PC klavye Serin Komut hatası..
Başlatan boraciner, 29 Haziran 2009, 18:00:32
boraciner
ccs diye geçen pic c complier'ı mı kullanacağız  ?
google dan baktım , example dosylarında bir örnek varmış sanırım glcd kullanımı hakkında..
boraciner
üstad, çok başını ağrıttım ama şöyle yaptım hata veriyor, bir bakabilirmisin acaba?
#include "D:\picc\klavye.h"
setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   define Clock portb.7
const unsigned char kucuk[67][2]={
      {0x0D,0x7E},{0x0E,'"'} ,{0x15,'q'},{0x16,'1'},
      {0x1A, 'z'},{0x1B,'s'} ,{0x1C,'a'},{0x1D,'w'},
      {0x1E, '2'},{0x21,'c'} ,{0x22,'x'},{0x23,'d'},
      {0x24, 'e'},{0x25,'4'} ,{0x26,'3'},{0x29,' '},
      {0x2A, 'v'},{0x2B,'f'} ,{0x2C,'t'},{0x2D,'r'},
      {0x2E, '5'},{0x31,'n'} ,{0x32,'b'},{0x33,'h'},
      {0x34, 'g'},{0x35,'y'} ,{0x36,'6'},{0x39,','},
      {0x3A, 'm'},{0x3B,'j'} ,{0x3C,'u'},{0x3D,'7'},
      {0x3E, '8'},{0x41,0xEF},{0x42,'k'},{0x43,  3},
      {0x44, 'o'},{0x45,'0'} ,{0x46,'9'},{0x49,  7},
      {0x4A, '.'},{0x4B,'l'} ,{0x4C,  2},{0x4D,'p'},
      {0x4E, '+'},{0x52,'i'} ,{0x54,  5},{0x55,0x5F},
      {0x5A,0xA3},{0x5B,0xF5},{0x5D,','},{0x61,'<'},
      {0x69, '1'},{0x6D,'4'} ,{0x6C,'7'},{0x70,'0'},
      {0x71, ','},{0x72,'2'} ,{0x73,'5'},{0x74,'6'},
      {0x75, '8'},{0x79,'+'} ,{0x7A,'3'},{0x7B,'-'},
      {0x7C, '*'},{0x7D,'9'} ,{0x00,0}
const unsigned char buyuk[67][2]={
      {0x0D,0x7E},{0x0E,'é'} ,{0x15,'Q'},{0x16,'!'},
      {0x1A, 'Z'},{0x1B,'S'} ,{0x1C,'A'},{0x1D,'W'},
      {0x1E, '2'},{0x21,'C'} ,{0x22,'X'},{0x23,'F'},
      {0x24, 'E'},{0x25,'+'} ,{0x26,'^'},{0x29,' '},
      {0x2A, 'V'},{0x2B,'F'} ,{0x2C,'T'},{0x2D,'R'},
      {0x2E, '%'},{0x31,'N'} ,{0x32,'B'},{0x33,'H'},
      {0x34, 'G'},{0x35,'Y'} ,{0x36,'&'},{0x39,'L'},
      {0x3A, 'M'},{0x3B,'J'} ,{0x3C,'U'},{0x3D,'/'},
      {0x3E, '('},{0x41, 0 },{0x42,'K'},{0x43, 'I'},
      {0x44, 'O'},{0x45,'='} ,{0x46,')'},{0x49,  7},
      {0x4A, ':'},{0x4B,'l'} ,{0x4C,  1},{0x4D,'P'},
      {0x4E, '?'},{0x52, 6 } ,{0x54,  5},{0x55,0x2D},
      {0x5A,0xA3},{0x5B, 4 },{0x5D,';'},{0x61,'>'},
unsigned char get_byte(void)
   char i;
   unsigned char veri=0;
   for(i=0;i<11;i++)            //11 bitlik veri gelecek
      while(Clock);            //Ilk önce Clock=1 olmali
      if( (i<9) && (i>0))         //2->9 bitler
         veri=veri>>1;
         if(Data==1)
            veri=veri | 0x80;
      while(!Clock);            //Son olarak Clock=1 olmali
   return veri;               //Algilanan deger gönderiliyor
unsigned char keyboard(void)
   unsigned char data=0;
   unsigned char shift, code_flag, i;
   for(;;)
      data=get_byte();
      if(data==0x0F)         //Tus birakildi
         code_flag=1;      //Tus algilandi
      if(code_flag==1)      //Tus algilandi, acaba bu shift mi diye bakiliyor
         code_flag=0;      //Yeni tus algilanmasi için bayrak sifirlaniyor
         if((data==0x12)||(data==0x59))   //Sag ya da sol shifte mi basildi
            shift=!shift;            //Capslock gibi çalisacak
      if(data==0x58)               //Capslock'a basildiysa
         shift=!shift;
      for(i=0;kucuk[i][0]!=data && kucuk[i][0]; i++);      //Tusun ascii karsiligi bulunuyor
      if(kucuk[i][0]==data)         //Data ascii tablolarimizda var mi bakiliyor
         if(!shift)               //Capslock açik değilse küçük harf, açiksa büyük harfin ascii degeri geri gönderiliyor
            return kucuk[i][1];
            return buyuk[i][1];
         return data;            //Eger tablomuzda o deger bulunmuyorsa direk klavyede okunan kod geri gönderiliyor
boraciner
proje dosyanı zipleyip gönderirsen çok yardımcı olursun hocam...
