Dogu1
            i = 0
            j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 6 Then
                        GoTo gpsHizOk
                     Else
                          i =  i + 1
                          j = j + 1
                          GoTo Hiz2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Hiz1
             i = 0
             j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 7 Then
                        GoTo gpsSapmaOk
                     Else
                          i =  i + 1
                          j = j + 1
                          GoTo Sapma2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Sapma1
             i = 0
             j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 8 Then
                        GoTo gpsTarihOk
                     Else
                          i =  i + 1
                          j = j + 1
                          GoTo Tarih2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Tarih1
gpsVeriOk:
           ErrGPS = NN
         Write 29,ErrGPS
         Write 30,gpsStatu
         Write 43,gpsKuzey[0]:Write 44,gpsKuzey[1]:Write 45,gpsKuzey[2]:Write 46,gpsKuzey[3]:Write 47,gpsK
armys2000
arkadaşlar kaynak kodu tam olarak yükleyemiyorum
armys2000
[code]
' AGS5V5.BAS
' 03.02.2008 12:46
adcon1  = 7
           TRISA.0 = 1
           TRISA.1 = 1
           TRISA.2 = 0
           TRISA.3 = 0
           TRISA.4 = 1
           TRISA.0 = 1
           TRISB= %11111111
           TRISC= %10011000
           TRISD= %01010100
           TRISE.0 = 0
           TRISE.1 = 0
           TRISE.2 = 0
         Prmtr         VAR         BYTE[6]
         cSync         VAR         BYTE
         cAck         VAR         BYTE
         cNak         VAR         BYTE
         cAckCnt         VAR         WORD
         cNakCnt         VAR         WORD
         ColorType      VAR         BYTE
         PreviewRes      VAR         BYTE
         JpegRes         VAR         BYTE
         ResimType      VAR         BYTE
         R_Temp           VAR           WORD
         Polarite          VAR        BYTE
         Dummy          VAR        BYTE
         TempC          VAR        WORD
         Kusurat          VAR          WORD
         'Real_Cold      CON          1
         'Deg            CON          223
         DrmTemp1      VAR          BYTE
         sysSaat         VAR         BYTE[2]
         sysAy         VAR         BYTE[2]
         sysGun         VAR         BYTE[2]
         sysYil         VAR         BYTE[2]
         datAcil         VAR         BYTE
         datSuphe      VAR         BYTE
         datAlarm      VAR         BYTE
         datAku         VAR         BYTE
         datKontak      VAR         BYTE
         datRole         VAR         BYTE
         datMdmSPwr      VAR         BYTE
         datMdmHPwr      VAR         BYTE
         mdmBat         VAR         BYTE
         mdmSin         VAR         BYTE
         mdmReg         VAR         BYTE
         mdmMsg         VAR         BYTE
         mdmRom         VAR         BYTE
         mdmSmsFull      VAR         BYTE
         mdmGprs         VAR         BYTE
         mdmSim         VAR         BYTE
         mdmData         VAR         BYTE
          ErrModem      VAR         BYTE
         gpsGun          VAR         BYTE[2]
         gpsAy          VAR         BYTE[2]
         gpsYil          VAR         BYTE[2]
         gpsSaat          VAR         BYTE[2]
         gpsStatu       VAR         BYTE
         gpsHiz          VAR         BYTE[7]
         gpsData         VAR         BYTE
         gpsTmp1         VAR         BYTE
         gpsTmp2         VAR         BYTE
         ErrGPS         VAR         BYTE
         gpsCHS         VAR         BYTE
         ApnUser         VAR         BYTE[8]
         ApnPass         VAR         BYTE[8]
         cagAcil1       VAR       BYTE
         cagAcil2       VAR       BYTE
         kntAcil        VAR       BYTE
         kntSuphe      VAR         BYTE
         kntAlarm       VAR       BYTE
         kntKontak         VAR       BYTE
         kntAku         VAR       BYTE
         kntBloke       VAR       BYTE
         kntKamera      VAR         BYTE
         kntTakip       VAR       BYTE
         kntYer         VAR       BYTE
         usrType         VAR         BYTE
         ' SYSTEM Ana Birimi
         wr            VAR       BYTE
         Sender         VAR         BYTE
          KnslRstDeg      VAR         WORD
         strComp         VAR         BYTE
         addr         VAR         BYTE
         SysCalType     VAR       BYTE
         i            VAR         BYTE
         j            VAR         BYTE
         VirSay         VAR         BYTE
         GWR            VAR         BYTE
         Deger         VAR         BYTE
         WhoIs         VAR         BYTE
         GpKomut         VAR         BYTE
         G24SAYAC      VAR         WORD
         GpTaWait      VAR         WORD
         TmpGpWait      VAR         WORD
         G24ADDR         VAR         WORD
         G24TMP1         VAR         BYTE
         G24TMP2         VAR         BYTE
         G24TMP3         VAR         BYTE
         SosType         VAR         BYTE
         MsgIndex      VAR         BYTE
         SmTaWait      VAR         WORD
         ' SYSTEM I2C Birimi
          MemAddrH      VAR         BYTE
          MemAddrL      VAR         BYTE
          MemAddr         VAR         WORD
          MemData         VAR         BYTE
         ' SYSTEM FLAGLAR
         FlagMsgVar      VAR         BYTE
         FlgAcil          VAR         BYTE
         FlgSuphe      VAR         BYTE
         FlgAlarm      VAR         BYTE
         FlgAku           VAR         BYTE
         FlgKontak       VAR         BYTE
         FlgTakip       VAR         BYTE
         FlgYer        VAR         BYTE
         FlgBloke      VAR         BYTE
           FlgMsgVar      VAR         BYTE
         FlgGsmReg      VAR         BYTE
         FlgGprsReg      VAR         BYTE
         FlgGprsRom      VAR         BYTE
         FlgGprsNet        VAR         BYTE
           FlgCalType      VAR         BYTE
           FlgGprsCom      VAR         BYTE
         FlgGpTakip      VAR         BYTE
         FlgGpYer       VAR         BYTE
         FlgSmTakip      VAR         BYTE
         FlgSmsYer      VAR         BYTE
         FlgMipCall      VAR         BYTE
         FlgMipOpen      VAR         BYTE
         FlgMipStat      VAR         BYTE
         FlgPingRec      VAR         BYTE
         FlgPingErr      VAR         BYTE
          FlgRING          VAR         BYTE
         FlgGpNoTxD      VAR         BYTE
         'SYSTEM SAYAÇLARI
         SayGsmSin      VAR         BYTE
         SayGsmReg      VAR         BYTE
         SayGprsReg      VAR         BYTE
         SayLink         VAR         BYTE
         SayG24Cev      VAR         BYTE
             SayPing       VAR         WORD
         SayPingErr      VAR         WORD
         SaySmTakip      VAR         WORD
         SayGpTakip      VAR         WORD
         SayMipOpen      VAR         WORD
         SaySoket      VAR         WORD
         SayMipCall      VAR         WORD
         CR            CON         13
         LF            CON         10
         CTRLZ         CON         $1A
         XON             CON        $11
           XOFF            CON        $13
         ENQ            CON         $05
         ACK            CON         $06
         NAK            CON        $15
         DLE            CON          $10
         STX            CON         $02
         ETX            CON         $03
         BEL            CON         $07
         SOH            CON        $01
         EOT            CON         $04
         ESC            CON         $1B
         G24_BAUD      CON         84
         GPS_BAUD      CON         84
         MAX_BAUD      CON         16416
         MCU_BAUD      CON         84
         CAM_BAUD      CON         84
         Bek10         CON         10
         Bek100         CON         100
         Bek200         CON         200
         Bek300         CON         300
         Bek500         CON         500
         Bek1000         CON         1000
         Bek1500         CON         1500
         Bek2000         CON         2000
         Bek3000         CON         3000
         Bek5000         CON         5000
         ART            CON         "+"
         BOL            CON         "/"
         ESTR         CON         "="
         DOLAR         CON         "$"
         BOSLUK         CON         " "
          VI            CON         ","
           SIF            CON         "0"
           BIR            CON         "1"
           IKI            CON         "2"
           UC            CON         "3"
           DOT            CON         "4"
           BES            CON         "5"
           ALT            CON         "6"
           YED            CON         "7"
           SEK            CON         "8"
           DOK            CON         "9"
           AA            CON         "A"
           BB            CON         "B"
           CC            CON         "C"
           DD            CON         "D"
           EE            CON         "E"
           FF            CON         "F"
           GG            CON         "G"
           HH            CON         "H"
           II            CON         "I"
           JJ            CON         "J"
           KK            CON         "K"
           LL            CON         "L"
           MM            CON         "M"
           NN            CON         "N"
           OO            CON         "O"
           PP            CON         "P"
           RR            CON         "R"
           SS            CON         "S"
           TT            CON         "T"
           UU            CON         "T"
           WW            CON         "W"
           XX            CON         "X"
           VV            CON         "V"
           YY            CON         "Y"
           ZZ            CON         "Z"
EEPROM 171,[255]
EEPROM 172,[255]
EEPROM 173,[255]
EEPROM 186,[255]
EEPROM 187,[255]
EEPROM 188,[255]
EEPROM 202,[255]
EEPROM 203,[255]
EEPROM 204,[255]
High G24_SPWR
'Low G24_SPWR
Low ROLE
For addr=1 TO 3
   High SYS_LED
   High GPRS_LED
   High GPS_LED
   'High ROLE
   Pause 1000
   Low SYS_LED
   Low GPRS_LED
   Low GPS_LED
   Low ROLE
   Pause 1000
Next addr
Low SYS_LED
Low GPRS_LED
Low GPS_LED
MemAddr = 0
SayModemRst = 0
'olee:
'IF PORTB.2=0 Then
'High ROLE
'EndIF
'IF PORTB.5=0 Then
'Low ROLE
'EndIF
'IF ROLE=0 Then
'Low PORTE.0
'EndIF
'IF ROLE=1 Then
'High PORTE.0
'EndIF
'GoTo olee
'               cSync[1]=$0000
'               cSync[2]=$0000
'   InitKameraL1 :
'    cSyncYok     :
 GpsInitOK    :
                 GoTo Main
MAIN :
     'GpGecVeriOK    :
     G24RstOk  :
GoTo MAIN
IsiOku   : addr = 0
                  addr = 0
                  Write 77,DrmTemp1
                  Return
               EndIF
               IF  strComp = 0 Then
                   addr =  addr + 1
                   GoTo LoopTemp1
               EndIF
                  Polarite  = "-"
                   TempC  = Div32 10
            Else
                   Polarite  = "+"
                   TempC = Div32 10
            EndIF
            Write 77,DrmTemp1
            Write 78,Polarite
            Write 79,TempC
            Write 80,Kusurat
Return
         IF WhoIs = DOK  Then
            WhoIs = SIF
            G24ADDR = 0
            Low G24_RTS
            While  G24ADDR < 350
            Wend
           GoTo G24ERR
         EndIF
         G24ADDR = 0
         Low G24_RTS
         While  G24ADDR < 350
         Wend
         GoTo G24ERR
         G24ERR:
         Low SYS_LED
              Next G24SAYAC
              GoTo MipVar
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
           EndIF
        Next G24ADDR
         GoTo MipYok
               For addr = 0 TO 63
               Next addr
               For addr = 0 TO 31
            Next addr
            Return
                                   FlgRING = BIR
                               EndIF
                            EndIF
                         EndIF
                      EndIF
            Next G24ADDR
Return
            sysSaat[1]          = SIF
            sysDakika[0]      = SIF
          sysDakika[1]      = SIF
          sysSaniye[0]      = SIF
          sysSaniye[1]      = SIF
          sysAy[0]         = SIF
          sysAy[1]         = SIF
          sysGun[0]         = SIF
          sysGun[1]         = SIF
          sysYil[0]         = SIF
          sysYil[1]         = SIF
            SayGsmReg         = 0
            SayGprsReg        = 0
            SayMipCall        = 0
            FlgMsgVar         = SIF
            FlgSosDurum       = SIF
            FlgMipCall          = SIF
          FlgMipOpen        = SIF
          FlgBaglanti       = SIF
          FlgPingSend       = SIF
          FlgPingRec        = SIF
          FlgPingErr        = SIF
            FlgMipCallErr     = SIF
          FlgMipOpenErr     = SIF
          GpKomut          = $FF
          SayGprsReg        = 0
          SayGsmReg          = 0
          SayPing           = 0
            SayMipCall        = 0
            SayMipOpen        = 0
            SayBaglanti       = 0
              SayPingErr        = 0
              SayG24Cev         = 0
          MsgIndex          = 1
          FlgGprsNet          = 0
          TxMesajType       = SIF
GoTo SysInitOk
                GoSub G24AcSoft
G24Loop       :
              Pause Bek300
             GoSub BuffDel
              GoSub MeReady
                            SayG24Cev = 0
                            GoTo G24AtOk
