16f628a ve ds1307 Saat&Tarih
Başlatan rck8942, 23 Ağustos 2009, 12:58:28
cetinkaya
Arkadaslar bu devreyi calistiramadim breadboarda kurdum ancak devre calismadi bi göz atarmisiniz kod larin dogru olup olmadigina dair. Sicaklik sensörü olarak ds18b20 kullandim proteusta calisti ama gercekte lcd de birsey göremiyorum.Ayrica ds1307 de 3 voltluk pili takmadim. +5V ile ds18b20 "dq" arasinda 4.7 kOhm koydum.
[/URL][/img]
Kod:
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 23.08.2009                                        *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
@ DEVICE pic16F628A
@ DEVICE pic16F628A, WDT_OFF
@ DEVICE pic16F628A, PWRT_ON
@ DEVICE pic16F628A, PROTECT_OFF
@ DEVICE pic16F628A, HS_OSC
Define OSC	4
CMCON=7
TRISA=%00010000
TRISB=%11000011
SYMBOL SCL=PORTA.7
SYMBOL SDA=PORTA.6
SYMBOL DQ=PORTB.6
OS VAR BYTE
SANIYE VAR BYTE
S1 VAR BYTE
S2 VAR BYTE
DAKIKA VAR BYTE
D1 VAR BYTE
D2 VAR BYTE
SAAT VAR BYTE
SA1 VAR BYTE
SA2 VAR BYTE
GUNADI VAR BYTE
GUN VAR BYTE
G1 VAR BYTE
G2 VAR BYTE
AY VAR BYTE
A1 VAR BYTE
A2 VAR BYTE
YIL VAR BYTE
Y1 VAR BYTE
Y2 VAR BYTE
ISI VAR WORD
HAM VAR WORD
TA1 VAR WORD
TA2 VAR WORD
TA3 VAR WORD
TA4 VAR WORD
TA5 VAR WORD
GA1 VAR BIT
GA2 VAR BIT
GA3 VAR BIT
GA4 VAR BIT
GA5 VAR BIT
OS.BIT7=0
GA2=0
GA4=0
I2CWRITE SDA,SCL,$D0,$00,[OS]
PAUSE 200
BASLA:
I2CREAD SDA,SCL,$D0,$00,[SANIYE,DAKIKA,SAAT,GUNADI,GUN,AY,YIL]
S1=SANIYE//16
S2=SANIYE-S1
S2=S2//15
D1=DAKIKA//16
D2=DAKIKA-D1
D2=D2//15
SA1=SAAT//16
SA2=SAAT-SA1
SA2=SA2//15
G1=GUN//16
G2=GUN-G1
G2=G2//15
A1=AY//16
A2=AY-A1
A2=A2//15
Y1=YIL//16
Y2=YIL-Y1
Y2=Y2//15
IF PORTB.1=1 THEN GA4=0
IF GA4=1 THEN BASLA
LCDOUT $FE,$80,#SA2,#SA1,":",#D2,#D1,":",#S2,#S1
LCDOUT $FE,$C8,#G2,#G1,".",#A2,#A1,".",#Y2,#Y1
DEM:
IF GUNADI=1 THEN LCDOUT $FE,$88," PAZAR  "
IF GUNADI=2 THEN LCDOUT $FE,$88," PZRTESI"
IF GUNADI=3 THEN LCDOUT $FE,$88," SALI   "
IF GUNADI=4 THEN LCDOUT $FE,$88," CRSAMBA"
IF GUNADI=5 THEN LCDOUT $FE,$88," PRSEMBE"
IF GUNADI=6 THEN LCDOUT $FE,$88," CUMA   "
IF GUNADI=7 THEN LCDOUT $FE,$88," CMRTESI"
IF GA5=1 THEN RETURN
IF GA1=1 THEN RETURN
IF PORTB.1=0 THEN AYAR1
OWOUT DQ,1,[$CC,$44]
DONGU:
OWIN DQ,4,[ISI]
IF ISI=0 THEN DONGU
OWOUT DQ,1,[$CC,$BE]
OWIN DQ,2,[HAM.LOWBYTE,HAM.HIGHBYTE]
IF HAM.BIT11=0 THEN HESAPLA
IF HAM.BIT11=1 THEN HESAPLA1
GOTO BASLA
AYAR1:GA1=1:GA2=1
GOTO AYAR2
AYAR2:
IF PORTB.7=0 THEN DAKIKA=DAKIKA+$01
IF DAKIKA.1=1 AND DAKIKA.3=1 THEN DAKIKA=DAKIKA+$10
