C0G standartını sağlayan kondansatörlere ihtiyacım var ?
Başlatan Seckin ALAN, 17 Şubat 2012, 10:06:41
Seckin ALAN
Alıntı YapQ: What does X7R and C0G mean?
A: The capacitance of all ceramic capacitors changes with temperature, voltage, frequency and over time. The marking specifies what performance you can expect.
C0G (sometimes marked as NP0) caps are very stable and are manufactured in sizes up to 10nF, while X7R caps are less stable, and manufactured in sizes up to 1uF. A third common type is Z5U, which is very low grade (though cheap), and suitable only for decoupling. There are many other types available, so if you come across one, just ask on the list if they are usable.
You can replace X7Rs with C0G caps, since C0G are of higher quality, but you should avoid any other substitutes unless you know for sure that you are getting a higer-quality part.
arkadaşlar C0G, standartını sağlayan kondansatörlere ihtiyacım var. Türkiyede bu standartta kondansatörleri nereden temin edebilirim.
ferdem
Bulunmaz ürünler değil, dorukan store da özelliklerde NPO dielektrik belirtilen kapasiteler var. Kolay gelsin.
