Siemens S7 1200 PLC detaylı fotoğrafları
Başlatan gtekdemir, 23 Mayıs 2013, 22:24:18
gtekdemir
Merhaba arkadaşlar, yaptığınız elektronik devre tasarımlarında belki işinize yarar diyerekten çektiğim fotoğrafları paylaşayım dedim. Fotoğraflardaki plc nin özellikleri şöyle; 24vdc besleme, 24vdc giriş, transistör çıkış ve iki tane 0-10v analog input(izole değil) şeklinde.
http://imageshack.us/a/img208/2282/201305231322190.jpg
http://imageshack.us/a/img208/5320/20130523132255.jpg
http://imageshack.us/a/img826/1390/20130523132350.jpg
http://imageshack.us/a/img834/3281/20130523132509.jpg
http://imageshack.us/a/img21/9341/20130523132531.jpg
http://imageshack.us/a/img11/5619/20130523132538.jpg
http://imageshack.us/a/img856/1131/20130523132551.jpg
http://imageshack.us/a/img543/6159/20130523132605.jpg
http://imageshack.us/a/img703/9045/20130523132611.jpg
http://imageshack.us/a/img809/4817/20130523140110.jpg
http://imageshack.us/a/img208/9770/20130523140207.jpg
http://imageshack.us/a/img14/1168/20130523140238.jpg
http://imageshack.us/a/img850/3170/20130523140309.jpg
http://imageshack.us/a/img829/8051/20130523140350.jpg
http://imageshack.us/a/img600/2784/20130523140358.jpg
http://imageshack.us/a/img404/7319/20130523140419.jpg
http://imageshack.us/a/img43/4383/20130523140440.jpg
http://imageshack.us/a/img191/497/20130523140527.jpg
http://imageshack.us/a/img845/364/20130523140614.jpg
http://imageshack.us/a/img593/6475/20130523140622.jpg
http://imageshack.us/a/img17/82/20130523140644.jpg
http://imageshack.us/a/img12/9899/20130523140742.jpg
http://imageshack.us/a/img801/4739/20130523140814.jpg
http://imageshack.us/a/img13/442/20130523141034.jpg
http://imageshack.us/a/img19/5387/20130523141111.jpg
http://imageshack.us/a/img705/9833/20130523141123.jpg
http://imageshack.us/a/img17/3510/20130523141133.jpg
http://imageshack.us/a/img163/6169/20130523141200.jpg
http://imageshack.us/a/img189/8236/20130523141317.jpg
http://imageshack.us/a/img832/7651/20130523141350.jpg
http://imageshack.us/a/img109/3932/20130523141441.jpg
http://imageshack.us/a/img842/1510/20130523141458.jpg
http://imageshack.us/a/img560/7568/20130523141516.jpg
http://imageshack.us/a/img855/4563/20130523141524.jpg
http://imageshack.us/a/img541/6603/20130523141612.jpg
http://imageshack.us/a/img153/1821/20130523141645.jpg
http://imageshack.us/a/img23/6569/20130523141706.jpg
http://imageshack.us/a/img703/3263/20130523141723.jpg
http://imageshack.us/a/img12/4810/20130523141742.jpg
http://imageshack.us/a/img837/6389/20130523141759.jpg
http://imageshack.us/a/img703/7633/20130523141835.jpg
http://imageshack.us/a/img842/1695/20130523141911.jpg
http://imageshack.us/a/img443/8972/20130523141920.jpg
http://imageshack.us/a/img19/9696/20130523141955.jpg
http://imageshack.us/a/img594/1485/20130523142001.jpg
camby
xilinx marka RTC kullanmışlar TCXO..
Alman malı da sanırım sadece Würth marka bir trafo var..
Ersin
Alıntı Yapxilinx marka RTC kullanmışlar TCXO..
RTC olduğuna eminmisin yada rtc ise xilinx olduğuna eminmisin.Xilinx rtc pek üretmez.
CoşkuN
gtekdemir
islergucler
Alıntı yapılan: CoşkuN - 24 Mayıs 2013, 08:34:24
İşlemci neymiş anlayan oldu mu?