                         EndIF
                      EndIF
              Next G24ADDR
                  High SYS_LED
                  SayG24Cev = 0
                 GoSub G24KapaSoft
                 GoTo G24Init
              Else
                 GoTo G24Loop
              EndIF
                Pause Bek100
                'Pause Bek100
                'Pause Bek100
                'Pause Bek100
                'Pause Bek100
                'Pause Bek100
                Pause Bek100
                Pause Bek100
                Pause Bek100
                Pause Bek100
                Pause Bek100
              Pause Bek100
              GoSub BuffDel
GoTo G24InitOk
         gpsCHS = $5A
         Pause Bek200
         gpsCHS = $5C
         Pause Bek200
         gpsCHS = $4E
         Pause Bek200
         gpsCHS = $59
         Pause Bek200
         gpsCHS = $5E
         Pause Bek200
         gpsCHS = $44
         'Pause Bek200
         'gpsCHS = $25
GoTo GpsInitOk
           sysAy[0]     = gpsAy[0]
           sysAy[1]     = gpsAy[1]
Return
              datAcil =BIR
            Else
                 datAcil =SIF
            EndIF
            IF SUPHE = 1 Then
              datSuphe =BIR
            Else
                 datSuphe =SIF
            EndIF
            IF ALARM = 1 Then
              datAlarm =BIR
            Else
                 datAlarm =SIF
            EndIF
            IF KONTAK = 1 Then
              datKontak =BIR
            Else
                 datKontak =SIF
            EndIF
            IF AKU = 1 Then
              datAku =BIR
            Else
                 datAku =SIF
            EndIF
            IF ROLE = 1 Then
              datRole =BIR
            Else
                 datRole =SIF
            EndIF
              datMdmSPwr =BIR
            Else
                 datMdmSPwr =SIF
            EndIF
            '  datMdmHPwr =BIR
            'Else
                 datMdmHPwr =SIF
            'EndIF
            Write 12,datAcil
            Write 13,datSuphe
            Write 14,datAlarm
            Write 15,datKontak
            Write 16,datAku
            Write 17,datRole
            Write 18,datMdmSPwr
              Write 19,datMdmHPwr
Return
               mdmSin           =  ZZ
               mdmReg          =  ZZ
               mdmMsg          =  ZZ
               mdmRom          =  ZZ
               mdmSmsFull       =  ZZ
               mdmGprs          =  ZZ
               mdmSim          =  ZZ
                  ErrModem       =  ZZ
                  'WhoIs = BIR
                  GoSub BuffDel
                  GoSub MdmEkrON
                   GoSub MeReady
                                        GoTo ModemStatuOk
                                 EndIF
                               EndIF
                            EndIF
                         EndIF
                      EndIF
                   Next G24ADDR
                       SayG24Cev = 0
                       GoSub G24KapaSoft
                       GoTo SysInit
                    Else
                       PauseUs 1
                       GoTo ModemEkranOku
                    EndIF
                   GoTo ModemStatuEr
           Write 20,ErrModem
           Write 21,mdmBat
           Write 22,mdmSin
           Write 23,mdmReg
           Write 24,mdmMsg
           Write 25,mdmRom
           Write 26,mdmSmsFull
           Write 27,mdmGprs
           Write 28,mdmSim
             WhoIs = BIR
             GoSub BuffDel
           GoSub MdmEkrOF
             GoSub MeReady
Return
             WhoIs = BIR
             GoSub BuffDel
           GoSub MdmEkrOF
             GoSub MeReady
Return
          Next addr
          For addr=0 TO 9
          Next addr
          For addr=0 TO 10
            gpsDogu[addr] = SIF
          Next addr
          For addr=0 TO 6
            gpsHiz[addr] = SIF
          Next addr
          For addr=0 TO 5
          Next addr
          gpsGun[0]     = SIF
          gpsGun[1]     = SIF
          gpsAy[0]      = SIF
          gpsAy[1]      = SIF
          gpsYil[0]     = SIF
          gpsYil[1]     = SIF
          gpsSaat[0]    = SIF
          gpsSaat[1]    = SIF
          gpsDakika[0]  = SIF
          gpsDakika[1]  = SIF
          gpsSaniye[0]  = SIF
          gpsSaniye[1]  = SIF
          ErrGPS     = EE
          i = 0
             GoTo gpsDataOk
          Else
             i = i + 1
             GoTo Loop1
          EndIF
               gpsStatu = VV
               GoTo gpsAntYok
            EndIF
               gpsStatu = TT
               GoTo gpsOlcYok
            EndIF
               gpsStatu = AA
               GoTo gpsOlcVar
            EndIF
               gpsStatu = DOK
               GoTo GpsErr1
            EndIF
            GoTo GpsErr1
            VirSay = 0
            i = 0
            j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 2 Then
                           GoTo gpsKuzeyOk
                        Else
                             i =  i + 1
                             j = j + 1
                             GoTo Kuzey2
                         EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Kuzey1
             i = 0
             j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 4 Then
                        GoTo gpsDoguOk
                     Else
                          i =  i + 1
                          j = j + 1
                          GoTo Dogu2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Dogu1
            i = 0
            j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 6 Then
                        GoTo gpsHizOk
                     Else
                          i =  i + 1
                          j = j + 1
                          GoTo Hiz2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Hiz1
             i = 0
             j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 7 Then
                        GoTo gpsSapmaOk
                     Else
                          i =  i + 1
                          j = j + 1
                          GoTo Sapma2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Sapma1
             i = 0
             j = 0
                 VirSay = VirSay + 1
                     IF  VirSay = 8 Then
                        GoTo gpsTarihOk
                     Else
                          i =  i + 1
                          j = j + 1
                          GoTo Tarih2
                      EndIF
                  EndIF
            EndIF
            i =  i + 1
   GoTo Tarih1
gpsVeriOk:
           ErrGPS = NN
         Write 29,ErrGPS
         Write 30,gpsStatu
         Write 43,gpsKuzey[0]:Write 44,gpsKuzey[1]:Write 45,gpsKuzey[2]:Write 46,gpsKuzey[3]:Write 47,gpsKuzey[4]
         Write 48,gpsKuzey[5]:Write 49,gpsKuzey
armys2000
parça parça gönderiyorum artık
' AGS5V5.BAS
' 03.02.2008 12:46
adcon1  = 7
            TRISA.0 = 1
            TRISA.1 = 1
            TRISA.2 = 0
            TRISA.3 = 0
            TRISA.4 = 1
            TRISA.0 = 1
            TRISB= %11111111
            TRISC= %10011000
            TRISD= %01010100
            TRISE.0 = 0
            TRISE.1 = 0
            TRISE.2 = 0
			Prmtr			VAR			BYTE[6]
			cSync			VAR			BYTE
			cAck			VAR			BYTE
			cNak			VAR			BYTE
			cAckCnt			VAR			WORD
			cNakCnt			VAR			WORD
			ColorType		VAR			BYTE
			PreviewRes		VAR			BYTE
			JpegRes			VAR			BYTE
			ResimType		VAR			BYTE
			R_Temp     		VAR		     WORD
			Polarite       	VAR 		 BYTE
			Dummy       	VAR 		 BYTE
			TempC       	VAR 		 WORD
			Kusurat       	VAR			 WORD
			'Real_Cold   	CON			 1
			'Deg         	CON			 223
			DrmTemp1		VAR			 BYTE
			sysSaat			VAR			BYTE[2]
			sysAy			VAR			BYTE[2]
			sysGun			VAR			BYTE[2]
			sysYil			VAR			BYTE[2]
			datAcil			VAR			BYTE
			datSuphe		VAR			BYTE
			datAlarm		VAR			BYTE
			datAku			VAR			BYTE
			datKontak		VAR			BYTE
			datRole			VAR			BYTE
			datMdmSPwr		VAR			BYTE
			datMdmHPwr		VAR			BYTE
			mdmBat			VAR			BYTE
			mdmSin			VAR			BYTE
			mdmReg			VAR			BYTE
			mdmMsg			VAR			BYTE
			mdmRom			VAR			BYTE
			mdmSmsFull		VAR			BYTE
			mdmGprs			VAR			BYTE
			mdmSim			VAR			BYTE
			mdmData			VAR			BYTE
		    ErrModem		VAR			BYTE
			gpsGun	    	VAR			BYTE[2]
			gpsAy	    	VAR			BYTE[2]
			gpsYil	    	VAR			BYTE[2]
			gpsSaat	    	VAR			BYTE[2]
			gpsStatu    	VAR			BYTE
			gpsHiz	    	VAR			BYTE[7]
			gpsData			VAR			BYTE
			gpsTmp1			VAR			BYTE
			gpsTmp2			VAR			BYTE
			ErrGPS			VAR			BYTE
			gpsCHS			VAR			BYTE
			ApnUser			VAR			BYTE[8]
			ApnPass			VAR			BYTE[8]
			cagAcil1    	VAR 		BYTE
			cagAcil2    	VAR 		BYTE
			kntAcil     	VAR 		BYTE
			kntSuphe		VAR			BYTE
			kntAlarm    	VAR 		BYTE
			kntKontak      	VAR 		BYTE
			kntAku      	VAR 		BYTE
			kntBloke    	VAR 		BYTE
			kntKamera		VAR			BYTE
			kntTakip    	VAR 		BYTE
			kntYer      	VAR 		BYTE
			usrType			VAR			BYTE
			' SYSTEM Ana Birimi
			wr				VAR 		BYTE
			Sender			VAR			BYTE
		    KnslRstDeg		VAR			WORD
			strComp			VAR			BYTE
			addr			VAR			BYTE
			SysCalType  	VAR 		BYTE
			i				VAR			BYTE
			j				VAR			BYTE
			VirSay			VAR			BYTE
			GWR				VAR			BYTE
			Deger			VAR			BYTE
			WhoIs			VAR			BYTE
			GpKomut			VAR			BYTE
			G24SAYAC		VAR			WORD
			GpTaWait		VAR			WORD
			TmpGpWait		VAR			WORD
			G24ADDR			VAR			WORD
			G24TMP1			VAR			BYTE
			G24TMP2			VAR			BYTE
			G24TMP3			VAR			BYTE
			SosType			VAR			BYTE
			MsgIndex		VAR			BYTE
			SmTaWait		VAR			WORD
			' SYSTEM I2C Birimi
		    MemAddrH		VAR			BYTE
		    MemAddrL		VAR			BYTE
		    MemAddr			VAR			WORD
		    MemData			VAR			BYTE
			' SYSTEM FLAGLAR
			FlagMsgVar		VAR			BYTE
			FlgAcil		    VAR			BYTE
			FlgSuphe		VAR			BYTE
			FlgAlarm		VAR			BYTE
			FlgAku 	    	VAR			BYTE
			FlgKontak 		VAR			BYTE
			FlgTakip 		VAR			BYTE
			FlgYer  		VAR			BYTE
			FlgBloke		VAR			BYTE
	        FlgMsgVar		VAR			BYTE
			FlgGsmReg		VAR			BYTE
			FlgGprsReg      VAR			BYTE
			FlgGprsRom		VAR			BYTE
			FlgGprsNet 	    VAR			BYTE
	        FlgCalType		VAR			BYTE
	        FlgGprsCom		VAR			BYTE
			FlgGpTakip		VAR			BYTE
			FlgGpYer 		VAR			BYTE
			FlgSmTakip		VAR			BYTE
			FlgSmsYer		VAR			BYTE
			FlgMipCall		VAR			BYTE
			FlgMipOpen      VAR			BYTE
			FlgMipStat		VAR			BYTE
			FlgPingRec   	VAR			BYTE
			FlgPingErr      VAR			BYTE
		    FlgRING		    VAR			BYTE
			FlgGpNoTxD		VAR			BYTE
			'SYSTEM SAYAÇLARI
			SayGsmSin		VAR			BYTE
			SayGsmReg		VAR			BYTE
			SayGprsReg		VAR			BYTE
			SayLink			VAR			BYTE
			SayG24Cev		VAR			BYTE
           	SayPing 		VAR			WORD
			SayPingErr		VAR			WORD
			SaySmTakip		VAR			WORD
			SayGpTakip		VAR			WORD
			SayMipOpen      VAR			WORD
			SaySoket		VAR			WORD
			SayMipCall      VAR			WORD
			CR				CON		   13
			LF				CON		   10
			CTRLZ			CON		   $1A
			XON             CON        $11
            XOFF            CON        $13
			ENQ				CON		   $05
			ACK				CON		   $06
			NAK				CON        $15
			DLE				CON	       $10
			STX				CON		   $02
			ETX				CON		   $03
			BEL				CON		   $07
			SOH				CON        $01
			EOT				CON		   $04
			ESC				CON		   $1B
			G24_BAUD		CON			84
			GPS_BAUD		CON			84
			MAX_BAUD		CON			16416
			MCU_BAUD		CON			84
			CAM_BAUD		CON			84
			Bek10			CON			10
			Bek100			CON			100
			Bek200			CON			200
			Bek300			CON			300
			Bek500			CON			500
			Bek1000			CON			1000
			Bek1500			CON			1500
			Bek2000			CON			2000
			Bek3000			CON			3000
			Bek5000			CON			5000
			ART				CON			"+"
			BOL				CON			"/"
			ESTR			CON			"="
			DOLAR			CON			"$"
			BOSLUK			CON			" "
		    VI				CON			","
            SIF				CON			"0"
            BIR				CON			"1"
            IKI				CON			"2"
            UC				CON			"3"
            DOT				CON			"4"
            BES				CON			"5"
            ALT				CON			"6"
            YED				CON			"7"
            SEK				CON			"8"
            DOK				CON			"9"
            AA				CON			"A"
            BB				CON			"B"
            CC				CON			"C"
            DD				CON			"D"
            EE				CON			"E"
            FF				CON			"F"
            GG				CON			"G"
            HH				CON			"H"
            II				CON			"I"
            JJ				CON			"J"
            KK				CON			"K"
            LL				CON			"L"
            MM				CON			"M"
            NN				CON			"N"
            OO				CON			"O"
            PP				CON			"P"
            RR				CON			"R"
            SS				CON			"S"
            TT				CON			"T"
            UU				CON			"T"
            WW				CON			"W"
            XX				CON			"X"
            VV				CON			"V"
            YY				CON			"Y"
            ZZ				CON			"Z"
EEPROM 171,[255]
EEPROM 172,[255]
EEPROM 173,[255]
EEPROM 186,[255]
EEPROM 187,[255]
EEPROM 188,[255]
EEPROM 202,[255]
EEPROM 203,[255]
EEPROM 204,[255]
High G24_SPWR
'Low G24_SPWR
Low ROLE
For addr=1 TO 3
    High SYS_LED
    High GPRS_LED
    High GPS_LED
    'High ROLE
    Pause 1000
    Low SYS_LED
    Low GPRS_LED
    Low GPS_LED
    Low ROLE
    Pause 1000
Next addr
Low SYS_LED
Low GPRS_LED
Low GPS_LED
MemAddr = 0
SayModemRst = 0
'olee:
'IF PORTB.2=0 Then
'High ROLE
'EndIF
'IF PORTB.5=0 Then
'Low ROLE
'EndIF
'IF ROLE=0 Then
'Low PORTE.0
'EndIF
'IF ROLE=1 Then
'High PORTE.0
'EndIF
'GoTo olee
'				   cSync[1]=$0000
'				   cSync[2]=$0000
'	InitKameraL1 :
'    cSyncYok     :
armys2000
  GpsInitOK    :
                  GoTo Main
MAIN :
      'GpGecVeriOK    :
      G24RstOk  :
GoTo MAIN
IsiOku   : addr = 0
	               addr = 0
	               Write 77,DrmTemp1
	               Return
	            EndIF
	            IF  strComp = 0 Then
	                addr =  addr + 1
	                GoTo LoopTemp1
	            EndIF
						Polarite  = "-"
		    			TempC  = Div32 10
				Else
		    			Polarite  = "+"
		    			TempC = Div32 10
    			EndIF
				Write 77,DrmTemp1
				Write 78,Polarite
				Write 79,TempC
				Write 80,Kusurat
