mcb1700 lpc1768 RTC&TFT uygulaması
Başlatan haydarpasamikro, 03 Ocak 2012, 20:17:32
haydarpasamikro
main.c
#include "lpc17xx.h"
#include "type.h"
#include "rtc.h"
#include "GLCD.h"
#include <stdio.h>
#define __FI        1                       /* Font index 16x24               */
extern volatile uint32_t alarm_on;
RTCTime local_time, alarm_time, current_time;
char text[10];
**   Main Function  main()
int main (void)
	uint8_t 	*wofday[] = {"Pazartesi","Sali","Carsamba","Persembe","Cuma","Cumartesi","Pazar"};
  /* SystemClockUpdate() updates the SystemFrequency variable */
  //SystemClockUpdate();
  /* Initialize RTC module */
  RTCInit();
  local_time.RTC_Sec = 5;
  local_time.RTC_Min = 23;
  local_time.RTC_Hour = 18;		/* current time 18:23:05 */
  local_time.RTC_Mday = 3;
  local_time.RTC_Wday = 1;
  local_time.RTC_Yday = 3;		/* current date 03/01/2012 */
  local_time.RTC_Mon = 1;
  local_time.RTC_Year = 2012;
  RTCSetTime( local_time );		/* Set local time */
//  alarm_time.RTC_Sec = 0;
//  alarm_time.RTC_Min = 0;
//  alarm_time.RTC_Hour = 0;
//  alarm_time.RTC_Mday = 5;
//  alarm_time.RTC_Wday = 1;
//  alarm_time.RTC_Yday = 5;		/* alarm date 01/01/2007 */
//  alarm_time.RTC_Mon = 1;
//  alarm_time.RTC_Year = 2012;
//  RTCSetAlarm( alarm_time );		/* set alarm time */
  NVIC_EnableIRQ(RTC_IRQn);
  /* mask off alarm mask, turn on IMYEAR in the counter increment interrupt
  register */
  //RTCSetAlarmMask(AMRMIN|AMRHOUR|AMRDOM|AMRDOW|AMRDOY|AMRMON|AMRYEAR);
  LPC_RTC->CIIR = IMSEC;
  RTCStart();
  LPC_GPIO1 -> FIODIR |= (1<<28);
  LPC_GPIO1 -> FIOCLR |= (1<<28);
  GLCD_Init();                               /* Initialize graphical LCD      */
  GLCD_Clear(White);                         /* Clear graphical LCD display   */
  GLCD_SetBackColor(Blue);
  GLCD_SetTextColor(White);
  GLCD_DisplayString(0, 0, __FI, "     HAYDARPASA     ");
  GLCD_DisplayString(1, 0, __FI, " TEKNiK Ve ENDUSTRi ");
  GLCD_DisplayString(2, 0, __FI, "  MESLEK ELEKTRONiK ");
  GLCD_SetBackColor(White);
  GLCD_SetTextColor(Blue);
  GLCD_DisplayString(4, 0, __FI, "Zaman:");
  GLCD_DisplayString(5, 0, __FI, "Tarih:");
  GLCD_DisplayString(6, 0, __FI, "H/gun:");
  GLCD_DisplayString(7, 0, __FI, "Y/gun:");
  GLCD_DisplayString(8, 0, __FI, "Gun  :");
  GLCD_SetTextColor(Red);
  while (1)
  {					/* Loop forever */
	if ( alarm_on != 0 ) /* Get current time when alarm is on */
		current_time = RTCGetTime();
		sprintf(text, "%02d", current_time.RTC_Hour);       /* format text for print out     */
		GLCD_DisplayString(4,6, __FI,  (unsigned char *)text);
		sprintf(text, ":%02d", current_time.RTC_Min);       /* format text for print out     */
		GLCD_DisplayString(4,8, __FI,  (unsigned char *)text);
		sprintf(text, ":%02d", current_time.RTC_Sec);       /* format text for print out     */
      	GLCD_DisplayString(4,11, __FI,  (unsigned char *)text);
		sprintf(text, "%02d", current_time.RTC_Mday);       /* format text for print out     */
		GLCD_DisplayString(5,6, __FI,  (unsigned char *)text);
		sprintf(text, ":%02d", current_time.RTC_Mon);       /* format text for print out     */
		GLCD_DisplayString(5,8, __FI,  (unsigned char *)text);
		sprintf(text, ":%02d", current_time.RTC_Year);       /* format text for print out     */
      	GLCD_DisplayString(5,11, __FI,  (unsigned char *)text);
