PIC16C54 ile motorsiklet alarmı
Başlatan ilker_32, 23 Temmuz 2009, 12:20:57
ilker_32
       title   "microalarm"
       ;       Version  1.1
       ;       A. Nixon                240695
       ;       71kHz clock
       ;       56uS instruction time
       ;       prescaler set 1 : 32 division
       ;       rtcc set to 190, = 0 in approx 100mS, = loop cycle time
       ;                 ** alarm operation **
       ;       *  Alarm is armed when the ignition is turned on
       ;          for more than 2 secs and less than 5 secs, then is
       ;          turned off and left off for more than 3 seconds.
       ;       *  Alarm is cancelled when ignition is turned back on
       ;       *  If ignition is kept on for longer than 5 seconds, then
       ;          the alarm will not arm.
       ;       *  Turning the ignition on will kill the siren and disable
       ;          the alarm.
       ;       *  siren announce alarm status
       ;       *  1 beep indicates alarm is now armed
       ;       *  2 beeps indicates alarm was tampered with
       ;       *  3 beeps indicates that alarm was set, but is in a
       ;          triggered condition and has disarmed itself
list p=16c54    ; processor type
       ;       equates list
       z equ 2h
       carry equ 0h
       rtcc equ 1h
       status equ 3h
       fsr equ 4h
       porta equ 5h
       portb equ 6h
       ;       output port assignments
       siren equ 7h    ; portb bit 7 - siren
       ign equ 1h      ; porta bit 1 - ignition
       sensor equ 1h   ; portb bit 1 - sensor
       ;       register list
       almset equ 0ah  ; flag, is alarm set
       beepfl equ 0ch  ; flag, is siren to beep
       beepct equ 0dh  ; times siren is to beep
       igdebn equ 0eh  ; ignition debounce counter
       igstat equ 0fh  ; ignition switch status flag
       error equ 10h   ; error status
       armed equ 11h   ; armed status
       onstat equ 12h  ; ignition on status
       icount equ 13h  ; ignition on/off counter
       triger equ 14h  ; trigger status
       sndebn equ 15h  ; sensor debounce counter
       sirenL equ 16h  ; siren on counter L
       sirenH equ 17h  ; siren on counter H
       igchan equ 18h  ; ignition change status
       tamper equ 19h  ; tamper announce timer
       beeptm equ 1ah  ; beep off timer
       ;       program start
       org 0h
start   movlw b'11111111'
;/start   clrw
       tris porta      ; all inputs
       movlw b'01111111'     ;/
       tris portb      ; portb bit 7 0/p, all others i/p's
       clrf porta
       clrf portb
       clrf almset
       clrf beepfl
       clrf beepct
       movlw .6        ; set for 6 debounce loops for ignition
       movwf igdebn
       clrf igstat
       clrf error
       clrf armed
       clrf onstat
       clrf icount
       clrf triger
       clrf sndebn
       clrf sirenL
       clrf sirenH
       clrf igchan
       clrf tamper
       clrf beeptm
       movlw b'11000100'    ;/
       option          ;/ set rtcc timing
       movlw .225      ;/
       movwf rtcc      ;/
mnloop  movf rtcc,w
       btfss status,z
       goto mnloop     ; wait here for rtcc to = 0, 50ms loop
       movlw .225      ;/
       movwf rtcc      ;/ reset rtcc timing
       ; Beep siren routine. The siren is turned on for 50mS and
       ; off every for 100mS.
       ; BEEPCT is decremented every time the siren is turned on.
       movf beepfl     ; if <> 0 then beep siren
       btfsc status,z
       goto dbchek     ; no beep siren
       btfsc portb,siren ; (7) test siren status
       goto siron
       movf beepct     ; if = 0 then exit, else beep siren and decrement
       btfss status,z
       goto dosirn
       clrf beepfl     ; clear the beep flag and exit
       goto dbchek
dosirn  movf beeptm
       btfss status,z
       goto onsirn
       incf beeptm
       goto dbchek
onsirn  decf beepct     ; beep counter - 1
       bsf portb,siren ; (7) turn siren on
       goto dbchek
siron   bcf portb,siren ; (7) turn siren off
       clrf beeptm
dbchek  movf igdebn     ; decrement ignition debounce if <> 0
       btfsc status,z  ; wait until debounce = 0
       goto ignsta
       decf igdebn
       goto mnloop
       ; Ignition status. Ignition switch is debounced for 4 loops.
ignsta  btfsc porta,ign ; (1) test ignition switch status
       goto igison
       ; Ignition switch is detected OFF.
       movf igchan     ; test if already detected low
       btfsc status,z
       goto chanlw     ; yes
       clrf igchan     ; flag ignition has changed to low
       movlw .6
       movwf igdebn
       goto mnloop
chanlw  movf igstat     ; test if flagged low
       btfsc status,z
       goto izfllw     ; is flagged low
       clrf igstat     ; set ignition status flag = low
       clrf icount     ; clear ignition counter
       clrf triger     ; clear trigger status
       clrf armed      ; clear system armed
       clrf tamper     ; clear tamper timer
       goto armchk     ; no need to error check
       ; Ignition is flagged low
izfllw  movf error      ; Error is flagged if arming sequence was
       btfss status,z  ; successful but sensor was triggered
       goto mnloop     ;
       ; If system is armed then do sensor check routines
       ; If ignition on timing was within limits (ONLIMIT <> 0), then
       ; wait until ignition is off for 40 loops. After this time arm
       ; system.