Return
          IF WhoIs = DOK  Then
             WhoIs = SIF
             G24ADDR = 0
             Low G24_RTS
             While  G24ADDR < 350
             Wend
            GoTo G24ERR
          EndIF
          G24ADDR = 0
          Low G24_RTS
          While  G24ADDR < 350
          Wend
          GoTo G24ERR
          G24ERR:
          Low SYS_LED
			     Next G24SAYAC
			     GoTo MipVar
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
			  EndIF
		  Next G24ADDR
          GoTo MipYok
                For addr = 0 TO 63
                Next addr
                For addr = 0 TO 31
				Next addr
				Return
				   	                 FlgRING = BIR
				   	             EndIF
				   	          EndIF
				   	       EndIF
				   	    EndIF
			   Next G24ADDR
Return
             sysSaat[1]	       = SIF
             sysDakika[0]	   = SIF
			 sysDakika[1]	   = SIF
			 sysSaniye[0]	   = SIF
			 sysSaniye[1]	   = SIF
			 sysAy[0]		   = SIF
			 sysAy[1]		   = SIF
			 sysGun[0]		   = SIF
			 sysGun[1]		   = SIF
			 sysYil[0]		   = SIF
			 sysYil[1]		   = SIF
             SayGsmReg         = 0
             SayGprsReg        = 0
             SayMipCall        = 0
             FlgMsgVar         = SIF
             FlgSosDurum       = SIF
             FlgMipCall	       = SIF
			 FlgMipOpen        = SIF
			 FlgBaglanti       = SIF
			 FlgPingSend       = SIF
			 FlgPingRec        = SIF
			 FlgPingErr        = SIF
             FlgMipCallErr     = SIF
			 FlgMipOpenErr     = SIF
			 GpKomut	       = $FF
			 SayGprsReg        = 0
			 SayGsmReg	       = 0
			 SayPing           = 0
             SayMipCall        = 0
             SayMipOpen        = 0
             SayBaglanti       = 0
           	 SayPingErr        = 0
           	 SayG24Cev         = 0
			 MsgIndex	       = 1
			 FlgGprsNet	       = 0
			 TxMesajType       = SIF
GoTo SysInitOk
                 GoSub G24AcSoft
G24Loop       :
			     Pause Bek300
				 GoSub BuffDel
			     GoSub MeReady
				   	          SayG24Cev = 0
				   	          GoTo G24AtOk
				   	       EndIF
				   	    EndIF
			     Next G24ADDR
			   		High SYS_LED
			   		SayG24Cev = 0
			  		GoSub G24KapaSoft
			  		GoTo G24Init
			     Else
			  		GoTo G24Loop
			     EndIF
                 Pause Bek100
                 'Pause Bek100
                 'Pause Bek100
                 'Pause Bek100
                 'Pause Bek100
                 'Pause Bek100
                 Pause Bek100
                 Pause Bek100
                 Pause Bek100
                 Pause Bek100
                 Pause Bek100
			     Pause Bek100
			     GoSub BuffDel
GoTo G24InitOk
armys2000
          gpsCHS = $5A
          Pause Bek200
          gpsCHS = $5C
          Pause Bek200
          gpsCHS = $4E
          Pause Bek200
          gpsCHS = $59
          Pause Bek200
          gpsCHS = $5E
          Pause Bek200
          gpsCHS = $44
          'Pause Bek200
          'gpsCHS = $25
GoTo GpsInitOk
            sysAy[0]     = gpsAy[0]
            sysAy[1]     = gpsAy[1]
Return
				  datAcil =BIR
			   Else
			   	  datAcil =SIF
 			   EndIF
 			   IF SUPHE = 1 Then
				  datSuphe =BIR
			   Else
			   	  datSuphe =SIF
 			   EndIF
 			   IF ALARM = 1 Then
				  datAlarm =BIR
			   Else
			   	  datAlarm =SIF
 			   EndIF
 			   IF KONTAK = 1 Then
				  datKontak =BIR
			   Else
			   	  datKontak =SIF
 			   EndIF
 			   IF AKU = 1 Then
				  datAku =BIR
			   Else
			   	  datAku =SIF
 			   EndIF
 			   IF ROLE = 1 Then
				  datRole =BIR
			   Else
			   	  datRole =SIF
 			   EndIF
				  datMdmSPwr =BIR
			   Else
			   	  datMdmSPwr =SIF
 			   EndIF
			   '  datMdmHPwr =BIR
			   'Else
			   	  datMdmHPwr =SIF
 			   'EndIF
 			   Write 12,datAcil
			   Write 13,datSuphe
			   Write 14,datAlarm
			   Write 15,datKontak
			   Write 16,datAku
			   Write 17,datRole
			   Write 18,datMdmSPwr
               Write 19,datMdmHPwr
Return
					mdmSin		     =  ZZ
					mdmReg			 =  ZZ
					mdmMsg			 =  ZZ
					mdmRom			 =  ZZ
					mdmSmsFull		 =  ZZ
					mdmGprs			 =  ZZ
					mdmSim			 =  ZZ
				   	ErrModem		 =  ZZ
				   	'WhoIs = BIR
				   	GoSub BuffDel
				   	GoSub MdmEkrON
	                GoSub MeReady
	                  		   	       GoTo ModemStatuOk
				   	               EndIF
				   	             EndIF
				   	          EndIF
				   	       EndIF
				   	    EndIF
				   	 Next G24ADDR
                        SayG24Cev = 0
                        GoSub G24KapaSoft
                        GoTo SysInit
                     Else
                        PauseUs 1
                        GoTo ModemEkranOku
                     EndIF
                    GoTo ModemStatuEr
    		  Write 20,ErrModem
			  Write 21,mdmBat
			  Write 22,mdmSin
			  Write 23,mdmReg
			  Write 24,mdmMsg
			  Write 25,mdmRom
			  Write 26,mdmSmsFull
			  Write 27,mdmGprs
			  Write 28,mdmSim
              WhoIs = BIR
              GoSub BuffDel
			  GoSub MdmEkrOF
              GoSub MeReady
Return
              WhoIs = BIR
              GoSub BuffDel
			  GoSub MdmEkrOF
              GoSub MeReady
Return
			 Next addr
			 For addr=0 TO 9
			 Next addr
			 For addr=0 TO 10
				gpsDogu[addr] = SIF
			 Next addr
			 For addr=0 TO 6
				gpsHiz[addr] = SIF
			 Next addr
			 For addr=0 TO 5
			 Next addr
			 gpsGun[0]     = SIF
			 gpsGun[1]     = SIF
			 gpsAy[0]      = SIF
			 gpsAy[1]      = SIF
			 gpsYil[0]     = SIF
			 gpsYil[1]     = SIF
			 gpsSaat[0]    = SIF
			 gpsSaat[1]    = SIF
			 gpsDakika[0]  = SIF
			 gpsDakika[1]  = SIF
			 gpsSaniye[0]  = SIF
			 gpsSaniye[1]  = SIF
			 ErrGPS     = EE
			 i = 0
			    GoTo gpsDataOk
			 Else
			 	i = i + 1
			    GoTo Loop1
			 EndIF
					gpsStatu = VV
					GoTo gpsAntYok
				EndIF
					gpsStatu = TT
					GoTo gpsOlcYok
				EndIF
					gpsStatu = AA
					GoTo gpsOlcVar
				EndIF
					gpsStatu = DOK
					GoTo GpsErr1
				EndIF
				GoTo GpsErr1
				VirSay = 0
				i = 0
				j = 0
			        VirSay = VirSay + 1
			         	IF  VirSay = 2 Then
									GoTo gpsKuzeyOk
								Else
						        	i =  i + 1
						        	j = j + 1
						        	GoTo Kuzey2
						    	EndIF
						EndIF
				EndIF
				i =  i + 1
	GoTo Kuzey1
				 i = 0
				 j = 0
			        VirSay = VirSay + 1
			         	IF  VirSay = 4 Then
								GoTo gpsDoguOk
							Else
						        i =  i + 1
						        j = j + 1
						        GoTo Dogu2
						    EndIF
						EndIF
				EndIF
				i =  i + 1
	GoTo Dogu1
				i = 0
				j = 0
			        VirSay = VirSay + 1
			         	IF  VirSay = 6 Then
								GoTo gpsHizOk
							Else
						        i =  i + 1
						        j = j + 1
						        GoTo Hiz2
						    EndIF
						EndIF
				EndIF
				i =  i + 1
	GoTo Hiz1
				 i = 0
				 j = 0
			        VirSay = VirSay + 1
			         	IF  VirSay = 7 Then
								GoTo gpsSapmaOk
							Else
						        i =  i + 1
						        j = j + 1
						        GoTo Sapma2
						    EndIF
						EndIF
				EndIF
				i =  i + 1
	GoTo Sapma1
				 i = 0
				 j = 0
			        VirSay = VirSay + 1
			         	IF  VirSay = 8 Then
								GoTo gpsTarihOk
							Else
						        i =  i + 1
						        j = j + 1
						        GoTo Tarih2
						    EndIF
						EndIF
				EndIF
				i =  i + 1
	GoTo Tarih1
gpsVeriOk:
            ErrGPS = NN
			Write 29,ErrGPS
			Write 30,gpsStatu
			Write 48,gpsKuzey[5]:Write 49,gpsKuzey[6]:Write 50,gpsKuzey[7]:Write 51,gpsKuzey[8]:Write 52,gpsKuzey[9]
			Write 53,gpsDogu[0] :Write 54,gpsDogu[1] :Write 55,gpsDogu[2] :Write 56,gpsDogu[3] :Write 57,gpsDogu[4]
			Write 58,gpsDogu[5] :Write 59,gpsDogu[6] :Write 60,gpsDogu[7] :Write 61,gpsDogu[8] :Write 62,gpsDogu[9] :Write 63,gpsDogu[10]
			Write 64,gpsHiz[0]  :Write 65,gpsHiz[1]  :Write 66,gpsHiz[2]  :Write 67,gpsHiz[3]  :Write 68,gpsHiz[4]  :Write 69,gpsHiz[5]  :Write 70,gpsHiz[6]
			Write 71,gpsSapma[0]:Write 72,gpsSapma[1]:Write 73,gpsSapma[2]:Write 74,gpsSapma[3]:Write 75,gpsSapma[4]:Write 76,gpsSapma[5]
            For addr = 77 TO 89
                Write addr,SIF
            Next addr
            SerOut2 PIO_TXD,MAX_BAUD,["GPS TIME : ",STR gpsSaat\2,":",STR gpsDakika\2,":",STR gpsSaniye\2,"  ", STR gpsGun\2 ,".",STR gpsAy\2,".","20",STR gpsYil\2,13,10]
			SerOut2 PIO_TXD,MAX_BAUD,["KUZEY ",STR gpsKuzey\10,13,10]
			'SerOut2 PIO_TXD,MAX_BAUD,["DOGU ",STR gpsDogu\11,13,10]
			'SerOut2 PIO_TXD,MAX_BAUD,["HIZ ",STR gpsHiz\7,13,10]
			'SerOut2 PIO_TXD,MAX_BAUD,["SAPMA ",STR gpsSapma\6,13,10,13,10]
   			Return
GpsErr1     :   High GPS_LED
                ErrGPS = EE
				Write 29,ErrGPS
			    Write 30,gpsStatu
				Write 31,gpsSaat[0]:Write 32,gpsSaat[1]
			    Write 37,gpsGun[0]:Write 38,gpsGun[1]
			    Write 39,gpsAy[0]:Write 40,gpsAy[1]
			    Write 41,gpsYil[0]:Write 42,gpsYil[1]
				For addr = 43 TO 89
                    Write addr,SIF
                Next addr
                SerOut2 PIO_TXD,MAX_BAUD,["GPS TIME : ",STR gpsSaat\2,":",STR gpsDakika\2,":",STR gpsSaniye\2,"  ", STR gpsGun\2 ,".",STR gpsAy\2,".","20",STR gpsYil\2,13,10] ' SerOut2 PIO_TXD,MAX_BAUD,["GPS DEC TIME : ",DEC2 gpsSaat,":",DEC2 gpsDakika,":",DEC2 gpsSaniye,"  ", DEC2 gpsGun ,".",DEC2 gpsAy,".","20",DEC2 gpsYil,13,10]
                Return			 'GoTo GpsVeriOku
armys2000
'****************        GPRS  ROAMING KONTROL RUTİNİ       ********************
GpRoKnt  :  wr = RR
            GoSub WRCalType
            SerOut2 PIO_TXD,MAX_BAUD,["ROAM: ",SysCalType,":",DEC2 FlgCalType,CR,LF]
            IF SysCalType = SIF Then
               'EtkenCalType = 49
               'wr = RR
               'GoSub WRCalType
               'GoTo GpRoKntOK
               FlgCalType = 97
            EndIF
            IF SysCalType = BIR Then
	            IF mdmRom = SIF Then        ' NOT ROAMING
	               'EtkenCalType = 50
	               'FlgGprsRom = SIF
	               'wr = RR
	               'GoSub WRCalType
	               'GoTo GpRoKntOK
	               IF FlgGprsReg = SIF Then ' GPRS HAT YOK
	                  FlgCalType = 97       ' Çalışma Şekli SMS ten Devam Et
	               Else
	                  FlgCalType = 98       ' SMS / GPRS MODUNDA KAL
	               EndIF
	            EndIF
	            IF mdmRom = BIR Then        ' ROAMING ENABLE
	               'EtkenCalType = 49
	               'FlgGprsRom = BIR
	               'wr = RR
	               'GoSub WRCalType
	               FlgCalType = 97          ' SMS MODUNA GEÇ
	               IF FlgBaglanti = BIR Then
	                  FlgGpYer = SIF          ' Roaming e Girildiğinde Birkereliğine YER Bilgisi Gönder
	                  FlgBaglanti = SIF
	                  GoSub G24KapaSoft
	                  GoTo SysInit
	               EndIF
	            EndIF
	        EndIF
GoTo GpRoKntOK
'*********************              SMS KONTROL             ********************
SmsKnt  :  SerOut2 PIO_TXD,MAX_BAUD,["SmsKnt: ",mdmMsg,":",DEC2 MsgIndex,CR,LF]
           IF mdmMsg = SIF Then
              GoTo SmsKntOK
           EndIF
           IF MsgIndex < 6 Then  ' Mesaj Fazlası Varsa Hepsini Sil İlk 5 Mesaj Önemli
              GoTo SmsKntLoop
           Else
              GoSub BuffDel
              Pause Bek200
              Pause Bek1000
              GoSub MeReady
              GoTo SmsKntOK
           EndIF
     SmsKntLoop :
           For addr= 0 TO 255
               RegGeneral[addr]=BOSLUK
           Next addr
           For addr= 0 TO 159
               SmsMesaj[addr]=BOSLUK
           Next addr
           GoSub BuffDel
           Pause Bek200
           GoSub MeReady
           GoSub BuffDel
           Pause Bek300
           GoSub MeReady
           WhoIs = DOK
           GoSub BuffDel
           Pause Bek300
           SerOut2 G24_TXD,G24_BAUD,["AT+CMGR=",#MsgIndex,CR,LF]
           GoSub MeReady
  		   'SerOut2 PIO_TXD,MAX_BAUD,["G24VERI:@"]
           'For G24ADDR=0 TO 349
           '    SerOut2 PIO_TXD,MAX_BAUD,[G24VERI(G24ADDR)]
           'Next G24ADDR
           'SerOut2 PIO_TXD,MAX_BAUD,["@",CR,LF]
		   	    IF G24VERI[(G24ADDR + 2)] = "M"  Then
		   	    IF G24VERI[(G24ADDR + 5)] = ":"  Then
		   	    IF G24VERI[(G24ADDR + 6)] = " "  Then
		   	       i       = 0
				   j       = 0
				   addr    = 7
				   strComp = "O"
                   MsgLoop1: IF G24VERI[( G24ADDR + 7 )] = strComp  Then
			                    IF j = 0 Then
						           strComp = "K"
						        EndIF
						        IF j = 1 Then
						           strComp = CR
						        EndIF
						        IF j = 2 Then
						           strComp = LF
						        EndIF
						        IF j >= 3 Then
						           VirSay = 0
						           i      = 0
						           j      = 0
						           GoTo MsgOkundu
						        EndIF
			                    j = j + 1
						     Else
						        j       = 0
						        strComp = "O"
						     EndIF
						     RegGeneral[i]=G24VERI[( G24ADDR + 7 )]
							 i = i + 1
							 GoTo MsgLoop1
	           	EndIF
		   	    EndIF
		   	    EndIF
		   	    EndIF
		   	    EndIF
		   	    EndIF
		   	    EndIF
		   Next G24ADDR
	       GoTo MsgIslOk
	 MsgOkundu :
	       IF 	(RegGeneral[i] = CR) AND ( RegGeneral[(i+1)] = LF) Then
		        i =  i + 1
		        GoTo MsgLoop2
		   Else
		        i= i + 1
		        GoTo MsgOkundu
		   EndIF
	 MsgLoop2  :
		       	GoTo MsgLoop3
		   Else
		        SmsMesaj[j]=RegGeneral[(i+1)]
		        i = i + 1
		        j = j + 1
		        GoTo MsgLoop2
		   EndIF
	 MsgLoop3  :
	       SerOut2 PIO_TXD,MAX_BAUD,["Q",STR SmsMesaj\160,"W",CR,LF]
	       wr = RR
	       GoSub WRusrAdmin
	       GoSub WRpasAdmin
	       usrKontrol[0] = SmsMesaj[0]
           usrKontrol[1] = SmsMesaj[1]
           usrKontrol[2] = SmsMesaj[2]
           usrKontrol[3] = SmsMesaj[3]
           usrKontrol[4] = SmsMesaj[4]
