Ynt: ECLIPSE sorunu,
Başlatan esensoy, 20 Haziran 2013, 11:20:26
esensoy
Eclipse IDE açarken hata veriyor, ilgili log dosya içeriğini de ekliyorum,
java kaynaklı olduğunu düşünüyorum ama çözüm için ne yapmalı fikrinize ihtiyacım var,
jdk 1.7.0_21 ve 1.6.0.38 kurulu, denetim masasından java --> java --> view seçeneğinden yalnız 1.6 yı enable yapıyorum,
log dosyası:
!SESSION 2013-06-20 11:14:21.453 -----------------------------------------------
eclipse.buildId=M20070212-1330
java.version=1.7.0_21
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=tr_TR
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.common 4 0 2013-06-20 11:14:21.828
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.0/Foundation-1.0,J2SE-1.3
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:294)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:329)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1046)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:573)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:495)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:275)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:455)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:189)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:291)
!ENTRY org.eclipse.update.configurator 4 0 2013-06-20 11:14:21.828
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.4,CDC-1.0/Foundation-1.0,J2SE-1.3
!ENTRY org.eclipse.core.runtime 4 0 2013-06-20 11:14:21.828
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2013-06-20 11:14:21.828
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar/ was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator_3.2.2.R32x_v20070111.jar/ was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/ was not resolved.
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:65)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2013-06-20 11:14:21.843
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-06-20 11:14:21.843
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2013-06-20 11:14:21.843
!MESSAGE Missing required bundle org.eclipse.equinox.registry_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.equinox.preferences_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.contenttype_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.update.configurator 2 0 2013-06-20 11:14:21.843
!MESSAGE Missing imported package org.xml.sax.helpers_0.0.0.
!MESSAGE Missing imported package org.w3c.dom_0.0.0.
!MESSAGE Missing imported package org.xml.sax_0.0.0.
!MESSAGE Missing imported package javax.xml.parsers_0.0.0.
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar/ [1] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.common 2 0 2013-06-20 11:14:21.843
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.0/Foundation-1.0,J2SE-1.3
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator_3.2.2.R32x_v20070111.jar/ [2] was not resolved.
!MESSAGE Missing required bundle org.eclipse.equinox.common_[3.2.0,4.0.0).
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/ [3] was not resolved.
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
mesaj birleştirme:: 20 Haziran 2013, 11:26:17
şimdi farkettim, log dosyasında java.version kısmında 1.7.0_21 yazıyor
bunu nasıl değiştiririz?
eclipse.ini dosyasını
-vmargs
-Xms40m
-Xmx256m
şeklindeydi,
içeriğini;
-vm
G:\Java\jdk1.6.0_38\jre
-vmargs
-Xms40m
-Xmx256m
şeklinde değiştirdim ama bu seferde jre or jdk bulunamadı diye hata veriyor
Ersin
Java son versiyon kur, son versiyon ise download edip tekrar dene
ahmets
Ben de yeni eclipse kullanmaya başladım ve jre veya jdk bulunamadı hatasını aldım.
java.ini dosyasına veya system environment path değişkenine javaw.exe'yi bulacağı yeri tanımlamak gerekiyormuş.
PATH'e "C:\Program Files (x86)\Java\jdk1.7.0_25\bin;" ilave edince çalıştı.
Bir de eclipse ve kullandığın jre veya jdk'nın ikisininde ya 32 bit veya 64 bit olması gerekiyor. Birisi 32 diğeri 64 bit olursa farklı bir hata verip çalışmıyor.
esensoy
Alıntı yapılan: Ersin - 20 Haziran 2013, 18:12:52
hocam aslında sorun yeni versiyon java ile ilişkilendirilmesi, yani java 1.6 ile ilişkilendirseydim de sorun çözülecekti,
ben 1.7 yi sistemden kaldırdım ve sorun çözüldü,
-vm parametresiyle eclipse.ini içine 1.6 nın yolunu yazdım ama olmadı, farklı bir yere yazmak gerekiyor demek ki