Mitsubishi
Fujitsu ile birleştiler. Sonra onlarıda NEC satın aldı.
camby
Alıntı yapılan: Ersin - 24 Mayıs 2013, 00:11:20
Evet şaşırdım ben de , fotolara göre işlemcinin sol üst tarafında R8564
http://www.xilinx.com/products/boards/ml310/current/pcb/ds/rtc-8564je.pdf
Ersin
Alıntı YapEvet şaşırdım ben de , fotolara göre işlemcinin sol üst tarafında R8564
Verdiğin linkin pdf ine dikkat li bak resmin altında www.epsondevice.com yazıyor.O pdf xilinx in sayfasında olması xilinx olduğunu göstermez , ML310 bordunda kullanılan bir rtc dir.
http://www.eea.epson.com/portal/page/portal/home/products/timing_devices/Real%20Time%20Clocks
camby
Alıntı yapılan: Ersin - 24 Mayıs 2013, 12:13:53
Google a R8564 yazınca çıkan sonuçtan ters köşe olmuşum feci : )
fthdmrl
arkadaşlar plc yardımı alabileceğim şirketler biliyormusunuz elektronik öğretmeniyim okulumzda plc bulunmuyor s7-300 falan veya s7-200 bulabilsem kendim bir set yapmak istiyorum yardım alabileceğimiz biryerler olabilirmi
gtekdemir
Besleme kartı üzerinde kaskat bağlanmış iki tane ITS4141N kodlu malzeme var, özellikleri güzel gibi yaptığımız devrelerde kullanabiliriz diye düşündüm.
Özellikleri şöyle;
• Short circuit protection
• Current limitation
• Overload protection
• Overvoltage protection (including load dump)
• Undervoltage shutdown with auto-restart and hysteresis
• Switching inductive loads
• Clamp of negative voltage at output with inductive loads
• CMOS compatible input
• Thermal shutdown with restart
• ESD - Protection
• Loss of GND and loss of Vbb protection
• Very low standby current
• Reverse battery protection with external resistor
• Improved electromagnetic compatibility (EMC)
Okan AKÇA
hocam oncelikle siemens  hayranlıgından vaz gecin  biraz para ayırıp deltadan   500 liraya plc  giriş cıkış ünitesi analog modül besleme alabilirsiniz. 300 tl daha vererek ekranda alabilirsiniz. Yardım edecek olan birisi olsada bende keşke alsam  projemin bitanesini beleşe getiririm.
gtekdemir
Alıntı yapılan: cyclone - 24 Mayıs 2013, 21:10:40
"Hayranlık duymak" seviyesinde olmasada sevdiğim bir plc dir siemens, kullanıcı dostu olmalarına göre sevdiğim plcleri sıralamaya koyarsam;
1-Schneider Quantum ve M340 cpu
2-Allen Bradley Controllogix, SLC5 ve Micrologix cpu
3-Siemens S7 1200 diyebilirim.
Zaten asıl konu alanında tecrübeli bir üreticinin, endüstriyel şartlarda problem çıkarmadan çalışan bir kontrol kartını nasıl yaptığını anlamaya çalışmak, fotoğrafları da o yüzden paylaştım. Electro magnetic interference konusu tasarım yaparken kafamı çok kurcalar, bundan dolayı bu işi iyi yapan adamların ürünlerini incelemeye çalışırım ve AllenBradley bu konuda on numara diyebilirim.
ground
Artık PLC lerde akıllandı.
Örneğin Eaton Moeller firması çıkardığı en düşük PLC de 400Mhz işlemci var.
Standart olarak  canopen modbus ethernet ip geliyor.
FTP server, Web server da standart geliyor.
Web server da Tag sınırı olmamakla birlikte ücretsiz.
Çok sevdiğim bir husus da Smartwire akıllı kablolama teknolojisi bulunması. Montaj işçiliği 7 de 1 oranın da düşüyor.
SmartWire-DT Application
| 田︱田田|
Picproje - Sözde değil özde paylaşım..