           usrKontrol[5] = SmsMesaj[5]
           usrKontrol[6] = SmsMesaj[6]
           usrKontrol[7] = SmsMesaj[7]
           pasKontrol[0] = SmsMesaj[8]
           pasKontrol[1] = SmsMesaj[9]
           pasKontrol[2] = SmsMesaj[10]
           pasKontrol[3] = SmsMesaj[11]
           GoSub usrTypeSor
           IF usrType = 9 Then
              FlgMsgVar	= SIF
              For addr= 0 TO 159
                  SmsMesaj[addr] = BOSLUK
              Next addr
              GoSub BuffDel
              Pause Bek300
              GoSub MesajSil
    		  GoSub MeReady
           Else
              GoSub BuffDel
              Pause Bek300
              GoSub MesajSil
              GoSub MeReady
              FlgMsgVar = BIR
           EndIF
MsgIslOk : IF  MsgIndex >= 5 Then
		       MsgIndex = 1
		   Else
		       MsgIndex =  MsgIndex + 1
		   EndIF
GoTo SmsKntOK
'********************            SMS KOMUT İCRA            *********************
SmKmtIc       :
                 IF FlgMsgVar = SIF Then			'SMS Komut Varmı
                    GoTo SmKmtIcOK
                 EndIF
                 IF SmsMesaj[12] = RR    Then  'SYSTEM RESET "R"
                     IF  SmsMesaj[13] = MM Then 'Modemi Reset Et
                         GoSub G24KapaSoft
                         GoTo SysInit
                     EndIF
                 EndIF
                 IF SmsMesaj[12] = DOK    Then  'SMS Bloke
                     IF  ((SmsMesaj[13] = BIR ) AND (SmsMesaj[14] = BIR )) Then
                          High ROLE
                     Else
                          Low ROLE
                     EndIF
                 EndIF
                 IF SmsMesaj[12] = YED  Then   ' Konsol ID Kayıt
				    KonsolID[0] = SmsMesaj[13]
				    KonsolID[1] = SmsMesaj[14]
					KonsolID[2] = SmsMesaj[15]
					KonsolID[3] = SmsMesaj[16]
					KonsolID[4] = SmsMesaj[17]
				    wr =WW
				   GoSub WRKonsolID
				 EndIF
                 IF SmsMesaj[12] = ALT    Then  'Server IP ve Port Kaydı
                    ipServer[0] = SmsMesaj[13]
		            ipServer[1] = SmsMesaj[14]
		            ipServer[2] = SmsMesaj[15]
		            ipServer[3] = SmsMesaj[16]
		            ipServer[4] = SmsMesaj[17]
		            ipServer[5] = SmsMesaj[18]
		            ipServer[6] = SmsMesaj[19]
		            ipServer[7] = SmsMesaj[20]
		            ipServer[8] = SmsMesaj[21]
		            ipServer[9] = SmsMesaj[22]
		            ipServer[10] = SmsMesaj[23]
		            ipServer[11] = SmsMesaj[24]
		            prtServer[0] =  SmsMesaj[25]
		            prtServer[1] =  SmsMesaj[26]
		            prtServer[2] =  SmsMesaj[27]
		            prtServer[3] =  SmsMesaj[28]
		            prtServer[4] =  SmsMesaj[29]
                    wr =WW
                    GoSub WRipServer
					GoSub WRprtServer
                    SysCalType = SmsMesaj[30]
                       wr=WW
                       GoSub WRCalType
                       GoSub G24KapaSoft
                       GoTo SysInit
                    EndIF
                    wr = WW
                    GoSub WRCalType
                 EndIF
                 IF SmsMesaj[12] = BES    Then  'Çalışma Şekli Belirleme
                    SysCalType = SmsMesaj[13]
                       wr=WW
                       GoSub WRCalType
                       GoSub G24KapaSoft
                       GoTo SysInit
                    EndIF
                    wr = WW
                    GoSub WRCalType
                 EndIF
                 IF SmsMesaj[12] = DOT  Then 'SMS APN KAYIT
                    ApnName[0]   = SmsMesaj[13]
			        ApnName[1]   = SmsMesaj[14]
			        ApnName[2]   = SmsMesaj[15]
			        ApnName[3]   = SmsMesaj[16]
			        ApnName[4]   = SmsMesaj[17]
			        ApnName[5]   = SmsMesaj[18]
			        ApnName[6]   = SmsMesaj[19]
			        ApnName[7]   = SmsMesaj[20]
			        ApnName[8]   = SmsMesaj[21]
			        ApnName[9]   = SmsMesaj[22]
			        ApnName[10]  = SmsMesaj[23]
			        ApnUser[0]  = SmsMesaj[24]
			        ApnUser[1]  = SmsMesaj[25]
			        ApnUser[2]  = SmsMesaj[26]
			        ApnUser[3]  = SmsMesaj[27]
			        ApnUser[4]  = SmsMesaj[28]
			        ApnUser[5]  = SmsMesaj[29]
			        ApnUser[6]  = SmsMesaj[30]
			        ApnUser[7]  = SmsMesaj[31]
			        ApnPass[0]  = SmsMesaj[32]
			        ApnPass[1]  = SmsMesaj[33]
			        ApnPass[2]  = SmsMesaj[34]
			        ApnPass[3]  = SmsMesaj[35]
			        ApnPass[4]  = SmsMesaj[36]
			        ApnPass[5]  = SmsMesaj[37]
			        ApnPass[6]  = SmsMesaj[38]
			        ApnPass[7]  = SmsMesaj[39]
			        wr=WW
			        GoSub WRApnKayit
                 EndIF
                 IF SmsMesaj[12] = UC    Then  'SMS UserName Şifre Değiştirme
                    usrAdmin[0]= SmsMesaj[13]
				    usrAdmin[1]= SmsMesaj[14]
				    usrAdmin[2]= SmsMesaj[15]
				    usrAdmin[3]= SmsMesaj[16]
				    usrAdmin[4]= SmsMesaj[17]
				    usrAdmin[5]= SmsMesaj[18]
				    usrAdmin[6]= SmsMesaj[19]
				    usrAdmin[7]= SmsMesaj[20]
				    pasAdmin[0]= SmsMesaj[21]
				    pasAdmin[1]= SmsMesaj[22]
				    pasAdmin[2]= SmsMesaj[23]
				    pasAdmin[3]= SmsMesaj[24]
				    wr = WW
				    GoSub WRusrAdmin
				    GoSub WRpasAdmin
                 EndIF
                 IF SmsMesaj[12] = IKI    Then  'SMS Yer
                    FlgSmsYer = BIR
                 EndIF
                 IF SmsMesaj[12] = BIR    Then  'SMS Takip
                    IF SmsMesaj[13]=SIF Then
					    FlgSmTakip = SIF
					EndIF
				    IF SmsMesaj[13]=BIR Then
					    FlgSmTakip = BIR
					EndIF
				    IF SmsMesaj[14]=SIF Then
					   	SmTaWait = 2
					EndIF
					IF SmsMesaj[14]=BIR Then
					   	SmTaWait = 15
					EndIF
					IF SmsMesaj[14]=IKI Then
					   	SmTaWait = 38
					EndIF
					IF SmsMesaj[14]=UC Then
					   	SmTaWait = 75
					EndIF
					IF SmsMesaj[14]=DOT Then
					   	SmTaWait = 230
					EndIF
					IF SmsMesaj[14]=BES Then
					  	SmTaWait = 450
					EndIF
				 EndIF
                 IF SmsMesaj[12]=SIF    Then  'GPRS Takip Durumu Kayıdı
                       FlgGpTakip = SIF
				       Write 109,FlgGpTakip
                    EndIF
                       FlgGpTakip = BIR
                    EndIF
         	     EndIF
         	     FlgMsgVar = SIF
GoTo SmKmtIcOK
'****************                 GPRS BLOK                 ********************
GPBLK :  'SerOut2 PIO_TXD,MAX_BAUD,["GPBLK: ",DEC2 FlgCalType,CR,LF]
'****************                GPRS MIPCALL               ********************
GpMipCall :        SerOut2 PIO_TXD,MAX_BAUD,["MIPCAL: ",DEC2 FlgCalType,":",FlgGsmReg,":",FlgGprsReg,":",FlgMipCall,":",DEC3 SayMipCall,CR,LF]
                   IF FlgCalType < 98 Then
                      GoTo GPBLKOK
                   EndIF
                   IF FlgGsmReg = SIF Then
                      SerOut2 PIO_TXD,MAX_BAUD,["GPMC2:",FlgGsmReg,CR,LF]
                      GoTo GPBLKOK
                   EndIF
                      GoTo GPBLKOK
                   EndIF
                   IF FlgMipCall = BIR Then
                      GoTo GpMipOpen
                   EndIF
                   wr = RR
                   GoSub WRApnKayit
                   GoSub BuffDel
                   SerOut2 G24_TXD,G24_BAUD,["at+mipcall=1,",34]
                   For addr = 0 TO 9
                       IF ApnName[addr] = 63 Then   ' ? İşareti İle Sonlandır
			              GoTo  DMipCik1
			           Else
				          SerOut2 G24_TXD,G24_BAUD,[ApnName(addr)]
				       EndIF
				   Next addr
              DMipCik1: SerOut2 G24_TXD,G24_BAUD,[34,VI,34]
                   For addr = 0 TO 7
                       IF ApnUser[addr] = 63 Then   ' ? İşareti İle Sonlandır
			              GoTo  DMipCik2
			           Else
				          SerOut2 G24_TXD,G24_BAUD,[ApnUser(addr)]
				       EndIF
				   Next addr
              DMipCik2: SerOut2 G24_TXD,G24_BAUD,[34,VI,34]
                   For addr = 0 TO 7
                       IF ApnPass[addr] = 63 Then   ' ? İşareti İle Sonlandır
			              GoTo  DMipCik3
			           Else
				          SerOut2 G24_TXD,G24_BAUD,[ApnPass(addr)]
				       EndIF
				   Next addr
              DMipCik3: SerOut2 G24_TXD,G24_BAUD,[34,CR,LF]
                   GoSub MeReady
				   	          SerOut2 PIO_TXD,MAX_BAUD,["MIPCALL OK1",CR,LF]
				   	       EndIF
				   	    EndIF
	        	   Next G24ADDR
                   SerOut2 PIO_TXD,MAX_BAUD,["MIPCALL ER1",CR,LF]
                   addr = 0
              MipCalL1:
                   GoSub BuffDel
                   SerOut2 G24_TXD,G24_BAUD,["at+mipcall?",CR,LF]
				   GoSub MeReady
				   	                IF G24VERI[(G24ADDR + 4)] = "C"  Then
				   	                   IF G24VERI[(G24ADDR + 5)] = "A"  Then
				   	                      IF G24VERI[(G24ADDR + 6)] = "L"  Then
				   	                         IF G24VERI[(G24ADDR + 7)] = "L"  Then
				   	                                        SerOut2 PIO_TXD,MAX_BAUD,["MIPCALL OK2",CR,LF]
				   	                                        FlgMipCall = BIR       ' MODEM NETTE
				   	                                        SayMipCall = 0
				   	                                        GoTo DMipCik4
				   	                                     EndIF
				   	                                  EndIF
				   	                               EndIF
				   	                            EndIF
				   	                         EndIF
				   	                      EndIF
				   	                   EndIF
				   	                EndIF
				   	             EndIF
				   	          EndIF
				   	       EndIF
				   	    EndIF
				   Next G24ADDR
				   MipCalEr   :   SerOut2 PIO_TXD,MAX_BAUD,["MIPCALL ER2 ",DEC3 addr,CR,LF]
				                  SerOut2 PIO_TXD,MAX_BAUD,["MC=",G24VERI(G24ADDR),cr,lf]
				                  Next G24ADDR
				                  Pause Bek1000
				                  IF addr >= 40 Then
				                     addr = 0
				                     FlgMipCall = SIF       ' MODEM NETTE DEĞİL
                                     SayMipCall = SayMipCall + 1
                                     GoTo DMipCik4
				                  Else
				                     addr = addr + 1
				                     GoTo MipCalL1
				                  EndIF
			      DMipCik4:
'****************                GPRS MIPOPEN               ********************
GpMipOpen :        SerOut2 PIO_TXD,MAX_BAUD,["MIPOPEN: ",FlgMipCall,":",FlgMipOpen,":",DEC3 SayMipOpen,CR,LF]
                   IF FlgMipCall = SIF Then
                      GoTo GPBLKOK
                   EndIF
                   IF FlgMipOpen = BIR Then
                      GoTo GpPing
                   EndIF
                   wr=RR
                   GoSub WRipServer
                   GoSub WRprtServer
                   GoSub WRKonsolID
                   GoSub BuffDel
                   'SerOut2 G24_TXD,G24_BAUD,["at+mipopen=1,1234,",34,"088.248.010.126",34,",","48100,0",CR,LF]
                   SerOut2 G24_TXD,G24_BAUD,["at+mipopen=1,1234,",34,ipServer(0),ipServer(1),ipServer(2),".",ipServer(3),ipServer(4),ipServer(5),".",ipServer(6),ipServer(7),ipServer(8),".",ipServer(9),ipServer(10),ipServer(11),34,VI,STR prtServer\5,VI,"0",CR,LF]
                    addr = 0
              MipOpL1:
                   GoSub BuffDel
                   SerOut2 G24_TXD,G24_BAUD,["at+mipopen?",CR,LF]
				   GoSub MeReady
				   	                IF G24VERI[(G24ADDR + 4)] = "O"  Then
				   	                   IF G24VERI[(G24ADDR + 5)] = "P"  Then
				   	                      IF G24VERI[(G24ADDR + 6)] = "E"  Then
				   	                         IF G24VERI[(G24ADDR + 7)] = "N"  Then
				   	                                  IF G24VERI[(G24ADDR + 10)] = "2"  Then
				   	                                        SerOut2 PIO_TXD,MAX_BAUD,["MIPOPEN OK",CR,LF]
				   	                                        FlgMipOpen  = BIR     ' MODEM SOKET BAĞLANTI YAPMIŞ
				                                            FlgBaglanti = BIR
				                                            SayMipOpen = 0
				                                            Low GPRS_LED
				   	                                        GoTo DMipCik5
				   	                                  EndIF
				   	                               EndIF
				   	                            EndIF
				   	                         EndIF
				   	                      EndIF
				   	                   EndIF
				   	                EndIF
				   	             EndIF
				   	          EndIF
				   	       EndIF
				   	    EndIF
				   Next G24ADDR
				   MipOpEr   :   SerOut2 PIO_TXD,MAX_BAUD,["MIPOPEN ER ",DEC3 addr,CR,LF]
				                  Pause Bek1000
				                  IF addr >= 30 Then
				                     addr = 0
				                     FlgMipOpen  = SIF     ' MODEM SOKET BAĞLANTI YAPAMAMIŞ
				                     FlgBaglanti = SIF
                                     SayMipOpen = SayMipOpen + 1
                                     High GPRS_LED
                                     GoTo DMipCik6
				                  Else
				                     addr = addr + 1
				                     GoTo MipOpL1
				                  EndIF
		          DMipCik5:
                                     'SerOut2 G24_TXD,G24_BAUD,["at+mipsets=1,6",CR,LF]
				                     'Pause Bek100
				                     GoSub BuffDel
				                     SerOut2 G24_TXD,G24_BAUD,["at+mipsend=1",VI,34,HEX2 STX,HEX2 KonsolID(0),HEX2 KonsolID(1),HEX2 KonsolID(2),HEX2 KonsolID(3),HEX2 KonsolID(4),"49",HEX2 ETX,34,CR,LF]
				                     Pause Bek100
				                     SerOut2 G24_TXD,G24_BAUD,["at+mippush=1",CR,LF]
				                     GoSub MeReady
				   DMipCik6:
