GSM MODÜL CONNECTION CLOSED
Başlatan izwirlee_35, 05 Ekim 2010, 14:32:09
izwirlee_35
Merhaba arkadaşlar kulllandığım komutlar şunlar
AT+CIPSTART="TCP","www.google.com","80"
OK
CONNECT OK
AT+CIPSEND
> GET http://www.google.com
Connection:Keep-Alive
SEND OK
HTTP/1.0 200 OK
Date: Tue, 05 Oct 2010 08:27:13 GMT
Expires: -1
Cache-Control: private, max-age=0
Content-Type: text/html; charset=ISO-8859-9
Set-Cookie: PREF=ID=758317c3110195c1:TM=1286267233:LM=1286267233:S=xFHrfgPfwy1ZL
kz9; expires=Thu, 04-Oct-2012 08:27:13 GMT; path=/; domain=.google.com.tr
Set-Cookie: NID=39=l3v8OBWCR3UVQ4cDFr8vnCBpw0tyAm0g8pREyw1_-8MBdeUGsTo6mrzRIsyxr
6_wY_cDal9K5I305j-aghmf79dfUpBjAACoAS6zenAWNd7MTZww-vrCpP5WRTPn1dXz; expires=Wed
, 06-Apr-2011 08:27:13 GMT; path=/; domain=.google.com.tr; HttpOnly
Server: gws
X-XSS-Protection: 1; mode=block
<!doctype html><html><head><meta http-equiv="content-type" content="text/html; c
harset=ISO-8859-9"><title>Google</title><script>window.google={kEI:"YeGqTOvpOpGU
jAft2KXGBw",kEXPI:"26614,26885,27006",kCSI:{e:"26614,26885,27006",ei:"YeGqTOvpOp
GUjAft2KXGBw",expi:"26614,26885,27006"},ml:function(){},kHL:"tr",time:function()
{return(new Date).getTime()},log:function(b,d,c){var a=new Image,e=google,g=e.lc
,f=e.li;a.onerror=(a.onload=(a.onabort=function(){delete g[f]}));g[f]=a;c=c||"/g
en_204?atyp=i&ct="+b+"&cad="+d+"&zx="+google.time();a.src=c;e.li=f+1},lc:[],li:0
,Toolbelt:{}};
              window.google.sn="webhp";window.google.timers={load:{t:{start:(new
 Date).getTime()}}};try{}catch(u){}window.google.jsrt_kill=1;
                                                             var _gjwl=location;
function _gjuc(){var e=_gjwl.href.indexOf("#");if(e>=0){var a=_gjwl.href.substri
ng(e);if(a.indexOf("&q=")>0||a.indexOf("#q=")>=0){a=a.substring(1);if(a.indexOf(
"#")==-1){for(var c=0;c<a.length;){var d=c;if(a.charAt(d)=="&")++d;var b=a.index
Of("&",d);if(b==-1)b=a.length;var f=a.substring(d,b);if(f.indexOf("fp=")==0){a=a
.substring(0,c)+a.substring(b,a.length);b=c}else if(f=="cad=h")return 0;c=b}_gjw
l.href="/search?"+a+"&cad=h";return 1}}}return 0}function _gjp(){!(window._gjwl.
hash&&
      window._gjuc())&&setTimeout(_gjp,500)};
                                             window._gjp && _gjp()</script><styl
e id=gstyle>body{margin:0}#gog{padding:3px 8px
CLOSED
0}td{line-height:.8em}.gac_m td{line-height:17px}form{margin-bottom:20px}body,td
,a,p,.h{font-family:arial,sans-serif}.h{color:#36c;font-size:20px}.q{color:#00c}
.ts td{padding:0}.ts{border-collapse:collapse}em{font-weight:bold;font-style:nor
mal}.lst{width:496px}.tiah{width:458px}input{font-family:inherit}a.gb1,a.gb2,a.g
b3,a.gb4{color:#11c !important}#gog{background:#fff}#gbar,#guser{font-size:13px;
padding-top:1px !important}#gbar{float:left;height:22px}#guser{padding-bottom:7p
x !important;text-align:right}.gbh,.gbd{border-top:1px solid #c9d7f1;font-size:1
px}.gbh{height:0;position:absolute;top:24px;width:100%}#gbs,.gbm{background:#fff
;left:0;position:absolute;text-align:left;visibility:hidden;z-index:1000}.gbm{bo
rder:1px solid;border-color:#c9d7f1 #36c #36c #a2bae7;z-index:1001}.gb1{margin-r
ight:.5em}.gb1,.gb3{zoom:1}.gb2{display:block;padding:.2em .5em}.gb2,.gb3{text-d
ecoration:
fakat bir sorun var bağlantı birden kesiliyor.Yukarıda gösterdiğim gibi CLOSED satırı ekrana geliyor  Tcp bağlantısı kesiliyor. TCP bağlantısıyla her bir seferde 1024 byte mı alınıyor eğer öyleyse bunu nasıl aşarız? transparent mode mu kullanmam gerek transparent moddada yazdığımı göremiyorum ATE1 yapıyorum fakat yinede yazdığımı göremiyorum. transparent moddaki olan durum ise şöyle :
at+cipstart="TCP","www.birsite.com","80"
OK
CONNECT
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
                                                  <html><head>
                                                              <title>501 Method
Not Implemented</title>
                       </head><body>
                                    <h1>Method Not Implemented</h1>
        <p>www.birsite.com to /index.html not supported.<br />
                                          </p>
                                              <hr>
                                                  <address>Apache/2.2.9 (Debian)
 PHP/5.2.6-1+lenny9 with Suhosin-Patch mod_ssl/2.2.9 OpenSSL/0.9.8g Server at li
n01.radore.net Port 80</address>
                                </body></html>
burada ise CONNECT satırı ekrana geldikten sonra ekrana yazdığımı görmeme rağmen
GET http://www.birsite.com
Connection:Keep-Alive yazıyorum ve ctrl+z ile gönderiyorum.
ve  defalarca entera basınca yukarıdaki kodlar karşıma geliyor.
Şimdiden teşekkürler...
keep learning . . .
izwirlee_35
yardımlarınız ı bekliyorum arkadaşlar
keep learning . . .
