LCD SAAT DEVRESİNE AYAR MENÜSÜ EKLEMEK
Başlatan erdogan2734, 03 Aralık 2010, 17:31:25
erdogan2734
Arkadaşlar tezimin son son bir bölümü olarak lcd ekranda pic 16f877a da saati ayarlamam gerek ancak bir yerlerde  hata yapıyorum galiba bir türlü saate ayar menüsü yapamadım. aşağıya yazmış olduğum programı koyuyorum pic basicde bu programın üzerine saat ayarı yapabilmem icin bana yardım ederseniz çok sevinirim...
PORTA=255
PORTB=0
TRISB=%00000000
TRISA=%00000000
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT  4
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 3
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT  2
DEFINE LCD_BITS  4
DEFINE LCD_LINES  2
ON INTERRUPT GOTO KESME
OPTION_REG=%10000101
INTCON=%10100000
TMR0=0
CMCON=7
SAYAC VAR BYTE
SN VAR BYTE
DAK VAR BYTE
SAAT VAR BYTE
GUN VAR BYTE
CLEAR
PAUSE 200
LCDOUT $FE,1
LOW PORTB.2
'*****KESME İŞLEMLERİ*****
OPTION_REG=%00000101         '1/64 BÖLME ORANI
INTCON=$A0                   'TMRO VE TÜM KESMELER AKTİF
ON INTERRUPT GOTO KESME      'KESME OLUŞTUĞUNDA BU ADRESE GİT
LCDOUT $FE,$CF,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$CE,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$CD,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$CC,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$CB,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$CA,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C9,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C8,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C7,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C6,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C5,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C4,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C3,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C2,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C1,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C0,"HOS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C0,"OS GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C0,"S GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C0," GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C0,"GELDiNiZ "
PAUSE 200
LCDOUT $FE,$C0,"ELDiNiZ "
PAUSE 200
LCDOUT $FE,$C0,"LDiNiZ "
PAUSE 200
LCDOUT $FE,$C0,"DiNiZ "
PAUSE 200
LCDOUT $FE,$C0,"iNiZ "
PAUSE 200
LCDOUT $FE,$C0,"NiZ "
PAUSE 200
LCDOUT $FE,$C0,"iZ "
PAUSE 200
LCDOUT $FE,$C0,"Z "
PAUSE 200
LCDOUT $FE,$C0," "
PAUSE 200
BASLA:
LCDOUT $FE,$84,DEC2 SAAT,":",DEC2 DAK,":",DEC2 SN
LCDOUT $FE,$40,$0A,$00,$11,$11,$11,$11,$0E,$00  'Ü
LCDOUT $FE,$C2,"AYAR MEN",0,"S",0," "
GOTO BASLA
DISABLE
KESME:
SAYAC=SAYAC+1
IF SAYAC=61 THEN
SAYAC=0
SN=SN+1
IF SN=60 THEN
SN=0
DAK=DAK+1
IF DAK=60 THEN
DAK=0
SAAT=SAAT+1
IF SAAT=24 THEN
SAAT=0
GUN=GUN+1
IF GUN=365 THEN
GUN=0
ENDIF
ENDIF
ENDIF
ENDIF
ENDIF
INTCON.2=0
RESUME
ENABLE
END
Bildiğim tek şey henüz hiç bir şey bilmediğim...
zamzam23
ilgili pini giriş yaparak başlayabilirsin.
erdogan2734
Alıntı yapılan: zamzam23 - 03 Aralık 2010, 17:40:33
ilgili pini giriş yapmakla bitmiyor galiba öyle olsaydı çok tan yapardım...
dombilik
Haliyle ilgili pini giriş yapmakla bitmiyor tabii.
Geriye biraz düşünmek kalıyor....
O giriş pinlerindeki butonlarla saat,dakika ve saniye
değerlerini +1 yada -1 arttırmak yada azaltmak ile
saati ayarlamak..
Örneğin ;
bir buton ile hangisini ayarlayacağını seç.
arttırma ve eksiltme butonları ile değerleri değiştir.
başka bir buton değişkene ata ve ana program döngüne devam et.
Bildiklerini kime miras bıraktın?kimseyemi? O zaman bildiklerinin ne önemi kalır. ******** /////////// ******** PROTON-ASM PROTEUS 7.4 SP3 EAGLE 5.40
neural
Alıntı yapılan: erdogan2734 - 03 Aralık 2010, 17:31:25
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
PAUSE 200
LCDOUT $FE,$C0,"Z "
PAUSE 200
LCDOUT $FE,$C0," "
PAUSE 200
Ayrıca programın bu kısmı program belleği açısından bayağı bir yer kaplar. Aynı işlemi LCD 'nin kaydırma komutlarının kullanarak daha basit yapabilirsiniz. [1] adresinde komutlar ile ilgili bilgi bulunmakta.
[1] http://www.dinceraydin.com/lcd/commands.htm
erdogan2734
arkadaslar dırek sıze donemedım ama cok sagolun menu ekledım tuslar calısıyor yardımlarınız ıcın tesekkur ederım...
solidus
Bunu nasıl yaptığınıda paylaşki diğer arkadaşlar da faydalansın..