IF DAKIKA.1=1 AND DAKIKA.3=1 THEN DAKIKA=DAKIKA-$0A
IF DAKIKA=$60 THEN DAKIKA=$00
IF PORTB.7=0 THEN GOSUB AYAR0
LCDOUT $FE,$83," "," "
PAUSE 80
LCDOUT $FE,$83,#D2,#D1
PAUSE 300
IF PORTB.1=1 THEN GA2=0
IF GA2=1 THEN AYAR2
IF PORTB.1=0 THEN GOTO AYAR3
GOTO AYAR2
AYAR3:
GA2=1
GOTO AYAR4
AYAR4:
IF PORTB.7=0 THEN SAAT=SAAT+$01
IF SAAT.1=1 AND SAAT.3=1 THEN SAAT=SAAT+$10
IF SAAT.1=1 AND SAAT.3=1 THEN SAAT=SAAT-$0A
IF SAAT=$24 THEN SAAT=$00
LCDOUT $FE,$80," "," "
PAUSE 80
PAUSE 300
IF GA2=1 THEN AYAR4
IF PORTB.1=0 THEN AYAR5
GOTO AYAR4
AYAR5:
GA2=1
GOTO AYAR6
AYAR6: GA5=1
IF PORTB.7=0 THEN GUNADI=GUNADI+$01
IF GUNADI=$08 THEN GUNADI=$01
LCDOUT $FE,$89,"       "
PAUSE 80
GOSUB DEM
PAUSE 300
IF GA2=1 THEN AYAR6
IF PORTB.1=0 THEN AYAR7
GOTO AYAR6
AYAR7:GA2=1:GA5=0
GOTO AYAR8
AYAR8:
IF PORTB.7=0 THEN GUN=GUN+$01
IF GUN.1=1 AND GUN.3=1 THEN GUN=GUN+$10
IF GUN.1=1 AND GUN.3=1 THEN GUN=GUN-$0A
IF (AY=$01 OR ay=$03 OR ay=$05 OR ay=$7 OR ay=$08 OR ay=$10 OR ay=$12) AND GUN=$32 THEN GUN=$01
IF (AY=$04 OR ay=$06 OR ay=$09 OR ay=$11) AND GUN=$31 THEN GUN=$01
IF (YIL=$08 OR YIL=$12 OR YIL=$16 OR YIL=$20) AND GUN=$30 THEN GUN=$01
IF (YIL=$07 OR YIL=$09 OR YIL=$10 OR YIL=$11 OR YIL=$13 OR YIL=$14 OR YIL=$15 OR YIL=$17 OR YIL=$18 OR YIL=$19 OR YIL=$21) AND GUN=$29 THEN GUN=$01
LCDOUT $FE,$C8," "," "
PAUSE 80
PAUSE 300
IF GA2=1 THEN AYAR8
IF PORTB.1=0 THEN AYAR9
GOTO AYAR8
AYAR9:
ga2=1
GOTO AYAR10
AYAR10:
IF PORTB.7=0 THEN AY=AY+$01
IF AY.1=1 AND AY.3=1 THEN AY=AY+$10
IF AY.1=1 AND AY.3=1 THEN AY=AY-$0A
IF AY=$13 THEN AY=$01
LCDOUT $FE,$CB," "," "
PAUSE 80
LCDOUT $FE,$CB,#A2,#A1
PAUSE 300
IF GA2=1 THEN AYAR10
IF PORTB.1=0 THEN AYAR11
GOTO AYAR10
AYAR11:
GA2=1
GOTO AYAR12
AYAR12:
IF PORTB.7=0 THEN YIL=YIL+$01
IF YIL.1=1 AND YIL.3=1 THEN YIL=YIL+$10
IF YIL.1=1 AND YIL.3=1 THEN YIL=YIL-$0A
LCDOUT $FE,$CE," "," "
PAUSE 80
LCDOUT $FE,$CE,#Y2,#Y1
PAUSE 300
IF GA2=1 THEN AYAR12
IF PORTB.1=0 THEN AYAR13
GOTO AYAR12
AYAR13:
GA1=0:GA4=1
GOTO BASLA
HESAPLA:
TA2=HAM.LOWBYTE
TA2=TA2//16
TA2=TA2/2
TA2=TA2*125
ta2=ta2/10
TA1=HAM//16
TA1=HAM-TA1
TA1=TA1/16
LCDOUT $FE,$C0,"+",#TA1,".",#TA2
GOTO BASLA
HESAPLA1:
TA3=$FFFF-HAM+1
TA4=TA3//16
TA4=TA4/2
TA4=TA4*125
ta4=ta4/10
TA5=TA3//16
TA5=TA3-TA5
TA5=TA5/16
LCDOUT $FE,$C0,"-",#TA5,".",#TA4
GOTO BASLA
AYAR0:PAUSE 200:
I2CWRITE SDA,SCL,$D0,$00,[SANIYE,DAKIKA,SAAT,GUNADI,GUN,AY,YIL]
GOSUB BASLA
RETURN
END
ete
Gördüğüm bazı hataları yazayım belki onları düzeltince çalışır.
