ccsc ile yzılmış pıc'li voltmetre yardım.
Başlatan xman, 27 Haziran 2012, 18:34:27
xman
mrb kodu derlerken sıkıntı yok simulasyonda çalışmıyor ama  sorun kodda yardım.
https://rapidshare.com/files/136120794/voltmetre.rar
#include <16F676.h>
#device adc=10
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
#use delay (clock=4000000) // 4MHz clock
#rom  0x3ff={0x3444}
#byte PORTA = 0x05
#byte PORTC = 0x07
#byte TRISA = 0x85
#byte TRISC = 0x87
#define SPORTA PORTA
#define SPORTC PORTC
#define  TICKS_BETWEEN_INTERRUPTS      5000 //5000
#define  INTERRUPT_OVERHEAD            35
#define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
const char SegCode[11] = {0x40,0x57,0x22,0x06,0x15,0x0C,0x08,0x56,0x00,0x04,0xFF};
   //                       0    1    2    3    4    5    6    7    8    9
const char Column[3]   = {0x02,0x01,0x04};
static char Segment[3] = {0x7f,0x7f,0x7f};
static unsigned char ColCount=0x00;
void CPU_SETUP(void);
void Display(void);
void HTO7S(unsigned int32 Num);
byte i;
unsigned int32 result;
#INT_TIMER1
void Timer1(void)
   set_timer1(TMR1RESET);
   Display();
void main()
   unsigned char i;
   CPU_SETUP();
   while(true)
      result=0;
      for (i=0;i<20;i++)
         set_adc_channel(3);
         delay_ms(1);
         result=result+read_adc();
       //result = 0x3fe;
       HTO7S(result*20);
      delay_ms(200);
void CPU_SETUP()
   setup_adc_ports(ALL_ANALOG);
   setup_comparator(NC_NC_NC_NC);   // not use comparator module
   setup_adc_ports( sAN3 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   TRISA=0b00011000;
   PORTA=0x27;
   TRISC=0b00000000;
   PORTC=0x37;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   enable_interrupts(GLOBAL);
   enable_interrupts(INT_TIMER1);
// Display routine
void Display()
   PORTA = 0b00100111;     // off all digits column and Segment G
   PORTC = 0b00111111;   // off segment a-f
   delay_cycles(2);
   if (ColCount>=3)
   ColCount=0;
   SPORTC = Segment[ColCount];
   SPORTA = ((Segment[ColCount] & 0b01000000)>>1) | (Column[ColCount]^0x07);
   ColCount++;
// Convet HEX 2 byte to 7-Segment code
   unsigned int32 res;
   Segment[0]=SegCode[30*Num/10230];
   if (Segment[0]==0x40)
   Segment[0]=0xFF;
   res = 30*Num%10230;
   Segment[1]=SegCode[10*res/10230];
   res=10*res%10230;
   Segment[2]=SegCode[10*res/10230];
taso
xman
simulasyonda çalışırken gerekmiyor  ısıs hallediyo o işi.
pea
xman
ben çoğu devreyi böyle çalıştırıyorum fakat bu devre simulasyonunda 0v var başka değer yok.
ctn1905
setup_adc_ports(ALL_ANALOG);  demişsin ama AN0 AN1 AN2 çıkış almışsın sadece AN3 seç A0 A1 A2 de çıkış olarak tanımla
striger
simulasyonda calıstıramdım bende devreyi benzer bi uygulama yapmıstım board uzerinde calısır devre deneyebilirsin
xman
Alıntı Yapsetup_adc_ports(ALL_ANALOG);  demişsin ama AN0 AN1 AN2 çıkış almışsın sadece AN3 seç A0 A1 A2 de çıkış olarak tanımla
TRISA=0b00011000;
TRISC=0b00000000;
portları böyle derliyorum yine aynı sadece yazılımda  //result = 0x3fe; çift slaşı kaldırınca bi değişiklik oluyo.
xman
serhat1990
RF modül ile yapmış olduğum ccs c dilinde yazdığım rfvoltmetre uygulaması umarım işinize yarar. İyi çalışmalar...
https://www.picproje.org/index.php/topic,39927.0.html
