Ynt: 18F8720 isis'te stack underflow HATASI nedir?
Başlatan mustafa_cmbz, 21 Eylül 2012, 18:00:38
mustafa_cmbz
merhabalar
isiste 128x64 glcd ve 18f8720 ile ufak bir devre kurdum .bmp uzantılı resimleri dönüştürüp ekrana basıyorum fakat isis devamlı stack underflow hatası vermekte..
neyden kaynaklanıyor olabilir?
eve gidinde resimleri yükleyeceğim..!
mesaj birleştirme:: 21 Eylül 2012, 19:48:13
isisin ekranındaki hata :
18f8720 kod:
INCLUDE "PROTON_G4.INT" ' Use a 4MHz XTAL
DIM  Xpos    AS BYTE	'Xpos BİLGİSİ 0....127
DIM  Ypos    AS BYTE	'Ypos BİLGİSİ 0....63
DIM  Addr    AS WORD     'EPROM ADRES BİLGİSİ
DIM  char    AS BYTE     'FONT KARAKTER BİLGİSİ
DIM VAR2 AS WORD
DIM VAR1 AS WORD
GOTO  START
 BASLA:
 CLS
 DELAYMS 500
 PRINT AT 1,3,"TEKDAG_ELEKTRONiK"
 PRINT AT 3,2,"tekdag-elektronik@"
 PRINT AT 4,3,"   gmail.com"
 PRINT AT 6,4,"Mustafa CAMBAZ"
 DELAYMS 5000
 CLS
 DELAYMS 300
 PRINT AT 2,4,"RUZGAR GULU "
 PRINT AT 5,4,"PROJESi"
 DELAYMS 5000
 CLS
 DELAYMS 300
 PRINT AT 1,1,
 PRINT AT 5,2,"%0"
 PRINT AT 5,16,"%100"
 PRINT AT 2,4," SYSTEM"
 PRINT AT 3,4," loading..."
 FOR Xpos = 30 TO 90                  ' Create a loop of 128
 LCDWRITE 5, Xpos, [%1010111]       ' Write to the LCD's top line
 DELAYMS 10  'çubuğun süresini kısar
 NEXT
 DELAYMS 5000
 CLS
 DELAYMS 500
 GOTO SSS
 SSS:
 GOTO SSS
 START:
 'LCDWRITE 4,1,[$MUSTAFA]
 'LCDWRITE 5,1,"MUSTAFA CAMBAZ"
 'LCDWRITE 6,1,"MUSTAFA CAMBAZ"
 'LCDWRITE 7,1,"MUSTAFA CAMBAZ"
 GOTO STAR2
 STAR2:
 FOR Ypos = 0 TO 7
 FOR Xpos = 0 TO 127
 Addr = (Ypos*128)+Xpos
 char = CREAD AAA+Addr
 LCDWRITE Ypos,Xpos,[char]
 NEXT
 NEXT
 DELAYMS 100
END
INCLUDE "PROTON_G4.INT":
DEVICE = 18F8720
        XTAL = 4
        TRISE=0
		LCD_DTPORT = PORTH
		LCD_RSPIN = PORTG.2
		LCD_ENPIN = PORTG.0
		LCD_RWPIN = PORTG.1
        LCD_CS1PIN = PORTG.4
		LCD_CS2PIN = PORTG.3
        LCD_TYPE = GRAPHIC
		INTERNAL_FONT = ON
		FONT_ADDR = 0
        ALL_DIGITAL = True	' Set PORTA and PORTE to all digital
AAA İNCLUDE DOSYASI : Resmin cdata formatındaki verileri
AAA:
    CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0C
	CDATA	$7C,$FC,$FC,$FC,$FC,$FC,$7C,$00,$00,$00,$00,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$80
	CDATA	$C0,$C0,$F0,$D0,$D0,$D0,$D0,$F0,$C0,$C0,$80,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$60,$E0
	CDATA	$E0,$E0,$E0,$E0,$E0,$E0,$E0,$00,$00,$00,$00,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$80,$40,$40,$80,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00
	CDATA	$80,$C3,$FF,$FF,$FF,$C3,$80,$00,$00,$00,$00,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF
	CDATA	$FF,$0F,$87,$C7,$E3,$71,$39,$19,$FF,$FF,$FF,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3F
	CDATA	$FF,$FF,$FF,$FF,$FF,$EF,$E0,$E0,$60,$20,$00,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$00,$00,$FF,$4A,$4A,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$0C,$1C,$7E,$FE,$7F,$3F,$1F,$07
	CDATA	$03,$01,$FF,$FF,$FF,$01,$03,$07,$0F,$1F,$1F,$3F,$7E,$3E,$1C,$0C
	CDATA	$FF,$83,$C1,$E0,$70,$38,$1C,$1E,$FF,$FF,$FF,$00,$00,$00,$00,$00
	CDATA	$C1,$F1,$FD,$7F,$3F,$1F,$07,$01,$00,$00,$00,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$80,$80,$FF,$FF,$FF,$FF,$89,$89,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$40,$40,$40,$40
	CDATA	$40,$40,$7F,$7F,$7F,$40,$40,$40,$40,$40,$40,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03
	CDATA	$0F,$1F,$1F,$1D,$1C,$1C,$1C,$1E,$0F,$07,$03,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$78,$1F
	CDATA	$07,$03,$01,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00
	CDATA	$00,$00,$00,$00,$00,$00,$0F,$1F,$3F,$7F,$7F,$7F,$7F,$3F,$1F,$0F
sıkıntı nedir bilemedim kafam durdu yemin ediyorum...
Stack taşması "GİDİP DE DÖNEMEMEK" mevzusu :)
Kodların tümü bu mu, Arasından sildin mi? Çünkü bu hali ile mantıklı bir akış yok.
mustafa_cmbz
https://320volt.com/proton-glcd-resim-basma-uygulamasi/
uygulama kodlarım burdan alıntıydı...tekrar kopyala yapıştır yaptım sorun çözüldü.
birde dün paylaştığım kodların sonunda inc. tanımlamaları yok bendeki kodda var...anlamadım gitti sıkıntı ya bir eksiklikten kaynaklandı gözden kaçan bir kısım yada protonun tam olmamasından kaynaklandı...bazı bazı böyle sıkıntılar yaşıyorum..
Program Sonunda END komutundan önce stop komutu kullanıp program akışını durdurmalısınız. Aksi halde END komutu görüldüğünde program baştan başlar. Bundan kaynaklanabilir. Basic Dillerinde ucu açık etiketler bırakmamak gerekiyor.
Bu program nasıl çalışır anlamadım
En basitinden,
SSS:
GOTO SSS
tyildizak
Alıntı yapılan: OG - 22 Eylül 2012, 09:51:14
stack overflow ile stack underflow farklı şeylerdir.  Stack underflow'da taşma değil de, stack'tan eleman çekilmeye çalışıldığında  alınacak birşey olmaması, boş olması sözkonusu.
bu hatalar genelde
gosub la gidip goto ile dönüldüğünd
goto ile gidip return ile döüldüğünde oluşur.
ayrıca basic yada asm ile yazdığımda program sonuna sonsuz döngü kurarım.
Alıntı yapılan: tyildizak - 22 Eylül 2012, 20:24:29
Ona da "GELİP DE GÖREMEMEK" diyelim :)
mustafa_cmbz
Alıntı yapılan: OG - 22 Eylül 2012, 16:18:20
En basitinden,
SSS:
GOTO SSS
yaf aslında bazı düzenlemeler yapıyordum mesela birkaç farklı resim denemesi yaparken ordan oraya dallandırıyordum yada kısır döngüye sokuyordum ondan dolayı :D