		sprintf(text, "%02d", current_time.RTC_Wday+1);       /* format text for print out     */
		GLCD_DisplayString(6,6, __FI,  (unsigned char *)text);
		sprintf(text, "%02d", current_time.RTC_Yday);       /* format text for print out     */
      	GLCD_DisplayString(7,6, __FI,  (unsigned char *)text);
		GLCD_DisplayString(8,6, __FI,  wofday[current_time.RTC_Wday]);
	  alarm_on = 0;
	  LPC_GPIO1 -> FIOPIN ^= (1<<28);
**                            End Of File
Mikro Dünyası.Haydarpaşa Teknik ve Endüstri Meslek Lisesi Mikrodenetleyici Atl. Şefi
Okan AKÇA
driver dosyalarını paylaşsanız daha faydalı olurdu hocam ellerinize saglık
haydarpasamikro
GLCD için Keil mdk ile gelen kütüphaneler kullanılmıştır.(C:\Keil_ARM\ARM\Boards\Keil\MCB1700\Blinky içerisindeki)
RTC için NXP keil code bunddles kütüphaneleri kullanılmıştır.(nxp sitesindeki mcb1700.code.bundle.lpc17xx.keil.zip)
rtc.c
 *   $Id:: rtc.c 5743 2010-11-30 23:18:58Z usb00423                         $
 *   Project: NXP LPC17xx RTC example
 *   Description:
 *     This file contains RTC code example which include RTC initialization,
 *     RTC interrupt handler, and APIs for RTC access.
 * Software that is described herein is for illustrative purposes only
 * which provides customers with programming information regarding the
 * products. This software is supplied "AS IS" without any warranties.
 * NXP Semiconductors assumes no responsibility or liability for the
 * use of the software, conveys no license or title under any patent,
 * copyright, or mask work right to the product. NXP Semiconductors
 * reserves the right to make changes in the software without
 * notification. NXP Semiconductors also make no representation or
 * warranty that such application will be suitable for the specified
 * use without further testing or modification.
#include "type.h"
#include "rtc.h"
volatile uint32_t alarm_on = 0;
** Function name:		RTC_IRQHandler
** Descriptions:		RTC interrupt handler, it executes based on the
**						the alarm setting
** parameters:			None
** Returned value:		None
void RTC_IRQHandler (void)
  LPC_RTC->ILR |= ILR_RTCCIF;		/* clear interrupt flag */
  alarm_on = 1;
  return;
** Function name:		RTCInit
** Descriptions:		Initialize RTC timer
** parameters:			None
void RTCInit( void )
  alarm_on = 0;
  /* Enable CLOCK into RTC */
  LPC_SC->PCONP |= (1 << 9);
  /* If RTC is stopped, clear STOP bit. */
  if ( LPC_RTC->RTC_AUX & (0x1<<4) )
	LPC_RTC->RTC_AUX |= (0x1<<4);
  /*--- Initialize registers ---*/
  LPC_RTC->AMR = 0;
  LPC_RTC->CIIR = 0;
  LPC_RTC->CCR = 0;
  return;
** Function name:		RTCStart
** Descriptions:		Start RTC timer
** parameters:			None
void RTCStart( void )
  /*--- Start RTC counters ---*/
  LPC_RTC->CCR |= CCR_CLKEN;
  LPC_RTC->ILR = ILR_RTCCIF;
  return;
** Function name:		RTCStop
** Descriptions:		Stop RTC timer
** parameters:			None
void RTCStop( void )
  /*--- Stop RTC counters ---*/
  LPC_RTC->CCR &= ~CCR_CLKEN;
  return;
** Function name:		RTC_CTCReset
** Descriptions:		Reset RTC clock tick counter
** parameters:			None
void RTC_CTCReset( void )
  /*--- Reset CTC ---*/
  LPC_RTC->CCR |= CCR_CTCRST;
  return;
** Function name:		RTCSetTime
** Descriptions:		Setup RTC timer value
** parameters:			None
void RTCSetTime( RTCTime Time )
  LPC_RTC->SEC = Time.RTC_Sec;
  LPC_RTC->MIN = Time.RTC_Min;
  LPC_RTC->HOUR = Time.RTC_Hour;
  LPC_RTC->DOM = Time.RTC_Mday;
