Basic pwm sorunu
Başlatan yildizelektronik, 01 Ocak 2012, 19:32:58
yildizelektronik
Hocam mclr ve dahili osilatör kullandım.
justice_for_all
:1000000000308A0036280000831A0A28A400030E54
:10001000A5000F288312A400030EA500A5140A084A
:10002000AB008A018313A40E0408A6002008A700D1
:100030002108A8002208A9002308AA0083128B1E09
:1000400023280B19C528260884002708A0002808A3
:10005000A1002908A2002A08A3002B088A00250E67
:1000600083008312240EA51883160900FF2383162C
:10007000900000308A00EB283008BA002F08B90041
:100080002E08B8002D08B7004130BE00C630BD00B4
:100090004E30BC006D30BB002030C300BF01C0013A
:1000A000C101C2013A08A3003908A2003808A10022
:1000B0003708A0000310201C6B283B08BF073C0832
:1000C00003183C0FC0073D0803183D0FC1073E0849
:1000D00003183E0FC207C20CC10CC00CBF0CA30C0E
:1000E000A20CA10CA00CC30B5A2839302007AD007C
:1000F0002108AE00303003183130AE072208AF00BF
:10010000003003180130AF072308B0000030031897
:100110000130B0072F08A0003008A100A201A30100
:100120002108B9002008B8003908BB003808BA0017
:100130007F30BD00FF30BC00A101A201A001A301DE
:100140003D08031DA6283C080319C0281030BE0036
:100150000310BA0DBB0DA00DA30D3D082302031D16
:10016000B3283C082002031CBC283C08A002031C46
:10017000A3033D08A3020314A10DA20DBE0BA828E2
:100180002008A1002308A2000800B508031DE528E7
:10019000FF30B5008316851283128516831605116C
:1001A000831205158316051283120516B10A31084C
:1001B000C73C0318E5283C202108B2003C20210858
:1001C000B3003C202108B400B101C8308100B50360
:1001D0000B118A11232884011F308305B10164307B
:1001E000B200B300B400B5011F1383161F109F1097
:1001F0001F119F11073083129900AC01831601086B
:10020000C73908388100831290010730990083169E
:100210000508850003308312A000A00B0D291908E2
:100220008C11831699010030850083128B16C03023
:100230008B04E630810032083502031D2329831622
:1002400085128312851233083502031D2B2983166C
:1002500005128312051234083502031D3329831653
:0A0260000511831205111B2963002C
:02400E00B401FB
:00000001FF
;PIC12F675
;CRC=73D8  CREATED="05-Oca-12 23:59"
sunu bir denermisiniz hocam sizin istediginiz pinlerden 3 pwm uretmesi gerek notepad farkli kaydet diyip dosyaadi.hex olarak kaydedin
yildizelektronik
Tamam hocam deniyorum şimdi cevabı yazarım birazdan.
justice_for_all
Alıntı yapılan: yildizelektronik - 06 Ocak 2012, 00:04:43
hocam devre su sekilde calismasi gerek belli bir surede random duty degerleri alip pwm uretiyo umarim calisir.
Merhabalar.
Burada kopyala yapıştır olarak verdiğiniz hex kodlarını kopyalayıp işlemciye yüklenecek haline yani .hex uzantılı dosyaya nasıl çeviriyorsunuz.
yildizelektronik
Hocam gönderdiğiniz program çalışıyor 3 kanalda da sorun yok. Ben sizin dediğiniz gibi o mantıkla yazayim kodları.
justice_for_all
Alıntı yapılan: Mucit23 - 06 Ocak 2012, 00:11:01
Merhabalar.
bos metin belgesi acilir kodlar icine yapistirilir sonra farkli kaydet diyip dosya adini yazarken uzanti yazan kismi all files yapiyoruz sonra dosya adi main olsun mesela main.hex yazarak kaydediyoruz..
Anladım Teşekkür ederim..
ibrahimdg
Alıntı yapılan: Mucit23 - 01 Ocak 2012, 23:25:51
Hocam PWM komutu birden fazla çıkışkullanılacaksa devrenin çalışmasını engeller. Sadece tek çıkış için kullanılabilir. Birden fazla pwm çıkışı için mutlaka kesme kullanmanız gerekiyor. Daha önce ben RGB ledlerle bir gece lambası benzeri birşey yapmıştım. 12F675 ile 3 adet pwm çıkışı alarak RGB ledde renk kontrolü yaptım. Bayağıda iyi olmuştu. Ete hocada buna benzer bir uygulama yapmıştı(Ben biraz ondan esinlendim :)) Kodlar iyileştirilebilir elbet. Ne zaman yaptığımı hatırlamıyorum :D Ama çalışıyor.
@ DEVICE pic12F675                      'işlemci 12F675
@ DEVICE pic12F675, WDT_ON              'Watch Dog timer açık
@ DEVICE pic12F675, PWRT_ON             'Power on timer açık
@ DEVICE pic12F675, PROTECT_OFF         'Kod Protek kapalı
@ DEVICE pic12F675, MCLR_off            'MCLR pini kullanılMIYOR.
