Li-ion pil şarj devresi lazım
Başlatan einstain90, 28 Ağustos 2008, 18:56:59
einstain90
Arkadaşlar elime 7.4 volt 1700mah bir Li-ion pil var.Acaba bu pil için elinizde bir devre varmı bu pili nasıl şarj edebilirim.
Her işte her zaman bir aksilik çıkar.Siz yeterki pes etmeyin...
ipek
Macera
"Art without engineering is dreaming; engineering without art is calculating." -- Steven K. Roberts
ISL6291  	   	Li-ion/Li Polymer Linear Battery Charger
  	ISL6292 	  	Li-ion/Li Polymer Battery Charger
  	ISL6292B 	  	Li-ion/Li Polymer Battery Charger
  	ISL6292C 	  	Li-ion/Li Polymer Battery Charger
  	ISL6292D 	  	Li-ion/Li Polymer Battery Charger
  	ISL6293 	  	Li-ion/Li Polymer Battery Charger Accepting Two Power Sources
  	ISL6294 	  	High Input Voltage Charger
  	ISL6297 	  	Li-ion/Li Polymer Battery Charger
  	ISL6298 	  	Li-ion/Li-Polymer Battery Charger
  	ISL6299A 	  	Li-ion/Li-Polymer Battery Charger Accepting Two Power Sources
  	ISL9203 	  	Li-ion/Li Polymer Battery Charger
       ISL9204
MAX1879
MAX1898
LT1571
LTC1731
LTC4054
LTC4056
http://www.discovercircuits.com/B/batt-chrg3.htm
http://www.discovercircuits.com/B/batt-chrg3a.htm
http://www.discovercircuits.com/B/batt-chrg3b.htm
Basit bir devre;
http://homepages.paradise.net.nz/bhabbott/lion.html
stlg
stlg
Birde bunu incelerseniz uygulanabilir nitelikte
[IMG]
