basicten protona Lookup uyarlaması
Başlatan satilla, 09 Ekim 2010, 02:25:17
satilla
basictetki bir lookup kod içeirgini protonda derleyeme kalkıyorum hata veriyor
örn lookup'ta çift tırnak içine almam lazım lookup degerini fakat protonda tek satırı kapsıyor böyle olunca,
kodu tek satıra çeviriyorum bu defada teks atırda 250 karakteri geçtiğime dair uyarı veriyor
LookUp data_reg,[$FF,$FF,$03,$F3,$F3,$F3,$73,$73,$73,$F3,$F3,$E3,$03,$B3,$B3,$B3,$03,$03,$83,$83,$83,$83,$83,$83,$03,$83,$83,$83,$83,$83,$83,$83_
,$03,$03,$03,$83,$83,$83,$83,$83,$03,$03,$83,$83,$83,$83,$83,$83,$03,$03,$B3,$B3,$B3,$03,$03,$83,$83,$83,$83,$83,$03,$03,$FF,$FF_
,$FF,$FF,$00,$FF,$FF,$FF,$1C,$1C,$1C,$1F,$1F,$0F,$00,$FF,$FF,$FF,$00,$FF,$FF,$FF,$83,$83,$83,$83,$00,$FF,$FF,$FF,$83,$83,$83,$FF_
,$FF,$00,$FF,$FF,$FF,$03,$01,$00,$00,$FF,$FF,$C7,$83,$83,$C7,$FF,$FF,$00,$FF,$FF,$FF,$00,$FF,$FF,$B3,$B3,$B3,$BF,$1F,$00,$FF,$FF_
,$FF,$FF,$00,$03,$03,$03,$00,$00,$00,$00,$00,$00,$00,$03,$03,$03,$00,$01,$03,$03,$03,$03,$03,$03,$00,$1F,$1F,$1F,$03,$03,$03,$01_
,$01,$00,$03,$03,$03,$00,$00,$00,$00,$01,$03,$03,$03,$03,$03,$03,$01,$60,$7F,$7F,$3F,$00,$01,$03,$03,$03,$03,$03,$03,$00,$FF,$FF_
,$FF,$FF,$00,$00,$00,$00,$02,$02,$FE,$02,$02,$00,$F8,$02,$00,$82,$F8,$00,$F8,$10,$08,$00,$FE,$20,$D0,$08,$00,$FA,$00,$18,$60,$80_
,$60,$18,$00,$F0,$28,$28,$28,$B0,$00,$0E,$00,$F8,$08,$08,$08,$F0,$00,$FA,$00,$F8,$08,$08,$08,$F0,$00,$00,$00,$00,$00,$00,$FF,$FF],veri
data_reg=data_reg+1  :  Return
drmp
VAR1 = LOOKUP INDEX , [ 10 , 20 , 30 ]  bu şekile olması gerekmiyormuydu  ? birde böyle dene bakalım
Ruzgarbey
Dim Index as Byte
Dim VERI as Byte
Dim data_reg as Byte
VERI = LookUp Index,[$FF,$FF,$03,$F3,$F3,$F3,$73,$73,$73,$F3,$F3,$E3,$03,$B3,$B3,$B3,$03,$03,$83,$83,$83,$83,$83,$83,$03,$83,$83,$83,$83,$83,$83]
INC data_reg
Return
kolay gelsin.
Hayatta En Hakiki Mürşid İlimdir. M.K. ATATÜRK
Alıntı yapılan: drmp - 09 Ekim 2010, 07:17:44
Buna ilave
Satır bitimini
$83_  ' bu şekilde değil
$83,_ ' bu şekilde deneyin
tabi bu durumda satırın başlamasındaki virgül olmayacak, çünkü virgül satır sonuna alındı. Yani,
,$03  ' değil
$03  ' olacak
İlk iki satır için örnek
LookUp data_reg,[$FF,$FF,$03,$F3,$F3,$F3,$73,$73,$73,$F3,$F3,$E3,$03,$B3,$B3,$B3,$03,$03,$83,$83,$83,$83,$83,$83,$03,$83,$83,$83,$83,$83,$83,$83,_
$03,$03,$03,$83,$83,$83,$83,$83,$03,$03,$83,$83,$83,$83,$83,$83,$03,$03,$B3,$B3,$B3,$03,$03,$83,$83,$83,$83,$83,$03,$03,$FF,$FF,_
satilla
yardımlarınız için tşk ederim
bu arada lookupl 'nin farkı ne ?
LookUp ta kullanılan Sabitler 8bitlik dir.LookUpL de farklı ve büyük olabiliyor. ama Bundada Ekeleyebileceğimiz değişken yada sabit 85 i geçemiyor.
satilla
yani 85 tane 16 bitlik tanımlama yapılabilir mi?
Denemedim ama Yapılabilir Görünüyor.