@ DEVICE pic12F675, INTRC_OSC_NOCLKOUT  'Dahili osilatör kullanılacak
DEFINE OSCCAL_1K 1
DEFINE OSC 4
CMCON = 7
ANSEL=0
OPTION_REG=%10001000 'Pull up dirençleri İPTAL- Bölme oranı 1/1
INTCON=%10100000 'Kesmeler aktif ve TMR0 kesmesi aktif
TRISIO=%00000100
ON INTERRUPT GOTO KESME
GPIO=0
SYMBOL RED=GPIO.0
SYMBOL GREEN=GPIO.1
SYMBOL BLUE=GPIO.4
SYMBOL TUS=GPIO.2
X     VAR WORD
Z     VAR BIT
W     VAR BYTE
I     VAR BYTE
R     VAR BYTE
G     VAR BYTE
B     VAR BYTE
HR    VAR BYTE
LR    VAR BYTE
HG    VAR BYTE
LG    VAR BYTE
HB    VAR BYTE
LB    VAR BYTE
BASLAGIC:
r=1:g=1:b=1
hr=r:hg=g:hb=b
lr=100-hr
lg=100-hg
lb=100-hb
Z=0
BASLA:
GOSUB GOKKUSAGI
GOSUB BEYAZ
GOSUB RASTGELE
GOTO BASLA
'------------GOKKUŞAĞI-----------------------
GOKKUSAGI:
Z=1
FOR R=1 TO 99   'KIRMIZI ARTTIR
GOSUB DELAY
NEXT
Z=0:R=99
GOSUB BEKLE  'BEKLE
Z=1
FOR G=1 TO 99 'YESIL ARTTIR
GOSUB DELAY
NEXT
Z=0:G=99
GOSUB BEKLE 'BEKLE
Z=1
FOR R=99 TO 1 STEP-1  'KIRMIZI AZALT
GOSUB DELAY
NEXT
Z=0:R=1
GOSUB BEKLE 'BEKLE
Z=1
FOR B=1 TO 99   'MAVİ ARTTIR.
GOSUB DELAY
NEXT
Z=0:B=99
GOSUB BEKLE 'BEKLE
Z=1
FOR G=99 TO 1 STEP-1   'YESIL AZALT
GOSUB DELAY
NEXT
Z=0:G=1
GOSUB BEKLE  'BEKLE
Z=1
FOR B=99 TO 1 STEP-1   'MAVİ AZALT
GOSUB DELAY
NEXT
Z=0:B=1:R=1:G=1
GOSUB BEKLE
RETURN
BEYAZ:
FOR W=0 TO 1
  Z=1
    GOSUB DELAY
  NEXT
  R=99
    GOSUB DELAY
  NEXT
  G=99
  FOR B=1 TO 99   'MAVI ARTTIR
    GOSUB DELAY
  NEXT
  Z=0:B=99
  GOSUB BEKLE
  Z=1
    GOSUB DELAY
  NEXT
  Z=0:R=1
  GOSUB BEKLE1
  Z=1
  FOR B=99 TO 1 STEP-1  'KIRMIZI AZALT
    GOSUB DELAY
  NEXT
  Z=0:B=1
  GOSUB BEKLE1
  Z=1
  FOR G=99 TO 1 STEP-1  'KIRMIZI AZALT
    GOSUB DELAY
  NEXT
  Z=0:G=1
  GOSUB BEKLE
NEXT W
RETURN
RASTGELE:Z=1
R=99:Z=0:GOSUB BEKLE1:Z=1
DEVAM:
FOR W=1 TO 2
G=99:Z=0:GOSUB BEKLE1:Z=1
R=1:Z=0:GOSUB BEKLE1:Z=1
B=99:Z=0:GOSUB BEKLE1:Z=1
G=1:Z=0:GOSUB BEKLE1:Z=1
B=1:Z=0:GOSUB BEKLE1:Z=1
NEXT W
RETURN
BEKLE:     'GECIKME
IF X<20000 THEN BEKLE
RETURN
BEKLE1:
IF X<10000 THEN BEKLE1
RETURN
DELAY:
      FOR I=0 TO 255:NEXT
      FOR I=0 TO 255:NEXT
      FOR I=0 TO 255:NEXT
      FOR I=0 TO 255:NEXT
      FOR I=0 TO 255:NEXT
RETURN
DELAY1:
      FOR I=0 TO 255:NEXT
      FOR I=0 TO 255:NEXT
RETURN
DISABLE
KESME:
IF red=1 THEN
hR=hR-1
  IF hR=0 then
    RED=1-RED:hR=R
  endif
ELSE
lR=lR-1
  IF lR=0 THEN
    red=1-red:lr=100-hr
  ENDIF
ENDIF
IF green=1 THEN
hg=hg-1
  IF hg=0 then
    green=1-GREEN:HG=G
  ENDIF
ELSE
lg=lg-1
  IF lg=0 THEN
    green=1-green:lg=100-hg
  ENDIF
ENDIF
IF blue=1 THEN
hb=hb-1
  IF hb=0 then
    blue=1-blue:hb=B
  ENDIF
ELSE
lb=lb-1
  IF lb=0 THEN
    blue=1-blue:lb=100-hb
  ENDIF
ENDIF
X=X+1
IF Z=1 THEN X=0
TMR0=254
INTCON.2=0
RESUME
ENABLE
END
Arkadaşlar merhaba, Led lerin parlaklığını bir türlü düşüremedim. R0 dan başlatamadım. Yardım edebilirseniz sevinirim.
