CRC li RF veri gönderme :(
Başlatan thenorthstar, 18 Nisan 2013, 13:50:24
thenorthstar
Merhaba Arkadaşlar;
Master ve Slave olarak iki RF kartım var bunlar arasında veri transveri yapabiliyorum, ben bunu crc kontrollü yapmak istiyorum crc kontrollü olarak nasıl yapabilirim yardımcı olurmusunuz?
Aşağıdaki Koda crc yi nasıl ekleyebilirim.
Verici:
#include <18F452.h>
#device adc=10
#FUSES HS,NOWDT,WDT128 ,NOBROWNOUT,NOLVPI/O
#use delay(clock=10000000)
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#define Buton       pin_e1
void Uyandir()
    for(i=0;i<5;i++)putc(170);
    for(i=0;i<5;i++)putc(0);
    for(i=0;i<5;i++)putc(255);
   for(i=0; i<11; i++)
   putc(TxBuffer[i]);
void Sorgu()
   TxBuffer[0] = '&';
   TxBuffer[1] = 1;
   TxBuffer[2] = ID;
   TxBuffer[3] = sayac2;
   TxBuffer[4] = *;
   TxBuffer[5] = 2;
   TxBuffer[6] = *;
   TxBuffer[7] = 3;
   TxBuffer[8] = *;
   TxBuffer[9] = 4;
   TxBuffer[10] = '#';
   Uyandir();
void main()
   setup_adc(ADC_OFF);   // ADC clock frekansı fosc/32
   setup_adc_ports(NO_ANALOGS); //RA0/AN0 girişi analog
 while(true)             // Sonsuz döngü
     if(!input(Buton1))
      while(!input(Buton1));
             delay_ms(100);
            Sorgu();
Alıcı:
#include <18F452.h>
#device adc=10
#include "2x16_4x20_LCD.c"
#define Led       pin_c1
int SerialCounter =0;
int RxBuffer[] =11;
int RxCounter = 0;
int Kontrol = 0;
int8 sayac=0;
int8 i=0;
#int_RDA
void RDA_isr(void)
   char vChar = getc();     // get a byte, put it in buffer
   if(vChar=='&')
    RxCounter = 0;
    RxBuffer[RxCounter++]='&';
   if (RxBuffer[0] == '&')
      RxBuffer[RxCounter++] = vChar;
   if(RxBuffer[RxCounter-1]== '#')      // increment counter
      RxBuffer[12] = '\0';
      RxCounter = 0;
      Kontrol = 1;
void main()
   enable_interrupts(INT_RDA);
   enable_interrupts(GLOBAL);   // Aktif edilen kesmelere izin ver
     lcd_init();
   delay_ms(500);
        if (Kontrol == 1)
         Kontrol = 0;
         if (RxBuffer[0] == '&' && RxBuffer[2] == 1 && RxBuffer[4] == '*' && RxBuffer[6] == '*' && RxBuffer[8] == '*' && RxBuffer[10] == '#')
            sayac=RxBuffer[3];
            output_high(led);
            lcd_gotoxy(1,1);printf(lcd_putc,"Sayac1=%d     ",sayac);
               for(i=0; i<11; i++)
               RxBuffer[i]=0;
Okan AKÇA
ccs nin icersinde crc kodu üreten driver var  ancak işlemciyi fazlasınla oyalıyor bunun icin kendiniz basit bir şey yapabilirsiniz.
HexfeT
Kullandığınız RF modül ile devam etmeniz şart değil ise CRC işini kendi içinde halleden bir RF modül kullanabilirsiniz.
thenorthstar
Elinde 5-6 adet Udea modülleri var Onları kullanacağım
@mihri  hocam aşağıdaki gibi bir kod vermişti formda ama nasıl kullanılacağını bulamadım.
crc.h
#ifndef __CRC_H
    #define __CRC_H
    #define CRC_LOOKUP_TABLE
    #if defined(CRC_LOOKUP_TABLE)
   		unsigned int CRC16(unsigned char * data, unsigned char dataLength);
   	#else
    	unsigned int CRC16(unsigned char *ptr, signed char count);
    #endif
#endif
crc.c
#include "crc.h"
    const rom unsigned int CRC16Table[256] =
        0x0000,  0x1021,  0x2042,  0x3063,  0x4084,  0x50a5,  0x60c6,  0x70e7,
        0x8108,  0x9129,  0xa14a,  0xb16b,  0xc18c,  0xd1ad,  0xe1ce,  0xf1ef,
        0x1231,  0x0210,  0x3273,  0x2252,  0x52b5,  0x4294,  0x72f7,  0x62d6,
        0x9339,  0x8318,  0xb37b,  0xa35a,  0xd3bd,  0xc39c,  0xf3ff,  0xe3de,
        0x2462,  0x3443,  0x0420,  0x1401,  0x64e6,  0x74c7,  0x44a4,  0x5485,
        0xa56a,  0xb54b,  0x8528,  0x9509,  0xe5ee,  0xf5cf,  0xc5ac,  0xd58d,
        0x3653,  0x2672,  0x1611,  0x0630,  0x76d7,  0x66f6,  0x5695,  0x46b4,
        0xb75b,  0xa77a,  0x9719,  0x8738,  0xf7df,  0xe7fe,  0xd79d,  0xc7bc,
        0x48c4,  0x58e5,  0x6886,  0x78a7,  0x0840,  0x1861,  0x2802,  0x3823,
        0xc9cc,  0xd9ed,  0xe98e,  0xf9af,  0x8948,  0x9969,  0xa90a,  0xb92b,