Başka hata varsa onlarıda sonra yazmaya çalışacağım.
TRISA= komutunda 4. biti 1 yapmışsın onu sıfır oalrak düzelt. Oraya LCD bağlı.
Devreyi kristalle çalıştıracak isen DS1307 yi başka pinlere bağla. Çünki sigorta tanımlamalarında
kullanmışsın. Bu tanımlama 10MHz ve yukarısı kristal bağlantıları içindir. Kristal ise PortA.6 ve PortA.7 pinlerine bağlanır.
Devreyi şekilde çizdiğin şekilde kullanacak isen tanımlamayı aşağıdaki şekilde değiştir.
@ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT  'Dahili osilatör kullanılacak
Ete
tnen
Ustadlar merhabalar;
Bu DS1307 nin backup pili bağlı olduğu halde (3V) enerji kestiğimde neden DS1307 nin osc si duruyor. Yani mesela enerjiyi 12:05 de kestim ve yarım saat sonra tekrar verdiğimde normalde 12:35 olması gerekirken 12:05 den devam ediyor.Sorun nedir acaba bi fikri olan var mı?
not: Program şu anda yanımda değil ondan ekleyemedim.
Ziya
Alıntı yapılan: "tnen"Ustadlar merhabalar;
Durmaz. Birincisi olayın mantığına ters. İkincisi benim yaptığım kartta kullandığım 1307 şehirler arası yolculuk bile yapıyor, saat durmuyor.
cetinkaya
Alıntı yapılan: "ete"Gördüğüm bazı hataları yazayım belki onları düzeltince çalışır.
Ete
hocam cevabiniz icin tesekkür ederim dediginiz gibi port a yi komple cikis yaptim. osilator olarak bu kodu yazdim
ve breadboardda denedim yine olmadi lcd birsey göstermiyor sadece lcd deki 5x7 noktalar bazen bi yanip sönüyor ondada hepsi değil saygilar sensör olarakta ds18b20 kullaniyorum kodlar uygunmudur onun icin ? hayirli ramazanlar
cetinkaya
Aktüel Sema & kod sorun halen devam ediyor!!
@ DEVICE pic16f628a , INTRC_OSC_NOCLKOUT
@ DEVICE pic16f628a , MCLR_OFF
CMCON=7
TRISA=%00000000
TRISB=%11000011
SYMBOL SCL=PORTA.7
SYMBOL SDA=PORTA.6
SYMBOL DQ=PORTB.6
OS VAR BYTE
SANIYE VAR BYTE
S1 VAR BYTE
S2 VAR BYTE
DAKIKA VAR BYTE
D1 VAR BYTE
D2 VAR BYTE
SAAT VAR BYTE
SA1 VAR BYTE
SA2 VAR BYTE
GUNADI VAR BYTE
GUN VAR BYTE
G1 VAR BYTE
G2 VAR BYTE
AY VAR BYTE
A1 VAR BYTE
A2 VAR BYTE
YIL VAR BYTE
Y1 VAR BYTE
Y2 VAR BYTE
ISI VAR WORD
HAM VAR WORD
TA1 VAR WORD
TA2 VAR WORD
TA3 VAR WORD
TA4 VAR WORD
TA5 VAR WORD
GA1 VAR BIT
GA2 VAR BIT
GA3 VAR BIT
GA4 VAR BIT
GA5 VAR BIT
OS.BIT7=0
GA2=0
GA4=0
PAUSE 200
BASLA:
S1=SANIYE//16
S2=SANIYE-S1
S2=S2//15
D1=DAKIKA//16
D2=DAKIKA-D1
D2=D2//15
SA1=SAAT//16
SA2=SAAT-SA1
