step motor lütfen yardım edin
Başlatan smail, 30 Ocak 2012, 19:21:29
smail
arkadaşlar bu kodlara ek olarak step motorun hep ileri veya hep geri dönmesi fonksiyonunu eklemem gerekiyor. ve hep ileri ve geri dönerken aynı zamanda hızını artırıp azaltmam gerekiyor.. teşekkür ederim...
'STEP MOTOR KONTROL DEVRESİ PROGRAMI
DEFINE OSC 4 ;4MHZ OSİLATÖR KULLANILACAK
TRISB=0      ;B PORTUNUN TÜM PİNLERİ ÇIKIŞ YAPILDI
TRISC=255    ;C PORTUNUN TÜM PİNLERİ GİRİŞ YAPILDI
TRISD=0      ;D PORTUNUN TÜM PİNLERİ ÇIKIŞ YAPILDI
@ DEVICE pic16F877A
@ DEVICE pic16F877A, PWRT_ON
@ DEVICE pic16F877A, WDT_OFF
@ DEVICE pic16F877A, PROTECT_OFF  ;kod koruması yok
@ DEVICE pic16F877A, XT_OSC       ;KRİSTAL OSİLATÖR KULLANILACAK
DEFINE LCD_DREG PORTD 'LCD data port
DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
DEFINE LCD_RSREG PORTD 'LCD register select port
DEFINE LCD_RSBIT 1 'LCD register select bit
DEFINE LCD_EREG PORTD 'LCD enable port
DEFINE LCD_EBIT 0 'LCD enable bit
DEFINE LCD_RWREG PORTD 'LCD read/write port
DEFINE LCD_RWBIT 2 'LCD read/write bit
DEFINE LCD_BITS 4 'LCD bus size 4 or 8
DEFINE LCD_LINES 2 'Number lines on LCD
DEFINE LCD_COMMANDUS 2000 'Command delay time in us
DEFINE LCD_DATAUS 50 'Data delay time in us
LCDOUT $FE,$40,4,14,21,4,4,4,4,0 ;YUKARI OK İŞARETİ SIFIRINCI ADRES
LCDOUT $FE,$48,4,4,4,4,21,14,4,0 ;AŞAĞI OK İŞARETİ BİRİNCİ ADRES
LCDOUT $FE,$50,0,4,8,31,8,4,0,0  ;SOL OK İŞARETİ  İKİNCİ ADRES
LCDOUT $FE,$58,0,4,2,31,2,4,0,0  ;SAG OK İŞARETİ ÜÇÜNCÜ ADRES
YUKARI VAR PORTC.0
ASAGI  VAR PORTC.1
OK     VAR PORTC.2
SAG    VAR PORTC.3
SOL    VAR PORTC.4
ADIM   VAR BYTE
HIZ    VAR BYTE
SAYI   VAR BYTE
X      VAR BYTE
Y      VAR BYTE
SURE   VAR WORD
M      VAR BYTE [2]
K      VAR BYTE [4]
LCDOUT $FE,1  ;LCD TEMİZLENİYOR
PAUSE 200
M[0]=0
M[1]=0
K[0]="A"
K[1]="G"
K[2]="O"
K[3]="L"
ADIM=1
HIZ=1
Y=0
SAYI=1
PORTB=0 ;MOTOR DATA PİNLERİNE SIFIR GÖNDERİLİYOR
ACILIS:
LCDOUT $FE,$83,"STEP MOTOR"
LCDOUT $FE,$C4,"KONTROL"
PAUSE 2000
LCDOUT $FE,1
LCDOUT $FE,$80,".....SiSTEM....."
LCDOUT $FE,$C0,"...YUKLENiYOR..."
PAUSE 1000
;MOTOR BU İKİ FOR DÖNGÜSÜ İLE RASTGELE SAĞA VE SOLA
;HAREKET ETTİRİLEREK SIFIR AYARI YAPILIR
FOR X=0 TO 16
PORTB=SAYI
PAUSE 5
SAYI=SAYI*2
IF SAYI>8 THEN SAYI=1
NEXT X
FOR X=0 TO 16
IF SAYI=1 THEN
SAYI=8
ELSE
SAYI=SAYI/2
ENDIF
PORTB=SAYI
PAUSE 5
NEXT X
WRITE 0,SAYI ;MOTORUN SON KALDIĞI KONUMUN ADRESİ HAFIZAYA KAYDEDİLİYOR
GOTO MENU1
MENU1:
LCDOUT $FE,$80,2
LCDOUT $FE,$82,"ADIM  SAYISI"
LCDOUT $FE,$8F,3
LCDOUT $FE,$C0,0
LCDOUT $FE,$C7,DEC3 ADIM
LCDOUT $FE,$CF,1
PAUSE 10
IF YUKARI=0 THEN  ;ADIM SAYISI ARTTIRILIR
ADIM=ADIM+1
IF ADIM>200 THEN
GOSUB UYARI1
ADIM=1
ENDIF
PAUSE 300 ;BUTONDAN ELİNİ ÇEKME SÜRESİ KADAR BEKLENİLİR
ENDIF
IF ASAGI=0 THEN ;ADIM SAYISI AZALTILIR
ADIM=ADIM-1
IF ADIM=0 THEN