				                      GoTo GpPing
'****************                 GPRS PING                 ********************
GpPing    :       SerOut2 PIO_TXD,MAX_BAUD,["MIP PING: ",FlgBaglanti,":",FlgPingSend,":",FlgPingRec,":",DEC3 SayPingErr,":",DEC3 SayPing,CR,LF]
                  IF FlgBaglanti = SIF Then
                     GoTo GPBLKOK
                  EndIF
                  IF FlgPingSend = BIR Then
                     SayPingErr = SayPingErr + 1
                     IF FlgPingRec  = BIR Then
                        SayPing    = 0
                        SayPingErr = 0
                        FlgPingSend = SIF
                        FlgPingRec  = SIF
                        GoTo GPBLKOK
                     EndIF
                     IF SayPingErr > 15 Then
                        SayPingErr = 0
                        GoSub G24KapaSoft
                        GoTo SysInit
                     EndIF
                  EndIF
                  IF SayPing < 100 Then
                     SayPing = SayPing + 1
                     GoTo GPBLKOK
                  EndIF
                  'SerOut2 PIO_TXD,MAX_BAUD,["PING SEND",13,10]
                  Deger = BOSLUK
                  wr=RR
                  GoSub WRKonsolID
                  'SerOut2 G24_TXD,G24_BAUD,["at+mipsend=1",VI,34,STR KonsolID\5,"50",34,CR,LF]
				  GoSub BuffDel
				  'Pause Bek100
				  SerOut2 G24_TXD,G24_BAUD,["at+mipsend=1",VI,34,HEX2 STX,HEX2 KonsolID(0),HEX2 KonsolID(1),HEX2 KonsolID(2),HEX2 KonsolID(3),HEX2 KonsolID(4),"50",HEX2 ETX,34,CR,LF]
				  Pause Bek100
                  GoSub MeReady
                  FlgPingSend = BIR
                  FlgPingRec  = SIF
                  SayPingErr  = 0
                  SayPing	  = 0
GoTo GPBLKOK
'******************************************************************* 27.04.2007
'********************           GPRS KOMUT İCRA            *********************
'******************************************************************** 06.10.2007
GpKoIc       :  SerOut2 PIO_TXD,MAX_BAUD,["GPKOIC: ",DEC3 MipData2[2],":",DEC3 MipData2[3],CR,LF]
				IF FlgCaltype < 98 Then
                     FlgGprsCom = SIF
                     GoTo GpKoIcOk
                 EndIF
                 IF FlgGprsCom = SIF Then			'GPRS Komut Varmı
                    GoTo GpKoIcOK
                 EndIF
                 'IF MipData2[0] <> STX Then	    'Komutun Başlığı STX Varmı
                 '   GoTo GpKoIcOK
                 'EndIF
                 IF MipData2[1] = RR Then
                    GWR =RR
                 EndIF
                 IF MipData2[1] = WW Then
                    GWR =WW
                 EndIF
                 GpKomut = MipData2[2]
                 IF GWR =WW Then
                     IF GpKomut = $30 Then          'GPRS Konsol Şifre Ayarları
                        usrAdmin[0]= MipData2[3]
				        usrAdmin[1]= MipData2[4]
				        usrAdmin[2]= MipData2[5]
				        usrAdmin[3]= MipData2[6]
				        usrAdmin[4]= MipData2[7]
				        usrAdmin[5]= MipData2[8]
				        usrAdmin[6]= MipData2[9]
				        usrAdmin[7]= MipData2[10]
				        pasAdmin[0]= MipData2[11]
				        pasAdmin[1]= MipData2[12]
				        pasAdmin[2]= MipData2[13]
				        pasAdmin[3]= MipData2[14]
				        wr = WW
				        GoSub WRusrAdmin
				        GoSub WRpasAdmin
				     EndIF
				     IF GpKomut = $31 Then      ' Konsol ID Kayıdı
				        KonsolID[0] = MipData2[3]
						KonsolID[1] = MipData2[4]
						KonsolID[2] = MipData2[5]
						KonsolID[3] = MipData2[6]
						KonsolID[4] = MipData2[7]
					    wr =WW
				        GoSub WRKonsolID
				     EndIF
			         IF GpKomut = $32 Then        'GPRS APN Kayıtları
				        ApnName[0]   = MipData2[3]
				        ApnName[1]   = MipData2[4]
				        ApnName[2]   = MipData2[5]
				        ApnName[3]   = MipData2[6]
				        ApnName[4]   = MipData2[7]
				        ApnName[5]   = MipData2[8]
				        ApnName[6]   = MipData2[9]
				        ApnName[7]   = MipData2[10]
				        ApnName[8]   = MipData2[11]
				        ApnName[9]   = MipData2[12]
				        ApnName[10]  = MipData2[13]
				        ApnUser[0]  = MipData2[14]
				        ApnUser[1]  = MipData2[15]
				        ApnUser[2]  = MipData2[16]
				        ApnUser[3]  = MipData2[17]
				        ApnUser[4]  = MipData2[18]
				        ApnUser[5]  = MipData2[19]
				        ApnUser[6]  = MipData2[20]
				        ApnUser[7]  = MipData2[21]
				        ApnPass[0]  = MipData2[22]
				        ApnPass[1]  = MipData2[23]
				        ApnPass[2]  = MipData2[24]
				        ApnPass[3]  = MipData2[25]
				        ApnPass[4]  = MipData2[26]
				        ApnPass[5]  = MipData2[27]
				        ApnPass[6]  = MipData2[28]
				        ApnPass[7]  = MipData2[29]
				        wr=WW
				        GoSub WRApnKayit
				     EndIF
				     IF GpKomut = $33 Then            'GPRS Server IP Port Ayarları
                        ipServer[0]  = MipData2[3]
			            ipServer[1]  = MipData2[4]
			            ipServer[2]  = MipData2[5]
			            ipServer[3]  = MipData2[6]
			            ipServer[4]  = MipData2[7]
			            ipServer[5]  = MipData2[8]
			            ipServer[6]  = MipData2[9]
			            ipServer[7]  = MipData2[10]
			            ipServer[8]  = MipData2[11]
			            ipServer[9]  = MipData2[12]
			            ipServer[10] = MipData2[13]
			            ipServer[11] = MipData2[14]
			            prtServer[0] = MipData2[15]
			            prtServer[1] = MipData2[16]
			            prtServer[2] = MipData2[17]
			            prtServer[3] = MipData2[18]
			            prtServer[4] = MipData2[19]
			            wr = WW
			            GoSub WRipServer
			            GoSub WRprtServer
	                 EndIF
				     IF GpKomut = $34 Then               'SMS Merkez Telefon Numarası
                         telMerkez[0]  = MipData2[3]
						 telMerkez[1]  = MipData2[4]
						 telMerkez[2]  = MipData2[5]
						 telMerkez[3]  = MipData2[6]
						 telMerkez[4]  = MipData2[7]
						 telMerkez[5]  = MipData2[8]
						 telMerkez[6]  = MipData2[9]
						 telMerkez[7]  = MipData2[10]
						 telMerkez[8]  = MipData2[11]
						 telMerkez[9]  = MipData2[12]
						 telMerkez[10] = MipData2[13]
						 telMerkez[11] = MipData2[14]
						 telMerkez[12] = MipData2[15]
						 telMerkez[13] = MipData2[16]
						 telMerkez[14] = MipData2[17]
				         wr=WW
				         GoSub WRtelMerkez
				     EndIF
				     IF GpKomut = $35 Then               'SMS Acil1 Telefon Numarası
				        telAcil1[0]   =  MipData2[3]
						telAcil1[1]   =  MipData2[4]
						telAcil1[2]   =  MipData2[5]
						telAcil1[3]   =  MipData2[6]
						telAcil1[4]   =  MipData2[7]
						telAcil1[5]   =  MipData2[8]
						telAcil1[6]   =  MipData2[9]
						telAcil1[7]   =  MipData2[10]
						telAcil1[8]   =  MipData2[11]
						telAcil1[9]   =  MipData2[12]
						telAcil1[10]  =  MipData2[13]
						telAcil1[11]  =  MipData2[14]
						telAcil1[12]  =  MipData2[15]
						telAcil1[13]  =  MipData2[16]
						telAcil1[14]  =  MipData2[17]
						cagAcil1      =  MipData2[18]
						wr =WW
						GoSub WRtelAcil1
				     EndIF
				      IF GpKomut = $36 Then               'SMS Acil2 Telefon Numarası
				         telAcil2[0]   =  MipData2[3]
						 telAcil2[1]   =  MipData2[4]
						 telAcil2[2]   =  MipData2[5]
						 telAcil2[3]   =  MipData2[6]
						 telAcil2[4]   =  MipData2[7]
						 telAcil2[5]   =  MipData2[8]
						 telAcil2[6]   =  MipData2[9]
						 telAcil2[7]   =  MipData2[10]
						 telAcil2[8]   =  MipData2[11]
						 telAcil2[9]   =  MipData2[12]
						 telAcil2[10]  =  MipData2[13]
						 telAcil2[11]  =  MipData2[14]
						 telAcil2[12]  =  MipData2[15]
						 telAcil2[13]  =  MipData2[16]
						 telAcil2[14]  =  MipData2[17]
						 cagAcil2      =  MipData2[18]
						 wr =WW
						 GoSub WRtelAcil2
				     EndIF
				     IF GpKomut = $37 Then    'SMS ACİL ALARM Mesajı Ve Merkeze Bilgi
				         msgAlarm [0]   = MipData2[3]
						 msgAlarm [1]   = MipData2[4]
						 msgAlarm [2]   = MipData2[5]
						 msgAlarm [3]   = MipData2[6]
						 msgAlarm [4]   = MipData2[7]
						 msgAlarm [5]   = MipData2[8]
						 msgAlarm [6]   = MipData2[9]
						 msgAlarm [7]   = MipData2[10]
						 msgAlarm [8]   = MipData2[11]
						 msgAlarm [9]   = MipData2[12]
						 msgAlarm [10]  = MipData2[13]
						 msgAlarm [11]  = MipData2[14]
						 msgAlarm [12]  = MipData2[15]
						 msgAlarm [13]  = MipData2[16]
						 msgAlarm [14]  = MipData2[17]
						 msgAlarm [15]  = MipData2[18]
						 msgAlarm [16]  = MipData2[19]
						 msgAlarm [17]  = MipData2[20]
						 msgAlarm [18]  = MipData2[21]
						 msgAlarm [19]  = MipData2[22]
						 msgAlarm [20]  = MipData2[23]
						 msgAlarm [21]  = MipData2[24]
						 msgAlarm [22]  = MipData2[25]
						 msgAlarm [23]  = MipData2[26]
						 msgAlarm [24]  = MipData2[27]
				         wr =WW
				         GoSub WRmsgAlarm
				     EndIF
				     IF GpKomut = $38 Then       'GPRS Konsol Çalışma Şekli Ayarı
                        FlgGprsCom = SIF
                        GpKomut = $FF
                        SysCalType = MipData2[3]
                        wr=WW
                        GoSub WRCalType
                        IF SysCalType=SIF Then
	                           wr=WW
	                           GoSub WRCalType
	                           GoTo SystemReset
			                EndIF
                        EndIF
				     EndIF
					 IF GpKomut = $39 Then       'GPRS Konsol RESET Ayarı
                        FlgGprsCom = SIF
                        GpKomut = $FF
                        kntSysReset = MipData2[3]
                        wr=WW
                        GoSub WRSysReset
				     EndIF
					 IF GpKomut = $40 Then       'GPRS Konsol KONTAK Ayarı
                        FlgGprsCom = SIF
                        GpKomut = $FF
                        kntKontak = MipData2[3]
                        wr=WW
                        GoSub WRSysKontak
				     EndIF
				     IF GpKomut = $41 Then               'GPRS Kontrol Ayarları
                        FlgGprsCom = SIF
                        GpKomut = $FF
                        kntAcil   = MipData2[3]
                        kntSuphe  = MipData2[4]
				        kntAlarm  = MipData2[5]
				        kntAku    = MipData2[6]
				        kntBloke  = MipData2[7]
				        kntKamera = MipData2[8]
				        kntTakip  = MipData2[9]
				        kntYer    = MipData2[10]
				        kntMrkzBilgi = MipData2[11]
				        wr=WW
				        GoSub WRkntKontrol
				     EndIF
				     IF GpKomut = $50 Then          'GPRS Takip  Durumu
				        IF MipData2[3]=SIF Then
					       FlgGpTakip = SIF
					    EndIF
				        IF MipData2[3]=BIR Then
				           FlgGpTakip = BIR
					    EndIF
					    Write 107,MipData2[4]   ' GPRS Takip Aralığı
				     EndIF
				     IF GpKomut = $51 Then           'GPRS Bloke
				        FlgBloke= MipData2[3]
				        IF FlgBloke = BIR Then
				           High ROLE
				        EndIF
				        IF FlgBloke = SIF Then
				           Low ROLE
				        EndIF
				     EndIF
                     IF GpKomut = $52 Then   ' Yer Bilgisi İste
                        FlgGprsCom = SIF
                        GpKomut = $FF
                        FlgGpYer = BIR
                     EndIF
				     IF GpKomut = $53 Then   'ACİL DURUM VER
				         SosType = BIR
				         FlgGprsCom = SIF
                         GpKomut = $FF
				         GoTo AlarmVer
                     EndIF
				     IF GpKomut = $54 Then   'ACİL DURUM İptal
				        SosType = SIF
				        FlgSosDurum = SIF
				     EndIF
				     IF GpKomut = $55 Then   'ALARM DURUM VER
				        SosType = IKI
				        FlgGprsCom = SIF
                        GpKomut = $FF
				        GoTo AlarmVer
                     EndIF
				     IF GpKomut = $56 Then   'ALARM İptal
				        FlgSosDurum = SIF
				        SosType = SIF
				     EndIF
  				     IF GpKomut = $99 Then          'GPRS PING Cevabı
                        IF ((MipData2[3] = ALT ) AND (MipData2[4] = ALT )) Then
                           FlgPingSend = SIF
                           FlgPingRec  =  BIR
                           FlgPingErr  = SIF
                           SayPingErr  = 0
                           SayPing     = 0
                        EndIF
                     EndIF
                 EndIF
                 FlgGprsCom = SIF
                 GpKomut = $FF
GoTo GpKoIcOK
'****************          SOS  DURUM VARSA UYGULA          ********************
'******************************************************************** 02.05.2007
SosKontrol    : GoSub SosOku
                IF FlgSosDurum = SIF Then
                   GoTo SosKontrolOK
                EndIF
     AlarmVer : IF FlgRING =  BIR Then   ' Komut İle Alarm Verdirmek İçin
                   SerOut2 PIO_TXD,MAX_BAUD,[SS,II,MM,BOSLUK,EE,RR,RR,13,10]
                   GoTo SosKontrolOK
                EndIF
                IF mdmSim = SIF Then   ' SIM Kart Takılı Değilse Vazgeç
                   GoSub CagriKapa
                EndIF
                For addr=0 TO 159
                Next addr
                For addr=0 TO 159
                    GprsMesaj[addr] = BOSLUK
                Next addr
                IF FlgCaltype > 97 Then ' Çalışma Şekli SMS/GPRS İse
                   IF FlgBaglanti = BIR Then  ' GPRS Bağlantısı Varsa Server a da ALARM/ACİL Durumunu Gönder
                      TxMesajType =  IKI      ' Gönderme Modu Büyük Paket
                      'Sender     =  BIR      ' Burda Önemi Yok
                      For addr= 0  TO 89
                          Read addr,Deger
			              RegGeneral[addr]=Deger
