149$ a pic c compiler
Başlatan PROTECH_, 05 Mayıs 2010, 11:31:59
PROTECH_
Hi-tech e rakip  c compiler olduğunu ileri süren BoostC
full lisans 149$
Alıntı YapWhat is BoostC
BoostC is our latest generation C compiler that works with PIC18, PIC16 and some PIC12 processors. BoostC was designed to rival Hi-Tech C compiler. This ANSI C compatible compiler supports features like source level debugging, signed data types, structures/unions and pointers.
Checkout the BoostC compiler Reference Manual in PDF format here.
The BoostC compiler can be used with the SourceBoost IDE (Integrated Development Environment), or can be integrated into Microchip MPLAB.
BoostC works under MS Windows 98/ME/NT/2000/XP/Vista/7.
What's in the software package
When you download the SourceBoost software package you get the SourceBoost IDE, BoostC compiler and all the other SourceBoost compilers. The compilers and IDE are activated by using the appropriate activation key.
Prefer to Program in C++?
The BoostC++ compiler has all the functionality of the BoostC compiler with the addition of C++ features. Existing BoostC code can be compiled with the BoostC++ Compiler without any changes.
License Limitations
All license options for the BoostC 'C' compiler support PIC12, PIC16 and PIC18 Target Devices. Please check the supported devices list to confirm the devices you require are supported.
Upgrade Policy
All licenses get free minor revision upgrades. That means any BoostC V6.x license can be upgraded to the latest BoostC V6.x at zero cost.
Major revision upgrades are chargeable. That means you will have to pay an upgrade fee in order to upgraded BoostC V6.x license to a BoostC V7.x license.
Costs of upgrades from other compilers to BoostC can be found here.
Anyone with a current support subscription will get major revision upgrades for Free
http://www.sourceboost.com/Products/BoostC/Overview.html
Multi-Core ,RTX,ThreadX, FreeRTOS, MODBUS  RTOS - Electronic-Hardware -- BERLIN
