4x18B20 ile sıcaklık ölçün
Başlatan ilker_32, 15 Şubat 2009, 22:50:05
ilker_32
DEFINE LCD_DREG     PORTB
DEFINE LCD_DBIT     4
DEFINE LCD_RSREG    PORTB
DEFINE LCD_RSBIT    0
DEFINE LCD_EREG     PORTB
DEFINE LCD_EBIT     1
DEFINE LCD_BITS     4
DEFINE LCD_LINES    4
TRISB=0
TRISD=%00001111
PORTB=0
PORTD=0
Comm_Pin     VAR Portd.0
Comm_Pin1    VAR Portd.1
Comm_Pin2    VAR Portd.2
Comm_Pin3    VAR Portd.3
Busy         VAR BIT
HAM          VAR WORD
ISI          VAR WORD
ISI1         VAR WORD
ISI2         VAR WORD
ISI3         VAR WORD
SIGN         VAR BYTE
SIGN1        VAR BYTE
SIGN2        VAR BYTE
SIGN3        VAR BYTE
SIGN_BITI   VAR HAM.Bit11
NEGAT_ISI   CON 1
Deg         con 223
TEMP        VAR BYTE
Float       VAR WORD
basla:
gosub sensor
gosub sensor1
gosub sensor2
gosub sensor3
gosub reklam
gosub disp
goto basla
sensor
           OWOUT   Comm_Pin, 1, [$CC, $44]
Bekle:
           OWIN    Comm_Pin, 4, [Busy]
           IF      Busy = 0 THEN Bekle
           OWOUT   Comm_Pin, 1, [$CC, $BE]
           OWIN    Comm_Pin, 2, [HAM.Lowbyte, HAM.Highbyte]
           GOSUB   Hesapla
           RETURN
Hesapla:
    Sign  = "+"
    IF SIGN_BITI = NEGAT_ISI THEN
       Sign   = "-"
       temp=($ffff-ham+1)*625
       ISI  = DIV32 10
       GOTO GEC
    endif
    TEMP = 625 * (HAM+1)
    ISI = DIV32 10
GEC:
    FLOAT = (ISI //1000)/100
    ISI=ISI/1000
    RETURN
 sensor1
           OWOUT   Comm_Pin1, 1, [$CC, $44]
Bekle1:
           OWIN    Comm_Pin1, 4, [Busy]
           IF      Busy = 0 THEN Bekle1
           OWOUT   Comm_Pin1, 1, [$CC, $BE]
           OWIN    Comm_Pin1, 2, [HAM.Lowbyte, HAM.Highbyte]
           GOSUB   Hesapla1
           RETURN
Hesapla1:
    Sign1  = "+"
       Sign1   = "-"
       ISI1  = DIV32 10
       GOTO GEC1
    endif
    ISI1 = DIV32 10
GEC1:
    FLOAT = (ISI1 //1000)/100
    ISI1=ISI1/1000
    RETURN
  sensor2
           OWOUT   Comm_Pin2, 1, [$CC, $44]
Bekle2:
           OWIN    Comm_Pin2, 4, [Busy]
           IF      Busy = 0 THEN Bekle2
           OWOUT   Comm_Pin2, 1, [$CC, $BE]
           OWIN    Comm_Pin2, 2, [HAM.Lowbyte, HAM.Highbyte]
           GOSUB   Hesapla2
           RETURN
Hesapla2:
    Sign2  = "+"
       Sign2   = "-"
       ISI2  = DIV32 10
       GOTO GEC2
    endif
    ISI2 = DIV32 10
GEC2:
    FLOAT = (ISI2 //1000)/100
    ISI2=ISI2/1000
    RETURN
  sensor3
           OWOUT   Comm_Pin3, 1, [$CC, $44]
Bekle3:
           OWIN    Comm_Pin3, 4, [Busy]
           IF      Busy = 0 THEN Bekle3
           OWOUT   Comm_Pin3, 1, [$CC, $BE]
           OWIN    Comm_Pin3, 2, [HAM.Lowbyte, HAM.Highbyte]
           GOSUB   Hesapla3
           RETURN
Hesapla3:
    Sign3  = "+"
       Sign3   = "-"
       ISI3  = DIV32 10
       GOTO GEC3
    endif
    ISI3 = DIV32 10
GEC3:
    FLOAT = (ISI3 //1000)/100
    ISI3=ISI3/1000
    RETURN
   reklam
   LCDOut $fe, 1 : PAUSEUS 50
   LCDOUT "********************"
   lcdout $fe, $C0,"********SOFIE********"
   LCDOut $fe, $94,"*****ELECTRONICS*****"
   LCDOut $fe, $D4,"********************"
   PAUSE 4000
RETURN
    disp
    lcdout $FE,1 : pauseus 50
    LCDOUT " 1.SICAKLIK : ",Sign,DEC ISI,Deg,"C"
    LCDOUT $FE, $C0," 2.SICAKLIK : ",Sign1,DEC ISI1,Deg,"C"
    LCDOUT $FE, $94," 3.SICAKLIK : ",Sign2,DEC ISI2,Deg,"C"
    LCDOUT $FE, $D4," 4.SICAKLIK : ",Sign3,DEC ISI3,Deg,"C"
    pause 1000
    return
End
Değerli bilgilerini bizimle paylaşan ETE hocaya sonsuz teşekkürler...
Kolay Gelsin...
aykut54
selam ilker paylaştığın uygulama için teşekkürler
sensör sayısını arttırabilirmiyiz?arttırırsak mesela  o yaptın uygulamada göre kaç tane sensör daha koyabiliriz?
sevgili ete hocamızın müstesna bilgileri sağolsun programcıı yaptı bizi:D
ilker_32
Tabi arttırabilirsin. Fakat, sensör okuma oldukça yavaşlar eğer daha fazla sensör okuyacaksan tüm DS'lerin datalarını ortak yapabilirsin. Gerekli bilgi datasheet'de yazıyor.
Maxim
bu sensörleri tek hat üzerine takabilmemiz lazım ,
ama bu konuda hiç bir örneğe rastlamadım ,
yani her DS18B20 sensöründe fabrika tarafından verilmiş bir ID numarası var ,dolayısı ile 10 tane sensörü bile tek bir hat üzerine takabiliyor olmamız lazım.
hatta ,
bu sensörlerin farklı bir versiyonu daha var ,
parasite power .
DS18B20-PAR
bunlarda ise gerçekten tek bir hat üzerinden bilgi alıyorsunuz ,
yani sadece data ve şase ,besleme yok .
normalde ,data + besleme + şase .
MURSEL
aynı hatta 78 adet sensorü baglayarak  kontrol sistemi kurmustum
alayli
@maxiboost'un da dediği gibi tek bir pin ile bir çok 1 wire cihazı okumak mümkün. Fakat bunun için maxim'in 187 nolu uygulama notunu iyice anlamak gerekiyor. Bu uygulama notu bir tür "arama algoritması (search algorithm)"nı açıkça anlatır. Bit bazında ROM taraması esasına dayanır. Buradan bakabilirsiniz...
Anca kazganmiş itmiş ilimiz törümüz erti. Türk Oguz begleri budun esiding. Üze tengri basmasar, asra yir telinmeser, Türk budun, ilingin törüngin kim artati? (udaci erti)
alayli
Alıntı yapılan: "maxiboost"........ama bu konuda hiç bir örneğe rastlamadım......
Artık rastlaşabilirsiniz örnekle... Sanırım sen proton+ kullanıyordun.Burada bir örnek var.
Maxim
Alaylı ,
şunları inceleyeyim ,sağol ..
cetinkaya
bu devredeki elemanlar ds18s20 mi yoksa ds18b20 arasinda fark varmi ??
Maxim
Alıntı yapılan: "rck8942"bu devredeki elemanlar ds18s20 mi yoksa ds18b20 arasinda fark varmi ??
farklı ,
devrede DS18B20 kullanılmış ,
DS18S20 nin kodları biraz farklı ,
aynı zamanda
DS18S20 ,DS1820 nin yeni versiyonu
o yüzden DS18S20 ile DS1820 nin kodları aynı
cetinkaya
ayni islemi ds18s20 de yapmak istiyorum bu kodu derlemeye calisinca pbp hata veriyor bi yardim ederseniz sevinirim tesekkürler
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 16.02.2009                                        *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
@ DEVICE pic16F877A
@ DEVICE pic16F877A, WDT_OFF
@ DEVICE pic16F877A, PWRT_ON
@ DEVICE pic16F877A, PROTECT_OFF
@ DEVICE pic16F877A, HS_OSC
Define OSC	20
DEFINE LCD_DBIT     0
DEFINE LCD_RSBIT    4
DEFINE LCD_EBIT     5
DEFINE LCD_BITS     4
DEFINE LCD_LINES    2
TRISB=0
TRISD=%00001111
PORTB=0
PORTD=0
Comm_Pin     VAR Porta.5
Busy         VAR BIT
HAM          VAR WORD
ISI          VAR WORD
SIGN         VAR BYTE
NEGAT_ISI   CON 1
Deg         con 223
TEMP        VAR BYTE
Float       VAR WORD
basla:
gosub sensoroku
SENSOROKU:
OWOUT Comm_Pin, 1, [$CC, $44]' ISI degerini oku
Bekle:
OWIN Comm_Pin, 4, [Busy] ' Busy degerini oku
IF Busy = 0 THEN Bekle ' hala mesgulmü? , evet ise goto Bekle..!
OWOUT Comm_Pin, 1, [$CC, $BE]' scratchpad memory oku
OWIn Comm_Pin, 0, [HAM.LOWBYTE, HAM.HIGHBYTE, Skip 4, Kalan, Sayac]
GOSUB Hesapla
RETURN
Hesapla: ' Ham degerden Santigrat derece hesabi
Sign = "+"
Sign = "-"
ISI=((($ffff-ham+1)*50)-25)+ (((Sayac - Kalan) * 100) / Sayac)
GOTO GEC
endif
ISI = (((HAM) * 50) - 25) + (((Sayac - Kalan) * 100) / Sayac)
' ISI=ISI-25
GEC:
ISI2 = (ISI //100)/10
ISI1=ISI/100
RETURN
tnen
http://picproje.org/index.php/topic,16168&highlight=
buradada DS nin seri numarası family codeu ve CRC kodu okuyabileceğiniz kod mevcut arkadaşlar. Bunları bildikten sonra tek hat üzerinden DSler bağlanabilir.
cetinkaya
tm ustada benim sorunum baska
tnen
Kalan , sayac, ısı1 ve ısı2 yi tanımlamamışsın bunları değişken   turune gore program başında tanımla
solidus
İlker tebrik ediyorum seni. Kodlar bu hali ile - ısılarda çalışıyor. +65 derecenin üzerini okumuyor. Hata bendemi yoksa proteus kandırıyormu beni ? Birde sanırsam bu şekilde düzenlenen devreler 1wire teknolojisinin mantığına biraz aykırı değil mi ?