			          Next addr
                      GoSub GpPakHaz          ' Paketi Hazırla Gel
                      SerOut2 PIO_TXD,MAX_BAUD,["GA SNDG",13,10]
				     GoSub GpMsgTX
			       EndIF
                EndIF
                GoSub MdmEkrOF
AclAlrDurumu  : wr = RR
                GoSub WRkntKontrol
	            GoSub WRKonsolID
			    GoSub WRtelMerkez
			    GoSub WRtelAcil1
			    GoSub WRtelAcil2
			    GoSub WRmsgAlarm
                IF kntMrkzBilgi = BIR Then
		           For addr = 0 TO 14
		               telEtkin[addr] = telMerkez[addr]
		           Next addr
		           IF SosType = BIR Then
		              SmsPacType[0]=BES : SmsPacType[1]=IKI    ' ACİL
		           EndIF
		           IF SosType = IKI Then
		              SmsPacType[0]=BES : SmsPacType[1]=UC     ' ALARM
		           EndIF
		           IF SosType = UC Then
		              SmsPacType[0]=BES : SmsPacType[1]=DOT    ' ŞÜPHE
		           EndIF
				   SmsMesaj[0] = KonsolID[0]
				   SmsMesaj[1] = KonsolID[1]
				   SmsMesaj[2] = KonsolID[2]
				   SmsMesaj[3] = KonsolID[3]
				   SmsMesaj[4] = KonsolID[4]
				   SmsMesaj[5] = SmsPacType[0]
				   SmsMesaj[6] = SmsPacType[1]
                   For addr= 0  TO 89
	                   Read addr,Deger
	                   SmsMesaj[(addr+7)] = deger
	               Next addr
	               For addr= 97  TO 159
	                   SmsMesaj[addr] = SIF
	               Next addr
		           SerOut2 PIO_TXD,MAX_BAUD,["SMS MESAJ:",STR SmsMesaj\160,13,10]
		           GoSub SmMsgTx
		        EndIF
                IF cagAcil1 = BIR Then   ' Mesaj Gönder
                   For addr = 0 TO 14
		               telEtkin[addr] = telAcil1[addr]
		           Next addr
                   GoSub SmAlarmPakHaz
		           GoSub SmMsgTx
                EndIF
                IF cagAcil1 = SIF Then     ' Çağrı Yap
                   For addr = 0 TO 14
		           Next addr
                   GoSub DialUp
                EndIF
                IF cagAcil2 = BIR Then   ' Mesaj Gönder
                   For addr = 0 TO 14
		               telEtkin[addr] = telAcil2[addr]
		           Next addr
		           GoSub SmAlarmPakHaz
		           GoSub SmMsgTx
		        EndIF
                IF cagAcil2 = SIF Then  ' Çağrı Yap
	               For addr = 0 TO 14
			       Next addr
			       GoSub DialUp
                EndIF
                FlgSosDurum = SIF
GoTo SosKontrolOK
armys2000
'****************               SMS TAKIP DURUMU            ********************
SmTakipDur   : IF FlgCalType > 97 Then ' GPRS Bağlantısı ve Takibi Varsa Çık
                  GoTo SmTakipDurOK
               EndIF
               IF FlgSmTakip = BIR Then
                  IF SaySmTakip >= SmTaWait  Then
		              SaySmTakip = 0
		              wr = RR
		              GoSub WRtelMerkez
		              For addr = 0 TO 14
		              Next addr
		              SmsPacType[0]=ALT : SmsPacType[1]=SIF    ' TAKIP
		              For addr= 0  TO 89
			              Read addr,Deger
			              SmsMesaj[(addr+7)]=Deger
			          Next addr
			          For addr= 97  TO 159
			          Next addr
				      GoSub SmMsgTx
		          EndIF
		          SaySmTakip  = SaySmTakip + 1
               EndIF
GoTo SmTakipDurOK
'****************           SMS YER SORMA DURUMU            ********************
SmYerSorma   :  SerOut2 PIO_TXD,MAX_BAUD,["SMS YER:",FlgSmsYer,13,10]
                   IF FlgSmsYer = BIR  Then
                   FlgSmsYer = SIF
                   wr = RR
                   GoSub WRtelMerkez
	               For addr = 0 TO 14
	               Next addr
	               SmsPacType[0]=ALT : SmsPacType[1]=BIR    ' YER
	               For addr= 0  TO 89
		               Read addr,Deger
		           Next addr
		           For addr= 97  TO 159
		           Next addr
				   GoSub SmMsgTx
				EndIF
GoTo SmYerSormaOK
'****************                KONTAK KONTROL             ********************
KontakKont    :   IF FlgCalType < 98 Then       ' Çalışma Şekli  SMS se Çık
                     GoTo KontakKontOK
                  EndIF
				  wr=RR
			      GoSub WRkntKontrol
                  IF kntKontak = SIF Then		' Kontak Kontrolü Yapılmayacaksa
                     FlgKontak = SIF
                     GoTo KontakKontOK
                  EndIF
                  ' 24.10.2007
                  IF KONTAK = 0 Then           ' Kontak Anahtarı Açık İse
			         FlgKontak = SIF
			         'FlgKntkGitA = SIF
			         FlgKntkGitK = SIF
			      EndIF
			      ' 24.10.2007
			      IF KONTAK = 1 Then           ' Kontak Anahtarı Kapalı İse
			         FlgKontak = BIR
			         FlgKntkGitA = SIF
			         'FlgKntkGitK = SIF
			      EndIF
	              'IF KONTAK = 0 Then
			      '   FlgKontak = BIR
			      '   FlgKntkGit = SIF
			      'Else
			      '   FlgKontak = SIF
				  'EndIF
                 SerOut2 PIO_TXD,MAX_BAUD,["kontak:",kntKontak,":",DEC2 FlgKontak,CR,LF]
                  Write 15 ,FlgKontak ' Kontak Bilgisinide Yaz
                  IF FlgBaglanti = SIF Then ' GPRS  Yoksa Çık
                     GoTo KontakKontOK
                  EndIF
                  ' 24.10.2007
                  IF FlgKontak = SIF Then             ' Kontak Açıldı Bilgisi
                     IF FlgKntkGitA = SIF Then
                        SerOut2 PIO_TXD,MAX_BAUD,["kontak ACIK :",CR,LF]
                        FlgKntkGitA = BIR
                        TxMesajType =  BIR ' Gönderme Modu Düşük Paket
                        Sender      =  UC  ' Gönderici Kontak
                        For addr= 0  TO 89
			                Read addr,Deger
			            Next addr
                        GoSub GpPakHaz
				        GoSub GpMsgTX
                     EndIF
                  EndIF
                  IF FlgKontak = BIR Then              ' Kontak Kapatıldı Bilgisi
                     IF FlgKntkGitK = SIF Then
                        SerOut2 PIO_TXD,MAX_BAUD,["kontak KAPALI :",CR,LF]
                        FlgKntkGitK = BIR
                        For addr= 0  TO 89
			                Read addr,Deger
			            Next addr
                        GoSub GpPakHaz
				        GoSub GpMsgTX
                     EndIF
                  EndIF
                  'IF FlgKontak = SIF Then
                  '   IF FlgKntkGit = SIF Then
                  '      FlgKntkGit = BIR
                  '      TxMesajType =  BIR ' Gönderme Modu Düşük Paket
                  '      Sender      =  UC  ' Gönderici Kontak
                  '      For addr= 0  TO 89
			      '          Read addr,Deger
			      '          RegGeneral[addr]=Deger
			      '      Next addr
                  '      GoSub GpPakHaz
				  '      GoSub GpMsgTX
                  '   EndIF
                  'EndIF
GoTo KontakKontOK
'****************              GPRS TAKIP DURUMU            ********************
'******************************************************************** 07.01.2007
GpTakipDur  :   wr=RR
			    GoSub WRkntKontrol
                IF kntTakip = SIF Then      ' Takip Kontrolü Yapılmayacaksa
                   GoTo GpTakipDurOK
                EndIF
                   GoTo GpTakipDurOK
                EndIF
                   GoTo GpTakipDurOK
                EndIF
                Read 109,FlgGpTakip       ' Takip Varmı Yokmu
                Read 107,addr             ' Takip Süresi Ne Olacak
                IF FlgGpTakip = BIR Then
                    ' Main Loop Süresi Yaklaşık 5 Saniye  Değerler Yaklaşık
		            IF addr=SIF Then TmpGpWait = 1     ' 4  Saniyede 1    *4 = 5
				    IF addr=BIR Then TmpGpWait = 3     ' 10 Saniyede 2    *4 = 10
				    IF addr=IKI Then TmpGpWait = 4     ' 15 Saniyede 3    *4 = 15
				    IF addr=UC  Then TmpGpWait = 6     ' 20 Saniyede 4    *4 = 20
				    IF addr=DOT Then TmpGpWait = 8     ' 30 Saniyede 6    *4 = 30
				    IF addr=BES Then TmpGpWait = 11    ' 40 Saniyede 8    *4 = 40
				    IF addr=ALT Then TmpGpWait = 13    ' 50 Saniyede 9    *4 = 50
				    IF addr=YED Then TmpGpWait = 16    ' 1  Dakikada 10   *4 = 1
				    IF addr=SEK Then TmpGpWait = 33    ' 2  Dakikada 20   *4 = 2
				    IF addr=DOK Then TmpGpWait = 76    ' 5  Dakikada 50   *4 = 5
				    IF addr=AA  Then TmpGpWait = 180   ' 10 Dakikada 100  *4 = 10
				    IF addr=BB  Then TmpGpWait = 250   ' 15 Dakikada 150  *4 = 15
				    IF addr=CC  Then TmpGpWait = 340   ' 20 Dakikada 300  *4 = 20
				    IF addr=DD  Then TmpGpWait = 480   ' 30 Dakikada 450  *4 = 30
				    IF addr=EE  Then TmpGpWait = 700   ' 45 Dakikada 450  *4 = 45
				    IF addr=FF  Then TmpGpWait = 780   ' 50 Dakikada 450  *4 = 50
				    IF addr=GG  Then TmpGpWait = 930   ' 1  Saatte   600  *4 = 1
				    IF addr=HH  Then TmpGpWait = 2790  ' 3  Saatte   1800 *4 = 3
				    IF addr=JJ  Then TmpGpWait = 4650  ' 5  Saatte   2400 *4 = 5
	                GpTaWait = TmpGpWait
	                   'Read 93,addr
	                   'IF addr=BIR Then GpTaWait = 930     ' 1  Saat    *4 = 10
				       'IF addr=IKI Then GpTaWait = 4650    ' 5  Saat    *4 = 15
				       'IF addr=UC  Then GpTaWait = 11160   ' 12 Saat    *4 = 20
				       ' Kontak Kapalıysa 1 Saatte Bir Gönder
	                'Else
	                '    GpTaWait = TmpGpWait  ' Kontak Açıksa Normal Peryodunda  Gönder
	                GoTo GpTakipDurOK   ' 03.11.2007 tarihinde eklendi kontak bilgisini tamamen off etmek için
	                EndIF
                    IF (SayGpTakip = GpTaWait ) OR (SayGpTakip > GpTaWait ) Then
                        SayGpTakip = 0
                        Sender      =  BIR ' Gönderici Takip
                        For addr= 0  TO 89
			                Read addr,Deger
			            Next addr
                        GoSub GpPakHaz
				        GoSub GpMsgTX
                     EndIF
                     SayGpTakip  = SayGpTakip + 1
                 EndIF
SerOut2 PIO_TXD,MAX_BAUD,["GP TAKIP:",DEC2 FlgCalType,":",FlgBaglanti,CR,LF]
GoTo GpTakipDurOK
'*****************************************************************************OK
'****************          GPRS YER SORMA DURUMU            ********************
GpYerSor     :  wr=RR
			    GoSub WRkntKontrol
                IF kntYer = SIF Then      ' Yer Kontrolü Yapılmayacaksa
                   FlgGpYer = SIF     ' Tekrarı Önlemek İçin
                   GoTo GpYerSOK
                EndIF
                   GoTo GpYerSOK
                EndIF
                   GoTo GpYerSOK
                EndIF
                IF FlgGpYer = BIR  Then
                   Sender      =  IKI ' Gönderici Yer Sorma
                   For addr= 0  TO 89
			           Read addr,Deger
			       Next addr
                   GoSub GpPakHaz
				   GoSub GpMsgTX
				EndIF
GoTo GpYerSOK
'****************          GPRS GEÇMİŞ VERİ SORMA           ********************
'******************************************************************** 03.05.2007
'GpGecVeri     :  IF FlgCalType < 98 Then ' Çalışma Şekli  SMS se Çık
'                   GoTo GpGecVeriOK
'                EndIF
'                IF FlgBaglanti = SIF Then ' GPRS  Yoksa Çık
'                   GoTo GpGecVeriOK
'                EndIF
'                IF FlgGecVeri = BIR  Then
'                   FlgGecVeri = SIF     ' Tekrarı Önlemek İçin
'                   For FindAddrH = 0 TO 65520 STEP 52
'						I2CRead M1_SDA,M1_SCL,$A0,FindAddrH,[STR FindTime\11]
'						Pause 10
'						IF FindTime[1]  = sorYilB[0]    Then
'						IF FindTime[2]  = sorYilB[1]    Then
'						IF FindTime[3]  = sorAyB[0]     Then
'						IF FindTime[4]  = sorAyB[1]     Then
'						IF FindTime[5]  = sorGunB[0]    Then
'						IF FindTime[6]  = sorGunB[1]    Then
'						IF FindTime[7]  = sorSaatB[0]   Then
'						IF FindTime[8]  = sorSaatB[1]   Then
'						IF FindTime[9]  = sorDakikaB[0] Then
'						IF FindTime[10] = sorDakikaB[1] Then
'						   FindAddrL = FindAddrH + 1
'						   For addr=0 TO  51
'						       I2CRead M1_SDA,M1_SCL,$A0,FindAddrL,[MemData]
'							   Pause 10
'							   RegGeneral[addr] = MemData
'						   Next addr
'                           Sender      =  DOT ' Gönderici Yer Sorma
'                           GoSub GpPakHaz     '
'				           GoSub GpMsgTX
'				        EndIF
'				        EndIF
'				        EndIF
'				        EndIF
'				        EndIF
'				        EndIF
'				        EndIF
'				        EndIF
'				        EndIF
'				        EndIF
'				   Next FindAddrH
'				EndIF
'GoTo GpGecVeriOK
'****************************************************************************OK
'****************             MODEM RESET RUTİNİ            *******************
'******************************************************************* 06.10.2007
G24Rst :     SerOut2 PIO_TXD,MAX_BAUD,["G24 RESET SAY: ",DEC5 SayModemRst,CR,LF]
             KnslRstDeg = 4500						' Eğer Hafızadan Düzgün Okunmassa Sabit 5 Saat
             Read 100,addr
             IF addr = SIF Then						' Reset Yap
                addr = UC							' Reset Tekrar 5 Saate Ayarlandı
                Write 100,addr						' Reset ten Sonra Tekrar Reset Bilgisini Kaydet
                GoTo SystemReset
             EndIF
             IF addr = BIR Then						' Reset Kontrolünü Yapma
                SayModemRst = 0
	            GoTo G24RstOk
             EndIF
             IF addr = IKI Then KnslRstDeg = 900    ' 1  Saatte Bir RESET
             IF addr = UC  Then KnslRstDeg = 4500   ' 5  Saatte Bir RESET
             IF addr = DOT Then KnslRstDeg = 10800  ' 12 Saatte Bir RESET
             SerOut2 PIO_TXD,MAX_BAUD,["RST: ",DEC3 addr,":",DEC5 KnslRstDeg,CR,LF]
             IF SayModemRst > KnslRstDeg Then
                GoTo SystemReset
             Else
                SayModemRst = SayModemRst + 1
             EndIF
