GPS MODÜLÜ ACİL!!!!
Başlatan byclgn, 27 Eylül 2013, 15:58:18
byclgn
FGPMMOPA6B   GPS mi modemiyle çalışıyorum rs  uart 0 a bağlı
gps ise uart 3 'e    uart3 den gps verisi çekip uart 3 E gönderiyorum ama bir türlü mantıklı veriler alamıyorum
işlemci lpc1768
gps enable  p2.6 da
Alıntı Yap#include "lpc17xx.h"
#include "lpc17xx_uart.h"
#include "lpc17xx_libcfg.h"
#include "lpc17xx_libcfg_default.h"
#include "lpc17xx_pinsel.h"
#include "lpc17xx_gpio.h"
void DelayMs(long);
void init3(void);
void init0(void);
void DelayMs(long ms)
long i; int j;
for (i = 0; i < ms; i++ )
for (j = 0; j < 7500; j++ );
void init3(){
   UART_CFG_Type UARTConfigStruct;
   PINSEL_CFG_Type PinCfg;
   PinCfg.Funcnum = 3;
   PinCfg.OpenDrain = 0;
   PinCfg.Pinmode = 0;
   PinCfg.Portnum = 4;
   PinCfg.Pinnum = 28;
   PINSEL_ConfigPin(&PinCfg);
   PinCfg.Pinnum = 29;
    Initialize UART Configuration parameter structure to default state:
    * Baudrate = 9600bps
    * 8 data bit
    * 1 Stop bit
    * None parity
   UART_ConfigStructInit(&UARTConfigStruct);
   // Re-configure baudrate to 115200bps
   UARTConfigStruct.Baud_rate = 19200;
   // Initialize DEBUG_UART_PORT peripheral with given to corresponding parameter
   UART_Init(LPC_UART3, &UARTConfigStruct);
   // Enable UART Transmit
   UART_TxCmd(LPC_UART3, ENABLE);
void init0(){
   PinCfg.Funcnum = 1;
   PinCfg.Pinmode = 0;
   PinCfg.Pinnum = 2;
   PinCfg.Portnum = 0;
   PinCfg.Pinnum = 3;
    * 8 data bit
    * 1 Stop bit
    * None parity
   UART_Init(LPC_UART0, &UARTConfigStruct);
   UART_TxCmd(LPC_UART0, ENABLE);
int main(){
   uint8_t len,buffer[10],i,idx;
GPIO_SetDir(2,1<<6,1);
   GPIO_ClearValue(2,1<<6);
   init0();
   init3();
   GPIO_SetValue(2,1<<6);
   while(1){
      len=UART_Receive(LPC_UART3, buffer,sizeof(buffer),NONE_BLOCKING);
               DelayMs(10);
     UART_Send(LPC_UART0,buffer,len, BLOCKING);
   while(1){
       len = 0;
        while (len == 0)
            len = UART_Receive(LPC_UART3, buffer, sizeof(buffer), NONE_BLOCKING);
        / Got some data /
        idx = 0;
        while (idx < len)
               Echo it back
               UART_Send(LPC_UART0, &buffer[idx], sizeof(buffer), BLOCKING);
            idx++;
   /*   delay(300);
   rec=0;
   rec=UART_Receive(LPC_UART3, (uint8_t*)rxbuf,sizeof(rx0buf),NONE_BLOCKING);
       if(rec>0)
               UART_Send(LPC_UART0,(uint8_t*)rxbuf,rec, BLOCKING);
while(1);
lütfen yardım
leblebitozu
Default baudrate 9600 görünüyor datasheet'te, kod da 19200.
byclgn
veriyi tam almak için buffer ı nasıl yazmam gerekiyor
tesladream
Temp diye bir buffer ayarla USART receive ederken bu tempi doldur aynı zamanda senin için gereken NMEA verisini tempin içinden çek ayrı bir buffer a yaz sonra işin kolaylaşıcak.Tek bir NMEA datası CheckSum a kadar sanırım 70 byte kadar sen bir 500 byte yap tempi.Ben aşağıdaki interrupt rutini kullanıyorum.İnş işine yarar.Kolay gelsin.
void USART3_IRQHandler(void)
	volatile int Sts;
	Sts=USART3->SR;
		temp[cnt] = USART3->DR;
	  if((cnt>=5)&& temp[cnt]=='C' && temp[cnt-1]=='M' && temp[cnt-2]=='R' && temp[cnt-3]=='P' && temp[cnt-4]=='G' && temp[cnt-5]=='$')
			for(j=0;j<6;j++) RxBuf[j]=temp[cnt+j-5];
			rmc=1;
		if(rmc==1)
			RxBuf[j-1]=temp[cnt];
			j++;
			if(temp[cnt]=='*'){msg=1;}
    cnt++;
		if(cnt==0x1E8) cnt=0;
