ortalama alma işlemi
Başlatan secretagent, 22 Şubat 2011, 21:30:18
Hattusa
bu şekilde derleyebildim ama isisde lcd ye görüntü gelmiyor ve isisde hata veriyor
Device 16F877A
Xtal 4
Declare Adin_Res 10   ' Sets the number of bits in the result
Declare Adin_Tad 32_Fosc  ' Sets the ADC's clock source
Declare Adin_Stime 10   ' Allows the internal capacitors to fully charge
'-------------------------- LCD connection settings ------------------------
Declare  LCD_Type ALPHA   ' Alphanumeric LCD type
Declare  LCD_DTPin  PORTD.4   ' LCD data port
Declare  LCD_ENPin  PORTD.3   ' E line
Declare  LCD_RSPin  PORTD.2   ' RS line
Declare  LCD_Interface  4   ' 4-line or 8-line interface
Declare  LCD_CommandUs  100   ' Time to wait (in uS) between commands sent to the LCD
Declare  LCD_DataUs  50   ' Time to wait (in microseconds) between data sent to the LCD
Declare  LCD_Lines   4   ' How many lines the LCD has
ADCON1 = %10000010
'-------------------------- Ports settings ---------------------------------
TRISA = %00011111
PORTA = 0
TRISB = %00000000
PORTB = 0
TRISC=  %00000000
PORTC = 0
TRISD = %00000000
PORTD = 0
TRISE = %00000000
PORTE = 0
Symbol fR = PORTE.0
Symbol OrNk1 = PORTE.1
Symbol oRnK2 = PORTE.2
'-------------------BUBBLE SORT DEĞİŞKENLERİ--------------------------
Symbol NuMuNeSaY1 = 10
Symbol nUmUnEsAy2 = 10
Dim gDegIsKeNa As Word
Dim GdEgIsKeNb As Word
Dim nDeX1 As Byte
Dim NdEx2 As Byte
Dim AdCoKu1 As Word
Dim aDcOkU2 As Word
Dim StAmAm1 As Byte
Dim sTaMaM2 As Byte
Dim SaMpLe1[NuMuNeSaY1 + 1] As Word
Dim sAmPlE2[nUmUnEsAy2 + 1] As Word
Dim N1 As Byte
Dim N2 As Byte
Dim X As Byte
AyArT:
GoSub TARAMA
GoSub BUBBLE_SORTA
GoSub BUBBLE_SORTB
Cls
Print At 1,1, Dec SaMpLe1[N1]
Print At 2,1, Dec sAmPlE2[N2]
Print At 3,1, Dec X
DelayMS 10
GoTo AyArT
TARAMA:
X = 1
Repeat
fR = 1
DelayUS 500
fR = 0
DelayUS 200
OrNk1 = 1
DelayUS 5
SaMpLe1[N1] = ADIn 1    '1 adc okuması
DelayUS 5
OrNk1 = 0
DelayUS 50
oRnK2 = 1
DelayUS 5
sAmPlE2[N2] = ADIn 4  '2 adc okuması
DelayUS 5
oRnK2 = 0
DelayUS 8000
Inc N1
Inc N2
Until X = 10
Return
BUBBLE_SORTA:
Repeat
StAmAm1 = 0
nDeX1 = 0
Repeat
If SaMpLe1[nDeX1] > SaMpLe1[nDeX1 + 1] Then
gDegIsKeNa = SaMpLe1[nDeX1]
SaMpLe1[nDeX1] = SaMpLe1[nDeX1 + 1]
SaMpLe1[nDeX1] = gDegIsKeNa
StAmAm1 = 1
EndIf
Inc nDeX1
Until nDeX1 = NuMuNeSaY1
Until gDegIsKeNa = 0
Return
BUBBLE_SORTB:
Repeat
sTaMaM2 = 0
NdEx2 = 0
Repeat
If sAmPlE2[NdEx2] > sAmPlE2[NdEx2 + 1] Then
GdEgIsKeNb = sAmPlE2[NdEx2]
sAmPlE2[NdEx2] = sAmPlE2[NdEx2 + 1]
sAmPlE2[NdEx2] = GdEgIsKeNb
sTaMaM2 = 1
EndIf
Inc NdEx2
Until NdEx2 = nUmUnEsAy2
Until GdEgIsKeNb = 0
Return
Unutulan Geçmiş Yöntemi
saygıdeğer Melih Karakelle nin bana anlattığı bir yöntem
Alıntı YapEvet benzer sebeplerden ben de başlayıp pek çok kez vazgeçtim.
Mikroişlemciye Kalman yaptıracağım diye float değişken hesaplatıp sonra da yeterli ölçüm sıklığına ulaşamadığın için kalmansız durumdan beter olmak var işin ucunda
Benim yöntem çok basit, bilgisayar programcısının can simididir unutulan değişken filtresi, hayat boyu binlerce yerde kullanmışımdır heralde.
Yöntem şöyle;
int X[10]; // bu array değişkenimiz olsun
yeniX = sensör_verisi; // bu da okuduğumuz değer olsun
for (i=0;i<9;i++) // 9 kere döngüyü döndürelim
j = 8 - i; //8 den 0 e doğru geriye saydıralım
X[j+1] = X[j] ; // Her seferinde eski X[j] değerini bir eskisinin yerine taşıyalım
veya aynı for işleminin daha az işlemci yükü gerektireni
X[9] = X[8];
X[8] = X[7];
X[7] = X[6];
X[6] = X[5];
X[5] = X[4];
X[4] = X[3];
X[3] = X[2];
X[2] = X[1];
X[1] = X[0];
Böylece her değişkeni bir alta taşıdık (bunun daha farklı yolu da var ama bu anlatılması en kolayı)
X[0] = yeniX ; // böylece ilk değer son sensör verisi oldu
OrtalamaX = SUM(X) / 10; // tüm X değerlerini toplayıp 10 a bölüyoruz.
ve elimizde en son 10 değerin ortalaması ile elde edilmiş OrtalamaX değeri kalıyor
Yöntem bukadar basit, bu yöntemin en büyük avantajı işlemci yükünün minimum olmasında, yukarıdaki halinden daha fazla optimize etmek de mümkün ve bu hali ile saniyede binlerce kez ölçüm alıp işlemeni mümkün kıldığı için en önemli sorun olan sensör parazitlerini ve titreşimi de gidermek çok kolay oluyor.
Ayrıca sensör çıkışında lowpass filtre kullanırsan bu tip yazılımsal taklaları daha da azaltman mümkün. Ben çıkışlarda 100kOhm direnç ve 100nF kondansatör kullanıyorum, çıkış sinyalini oldukça iyi yumşatıyor (30hz civarında) , eğer daha yavaş ve yumuşak sinyaller istersen 1 megaohm direnç kullan.
Hiçbir yazılımsal filtre gerçek bir kondansatör ve dirençten daha güzel sinyal yumşatamaz, bu yüzden analog sensörler hala dijitallerden daha kullanışlı.
Hattusa
muhiddin hocam verdiğiniz bilgiler için teşekkür ederim.
söylediğiniz tekniği emin olun deneyeceğim. benim sorunum 10 kez okuttuğum ADC değerinde pik atan (amiyane deyim sanırım) adc ölçümlerini hesaplamadan çıkartmak, yani 10 tane ADC okutma sonucum,
(100,101,99,110,108,200,96,250,102,105) işte 10 tanede benim ortalama aldırdığım sonuçtan 2 sini hiç hesaba katmamak, sanırım bu iş söylemek kolay yapmak zor... ;D
pcb
@TR_PRO
bence aritmetik ortalama, filtre vs. ile sinyali düzeltmek yerine, böyle spike ların oluşduğu çıkış ile uğraşmak daha önemli bence.
sonuç değer kısa sürede tepki vermesi gereken başka bir sinyali tetiklemesi gerekiyorsa 10-20 kere ortalama aldırmaktan vazgeçecek ve bozuk sinyal çıkış kaynağına tekrar döneceksiniz.
Toplam zaman kaybı , sample aldığınız noktaların tekrarlama (frekans) süresinin toplamı ile alakalı. Hareket halinde veya 50-60hz parazit yüklü bir sinyalle uğraşıyorsunuz sanırım.
50-60hz parazit elimine edici adc ler var piyasada. incelemenizi tavsiye ederim.
Projeniz hakkında hiç bir fikrim yok ve diğer sayfalardaki yazıları okumadım, benimki sadece bir tavsiye
Hattusa
Alıntı yapılan: pcb - 24 Şubat 2011, 23:03:45
@TR_PRO
ustam bunlarla ilgili örnek bir entegre verebilirmisiniz, çalıştığım frekans 100 hertz ve ben bu 100 hertzlik kare dalga sinyalden her pals bitiminde 2 farklı adc okutuyorum. ve bu işlemi 10 ile 20 kez yapıyorum ortalamasını aldırıyorum. sonuçtan memnun değilim. zira 8 bit ADC de sorun yok, 10 bit ADC biraz artıyor, 12 bit ADC de dahada artacak, belki 24 bite yükseldiğimizde nasıl stabileştireceğim?
pcb
10 bit çok hassas okumalar için yeterli bence daha yüksek çözünürlüklerde okumalar içinden çıkılmaz sonuçlar oluşturabilir.
sözünü ettiğim 50-60hz parazit elimine edici ADC ler 50-60hz de 1 kere okuma yapıyor ve delta-sigma adc olarak bilinir, tabi bu ADC lerin sample alma hızları değiştirilebliyor. sadece 50-60hz de okuma yapma durumu malum sürekli aynı noktayı okuduğundan parazitin değerinide hep aynı görüyor yani o noktadaki değeri.
