GMS30C7201 nedir?
Başlatan Manve_13, 14 Ekim 2010, 00:24:08
Manve_13
Merhabalar,
Elimde bir kutu var ve uzerinde device olarak GMS30C7201 yaziyor. Arastirdigim kadariyla bir cesit processor bu. Fakat kesin bilgiye ulasamadim. Dedim belki burda bilen biri cikar.
Ayrica kutunun ustunde IWXX 3165-0017, CPU, ARM, 7201, COMROAD yaziyor.
Biraz eksi bir donanim sanirsam =)
Google da ilk sırada datası çıkıyor.
Alıntı YapThe GMS30C7201 is a highly-integrated microprocessor for personal digital assistants, and
other applications described below. The device incorporates an ARM720T CPU, Piccolo DSP,
and system interface logic to interface with various types of devices. GMS30C7201 is a highlymodular
design based on the AMBA bus architecture between CPU and internal modules.
The on-chip peripherals include keyboard controller, VGA and LCD controller complete with
DMA support for external SDRAM memory. The GMS30C7201 also supports voice recording,
sound playback and a touch panel interface. Piccolo enables softmodems to be used, and an on
chip CODEC interface enables a low-cost modem solution.
The power management features result in very low power consumption.
The GMS30C7201 provides an excellent solution for personal digital assistants(PDAs)
,and data terminal running the Microsoft Windows CE operating system. Other applications
include smart phones, Internet appliances, car navigation, particularly where Windows CE
support is required.
• 32-bit ARM7TDMI RISC static CMOS CPU core
• 8Kbytes combined instruction/data cache
• Memory management unit for WindowsCE
• Piccolo DSP(supports softmodem)
• 512-byte instruction cache for Piccolo DSP
• Supports Little Endian operating system
• On-chip peripherals with individual power-down:
- Multi-channel DMA
- Timer
- Interrupt Controller
- Memory controller for ROM, Flash, SRAM, SDRAM
- PCMCIA II and Compact Flash Controller
- Power management unit
- LCD Controller for mono/color STN and TFT LCD
- VGA Controller with on-chip DACs (for direct drive of monitors)
- Real-time clock (32.768kHz oscillator)
- Infrared communications (IrDA support for 4Mbps and lower rates)
- 2 UARTs (16C550 compatible)
- AFE (Analog Front End or CODEC) interface
- Keyboard control interface
- GPIO
- Synchronous Serial Interface module for MMC Card
- USB (target)
- ADC and interface module (touch panel)
- DAC and interface module (sound output)
- PLL
• JTAG debug interface and boundary scan
• 0.35mm process
• 3.3V supply voltage
• 360-pin BGA package
• 60MHz operation frequency
• Low power consumption
Manve_13
Hmm haklsini onu gormustum de, iste burdan bilen eden var mi diye sormak istedim.
Elimdeki kutuda 70 tane var bunlardan ve satmak istiyorum da. Hani bilen eden varsa fiyatlandirma konusunda yardimci olabilir diye dusundum.
Burak B
Manve_13;
O chiplerin modası geçti biraz. Kimsenin işine yarayacaklarını sanmıyorum. Zira 60Mhz için o kadar dizayn v.s. uğraşmaktansa 2410 bir kart için (S3C2410A-266Mhz 9-10 Euro sadece chip)  uğraşmak daha mantıklı. Bilmem anlatabildim mi? Lafın kısası chiplerin özellikle kulanıldığı bir alet edevat, teknik servis, yedek parça, v.s. için kullanacak olan yoksa taliplisi çıkmayacaktır.
Kartlardan birisinin yakın çekim fotosunu görebilirmiyim?
Manve_13
Hmm ben de oyle dusunuyorum bytemaster, ama iste bakalim koyalim ebaye alan olur belki =)
Bunalmis kart olarak degil de sadece islemciler var sanirsam. Acilmamis bir paketin icinde duruyorlar, acmak da istemedim unpacked satmak icin.
