jn5148 hakkında yardım
Başlatan buyruklu, 09 Mayıs 2013, 00:04:51
buyruklu
elimde resimde http://www.digikey.com/product-detail/en/JN5148%2F001M00T,534/616-1045-1-ND/2139684  görülen mikrodenetleyici  var buna ben program nasıl atarım biri bilgisi olan varmıdır?.
arslan74
Datasheetin de yazıyor.
Alıntı YapFor normal operation of the module and programming over the UART, SPISSZ should be connected to SPISSM.
mustafaelektro
flash programmer denen yükleme programını indir, kod yaz, derle, üretilen .bin dosyasını flash programmer ile uart0 portuna FTDI seri port dönüştürücü ile bağlandığın jennic chipine yüklemeye çalış. verilen parçalı bigileri jennic dokümanlarıyla harmanla anlamazsan tekrar gel."JN-RM-2056-USB-Programming-Dongle.pdf
What are the minimum connections required for programming modules?
1) Connect power and ground on pins 24 (VDD), 25 (GND) & 26 (VSSA).
2) Ensure that pins 9 (SSZ) and 13 (SSM) are tied together. This allows the SPI Select signal from the JN5121 device to communicate with the FLASH.
3) Disable the write protect on the FLASH by tying pin 14 (SWP) HIGH.
4) To ensure correct power up, the reset circuit shown below must be applied to pin 29 (RESETN). If required a switch can be applied between RESETN and GROUND.
5) At power up or reset the Boot Loader first looks at pin 7 (MISO) to determine whether to go into programming mode. To enter programming mode, pin 7 (MISO) must be held LOW at power up or reset and then released.
6) Serial communications are made on pins 18 & 19 (TXD, RXD). These signal levels must be level shifted to 3.3V.
If you are using the Jennic serial dongle to level shift then a signal (PGM) is available to put the device into programming mode. This signal should be connected to the module as shown below.
Note:
Some terminal programs i.e. Hyperterminal pull the serial PGM/RTS line down by default, thus, setting the device into programming mode at power on/reset. After programming, when powering on the module, ensure you have quit or disconnected hyperterminal or disconnect the serial lead."
