PIC gücü !
Başlatan bulut_01, 04 Ekim 2012, 20:30:06
bulut_01
kücük bir video yayınlamak ıstedım bu yenı pic ler baya iyi çok can yakar pic ve arm tartışmasına küçük bir örnek video..
http://www.microchip.com/pagehandler/en-us/technology/ethernet/tools/home.html#ooid=NhZDhoMjog_r1jiv8IvKiHmCOgEECnZc
MCU Core
80MHz, 1.56 DMIPS/MHz, 32-bit MIPS M4K® Core
USB 2.0 On-The-Go Peripheral with integrated PHY
10/100 Ethernet MAC with MII/RMII Interfaces
2 x CAN2.0b modules with 1024 buffers
8 Dedicated DMA Channels for USB OTG, Ethernet, and CAN
5 Stage pipeline, Harvard architecture
MIPS16e mode for up to 40% smaller code size
Single cycle multiply and hardware divide unit
32 x 32-bit Core Registers
32 x 32-bit Shadow Registers
Fast context switch and interrupt response
MCU System Features
512K Flash (plus 12K boot Flash)
128K RAM (can execute from RAM)
8 Channel General Hardware DMA Controller
Flash prefetch module with 256 Byte cache
Lock instructions or data in cache for fast access
Programmable vector interrupt controller
Analog Features
Fast and Accurate 16 channel 10-bit ADC,
Max 1 Mega sample per second at +/- 1LSB, conversion available during SLEEP & IDLE
Power Management Modes
RUN, IDLE, and SLEEP modes
Multiple switchable clock modes for each power mode, enables optimum power settings
Debug Features
iFlow Trace: Non-intrusive Hardware Instruction Trace port (5 Wires)
8 hardware breakpoints (6 Instruction and 2 Data)
2 wire programming and debugging interface
JTAG interface supporting Programming, Debugging and Boundary scan
Other MCU Features
Fail-Safe Clock Monitor - allows safe shutdown if clock fails
2 Internal oscillators (8MHz & 31KHz)
Hardware RTCC (Real-Time Clock and Calendar with Alarms)
Watchdog Timer with separate RC oscillator
Pin compatible with 16-bit PIC® MCUs
Serial Communication Modules allow flexible UART/SPI/I2C™ configuration
''arm tokatlar döner gine tokatlar'' katagorısınde kapısır her türlü  ;D
not: 9 dolar burda o fiyata 16f877 veriyolar  :)
YENİLMEZ..
mcn
adı çıkmış 9 a inmez 8 e derler ya, microchip işlemcilerini geliştirebilir, bir çok yerde kullanılıyor, kullanılmaya da devam edecek, ancak ne kadar geliştirirse geliştirsin hiçbir zaman arm core luların yerine tercih edilen olmayacaktır.
www.teknikyazi.com --üşenme,erteleme,vazgeçme...
Yalnız bu konu PIC - ARM kapışması değil, MIPS - ARM kapışması. Karşılaştırmayı hangi seviyede yaptığınıza dikkat edin. Hani elmalar ve armutlarla ilgili bir söz vardır ya...
bulut_01
millet tutturmus arm arm ne war bunda altın mu buluyo arm bulan   :) bu arm gizemi acıklarmısınız  ;D
YENİLMEZ..
hemen açıklayayım (Bir Fan değilim ama mantıklıyım. Hangisi işime gelirse onu kullanırım. Örneğin 4520 ile bir cihaz üzerinde çalışıyorum.)
ARM daha Ucuz.
XX_CİHAN_XX
Hehehe birde şuna bakın o zaman
http://www.st.com/internet/mcu/product/252140.jsp
Fiyatı da 7$
''arm tokatlar döner gine tokatlar''     :D
EmaNet
Fiyat farkı var. Ama Microchip'inde hakkını yememek lazım 32 bit piyasasında sağlam bir yerlere gelecek gibi. Zaten microchip'in en büyük özelliği çok fazla example bulma olanağı.
Keşke 3 yıl kadar önce Bu arm ile bukadar haşır neşir olsaydım. şu anda 3000usd daha zengin olacaktım :D
bulut_01
cortex m4 sıkı mcu 210 dmips mişş bukadar beygiri bu mcu nasıl sokmuslar  ;D şaka bir yana gönlümüz hep pic yana m4 kullanacak hakkıyla burda kac proje vardır o mcu zorlayacak varsa burda örnek verirlerse bizde ögreniriz  ;D
YENİLMEZ..
zorlamaya gerek yok. aynı fiyata alıyorsın, daha fazla özelliği.
XX_CİHAN_XX
Alıntı yapılan: bulut_01 - 04 Ekim 2012, 21:23:42
Boşver hocam sen bunlarla sıkma canını pice devam edersin olur biter :)
serhat1990
Alıntı yapılan: muhittin_kaplan - 04 Ekim 2012, 21:18:31
Hocam katılıyorum . Ben para kısmına değilde yapacağım işlemlerin boyutuna bağladım sonucu :) :)
Keşke Hocam biraz daha önceden vursaymış enseme tokatı :)
bulut_01
can sıkıntısı deıl cihan maksat muhabbet bişeler ögreniyoz mips yok cortex yok bılmem ne ögrenmek iyidir bu hayvanları zorluyacak kodlar yada işletim sistemi gibi seyler yapabılsek daha nolurkı ben C baslıyalı 1 sene olmamısdır asker git gel hersey unuttuk tabi ama bu aralar c haşır neşirim bıde su blcd motor kodları bıtırsem aşama aşama gidiyorum..
YENİLMEZ..
ipek
öğrencilik yıllarımda sağ görüşlü fan'ların klişe sözleri vardı davadan döneni vurun diye .. ;D
ben microchip'in mecburi hizmetkarıyım bu yaştan sonra......arm marm derken korkarım forumun adınıda değiştirmeye kalkmasınlar Armproje diye....... ;D ;D
serhat1990
Alıntı yapılan: ipek - 04 Ekim 2012, 22:03:27
İsim değişmez heralde Hocam :) :) İlk göz ağrısı unutulmaz derler :)