SA2=SA2//15
G1=GUN//16
G2=GUN-G1
G2=G2//15
A1=AY//16
A2=AY-A1
A2=A2//15
Y1=YIL//16
Y2=YIL-Y1
Y2=Y2//15
IF GA4=1 THEN BASLA
DEM:
DONGU:
OWIN DQ,4,[ISI]
IF ISI=0 THEN DONGU
GOTO BASLA
AYAR1:GA1=1:GA2=1
GOTO AYAR2
AYAR2:
PAUSE 80
PAUSE 300
IF GA2=1 THEN AYAR2
GOTO AYAR2
AYAR3:
GA2=1
GOTO AYAR4
AYAR4:
PAUSE 80
PAUSE 300
IF GA2=1 THEN AYAR4
GOTO AYAR4
AYAR5:
GA2=1
GOTO AYAR6
AYAR6: GA5=1
LCDOUT $FE,$89,"       "
PAUSE 80
GOSUB DEM
PAUSE 300
IF GA2=1 THEN AYAR6
GOTO AYAR6
AYAR7:GA2=1:GA5=0
GOTO AYAR8
AYAR8:
PAUSE 80
PAUSE 300
IF GA2=1 THEN AYAR8
GOTO AYAR8
AYAR9:
ga2=1
GOTO AYAR10
AYAR10:
PAUSE 80
PAUSE 300
GOTO AYAR10
AYAR11:
GA2=1
GOTO AYAR12
AYAR12:
PAUSE 80
PAUSE 300
GOTO AYAR12
AYAR13:
GA1=0:GA4=1
GOTO BASLA
HESAPLA:
TA2=HAM.LOWBYTE
TA2=TA2//16
TA2=TA2/2
TA2=TA2*125
ta2=ta2/10
TA1=HAM//16
TA1=HAM-TA1
TA1=TA1/16
GOTO BASLA
HESAPLA1:
TA3=$FFFF-HAM+1
TA4=TA3//16
TA4=TA4/2
TA4=TA4*125
ta4=ta4/10
TA5=TA3//16
TA5=TA3-TA5
TA5=TA5/16
GOTO BASLA
AYAR0:PAUSE 200:
GOSUB BASLA
RETURN
END
nurim
Devrede ve programda bir iki ufak değişiklik yaptım, isis'te çalışıyor.Bu durumda gerçek devre kurulduğunda da çalışması gerekir.
Eğer çalışmıyorsa bağlantıları ve kullandığın malzemeyi gözden geçir derim.
@ DEVICE pic16F628A
@ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT 'dahili osilatör
'@ DEVICE pic16F628A, HS_OSC 'kristal bağlamak için
Define OSC   4
CMCON=7
TRISA=%00000000
TRISB=%11110010
SYMBOL SCL=PORTB.4
SYMBOL SDA=PORTB.5
SYMBOL DQ =PORTB.6
OS VAR BYTE
SANIYE VAR BYTE
S1 VAR BYTE
S2 VAR BYTE
DAKIKA VAR BYTE
D1 VAR BYTE
D2 VAR BYTE
SAAT VAR BYTE
SA1 VAR BYTE
SA2 VAR BYTE
GUNADI VAR BYTE
GUN VAR BYTE
G1 VAR BYTE
G2 VAR BYTE
AY VAR BYTE
A1 VAR BYTE
A2 VAR BYTE
YIL VAR BYTE
Y1 VAR BYTE
Y2 VAR BYTE
ISI VAR WORD
HAM VAR WORD
TA1 VAR WORD
TA2 VAR WORD
TA3 VAR WORD
TA4 VAR WORD
TA5 VAR WORD
GA1 VAR BIT
GA2 VAR BIT
GA3 VAR BIT
GA4 VAR BIT
GA5 VAR BIT
OS.BIT7=0
GA2=0
GA4=0
PAUSE 200
BASLA:
PAUSE 100
S1=SANIYE//16
S2=SANIYE-S1
S2=S2//15
D1=DAKIKA//16
D2=DAKIKA-D1
D2=D2//15
SA1=SAAT//16
SA2=SAAT-SA1
SA2=SA2//15
G1=GUN//16
G2=GUN-G1
G2=G2//15
A1=AY//16
A2=AY-A1
A2=A2//15
Y1=YIL//16
Y2=YIL-Y1
Y2=Y2//15
IF GA4=1 THEN BASLA
DEM:
DONGU:
OWIN DQ,4,[ISI]
IF ISI=0 THEN DONGU
GOTO BASLA
AYAR1:GA1=1:GA2=1
GOTO AYAR2
AYAR2:
PAUSE 80
PAUSE 300
IF GA2=1 THEN AYAR2
GOTO AYAR2
AYAR3:
GA2=1
GOTO AYAR4
AYAR4:
PAUSE 80
PAUSE 300
IF GA2=1 THEN AYAR4
GOTO AYAR4
AYAR5:
GA2=1
GOTO AYAR6
AYAR6: GA5=1
LCDOUT $FE,$89,"       "
PAUSE 80
GOSUB DEM
PAUSE 300
IF GA2=1 THEN AYAR6
GOTO AYAR6
AYAR7:GA2=1:GA5=0
GOTO AYAR8
AYAR8:
PAUSE 80
PAUSE 300
IF GA2=1 THEN AYAR8
GOTO AYAR8
AYAR9:
ga2=1
GOTO AYAR10
AYAR10:
PAUSE 80
PAUSE 300
GOTO AYAR10
AYAR11:
GA2=1
GOTO AYAR12
AYAR12:
PAUSE 80
PAUSE 300
GOTO AYAR12
AYAR13:
GA1=0:GA4=1
GOTO BASLA
HESAPLA:
TA2=HAM.LOWBYTE
TA2=TA2//16
TA2=TA2/2
TA2=TA2*125
ta2=ta2/10
TA1=HAM//16
TA1=HAM-TA1
TA1=TA1/16
GOTO BASLA
HESAPLA1:
TA3=$FFFF-HAM+1
TA4=TA3//16
TA4=TA4/2
TA4=TA4*125
ta4=ta4/10
TA5=TA3//16
TA5=TA3-TA5
TA5=TA5/16
GOTO BASLA
AYAR0:PAUSE 200:
GOSUB BASLA
RETURN
END
Kolay gelsin
nurim
cetinkaya
sensör olarak ds1822 yi kullanmiyorum ds18b20 kullaniyorum ikisi icindemi gecerli bu kodlar ? onu anlayamadim.
nurim
Alıntı yapılan: "rck8942"sensör olarak ds1822 yi kullanmiyorum ds18b20 kullaniyorum ikisi icindemi gecerli bu kodlar ? onu anlayamadim.
Hem DS1822, ve hemde DS18B20, ile çalışıyor....
Kolay gelsin
nurim
cetinkaya
nuri hocam devreyi proteusta simule edemiyorum sizin devrenin aynisi cizdim olmadi 7.6 sp0 kullaniyorum.
nurim
Alıntı yapılan: "rck8942"nuri hocam devreyi proteusta simule edemiyorum sizin devrenin aynisi cizdim olmadi 7.6 sp0 kullaniyorum.
Çalışan dosya örneğini,B U R A D A N İndirebilirsin.
Ben 7.5 SP3 kullanıyorum.
Kolay gesin
nurim
cetinkaya
Tesekkürler hocam emeğinize saglik ama simulasyonda derece hep 23.5 24.5 vs. hep .5 li gösteriyor gercektede böyle olmasin ?
nurim
Alıntı yapılan: "rck8942"Tesekkürler hocam emeğinize saglik ama simulasyonda derece hep 23.5 24.5 vs. hep .5 li gösteriyor gercektede böyle olmasin ?
İsiste "DS18B20" için değer değişimi ,o şekilde ayarlanmış.Gerçekte DS18B20 öyle çıkış vermez.
Kolay gelsin
nurim
cetinkaya
hocam devreyi kurdum breadboarda yanliz lcd de sadece
20:20:20
            20.20.20   gösteriyor ? sorun nerde olabilir sizce ? gün adini ve dereceyi hic göstermiyor butonlara basinca ayarlama yapamiyorum. yardimci olursaniz sevinirim
nurim
Alıntı yapılan: "rck8942"hocam devreyi kurdum breadboarda yanliz lcd de sadece
20:20:20
By nurim
Bağlantılara dikkat DS1307, ve DS18B20 doğru bağlanmamışsa yada çalışmıyorlarsa çıkış bu şekilde oluyor.
Kolay gelsin
nurim
