ccs c 8x48 kayan yazı sorunu...
Başlatan ozhan_ates, 15 Nisan 2011, 20:57:33
ozhan_ates
Merhaba arkadaşlar devreyi çalıştırdığımda "DENEME" yazısının kaymasını istiyorum fakat "ABCDEFGH....Z" yazısı "Z"den sonrada 4-5 satırlık belirsiz bi karakter kayıyor neden olduğunu anlamadım.Yardımcı olursanız sevinirim.İsterseniz devre şemasınıda gönderebilirim
devre şeması
char isim[]="DENEME";
int A[]={0xFC,0xFE,0x1B,0x1B,0xFE,0xFC,0x00};
int B[]={0xFF,0x9B,0x9B,0x9B,0xFF,0x66,0x00};
int C[]={0x7E,0xFF,0xC3,0xC3,0xE7,0x66,0x00};
int D[]={0xFF,0xC3,0xC3,0xC3,0x7E,0x3C,0x00};
int E[]={0xFF,0xFF,0xDB,0xDB,0xC3,0x00};
int F[]={0xFF,0xFF,0x1B,0x1B,0x3,0x00};
int G[]={0x7E,0xFF,0xC3,0xDB,0xFB,0x7A,0x00};
int H[]={0xFF,0xFF,0x18,0x18,0xFF,0xFF,0x00};
int I[]={0xFF,0xFF,0x0};
int J[]={0x60,0xE0,0xC0,0xFF,0x7F,0x00};
int K[]={0xFF,0xFF,0x3C,0x66,0xC3,0x81,0x0};
int L[]={0xFF,0xFF,0xC0,0xC0,0xC0,0x0};
int M[]={0xFF,0xFF,0x1C,0x38,0x1C,0xFF,0xFF,0x0};
int N[]={0xFF,0xFE,0x1C,0x38,0x7F,0xFF,0x0};
int O[]={0x7E,0xFF,0xC3,0xC3,0xFF,0x7E,0x0};
int P[]={0xFF,0xFF,0x1B,0x1B,0x1F,0xE,0x0};
int R[]={0xFF,0xFF,0x3B,0x7B,0xDF,0x8E,0x0};
int S[]={0x6E,0xDF,0xDB,0xDB,0xFB,0x72,0x0};
int T[]={0x3,0x3,0xFF,0xFF,0x3,0x3,0x0};
int U[]={0x7F,0xFF,0xC0,0xC0,0xFF,0x7F,0x0};
int V[]={0x1F,0x3F,0xE0,0xE0,0x3F,0x1F,0x0};
int Y[]={0x7,0xF,0xF8,0xF8,0xF,0x7,0x0};
int Z[]={0xC3,0xE3,0xF3,0xDB,0xCF,0xC7,0x0};
void main()
int i,d;
int b=1;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_ccp1(CCP_OFF);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!!+98
   while(1)
      for(d=0;d<1;d++)
        int a;
        a=b;
           for(i=0;i<48;i++)
             output_low(pin_d4);
             output_low(pin_d5);
             output_d(i);
             output_b(isim[a]);
             delay_us(400);
             a++;
    b++;
frkcn
kodun buna ait olduğuna eminmisin
Bugün ömrümün geride kalan son günü...
ozhan_ates
Evet kodlar doğru zaten kendim yaptım devreyle yazılımı yazıda problem yok ama isim dizisi diğer A;B;C;D ...Z dizilerinide içine alıyo anlamadım onu
hakanmos
