Aşağıdaki kodlar bir kesmemidir ?
Başlatan armsistem, 18 Kasım 2011, 19:53:32
armsistem
** Function name:		UART0_IRQHandler
** Descriptions:		UART0 interrupt handler
** parameters:			None
** Returned value:		None
void UART0_IRQHandler (void)
  uint8_t IIRValue, LSRValue;
  uint8_t Dummy = Dummy;
  IIRValue = LPC_UART0->IIR;
  IIRValue >>= 1;			/* skip pending bit in IIR */
  IIRValue &= 0x07;			/* check bit 1~3, interrupt identification */
  if ( IIRValue == IIR_RLS )		/* Receive Line Status */
	LSRValue = LPC_UART0->LSR;
	if ( LSRValue & (LSR_OE|LSR_PE|LSR_FE|LSR_RXFE|LSR_BI) )
	  /* There are errors or break interrupt */
	  /* Read LSR will clear the interrupt */
	  UART0Status = LSRValue;
	  Dummy = LPC_UART0->RBR;		/* Dummy read on RX to clear
							interrupt, then bail out */
	  return;
	if ( LSRValue & LSR_RDR )	/* Receive Data Ready */
	  /* If no error on RLS, normal ready, save into the data buffer. */
	  /* Note: read RBR will clear the interrupt */
	  UART0Buffer[UART0Count] = LPC_UART0->RBR;
	  UART0Count++;
	  if ( UART0Count == BUFSIZE )
		UART0Count = 0;		/* buffer overflow */
  else if ( IIRValue == IIR_RDA )	/* Receive Data Available */
	UART0Count++;
  else if ( IIRValue == IIR_CTI )	/* Character timeout indicator */
	/* Character Time-out indicator */
	UART0Status |= 0x100;		/* Bit 9 as the CTI error */
  else if ( IIRValue == IIR_THRE )	/* THRE, transmit holding register empty */
	/* THRE interrupt */
	LSRValue = LPC_UART0->LSR;		/* Check status in the LSR to see if
									valid data in U0THR or not */
	if ( LSRValue & LSR_THRE )
	  UART0TxEmpty = 1;
	  UART0TxEmpty = 0;
armsistem
Aşağıdaki gibi mi ?
   LPC_UART0->IER = IER_RBR | IER_THRE | IER_RLS;	/* Enable UART0 interrupt */