             GoTo G24RstOk
'****************             SYSTEM  RESET  RUTİNİ         ********************
SystemReset    :   SayModemRst = 0
                   Sender      =  DOK ' Gönderici Yer Sorma
                   For addr= 0  TO 89
			           Read addr,Deger
			       Next addr
                   GoSub GpPakHaz
				   GoSub GpMsgTX
                EndIF
                SerOut2 PIO_TXD,MAX_BAUD,["RESET TIME : ",STR sysSaat\2,":",_
                        STR sysDakika\2,":",STR sysSaniye\2,"  ", STR sysGun\2 ,_
                        ".",STR sysAy\2,".","20",STR sysYil\2,13,10]
                GoSub G24KapaSoft
                GoTo SysInit
'****************        GPRS MESAJ GÖNDERME RUTİNİ         ********************
GpMsgTX :      wr =RR
               GoSub WRKonsolID
		       GoSub BuffDel
		       SerOut2 G24_TXD,G24_BAUD,["at+mipsend=1",VI,34,HEX2 STX,HEX2 KonsolID(0),_
		       HEX2 KonsolID(1),HEX2 KonsolID(2),HEX2 KonsolID(3),HEX2 KonsolID(4),HEX2 GprsPacType]
			   IF TxMesajType =  BIR Then     ' GPRS TAKIP Merkeze  Gidecek Şekil
                  For addr = 0  TO 50
			          SerOut2 G24_TXD,G24_BAUD,[HEX2 GprsMesaj(addr)]
			          Pause Bek10
			      Next addr
			      SerOut2 G24_TXD,G24_BAUD,[HEX2 ETX,34,CR,LF]
			   EndIF
			   IF TxMesajType =  IKI Then     ' GPRS SOS Durumları Merkeze  Gidecek Şekil
			      For addr = 0  TO 63
			      Next addr
			   EndIF
			   GoSub BuffDel
		       GoSub MeReady
			   Pause Bek100
			   SerOut2 PIO_TXD,MAX_BAUD,["GPRS SENDED",13,10]
		       TxMesajType =  SIF
		       GoSub BuffDel
		       GoSub MeReady
Return
'*******************         SMS MESAJ GÖNDERME       **************************
'******************************************************************** 26.10.2005
SmMsgTx:      GoSub BuffDel
              SerOut2 G24_TXD,G24_BAUD,["AT+CMGF=1",CR,LF]
              Pause Bek100
              GoSub MeReady
              GoSub BuffDel
              SerOut2 G24_TXD,G24_BAUD,["AT+CMGS=",34]
              Pause Bek100
              For addr = 0 TO 14
                  IF telEtkin[addr] = $FF Then
                     GoTo DonguCik
                  Else
                     SerOut2 G24_TXD,G24_BAUD,[telEtkin(addr)]
                  EndIF
              Next addr
DonguCik  :
             SerOut2 G24_TXD,G24_BAUD,[34,",145",CR]
             WhoIs = DOK
             addr = 0
SmMsgLp1  :  GoSub MeReady
             For G24ADDR = 0 TO 349
				 IF G24VERI[G24ADDR] = ">"  Then
				    SerOut2 PIO_TXD,MAX_BAUD,["> OK",13,10]
				    GoTo MsgTxRdy
				 EndIF
		  	 Next G24ADDR
             Pause Bek200
             IF addr > 6 Then
                SerOut2 PIO_TXD,MAX_BAUD,["> ER",13,10]
                GoTo MsgTxErr
             Else
                addr = addr + 1
                GoSub BuffDel
                GoTo SmMsgLp1
             EndIF
MsgTxRdy:   GoSub BuffDel
            Pause Bek200
	        SerOut2 G24_TXD,G24_BAUD,[STR SmsMesaj\160]
            Pause Bek100
            SerOut2 G24_TXD,G24_BAUD,[26]
            addr = 0
            TxMesajType =  SIF
MsgTxDon:   GoSub MeReady
				 IF G24VERI[G24ADDR]       = "+"  Then
				 IF G24VERI[(G24ADDR + 1)] = "C"  Then
				 IF G24VERI[(G24ADDR + 3)] = "G"  Then
				 IF G24VERI[(G24ADDR + 4)] = "S"  Then
				     SerOut2 PIO_TXD,MAX_BAUD,["+CMGS OK",13,10]
				     GoTo MsgSendOk
			   	 EndIF
				 EndIF
				 EndIF
				 EndIF
				 EndIF
			 Next G24ADDR
             Pause bek500
             IF addr > 49 Then
                SerOut2 PIO_TXD,MAX_BAUD,["+CMGS ER",DEC3 G24SAYAC,13,10]
                GoTo MsgTxErr
             Else
                addr = addr + 1
                GoSub BuffDel
                GoTo  MsgTxDon
             EndIF
MsgSendOk : GoSub BuffDel
            SerOut2 G24_TXD,G24_BAUD,[ESC]
            GoSub MeReady
            Return
MsgTxErr  : GoSub BuffDel
            GoSub MeReady
             Return
'*********************               DIAL UP             ***********************
DialUp       :  GoSub BuffDel
			    GoSub MdmEkrON
			    GoSub MeReady
	            GoSub BuffDel
	            SerOut2 G24_TXD, G24_BAUD,[AA,TT,DD]
	            For addr = 0 TO 14
	                IF telEtkin[(addr+1)] = $FF Then
				       GoTo DialLoop1
				    Else
				       SerOut2 G24_TXD,G24_BAUD,[telEtkin(addr+1)]
				    EndIF
				Next addr
 DialLoop1   :   SerOut2 G24_TXD, G24_BAUD,[";",CR,LF]
                 addr = 0
 DialLoop2   :    GoSub MeReady
				   	    IF G24VERI[(G24ADDR + 2)] = "I"  Then
				   	    IF G24VERI[(G24ADDR + 3)] = "E"  Then
				   	    IF G24VERI[(G24ADDR + 4)] = "V"  Then
				   	    IF G24VERI[(G24ADDR + 7)] = "4"  Then
				   	    IF G24VERI[(G24ADDR + 8)] = ","  Then
				   	    IF G24VERI[(G24ADDR + 9)] = "1"  Then
				   	       Sound G24_AUIN,[115,10,110,10,115,10,110,10]
				   	       GoTo DialUpSon
				   	    EndIF
				   	    EndIF
				   	    EndIF
				   	    EndIF
				   	    EndIF
				   	    EndIF
				   	    EndIF
				   	    EndIF
				   	    EndIF
				   	    EndIF
				   Next G24ADDR
                   Pause bek1000
                   GoSub BuffDel
                   IF  addr > 10 Then   ' Dial Up Cevap Verme Süresi Yaklaşık 2 Çaldırma
                       GoTo DialUpSon
                   Else
                       addr = addr + 1
                       GoTo DialLoop2
                   EndIF
   DialUpSon :     GoSub BuffDel
                   GoSub MdmEkrOF
                   Pause Bek100
                   GoSub CagriKapa
                   GoSub MeReady
Return
'****************         GPRS PAKET HAZIRLA DURUMU         ********************
GpPakHaz :
               IF TxMesajType =  BIR  Then  ' TAKİP YER KONTAK RESET PAKET TİPİ
	              IF Sender = BIR Then
	                 GprsPacType = TT   ' TAKİP
	              EndIF
	           	  IF Sender = IKI Then
	                 GprsPacType = YY   ' YER
	              EndIF
	           	  IF Sender = UC Then
        	         GprsPacType = KK   ' KONTAK
               	  EndIF
	           	  IF Sender = DOT Then
        	         GprsPacType = KK   ' GEÇMİŞ VERİ
               	  EndIF
	           	  IF Sender = DOK Then
	                 GprsPacType = RR   ' RESET
	              EndIF
		          Sender = SIF
		          'System Zaman
	              GprsMesaj[0]   =  RegGeneral[10] ' sysYıl[0]
		          GprsMesaj[1]   =  RegGeneral[11] ' sysYıl[1]
		          GprsMesaj[2]   =  RegGeneral[8]  ' sysAy[0]
		          GprsMesaj[3]   =  RegGeneral[9]  ' sysAy[1]
		          GprsMesaj[4]   =  RegGeneral[6]  ' sysGun[0]
		          GprsMesaj[5]   =  RegGeneral[7]  ' sysGun[1]
		          GprsMesaj[6]   =  RegGeneral[0]  ' sysSaat[0]
		          GprsMesaj[7]   =  RegGeneral[1]  ' sysSaat[1]
		          GprsMesaj[8]   =  RegGeneral[2]  ' sysDakika[0]
		          GprsMesaj[9]   =  RegGeneral[3]  ' sysDakika[1]
		          GprsMesaj[10]  =  RegGeneral[4]  ' sysSaniye[0]
		          GprsMesaj[11]  =  RegGeneral[5]  ' sysSaniye[1]
	              'Kuzey
		          GprsMesaj[12]  =  RegGeneral[43]
		          GprsMesaj[13]  =  RegGeneral[44]
		          GprsMesaj[14]  =  RegGeneral[45]
		          GprsMesaj[15]  =  RegGeneral[46]
		          GprsMesaj[16]  =  RegGeneral[47]
		          GprsMesaj[17]  =  RegGeneral[48]
		          GprsMesaj[18]  =  RegGeneral[49]
		          GprsMesaj[19]  =  RegGeneral[50]
		          GprsMesaj[20]  =  RegGeneral[51]
		          GprsMesaj[21]  =  RegGeneral[52]
		          'Dogu
		          GprsMesaj[22]  =  RegGeneral[53]
		          GprsMesaj[23]  =  RegGeneral[54]
		          GprsMesaj[24]  =  RegGeneral[55]
		          GprsMesaj[25]  =  RegGeneral[56]
		          GprsMesaj[26]  =  RegGeneral[57]
		          GprsMesaj[27]  =  RegGeneral[58]
		          GprsMesaj[28]  =  RegGeneral[59]
		          GprsMesaj[29]  =  RegGeneral[60]
		          GprsMesaj[30]  =  RegGeneral[61]
		          GprsMesaj[31]  =  RegGeneral[62]
		          GprsMesaj[32]  =  RegGeneral[63]
		          'Hiz
		          GprsMesaj[33]  =  RegGeneral[64]
		          GprsMesaj[34]  =  RegGeneral[65]
		          GprsMesaj[35]  =  RegGeneral[66]
		          GprsMesaj[36]  =  RegGeneral[67]
		          GprsMesaj[37]  =  RegGeneral[68]
		          GprsMesaj[38]  =  RegGeneral[69]
		          GprsMesaj[39]  =  RegGeneral[70]
		          'Sapma
		          GprsMesaj[40]  =  RegGeneral[71]
		          GprsMesaj[41]  =  RegGeneral[72]
		          GprsMesaj[42]  =  RegGeneral[73]
		          GprsMesaj[43]  =  RegGeneral[74]
		          GprsMesaj[44]  =  RegGeneral[75]
		          GprsMesaj[45]  =  RegGeneral[76]
		          GprsMesaj[46]  =  RegGeneral[30]  ' GPS STATU
		          GprsMesaj[47]  =  RegGeneral[17]  ' ROLE
		          GprsMesaj[48]  =  RegGeneral[15]  ' KONTAK
		          GprsMesaj[49]  =  RegGeneral[25]  ' G24 ROM
                  GprsMesaj[50]  =  RegGeneral[22]  ' G24 SIN
               EndIF
               IF TxMesajType =  IKI  Then  ' ACİL VE ALARM DURUMUNDAKİ PAKET TİPİ
                     GprsPacType = AA  ' ACIL
                  EndIF
                     GprsPacType = LL   ' ALARM
                  EndIF
                     GprsPacType = HH   ' ŞÜPHE
                  EndIF
                  'System Zaman
	              GprsMesaj[0]   =  RegGeneral[11] ' sysYıl[0]
		          GprsMesaj[1]   =  RegGeneral[10] ' sysYıl[1]
		          GprsMesaj[2]   =  RegGeneral[9]  ' sysAy[0]
		          GprsMesaj[3]   =  RegGeneral[8]  ' sysAy[1]
		          GprsMesaj[4]   =  RegGeneral[7]  ' sysGun[0]
		          GprsMesaj[5]   =  RegGeneral[6]  ' sysGun[1]
		          'Gps Statü
		          GprsMesaj[12]   =  RegGeneral[30]
		          'Kuzey ,Dogu,Hiz,Sapma
		          GprsMesaj[13]  =  RegGeneral[43]
		          GprsMesaj[14]  =  RegGeneral[44]
		          GprsMesaj[15]  =  RegGeneral[45]
		          GprsMesaj[16]  =  RegGeneral[46]
		          GprsMesaj[17]  =  RegGeneral[47]
		          GprsMesaj[18]  =  RegGeneral[48]
		          GprsMesaj[19]  =  RegGeneral[49]
		          GprsMesaj[20]  =  RegGeneral[50]
		          GprsMesaj[21]  =  RegGeneral[51]
		          GprsMesaj[22]  =  RegGeneral[52]
		          GprsMesaj[23]  =  RegGeneral[53]
		          GprsMesaj[24]  =  RegGeneral[54]
		          GprsMesaj[25]  =  RegGeneral[55]
		          GprsMesaj[26]  =  RegGeneral[56]
		          GprsMesaj[27]  =  RegGeneral[57]
		          GprsMesaj[28]  =  RegGeneral[58]
		          GprsMesaj[29]  =  RegGeneral[59]
		          GprsMesaj[30]  =  RegGeneral[60]
		          GprsMesaj[31]  =  RegGeneral[61]
		          GprsMesaj[32]  =  RegGeneral[62]
		          GprsMesaj[33]  =  RegGeneral[63]
		          GprsMesaj[34]  =  RegGeneral[64]
		          GprsMesaj[35]  =  RegGeneral[65]
		          GprsMesaj[36]  =  RegGeneral[66]
		          GprsMesaj[37]  =  RegGeneral[67]
		          GprsMesaj[38]  =  RegGeneral[68]
		          GprsMesaj[39]  =  RegGeneral[69]
		          GprsMesaj[40]  =  RegGeneral[70]
		          GprsMesaj[41]  =  RegGeneral[71]
		          GprsMesaj[42]  =  RegGeneral[72]
		          GprsMesaj[43]  =  RegGeneral[73]
		          GprsMesaj[44]  =  RegGeneral[74]
		          GprsMesaj[45]  =  RegGeneral[75]
		          GprsMesaj[46]  =  RegGeneral[76]
		          'Modem Ekran Bilgisi
		          GprsMesaj[47]  =  RegGeneral[21]
		          GprsMesaj[48]  =  RegGeneral[22]
		          GprsMesaj[49]  =  RegGeneral[23]
		          GprsMesaj[50]  =  RegGeneral[24]
		          GprsMesaj[51]  =  RegGeneral[25]
		          GprsMesaj[52]  =  RegGeneral[26]
		          GprsMesaj[53]  =  RegGeneral[27]
		          GprsMesaj[54]  =  RegGeneral[28]
		          'PIO Bilgisi
		          GprsMesaj[55]  =  RegGeneral[12]
		          GprsMesaj[56]  =  RegGeneral[13]
		          GprsMesaj[57]  =  RegGeneral[14]
		          GprsMesaj[58]  =  RegGeneral[15]
		          GprsMesaj[59]  =  RegGeneral[16]
		          GprsMesaj[60]  =  RegGeneral[17]
		          GprsMesaj[61]  =  RegGeneral[18]
		          GprsMesaj[62]  =  RegGeneral[19]
               EndIF
Return
armys2000
'****************          SMS ALARM PAKETİ HAZIRLA         ********************
SmAlarmPakHaz  :   SmsMesaj[0] = KonsolID[0]
				   SmsMesaj[5] = BOSLUK
				   SmsMesaj[6] = BOSLUK
				   SmsMesaj[7] = BOSLUK
				   SmsMesaj[8] = BOSLUK
		              SmsMesaj[9]  = "A"
			          SmsMesaj[10] = "C"
			          SmsMesaj[11] = "I"
			          SmsMesaj[12] = "L"
			          SmsMesaj[13] = BOSLUK
		              SmsMesaj[14] = BOSLUK
		           EndIF
		              SmsMesaj[9]  = "A"
			          SmsMesaj[10] = "L"
			          SmsMesaj[11] = "A"
			          SmsMesaj[12] = "R"
			          SmsMesaj[13] = "M"
		           EndIF
		              SmsMesaj[9]  = "S"
			          SmsMesaj[10] = "U"
			          SmsMesaj[11] = "P"
			          SmsMesaj[12] = "H"
			          SmsMesaj[13] = "E"
		           EndIF
		           Deger = 48
                   Read 0,Deger
		           SmsMesaj[15]=Deger
                   Read 1,Deger
		           SmsMesaj[16]=Deger
                   SmsMesaj[17]=":"
                   Read 2,Deger
		           SmsMesaj[18]=Deger
                   Read 3,Deger
		           SmsMesaj[19]=Deger
                   SmsMesaj[20]=":"
                   Read 4,Deger
		           SmsMesaj[21]=Deger
                   Read 5,Deger
		           SmsMesaj[22]=Deger
                   SmsMesaj[23]=" "
                   Read 6,Deger
		           SmsMesaj[24]=Deger
                   Read 7,Deger
		           SmsMesaj[25]=Deger
                   SmsMesaj[26]="."
                   Read 8,Deger
		           SmsMesaj[27]=Deger
                   Read 9,Deger
		           SmsMesaj[28]=Deger
                   SmsMesaj[29]="."