çok teşekkürler, ellerine sağlık
boraciner
bugün çoook yoruldum , kafamı kaldıracak halim yok ama yarın ilk iş onu deneyeceğim çok teşekkür ederim
boraciner
bi tane pro bulup indirmeye çalışıyorum üstad..
boraciner
hi-tech ile derleyemedim.. proton basic 'de şimdi başka bir klavye deniyorum clk ve data 5V gösteriyor hiçbir tuşa basmadan, bakalım umarım yapabilirm kodları düznleyince
boraciner
şu kodu yazdım fakat şimdi de lcd de şu iki satırı görebiliyorum sadece
clk 0
clk 1
yani clk 0 again 'e hiç düşmüyor..
Include "PROTON18_452.BAS"
Device 16F877
		WARNINGS = OFF
 TRISB=%0110000
Symbol  Giris  PORTB.6
Symbol  Clk    PORTB.5
Dim dur As Bit
    Dim ComingData As Byte
    Dim B0 As Byte
    Dim xpos As Byte
    Dim ypos As Byte
    Dim OKU As Byte
    Dim ADRS As Word
    Dim TEKRAR As Word
    Dim ARRAY1[9] As Byte
    Cls
   BEGIN:
Dim i As Word
For i = 0 To 10 Step 1  '11 bitlik veri gelecek
Print At 0,0,"clk 0"
While Clk =1    ' Ilk önce Clock=1 olmali
Print At 1,1,"clk 1"
Wend
If i<9 & i>0 Then
SURE:
If Clk = 0 Then
Print At 2,2,"clk 0 again"
GoTo SURE
EndIf
Print At 3,3,"array is here"
ARRAY1[i]=ComingData
EndIf
While Clk = 0
Wend
While Clk = 0
Wend
Next
Cls
Print At 4,4, Str ARRAY1
GoTo BEGIN
End
    Include "FONT.INC"
    Include "TABLO.inc"
boraciner
şu kodu yazdığımda ise clk 0 , 1 ve tekrar sıfır oluyor fakat şöyle bir sorun var, ben herhangi bir tuşa basmıyorum. aslında böyle bir durumda clk sabit kalması gerekiyormuş
' Yazý ve grafikleri gösterir. designed By TangoDancer
Device 16F877
		WARNINGS = OFF
 TRISB=%0110000
Symbol  Clk    PORTB.5
Dim dur As Bit
    Dim B0 As Byte
    Dim xpos As Byte
    Dim ypos As Byte
    Dim OKU As Byte
    Dim ADRS As Word
    Dim TEKRAR As Word
    Cls
   BEGIN:
Dim i As Word
Print At 0,0,"clk 1"
Wend
While Clk =0    ' Ilk önce Clock=1 olmali
Print At 1,1,"clk 0"
Wend
Print At 2,2,"clk 1"
Wend
GoTo BEGIN
End
    Include "FONT.INC"
    Include "TABLO.inc"
boraciner
olmuyor, hiçbir türlü clk ve data yı kullanamıyorum....
yine serin ile almaya çalışacağım ... :cry:  :cry:
