555 problemi
Başlatan cenkishan, 30 Nisan 2009, 13:47:09
cenkishan
Slm  arkadaslar NE 555P ile NE 555N arasındaki fark yaşayan varmı.NE 555D,NE555F,NE555N,NE555P,NE555Y tipleri var.Bunların arasındaki farkları bilen yada daha önce problem yaşayan varmı.Sonundaki  harf üretici ismi olabilirmi yada kılıf tipi bütün bu seriler dıp kılıf değilmi emin olamadım.
EDIT: Tamamdır package listesini buldum.Hallettim
Bir bit olsam dolaşsam C de byte byte
ibrsel
NE531N-PHI OPAMP 1x 44V 1MHz 35V/us
NE532N Bakınız: LM358N-MBR
NE542N-PHI Bakınız: LM387N-MBR
NE544N-PHI ...?...
NE545B-PHI Bakınız: NE645N-MBR
NE5512N-PHI OPAMP 1x 32V 3MHz 1V/us
NE5514N-PHI OPAMP 4x 32V 3MHz 1V/us
NE5517N-PHI DUAL TRANSCOND.OPAMP 16p
NE5520N-PHI LVDT SIGNAL CONDITION.14p
NE5521N-PHI LVDT SIGNAL CONDITIONER
NE5532AN-MBR OPAMP 2x 44V 10MHz 9V/us
NE5532N-MBR OPAMP 2x 44V 10MHz 9V/us
NE5533AN-PHI OPAMP 2x 44V 10MHz 13V/us
NE5533N-PHI OPAMP 2x 44V 10MHz 13V/us
NE5534AN-MBR OPAMP 1x 44V 10MHz 13V/us
NE5534N-MBR OPAMP 1x 44V 10MHz 13V/us
NE5535N-MBR DUAL HIGH SLEW RATE OPAMP
NE5537N-PHI SAMPLE+HOLD AMP. LOW LEAK
NE5539N-PHI OPAMP 1x 24V 350MHz 600V/
NE555-CMOS Bakınız: NE555NCMOS-MBR
NE555D-MBR SINGLE TIMER 8p SMD
NE555H-MBR TIMER TO99 HOUSING
NE555N-MBR RC TIMER 1x 16V 500KHz
NE555N/DIV SINGLE TIMER 8p
NE555NCMOS-MBR C-MOS VERSION NE555
NE556D-MBR DUAL TIMER 14p SMD
NE556N-MBR RC TIMER 2x =SM8330/8336
NE556NCMOS-MBR C-MOS VERSION NE556
NE558N-MBR RC TIMER 4x 16V
NE5592N-PHI VIDEO-AMP 2x 16V 110MHz
NE564N-PHI PHASE LOCKED LOOP 5V 50MH
NE565N-MBR Bakınız: NE565N/DIV
NE565N/DIV PHASE LOCKED LOOP
NE566N-MBR FUNCTION GENERATOR 24V
NE567F TONE/FREQ.DECODER PLL
NE567N-MBR TONE/FREQ.DECODER PLL
NE570N-PHI ANALOG COMPANDER 16p
NE571N-MBR ANALOG COMPANDER =UPC1571
NE572N-PHI DUAL-COMPANDER
NE575N-MBR LOW-VOLT COMPANDER
NE587N-PHI LED DECODER/DRIVER BCD-IN
NE5900N-PHI CALL PROGRESS DECODER
NE590N-PHI ADDRES.PERIPH.DR. 8x 0.3A
NE591N-PHI ADDRES.PERIPH.DR. 8x 0.3A
NE592N14-MBR VIDEO-AMP 16V 120MHz
NE592N8-MBR VIDEO-AMP 16V 120MHz
NE594N-MBR VAC.FLUORESC.DISPL DRV.
NE602 Bakınız: NE602AN-PHI
NE602AN-PHI DOUBLE BAL.MIXER+OSC.
NE604AN-PHI Bakınız: NE614AN-PHI
NE605N-PHI LOW POWER MIXER FM IF SYS
NE612AN-PHI DOUBLE BALANCE MIXER+OSC.
NE614AN-PHI LOW POWER FM IF SYST.