        0x5af5,  0x4ad4,  0x7ab7,  0x6a96,  0x1a71,  0x0a50,  0x3a33,  0x2a12,
        0xdbfd,  0xcbdc,  0xfbbf,  0xeb9e,  0x9b79,  0x8b58,  0xbb3b,  0xab1a,
        0x6ca6,  0x7c87,  0x4ce4,  0x5cc5,  0x2c22,  0x3c03,  0x0c60,  0x1c41,
        0xedae,  0xfd8f,  0xcdec,  0xddcd,  0xad2a,  0xbd0b,  0x8d68,  0x9d49,
        0x7e97,  0x6eb6,  0x5ed5,  0x4ef4,  0x3e13,  0x2e32,  0x1e51,  0x0e70,
        0xff9f,  0xefbe,  0xdfdd,  0xcffc,  0xbf1b,  0xaf3a,  0x9f59,  0x8f78,
        0x9188,  0x81a9,  0xb1ca,  0xa1eb,  0xd10c,  0xc12d,  0xf14e,  0xe16f,
        0x1080,  0x00a1,  0x30c2,  0x20e3,  0x5004,  0x4025,  0x7046,  0x6067,
        0x83b9,  0x9398,  0xa3fb,  0xb3da,  0xc33d,  0xd31c,  0xe37f,  0xf35e,
        0x02b1,  0x1290,  0x22f3,  0x32d2,  0x4235,  0x5214,  0x6277,  0x7256,
        0xb5ea,  0xa5cb,  0x95a8,  0x8589,  0xf56e,  0xe54f,  0xd52c,  0xc50d,
        0x34e2,  0x24c3,  0x14a0,  0x0481,  0x7466,  0x6447,  0x5424,  0x4405,
        0xa7db,  0xb7fa,  0x8799,  0x97b8,  0xe75f,  0xf77e,  0xc71d,  0xd73c,
        0x26d3,  0x36f2,  0x0691,  0x16b0,  0x6657,  0x7676,  0x4615,  0x5634,
        0xd94c,  0xc96d,  0xf90e,  0xe92f,  0x99c8,  0x89e9,  0xb98a,  0xa9ab,
        0x5844,  0x4865,  0x7806,  0x6827,  0x18c0,  0x08e1,  0x3882,  0x28a3,
        0xcb7d,  0xdb5c,  0xeb3f,  0xfb1e,  0x8bf9,  0x9bd8,  0xabbb,  0xbb9a,
        0x4a75,  0x5a54,  0x6a37,  0x7a16,  0x0af1,  0x1ad0,  0x2ab3,  0x3a92,
        0xfd2e,  0xed0f,  0xdd6c,  0xcd4d,  0xbdaa,  0xad8b,  0x9de8,  0x8dc9,
        0x7c26,  0x6c07,  0x5c64,  0x4c45,  0x3ca2,  0x2c83,  0x1ce0,  0x0cc1,
        0xef1f,  0xff3e,  0xcf5d,  0xdf7c,  0xaf9b,  0xbfba,  0x8fd9,  0x9ff8,
        0x6e17,  0x7e36,  0x4e55,  0x5e74,  0x2e93,  0x3eb2,  0x0ed1,  0x1ef0
        unsigned int crc;
    	unsigned char i;
        crc = 0;
    	for(i=0;i<dataLength;i++)
            crc = (crc << 8) ^ CRC16Table[(crc>>8) ^ *data++];
    	return crc;
#else
        unsigned int crc;
        unsigned char i;
        crc = 0;
        while(--count >= 0 )
            crc = crc ^ ((unsigned int) *ptr++ << 8);
            for(i = 0; i < 8; i++)
                if( crc & 0x8000 )
                    crc = (crc << 1) ^ 0x1021;
                    crc = crc << 1;
        return crc;
#endif
TxBuffer datasını  aşağıdaki gibi crc işlemine sokuyorum fakat crc hep 0 çıkıyor.
TxBuffer[0] = '&';
   TxBuffer[1] = 1;
   TxBuffer[2] = ID;
   TxBuffer[4] = *;
   TxBuffer[5] = 2;
   TxBuffer[6] = *;
   TxBuffer[7] = 3;
   TxBuffer[8] = *;
   TxBuffer[9] = 4;
   TxBuffer[10] = '#';
 [b]CRC16(TxBuffer , 11)[/b]
Gürültülü ortamlarda alınan verilerde hata bulma ve düzeltme kodlarından FEC'i inceleyebilirsin.
Sen kullanmayacak olsan bile link forumda kalsın.
http://www.abramovbenjamin.net/labs/lab4.pdf
http://en.wikipedia.org/wiki/Forward_error_correction
haydarpasamikro
Benim Ethernet için kullandığım paketlerde kullandığım CRC hesaplama fonksiyonu:
unsigned int MAC_CalculateCRC(unsigned int len_ip_header, unsigned char *buf){
   unsigned int word16 = 0;
   unsigned long sum = 0;
   unsigned int i;
      // make 16 bit words out of every two adjacent 8 bit words in the packet
      // and add them up
      for (i=0;i<len_ip_header;i=i+2){
         word16 =(((unsigned int)*buf<<8)& 0xFF00)+((unsigned int)*(buf+1)& 0xFF);
         sum = sum + (unsigned long) word16;
         buf += 2;
      // take only 16 bits out of the 32 bit sum and add up the carries
      while (sum>>16)
        sum = (sum & 0xFFFF)+(sum >> 16);
      // one's complement the result
      sum = ~sum;
   return ((unsigned int) sum);
Fonksiyon geriye 16-bit int crc değerini dönderiyor. Parametre olarak buffer uzunluğu ve buffer ın başlangıcı veriliyor. Olay bundan ibaret.
Mikro Dünyası.Haydarpaşa Teknik ve Endüstri Meslek Lisesi Mikrodenetleyici Atl. Şefi