GOSUB UYARI2
ADIM=200
ENDIF
ENDIF
IF SAG=0 THEN ;HIZ MENÜSÜNE GEÇİŞ YAPILIR
LCDOUT $FE,1
GOTO MENU2
ENDIF
IF SOL=0 THEN  ;YÖN MENÜSÜNE GEÇİŞ YAPILIR
LCDOUT $FE,1
GOTO MENU3
ENDIF
IF OK=0 THEN GOSUB ISLE ;GİRİLEN İŞLEMİN MOTORA UYGULANACAK MENUYE GİDİLİR
GOTO MENU1
MENU2:
LCDOUT $FE,$80,2
LCDOUT $FE,$83,"HIZ  AYARI"
LCDOUT $FE,$8F,3
LCDOUT $FE,$C0,0
LCDOUT $FE,$C6,DEC3 HIZ
LCDOUT $FE,$CF,1
PAUSE 10
IF YUKARI=0 THEN
HIZ=HIZ+1
IF HIZ>200 THEN
GOSUB UYARI3
HIZ=1
ENDIF
ENDIF
IF ASAGI=0 THEN
HIZ=HIZ-1
IF HIZ=0 THEN
GOSUB UYARI4
HIZ=200
ENDIF
ENDIF
IF SOL=0 THEN
LCDOUT $FE,1
GOTO MENU1
ENDIF
IF SAG=0 THEN
LCDOUT $FE,1
GOTO MENU3
ENDIF
GOTO MENU2
MENU3:
LCDOUT $FE,$80,2
LCDOUT $FE,$83,"YON  AYARI"
LCDOUT $FE,$8F,3
LCDOUT $FE,$C0,0
LCDOUT $FE,$C6,"S",K[Y],K[Y+1]
LCDOUT $FE,$CF,1
PAUSE 10
IF YUKARI=0 THEN
Y=2 ;YÖN SEÇİMİNİN SOL OLARAK AYARLANMASI
ENDIF
IF ASAGI=0 THEN
Y=0 ;YÖN SEÇİMİNİN SAĞ OLARAK AYARLANMASI
ENDIF
IF SOL=0 THEN
LCDOUT $FE,1
GOTO MENU2
ENDIF
IF SAG=0 THEN
LCDOUT $FE,1
GOTO MENU1
ENDIF
GOTO MENU3
CALIS:
SURE=1000/HIZ
READ 0,SAYI
M[1]=M[0]
M[0]=Y
IF M[0]=M[1] THEN
ADIM=ADIM-1
ELSE
ENDIF
IF Y=2 THEN
FOR X=0 TO ADIM
PORTB=SAYI
PAUSE SURE
SAYI=SAYI*2
NEXT X
ENDIF
IF Y=0 THEN
FOR X=0 TO ADIM
IF SAYI=1 THEN
SAYI=8
ELSE
SAYI=SAYI/2
ENDIF
PORTB=SAYI
PAUSE SURE
NEXT X
ENDIF
WRITE 0,SAYI
IF M[0]=M[1] THEN ADIM=ADIM+1
PORTB=0
RETURN
TRISB = %0000
sol:
       PORTB = %0001
       PAUSE 1
       PAUSE = %0011
       PAUSE 1
       PORTB = %0010
       PAUSE 1
       PORTB = %0110
       PAUSE 1
       PORTB = %0100
       PAUSE 1
       PORTB = %1100
       PAUSE 1
       PORTB = %1000
       PAUSE 1
       PORTB = %1001
       PAUSE 1
       GOTO sol
       PORTB = %0000
       RETURN
TRISB = %0000
sag:
       PORTB = %1000
       PAUSE 1
       PORTB = %1100
       PAUSE 1
       PORTB = %0100
       PAUSE 1
       PORTB = %0110
       PAUSE 1
       PORTB = %0010
       PAUSE 1
       PORTB = %0011
       PAUSE 1
       PORTB = %0001
       PAUSE 1
       PORTB = %1001
       PAUSE 1
       GOTO sag
       PORTB = %0000
       RETURN
ISLE:
LCDOUT $FE,1
PAUSE 1000
GOSUB CALIS
LCDOUT $FE,1
RETURN
UYARI1:
LCDOUT $FE,1
LCDOUT $FE,$82,"MAKSiMUM 200"
LCDOUT $FE,$C6,"ADIM"
PAUSE 2000
LCDOUT $FE,1
RETURN
UYARI2:
LCDOUT $FE,1
LCDOUT $FE,$83,"MiNiMUM 1"
PAUSE 2000
LCDOUT $FE,1
RETURN
UYARI3:
LCDOUT $FE,1
LCDOUT $FE,$82,"MAKSiMUM HIZ"
LCDOUT $FE,$C1,"200 ADIM/SANiYE"
PAUSE 2000
LCDOUT $FE,1
RETURN
UYARI4:
LCDOUT $FE,1
LCDOUT $FE,$82,"MiNiMUM HIZ"
LCDOUT $FE,$C2,"1 ADIM/SANiYE"
PAUSE 2000
LCDOUT $FE,1
RETURN
fryrmnd
sağa sola döndürdüğün kodları sonsuz döngü içinde kullanırsan motor hep sağa ve hep sola döner.  faz sinyalleri arasındaki beklemeleri (pause) kısaltırsan  hızlanır uzatırsan yavaşlar.
