lpc 2368 wdt örnek
Başlatan armsistem, 16 Mayıs 2013, 00:09:56
armsistem
Arkadaşlar merhaba ; aşağıda wdt ile bir örnek var , anlayamadığım verilen süre sonrasında oluşan kesmede işlemci soft olarak resetleniyor mu ?
- WDT kullanmadan soft. olarak nasıl işlemciyi resetlerim.
 *   wdt.c:  Watchdog C file for NXP LPC23xx/24xx Family Microprocessors
 *   Copyright(C) 2006, NXP Semiconductor
 *   All rights reserved.
 *   History
 *   2006.07.20  ver 1.00    Prelimnary version, first Release
#include "LPC23xx.h"                        /* LPC23xx/24xx definitions */
#include "type.h"
#include "irq.h"
#include "timer.h"
#include "wdt.h"
volatile DWORD wdt_counter;
** Function name:		WDTHandler
** Descriptions:		Watchdog timer interrupt handler
** parameters:			None
** Returned value:		None
void WDTHandler(void) __irq
  WDMOD &= ~WDTOF;		/* clear the time-out terrupt flag */
  IENABLE;			/* handles nested interrupt */
  wdt_counter++;
  IDISABLE;
  VICVectAddr = 0;		/* Acknowledge Interrupt */
** Function name:		WDTInit
** Descriptions:		Initialize watchdog timer, install the
**				watchdog timer interrupt handler
** parameters:			None
** Returned value:		true or false, return false if the VIC table
**				is full and WDT interrupt handler can be
**				installed.
DWORD WDTInit( void )
  wdt_counter = 0;
  if ( install_irq( WDT_INT, (void *)WDTHandler, HIGHEST_PRIORITY ) == FALSE )
	return (FALSE);
  WDTC = WDT_FEED_VALUE;	/* once WDEN is set, the WDT will start after feeding */
//  WDMOD = WDEN | WDRESET;
  WDMOD = WDEN;
  WDFEED = 0xAA;		/* Feeding sequence */
  WDFEED = 0x55;
  return( TRUE );
** Function name:		WDTFeed
** Descriptions:		Feed watchdog timer to prevent it from timeout
** parameters:			None
void WDTFeed( void )
  WDFEED = 0x55;
  return;
**                            End Of File