  LPC_RTC->DOW = Time.RTC_Wday;
  LPC_RTC->DOY = Time.RTC_Yday;
  LPC_RTC->MONTH = Time.RTC_Mon;
  LPC_RTC->YEAR = Time.RTC_Year;
  return;
** Function name:		RTCSetAlarm
** parameters:			None
void RTCSetAlarm( RTCTime Alarm )
  LPC_RTC->ALSEC = Alarm.RTC_Sec;
  LPC_RTC->ALMIN = Alarm.RTC_Min;
  LPC_RTC->ALHOUR = Alarm.RTC_Hour;
  LPC_RTC->ALDOM = Alarm.RTC_Mday;
  LPC_RTC->ALDOW = Alarm.RTC_Wday;
  LPC_RTC->ALDOY = Alarm.RTC_Yday;
  LPC_RTC->ALMON = Alarm.RTC_Mon;
  LPC_RTC->ALYEAR = Alarm.RTC_Year;
  return;
** Function name:		RTCGetTime
** Descriptions:		Get RTC timer value
** parameters:			None
** Returned value:		The data structure of the RTC time table
RTCTime RTCGetTime( void )
  RTCTime LocalTime;
  LocalTime.RTC_Sec = LPC_RTC->SEC;
  LocalTime.RTC_Min = LPC_RTC->MIN;
  LocalTime.RTC_Hour = LPC_RTC->HOUR;
  LocalTime.RTC_Mday = LPC_RTC->DOM;
  LocalTime.RTC_Wday = LPC_RTC->DOW;
  LocalTime.RTC_Yday = LPC_RTC->DOY;
  LocalTime.RTC_Mon = LPC_RTC->MONTH;
  LocalTime.RTC_Year = LPC_RTC->YEAR;
  return ( LocalTime );
** Function name:		RTCSetAlarmMask
** Descriptions:		Set RTC timer alarm mask
** parameters:			Alarm mask setting
void RTCSetAlarmMask( uint32_t AlarmMask )
  /*--- Set alarm mask ---*/
  LPC_RTC->AMR = AlarmMask;
  return;
**                            End Of File
rtc.h
 *   $Id:: rtc.h 5743 2010-11-30 23:18:58Z usb00423                         $
 *   Description:
 *     This file contains RTC code header definition.
#ifndef __RTC_H
#define __RTC_H
typedef struct {
    uint32_t RTC_Sec;     /* Second value - [0,59] */
    uint32_t RTC_Min;     /* Minute value - [0,59] */
    uint32_t RTC_Hour;    /* Hour value - [0,23] */
    uint32_t RTC_Mday;    /* Day of the month value - [1,31] */
    uint32_t RTC_Mon;     /* Month value - [1,12] */
    uint32_t RTC_Year;    /* Year value - [0,4095] */
    uint32_t RTC_Wday;    /* Day of week value - [0,6] */
    uint32_t RTC_Yday;    /* Day of year value - [1,365] */
} RTCTime;
#define IMSEC		0x00000001
#define IMMIN		0x00000002
#define IMHOUR		0x00000004
#define IMDOM		0x00000008
#define IMDOW		0x00000010
#define IMDOY		0x00000020
#define IMMON		0x00000040
#define IMYEAR		0x00000080
#define AMRSEC		0x00000001  /* Alarm mask for Seconds */
#define AMRMIN		0x00000002  /* Alarm mask for Minutes */
#define AMRHOUR		0x00000004  /* Alarm mask for Hours */
#define AMRDOM		0x00000008  /* Alarm mask for Day of Month */
#define AMRDOW		0x00000010  /* Alarm mask for Day of Week */
#define AMRDOY		0x00000020  /* Alarm mask for Day of Year */
#define AMRMON		0x00000040  /* Alarm mask for Month */
#define AMRYEAR		0x00000080  /* Alarm mask for Year */
#define PREINT_RTC	0x000001C8  /* Prescaler value, integer portion,
				    PCLK = 15Mhz */
#define PREFRAC_RTC	0x000061C0  /* Prescaler value, fraction portion,
				    PCLK = 15Mhz */
#define ILR_RTCCIF	0x01
#define ILR_RTCALF	0x02
#define CCR_CLKEN	0x01
#define CCR_CTCRST	0x02
#define CCR_CLKSRC	0x10
extern void RTC_IRQHandler (void);
extern void RTCInit( void );
extern void RTCStart( void );
extern void RTCStop( void );
extern void RTC_CTCReset( void );
extern void RTCSetTime( RTCTime );
extern RTCTime RTCGetTime( void );
extern void RTCSetAlarm( RTCTime );
extern void RTCSetAlarmMask( uint32_t AlarmMask );
#endif /* end __RTC_H */
**                            End Of File