Max11040 diye bir ADC var muhteşem bir ürün ama pahallı biraz, 1 mikrosaniye aralıklarla 3-4 okuma yapabiliyor bu süre daha uzatılabiliyor. delta sigma özelliği yok ama 1 mikrosaniye aralıklı okumanın birbirine çok yakın olması gerekli buradan çözüme ulaşılabilir.
LTC2480 delta-sigma ADC dir parazit önleyici özelliği var. Tabi siz 100hz frekansınızı 50-60hz e düşürmeniz gerekiyor.
Veya şöyle olabilir, siz çalışma frekansınızı 100hz değilde 120 hz e yükseltirseniz 60hz paraziti engelleyebilirsiniz ama 2 pals da bir okuma yaparak bu sabit değeri koruyabilirsiniz.
Delta sigma adc diye arama yapın onlarca bulacaksınız.
kolay gelsin
Hattusa
Alıntı yapılan: muhittin_kaplan - 24 Şubat 2011, 21:58:07
Yöntem şöyle;
X[9] = X[8];
X[8] = X[7];
X[7] = X[6];
X[6] = X[5];
X[5] = X[4];
X[4] = X[3];
X[3] = X[2];
X[2] = X[1];
X[1] = X[0];
s.a.
Muhiddin hocam "UNUTULAN GEÇMİŞ" işlemini anlayamadım, yani bu teknik ile nasıl bir filtreleme oluyor. yani örnek olarak elimde 10 tane ADC ölçümü var diyelim bunlar;
A0= 200
A1= 500
A2= 210
A3= 190
A4= 205
A5= 450
A6= 195
A7= 202
A8= 212
A9= 300
burda elimdeki değerlerde sorun olduktan sonra A1 ile A0 ın yerinin değişiminin filtreleme işleminde ne gibi bir faydası olacak, bu konuda bilgisi olan arkadaşların önerilerini bekliyorum.
Hattusa
#37
Alıntı Yap
TARAMA:
X = 1
Repeat
fR = 1
DelayUS 500
fR = 0
DelayUS 200
OrNk1 = 1
DelayUS 5
SaMpLe1 = ADIn 1    '1 adc okuması
DelayUS 5
OrNk1 = 0
DelayUS 50
oRnK2 = 1
DelayUS 5
sAmPlE2 = ADIn 4  '2 adc okuması
DelayUS 5
oRnK2 = 0
DelayUS 8000
'ben buraya repeat komutu  oluşturduğum 10 turluk döngüde her turda okuttuğum ADC değerlerini registerlerin içerisine 'kaydedemiyorum.
Until X = 10
Return
'ben buraya repeat komutu  oluşturduğum 10 turluk döngüde her turda okuttuğum ADC değerlerini Sample1[x1],sample1[x2],sample1[x3]........sample1[x10] aynı şekild sample2 değerlerini registerlerin içerisine kaydedemiyorum.
bana bu konuda yardımcı olmanızı bekliyorum.
Hocam Kodla değilde mümkün olduğunca mantığını anlatmaya çalışayım. (kodlar hatalıdır not defterinde yazıyorum)
siz 10 adet kayıtı bir değişkene atmak istiyorsunuz sanırım
dim Okunan_1[10] as byte        ;Değişken Tanımla
dim Okunan_2[10] as byte        ;Değişken Tanımla
dim Loop as byte
Oku:
      for loop=0 to 9
         okunan_1[Loop]=adin 0
         delayms 100
         okunan_2[Loop]=adin 1
         delays 100
      next
Yaparak her kanalın okuduğu 10 değeri, 10 adet derinliğindeki değişkene atarsın..
Hattusa
Alıntı yapılan: muhittin_kaplan - 26 Şubat 2011, 13:22:33
dim Loop as byte
Oku:
      for loop=0 to 9
         delayms 100
         delays 100
      next
peki hocam benim anlamadığım, okunan_1 ve okunan_2  bunlar ADC değerleri ise byte boyundan büyük değil mi? yani 10 bit ADC değerimiz 1023 değerinde.
birde LCD ye bu değerleri basmak istersem mesela adin 0' ın 5. sırada okunan değerini bunu nasıl tanımlamalıyım? yani
print at 1,1,dec okunan_1[5] dediğimde hata veriyor?  ;D
sanırım bu kısmı karıştırdım ya hadi hayırlısı...
pek tabiki hocam 10bit se word olmalı.
Aşağıdaki kodları derliyor.
Basla:
        For Loop=0 To 9
            Okunan_1[Loop]=loop*100
            DelayMS 100
            Print At 1,1,Dec Okunan_1[Loop]
        Next
        GoTo Basla
        Stop
frederic
#41
Merhaba aşağıdaki kodu değiştirip denedim, x değeri 5 olduğunda 251 gibi alakasız bir ortalama veriyor fakat x değerini 0 yapınca ortalama değer olarak 10 değerini veriyor, yani doğru değeri veriyor. X değeri baştan ve sondan bir takım değerleri atmak için tasarlanmış konunun başında anlaşılacağı üzere, 251 değeri gibi alakasız bir değeri neden üretiyor acaba?
#include <18F46K22.h>
#device ADC=10
#FUSES INTRC_IO
#FUSES NOMCLR
#use delay(internal=16000000)
#include <4x20LCD.c>
int d[] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20};
int i, j, g, x = 5, toplam, ort;
void main()
   setup_adc (adc_off);
   setup_adc_ports (no_analogs);
   lcd_init();
    //diziye öylesine 20 deger atıyorum
   //sıralıyorum
   for (i = 0; i < sizeof(d);i++)
      for(j=0; j < sizeof(d);j++)
         if(d[i] > d[j])
            g = d[i];
            d[i] = d[j];
            d[j] = g;
   //başından ve sonundan x değeri kadarını yoksayıp, toplayıp ortalamalarını alıyorum
   for(i = x; i < sizeof(d) - x ; i++)
      toplam += d[i];
   ort = toplam / sizeof(d) - (x * 2);
   lcd_gotoxy(1,1);
    printf(lcd_putc,"value    W=%u       ",ort);
kantirici
Alıntı yapılan: pro-TR - 24 Şubat 2011, 22:12:16
Bu pik değerini neyi referans alıp atacaksın peki. 110 değeri neye göre pik değer sayılmalı ?
aliveli
@RcALTIN dediği radial olypic ve oldukça faydalıdır. alınan ölçümlerden en düşük ve en yüksek değerleri pik kabul edip hesaplamadan çıkarır. aşağıdaki kod c içindir basic için fikir verebilir. basic diline çeviren olursa başkasına da faydalı olacaktır.
//16 kere adcden okuma yapılır, değerler sıralanır, alttaki ve üstteki dört değer çıkarılır,ortadaki 8 değerin ortalaması alınır
unsigned int16 adchlx(void){
 unsigned int8 i;  unsigned int16 accum=0;
 unsigned int16 s, b[16]; int1 didswap=1;
//bu döngü 16 kere okuma yapar ve b[] dizisine yerleştirir
   for ( i = 0 ; i < 16;  i++ ) {
           b[i]= read_adc(ADC_start_and_read); // ADC okunur diziye  atılır
           delay_us(8);
// bubble sort algoritması b[] dizisindeki elemanlar küçükten büyüğe sıralanır.
   while(didswap){
     didswap=0;
     for (i=0; i<15; i++){ // i 0-15
      if(b[(i)]>b[(i+1)]){ // eğer değer sonrakinden büyükse sırayı değiştir
           s=b[i]; // yükseği tut
           b[i]=b[(1+i)];
           b[(1+i)]=s;
           didswap=1; // yer değiştirme işi bitince döngüden çıkartır duruma göre işlemi kısaltabilir
      } // ~if
     } // ~for
    } // ~while
   //elemanları sıralanan  b[] dizisinde ortadaki 8 değerin ortalaması alınır.
   for (i=4; i<12; i++){  accum +=b[i];  }
   return(accum>>3);
burada verilen 16 , 4 değerleri isteğe göre artırılıp azaltılabilir.
Mr.Java
#44
Diziyi sıralama algoritması geliştirilebilir.Hız faktörü hesaplanıp daha stabil programlar yazılabilir.Aşağıdaki kod yol gösterebilir.
#include<stdio.h>
#include<conio.h>
void quick_sort(int arr[20], int, int);
void main()
	int arr[20], n, i;
	clrscr();
	printf("Enter the number of elements in the Array: ");
	scanf("%d", &n);
	printf("\nEnter %d elements:\n\n", n);
	for (i = 0; i < n; i++) {
		printf(" Array[%d] = ", i);
		scanf("%d", &arr[i]);
	quick_sort(arr, 0, n - 1);
	printf("\nThe Sorted Array is:\n\n");
		printf(" %4d", arr[i]);
	getch();
void quick_sort(int arr[20], int low, int high)
	int pivot, j, temp, i;
	if (low < high) {
		pivot = low;
		i = low;
		j = high;
		while (i < j) {
			while ((arr[i] <= arr[pivot])&&(i < high)) {
				i++;
			while (arr[j] > arr[pivot]) {
				j--;
			if (i < j) {
				temp = arr[i];
				arr[i] = arr[j];
				arr[j] = temp;
		temp = arr[pivot];
		arr[pivot] = arr[j];
		arr[j] = temp;
		quick_sort(arr, low, j - 1);
		quick_sort(arr, j + 1, high);