       ; If ignition stays off for less than 40 loops then arming sequence
       ; will abort.
armchk  movf armed      ; check system armed status
       btfss status,z
       goto syston     ; system is already armed
       movf onstat     ; if <> 0, then ignition was on within arming
       btfsc status,z  ; limits, so count loops ignition is off
       goto mnloop
       incf icount     ; ignition off count + 1
       movlw .40       ; test if 40 loops reached
       xorwf icount,w
       btfss status,z
       goto mnloop     ; no
       btfsc portb,sensor ; (1) test if sensor is triggered. If so,
       goto nosens        ; beep siren 3 times
       movlw .3
       movwf beepct
       movlw .1
       movwf beepfl
       clrf onstat     ; clear arm status
       goto mnloop
nosens  movlw 0xff      ; flag system is armed
       movwf armed
       movlw .1        ; beep siren once
       movwf beepct
       movlw .1
       movwf beepfl
       goto mnloop
       ; Ignition is detected on
igison  movf igchan     ; test if already detected high
       btfss status,z
       goto chanhi     ; yes
       movlw 0xff
       movwf igchan    ; flag ignition has changed to low
       movlw .6
       movwf igdebn
       goto mnloop
chanhi  movf igstat     ; test if flagged high
       btfss status,z
       goto izflhy     ; is flagged high
       movf armed      ; if system was armed, then disarm
       btfss status,z
       goto wasarm
sethi   movlw 0xff
       movwf igstat    ; set ignition status flag = high
       clrf error      ; clear error status
       clrf onstat
       goto mnloop
       ; System was armed, if triggered turn siren off if on. If siren
       ; is off already, then beep twice.
wasarm  movf triger
       btfsc status,z
       goto sethi
       clrf sndebn     ; clear sensor debounce counter
       btfss portb,siren ; (7)
       goto beeptr
       clrf sirenH
       clrf sirenL
       goto sethi
beeptr  movlw .40       ; set tamper timer
       movwf tamper
       goto sethi
       ; Ignition is flagged high, do on timing and checks
       ; To arm ignition must be on initially between 20 loops (1.2secs),
       ; and 60 loops (3 secs). If in between these limits then ONSTAT
       ; <> 0. Outside these limits ONSTAT = 0.
izflhy  movf armed      ; if armed was set dont increment counters
       btfsc status,z
       goto docnt
       ; Ignition has been turned on after arming. If triggered as well
       ; wait 2 secs before announcing such with 2 beeps
       movf tamper
       btfsc status,z
       goto mnloop
       decfsz tamper
       goto mnloop
       movlw .2        ; beep twice to indicate tamper
       movwf beepct
       movlw .1
       movwf beepfl
       goto mnloop
docnt   movlw .61
       xorwf icount,w  ; if on count = 61 then no more counting
       btfsc status,z  ; ignition has been on too long
       goto mnloop
       incf icount     ; ignition counter + 1
       movlw .20
       xorwf icount,w
       btfss status,z
       goto upperc     ; test if 60
       movlw 0xff      ; flag is in limits
       movwf onstat
       goto mnloop
upperc  movlw .60
       xorwf icount,w
       btfss status,z
       goto mnloop
       clrf onstat     ; flag is out of limits
       goto mnloop
       ; System is armed. Check sensor and siren status
syston  movf triger     ; if triggered check siren times
       btfsc status,z
       goto tsttrg     ; no
       movf sirenH
       btfss status,z
       goto decsir
       movf sirenL
       btfss status,z
       goto decsir
       bcf portb,siren ; (7) turn off siren
       goto tsttrg     ; siren timer = 0
decsir  decf sirenL     ; siren timers - 1
       movf sirenL,w
       xorlw 0xff
       btfss status,z
       goto mnloop
       movf sirenH
       btfss status,z
       decf sirenH
       goto mnloop
       ; Test for system trigger. Sensor is debounced for 1 loop
tsttrg  btfss portb,sensor ; (1) alarm is triggered if = 0
       goto iztrig
       goto mnloop
iztrig  movf sndebn     ; if <> 0 then sensor is debounced
       btfss status,z
       goto trigok
       incf sndebn
       goto mnloop
trigok  movlw 0xff      ; flag system is now triggered
       movwf triger
       movlw .4        ; set siren timers = 4b0h
       movwf sirenH
       movlw 0xb0
       movwf sirenL
       goto mnloop
       ;       reset vector
       org 1ffh
       goto start
       end