                   Read 10,Deger
		           SmsMesaj[30]=Deger
                   Read 11,Deger
		           SmsMesaj[31]=Deger
                   SmsMesaj[32]=" "
		           For addr= 0  TO 24
		               SmsMesaj[(addr+33)] = msgAlarm[addr]
		           Next addr
		           For addr= 58  TO 159
		           Next addr
Return
'****************           MEMORY VERİ YAZ  		        ********************
NormlVeriYaz :   Read 105,MemAddrH
                 Read 106,MemAddrL
                 MemAddr.byte1 = MemAddrH
                 MemAddr.byte0 = MemAddrL
                    IF FlgTakip = BIR Then
                        MemVeri[0]= "*"
                    Else
                        MemVeri[0]= " "
                    EndIF
                 EndIF
                 Read 11,addr                   ' SYS YIL[0]
                 MemVeri[1]= addr
                 Read 10,addr                   ' SYS YIL[1]
                 MemVeri[2]= addr
                 Read 9,addr                    ' SYS AY[0]
                 MemVeri[3]= addr
                 Read 8,addr                    ' SYS AY[1]
                 MemVeri[4]= addr
                 Read 7,addr                    ' SYS GUN[0]
                 MemVeri[5]= addr
                 Read 6,addr                    ' SYS GUN[1]
                 MemVeri[6]= addr
                 Read 0,addr                    ' SYS SAAT[0]
                 MemVeri[7]= addr
                 Read 1,addr                    ' SYS SAAT[1]
                 MemVeri[8]= addr
                 Read 2,addr                    ' SYS DAKİKA[0]
                 MemVeri[9]= addr
                 Read 3,addr                    ' SYS DAKİKA[1]
                 MemVeri[10]= addr
                 Read 4,addr                    ' SYS SANİYE[0]
                 MemVeri[11]= addr
                 Read 5,addr                    ' SYS SANİYE[1]
                 MemVeri[12]= addr
                 For addr = 43 TO 76             ' Kuzey,Dogu,Hız,Sapma
                     Read addr,MemVeri[(addr-30)]
                 Next addr
                 Read 30,addr                    ' GPS Statü
                 MemVeri[47]= addr
                 Read 17,addr                    ' Röle
                 MemVeri[48]= addr
                 Read 14,addr                    ' Kontak
                 MemVeri[49]= addr
                 Read 25,addr                    ' Roaming
                 MemVeri[50]= addr
                 Read 22,addr                    ' Sinyal
                 MemVeri[51]= addr
                 For addr= 0 TO 51
                     MemData = MemVeri[addr]
                     I2CWrite M1_SDA,M1_SCL,$A0,MemAddr,[MemData]
                     Pause Bek10
                     MemAddr = MemAddr + 1
                 Next addr
                 IF MemAddr > 65520 Then
                    MemAddr = 0
                 EndIF
                 MemAddrH = MemAddr.byte1
                 MemAddrL = MemAddr.byte0
                 Write 105,MemAddrH
                 Write 106,MemAddrL
Return
'****************           MEMORY VERİ OKU  		        ********************
NormlVeriOku :
Return
'*****************            USER TYPE SORGULA              *******************
 usrTypeSor   : IF usrKontrol[0] = BIR Then
 				 IF usrKontrol[1] = DOT Then
 				  IF usrKontrol[2] = ALT Then
 				   IF usrKontrol[3] = SEK Then
 				    IF usrKontrol[4] = BIR Then
 				     IF usrKontrol[5] = DOT Then
 				      IF usrKontrol[6] = ALT Then
 				       IF usrKontrol[7] = SEK Then
 					    IF pasKontrol[0] = BIR Then
 				         IF pasKontrol[1] = DOT Then
 				          IF pasKontrol[2] = ALT Then
 				           IF pasKontrol[3] = SEK Then
 				              usrType = 1
 				              GoTo usrTypeOk
 						   EndIF
 						  EndIF
 						 EndIF
 						EndIF
 				       EndIF
 				      EndIF
 				     EndIF
 				    EndIF
 				   EndIF
 				  EndIF
 				 EndIF
 				EndIF
				IF usrKontrol[0]= usrAdmin[0] Then
 				 IF usrKontrol[1]= usrAdmin[1] Then
 				  IF usrKontrol[2]= usrAdmin[2] Then
 				   IF usrKontrol[3]= usrAdmin[3] Then
 				    IF usrKontrol[4]= usrAdmin[4] Then
 					 IF usrKontrol[5]= usrAdmin[5] Then
 					  IF usrKontrol[6]= usrAdmin[6] Then
 					   IF usrKontrol[7]= usrAdmin[7] Then
 					    IF pasKontrol[0]= pasAdmin[0] Then
 						 IF pasKontrol[1]= pasAdmin[1] Then
 						  IF pasKontrol[2]= pasAdmin[2] Then
 						   IF pasKontrol[3]= pasAdmin[3] Then
 						      usrType = 2
 							  GoTo usrTypeOk
 						   EndIF
 						  EndIF
 						 EndIF
 						EndIF
 					   EndIF
 					  EndIF
 					 EndIF
 					EndIF
 				   EndIF
 				  EndIF
 			     EndIF
 			    EndIF
 usrTypeErr : usrType = 9
 			  Return
 usrTypeOk  :
 Return
'*************************          SOS OKU            *************************
SosOku    :    wr=RR
			   GoSub WRkntKontrol
               IF kntAcil = BIR Then
                  IF ACIL = 0 Then
				     FlgAcil = BIR
				     FlgSosDurum =BIR
				     SosType = BIR
				  Else
				     FlgAcil = SIF
				  EndIF
		       EndIF
		       IF kntSuphe = BIR Then
                  IF SUPHE = 0 Then
				     FlgSuphe = BIR
				     FlgSosDurum =BIR
				     SosType = UC
				  Else
				     FlgAcil = SIF
				  EndIF
		       EndIF
               IF kntAlarm = BIR Then
	              IF ALARM = 0 Then
			        Pause Bek3000
			        IF ALARM = 0 Then
			            FlgAlarm=BIR
			            FlgSosDurum =BIR
			            SosType = IKI
			        Else
			            FlgAlarm=SIF
			        EndIF
			     EndIF
			   EndIF
Return
'****************        GSM  REGISTER KONTROL RUTİNİ       ********************
GsRgKnt  :   IF mdmReg = BIR Then
                FlgGsmReg = SIF
                SayGsmReg = SayGsmReg + 1
                SayModemRst = SayModemRst + 20
             EndIF
             IF mdmReg = SIF Then
                SayGsmReg = 0
                FlgGsmReg = BIR
             EndIF
Return
'****************       GPRS  REGISTER KONTROL RUTİNİ       ********************
GpRgKnt  :  IF mdmGprs = SIF Then
               FlgGprsReg = SIF    ' GPRS YOK
               FlgPingRec = SIF
               SayGprsReg = SayGprsReg + 1
            EndIF
            IF mdmGprs = BIR Then
               SayGprsReg = 0
               FlgGprsReg = BIR
            EndIF
Return
'***********            Modemin Software  olarak Açılması           ************
G24AcSoft  : Low G24_SPWR
			 Pause Bek1500
			 High G24_SPWR
			 Pause Bek5000
             Pause Bek5000
Return
'***********            Modemin Software olarak Kapatılması          ***********
G24KapaSoft: Low G24_SPWR
             Pause Bek3000
             High G24_SPWR
             Pause Bek5000
             Pause Bek5000
Return
'***********              MODEM EKRAN BİLGİ İSTEĞİ AÇ               ************
MdmEkrON : 'SerOut2 G24_TXD,G24_BAUD,["AT+CMER=0,0,0,1,0",CR,LF]
           SerOut2 G24_TXD,G24_BAUD,[AA,TT,ART,CC,MM,EE,RR,ESTR,SIF,VI,SIF,_
           VI,SIF,VI,BIR,VI,SIF,CR,LF]
Return
'***********            MODEM EKRAN BİLGİ İSTEĞİ KAPA               ************
MdmEkrOF : 'SerOut2 G24_TXD,G24_BAUD,["AT+CMER=0,0,0,0,0",CR,LF]
           VI,SIF,VI,SIF,VI,SIF,CR,LF]
Return
'********************       OKUNAN MESAJIN SİLİNMESİ       *********************
MesajSil : 'SerOut2 G24_TXD,G24_BAUD,["AT+CMGD=",#MsgIndex,CR,LF]
           SerOut2 G24_TXD,G24_BAUD,[AA,TT,ART,CC,MM,GG,DD,ESTR,#MsgIndex,CR,LF]
           Pause Bek100
Return
'****************             ÇAĞRI SONLANDIRMA             ********************
CagriKapa	: FlgRING = SIF
              SerOut2 G24_TXD,G24_BAUD,[AA,TT,HH,CR,LF]
Return
'****************                MODEM ME BUSY              ********************
MeBusy	:  High G24_RTS
           'SerOut2 G24_TXD,G24_BAUD,[XOFF,13,10]
Return
'****************            G24 BUFFER DELETE              ********************
BuffDel	:  For G24ADDR = 0 TO 349
               G24VERI(G24ADDR)=$FF
           Next G24ADDR
Return
'*******************       APN NAME/USER/PASS KAYIT       **********************
WRApnKayit    : IF wr = WW Then
					For addr=110 TO 119
				    	Write addr,ApnName[(addr-110)]
					Next addr
					For addr=120 TO 127
				    	Write addr,ApnUser[(addr-120)]
					Next addr
					For addr=130 TO 137
				    	Write addr,ApnPass[(addr-130)]
					Next addr
				EndIF
				IF wr = RR Then
					For addr=110 TO 119
				    	Read addr,ApnName[(addr-110)]
					Next addr
					For addr=120 TO 127
				    	Read addr,ApnUser[(addr-120)]
					Next addr
					For addr=130 TO 137
				    	Read addr,ApnPass[(addr-130)]
					Next addr
				EndIF
Return
'**********************         ADMIN USERNAME          ************************
WRusrAdmin    : IF wr = WW Then
					For addr=142 TO 149
				    	Write addr,usrAdmin[(addr-142)]
					Next addr
				EndIF
				IF wr = RR Then
					For addr=142 TO 149
				 		Read addr,usrAdmin[(addr-142)]
					Next addr
				EndIF
Return
'**********************          ADMIN PASSWORD         ************************
WRpasAdmin    : IF wr = WW Then
				   For addr=150 TO 153
				       Write addr,pasAdmin[(addr-150)]
				   Next addr
				EndIF
				IF wr = RR Then
				   For addr=150 TO 153
				       Read addr,pasAdmin[(addr-150)]
				   Next addr
				EndIF
Return
'**********************         KONSOL ID KAYDI         ************************
WRKonsolID    :	IF wr = WW Then
				   For addr = 154 TO 158
				       Write addr,KonsolID(addr-154)
				   Next addr
				EndIF
				IF wr = RR Then
				       Read addr,KonsolID(addr-154)
				   Next addr
				EndIF
Return
'**********************      MERKEZ TELEFON NUMARASI    ************************
WRtelMerkez   :	IF wr = WW Then
				   For addr = 159 TO 173
				       Write addr,telMerkez(addr-159)
				   Next addr
				EndIF
				IF wr = RR Then
				       Read addr,telMerkez(addr-159)
				   Next addr
				EndIF
Return
'************      ACİL ÇAĞRI TELEFONU 1 VE ÇAĞRI TİPİ     *********************
WRtelAcil1    :	IF wr = WW Then
				   For addr = 174 TO 188
				       Write addr,telAcil1(addr-174)
				   Next addr
				   addr = 189
				   Write addr,cagAcil1
				EndIF
				IF wr = RR Then
				       Read addr,telAcil1(addr-174)
				   Next addr
				   addr = 189
				   Read addr,cagAcil1
				EndIF
Return
'************      ACİL ÇAĞRI TELEFONU 2 VE ÇAĞRI TİPİ     *********************
WRtelAcil2    :	IF wr = WW Then
				   For addr = 190 TO 204
				       Write addr,telAcil2(addr-190)
				   Next addr
				   addr = 205
				   Write addr,cagAcil2
				EndIF
				IF wr = RR Then
				       Read addr,telAcil2(addr-190)
				   Next addr
				   addr = 205
				   Read addr,cagAcil2
				EndIF
Return
'**********************            ALARM MESAJI         ************************
WRmsgAlarm    :	IF wr = WW Then
	   			   For addr = 206 TO 230
				       Write addr,msgAlarm(addr-206)
				   Next addr
				EndIF
				IF wr = RR Then
				       Read addr,msgAlarm(addr-206)
				   Next addr
				EndIF
Return
'**********************         SERVER   IP KAYDI       ************************
WRipServer   :	IF wr = WW Then
				   For addr = 231 TO 242
				       Write addr,ipServer(addr-231)
				   Next addr
				EndIF
				IF wr = RR Then
				       Read addr,ipServer(addr-231)
				   Next addr
				EndIF
Return
'**********************         SERVER   PORT KAYDI     ************************
WRprtServer  :	IF wr = WW Then
				   For addr = 243 TO 247
				       Write addr,prtServer(addr-243)
				   Next addr
			    EndIF
				IF wr = RR Then
				       Read addr,prtServer(addr-243)
				   Next addr
				EndIF
Return
'************  KONTROLÜ YAPILACAKLAR / YAPILMAYACAKLAR      ********************
WRkntKontrol  :	IF wr = WW Then
				   addr = 90
	     		   Write addr,kntAcil
				   addr = 91
	     		   Write addr,kntSuphe
				   addr = 92
	     		   Write addr,kntAlarm
				   'addr = 93
	     		   'Write addr,kntKontak
	     		   addr = 94
	     		   Write addr,kntAku
	     		   addr = 95
	     		   Write addr,kntBloke
	     		   addr = 96
	     		   Write addr,kntKamera
	     		   addr = 97
	     		   Write addr,kntTakip
				   addr = 98
	     		   Write addr,kntYer
	     		   addr = 99
				   Write addr,kntMrkzBilgi
                EndIF
				IF wr = RR Then
				   addr = 90
	     		   Read addr,kntAcil
				   addr = 91
	     		   Read addr,kntSuphe
				   addr = 92
	     		   Read addr,kntAlarm
				   'addr = 93
	     		   'Read addr,kntKontak
	     		   addr = 94
	     		   Read addr,kntAku
	     		   addr = 95
	     		   Read addr,kntBloke
	     		   addr = 96
	     		   Read addr,kntKamera
	     		   addr = 97
	     		   Read addr,kntTakip
				   addr = 98
	     		   Read addr,kntYer
	     		   addr = 99
	     		   Read addr,kntMrkzBilgi
				EndIF
Return
'**********************           RESET  BİLGİ          ************************
WRSysReset   :  IF wr = WW Then
                    addr = 100
				    Write addr,kntSysReset
                 EndIF
                 IF wr = RR Then
                   addr = 100
	     		   Read addr,kntSysReset
	     	     EndIF
Return
'**********************         KONTAK   BİLGİ          ************************
WRSysKontak   :  IF wr = WW Then
                    addr = 93
                 EndIF
                 IF wr = RR Then
                   addr = 93
	     		   Read addr,kntKontak
	     	     EndIF
Return
'**********************         SMS GPRS SEÇİM          ************************
WRCalType  :	IF wr = WW Then
				   addr = 255
				   Write addr,SysCalType
				EndIF
				IF wr = RR Then
		           addr = 255
	     		   Read addr,SysCalType
	     		   'FlgCalType = SysCalType + EtkenCalType
				EndIF
Return
'**********************            END OF CODE          ************************
'***************************************************************** JUST BUILDING
End
armys2000
kamera modülü ve ısı modülü aktif değildir dikkate almayın yapmak isteyen arkadaşlar uğraşabilir.
atioky_216
gps modulu kullandıgın yazıyordu yanlıs anlamadı isem  verdiğin adresteki sitede.modul ne sekillerdeki AGS5V1 yazan parcamı?
Bir de PBC sini sen yaptıysan bana cok profesyonelce geldi gerci hiç kendi yapmıslıgım yok ta..
çok teşekkür ederim armys200 kardesim.Her ne kadar daha elektronik talebesi oldugumuzdan daha bişey bilemesemde hep bu proje nin hayalini kuruyordum...
Andromeda
paylaşım için sağol.
aslında programı sayfaya eklemesende olur.
zaten web sayfanı vermişsin.
Alıntı yapılan: "armys2000"Arkadaşlar şema ve pcb demo programı vs dokümanı www.endofcode.com sitesinde bulabilirsiniz. son hali bu. Hatalar vs varsa arkadaşlar düzeltsin.
Dosyaların şifreli ?
armys2000
