SSD1963 kodlarını SSD1289 a uyarlamak.
Başlatan Kaanx, 09 Ekim 2013, 12:27:53
Kaanx
Merhaba arkadaşlar elimde SSd1963 ve ssd2119 olması sanırım iki adet kod var işlemci aynı fakat lcd ler farklı benim elimdeki LCD ise SSD1289 var bunları uyarlayabilir miyim ? Sadece LCD.h ve LCD.c değiştirmem yeterli olur mu ?
Mnemonic
elinizdeki SSD1963 dosyalarını paylaşabilirmisiniz ?
Kaanx
Denemenizde fayda var yanlış olabilir. SSD2119 için var sımdılık dıgerını bulamadım
LCD.h
  * @file    stm324xg_discovery_lcd.h
  * @author  MCD Application Team
  * @version V1.0.0
  * @date    30-September-2011
  * @brief   This file contains all the functions prototypes for the
  *          stm324xg_discovery_lcd.c driver.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; Portions COPYRIGHT 2011 STMicroelectronics</center></h2>
  * <h2><center>&copy; Portions COPYRIGHT 2012 Embest Tech. Co., Ltd.</center></h2>
  * @file    stm32f4_discovery_lcd.h
  * @author  CMP Team
  * @version V1.0.0
  * @date    28-December-2012
  *          Modified to support the STM32F4DISCOVERY, STM32F4DIS-BB, STM32F4DIS-CAM
  *          and STM32F4DIS-LCD modules.
  * @attention
  * TIME. AS A RESULT, Embest SHALL NOT BE HELD LIABLE FOR ANY DIRECT, INDIRECT
  * OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE CONTENT
  * OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING INFORMATION
  * CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM32F4_DISCOVERY_LCD_H
#define __STM32F4_DISCOVERY_LCD_H
#ifdef __cplusplus
 extern "C" {
#endif
/* Includes ------------------------------------------------------------------*/
#include "stm32f4xx.h"
#include "fonts.h"
/** @addtogroup Utilities
/** @addtogroup STM32F4_DISCOVERY
/** @addtogroup STM32F4_DISCOVERY_LCD
/** @defgroup STM32F4_DISCOVERY_LCD_Exported_Types
typedef struct
  int16_t X;
  int16_t Y;
} Point, * pPoint;
  * @brief Various internal SD2119 registers name labels
#define SSD2119_DEVICE_CODE_READ_REG  0x00
#define SSD2119_OSC_START_REG         0x00
#define SSD2119_OUTPUT_CTRL_REG       0x01
#define SSD2119_LCD_DRIVE_AC_CTRL_REG 0x02
#define SSD2119_PWR_CTRL_1_REG        0x03
#define SSD2119_DISPLAY_CTRL_REG      0x07
#define SSD2119_FRAME_CYCLE_CTRL_REG  0x0B
#define SSD2119_PWR_CTRL_2_REG        0x0C
#define SSD2119_PWR_CTRL_3_REG        0x0D
#define SSD2119_PWR_CTRL_4_REG        0x0E
#define SSD2119_GATE_SCAN_START_REG   0x0F
#define SSD2119_SLEEP_MODE_1_REG      0x10
#define SSD2119_ENTRY_MODE_REG        0x11
#define SSD2119_SLEEP_MODE_2_REG      0x12
#define SSD2119_GEN_IF_CTRL_REG       0x15
#define SSD2119_PWR_CTRL_5_REG        0x1E
#define SSD2119_RAM_DATA_REG          0x22
#define SSD2119_FRAME_FREQ_REG        0x25
#define SSD2119_ANALOG_SET_REG        0x26
#define SSD2119_VCOM_OTP_1_REG        0x28
#define SSD2119_VCOM_OTP_2_REG        0x29
#define SSD2119_GAMMA_CTRL_1_REG      0x30
#define SSD2119_GAMMA_CTRL_2_REG      0x31
#define SSD2119_GAMMA_CTRL_3_REG      0x32
#define SSD2119_GAMMA_CTRL_4_REG      0x33
#define SSD2119_GAMMA_CTRL_5_REG      0x34
#define SSD2119_GAMMA_CTRL_6_REG      0x35
#define SSD2119_GAMMA_CTRL_7_REG      0x36
#define SSD2119_GAMMA_CTRL_8_REG      0x37
#define SSD2119_GAMMA_CTRL_9_REG      0x3A
#define SSD2119_GAMMA_CTRL_10_REG     0x3B
#define SSD2119_V_RAM_POS_REG         0x44
#define SSD2119_H_RAM_START_REG       0x45
#define SSD2119_H_RAM_END_REG         0x46
#define SSD2119_X_RAM_ADDR_REG        0x4E
#define SSD2119_Y_RAM_ADDR_REG        0x4F
#define ENTRY_MODE_DEFAULT 0x6830
#define ENTRY_MODE_BMP 	   0x6810
#define MAKE_ENTRY_MODE(x) ((ENTRY_MODE_DEFAULT & 0xFF00) | (x))
  * @brief The dimensions of the LCD panel.
#define LCD_VERTICAL_MAX   480
#define LCD_HORIZONTAL_MAX 800
  * @brief Various definitions controlling coordinate space mapping and drawing
           direction in the four supported orientations.
#define PORTRAIT
#ifdef PORTRAIT
#define HORIZ_DIRECTION 0x28
#define VERT_DIRECTION 0x20
#define MAPPED_X(x, y) (319 - (y))
#define MAPPED_Y(x, y) (x)
#endif
#ifdef LANDSCAPE
#define HORIZ_DIRECTION 0x00
#define VERT_DIRECTION  0x08
#define MAPPED_X(x, y) (319 - (x))
#define MAPPED_Y(x, y) (239 - (y))
#endif
#ifdef PORTRAIT_FLIP
#define HORIZ_DIRECTION 0x18
#define VERT_DIRECTION 0x10
#define MAPPED_X(x, y) (y)
#define MAPPED_Y(x, y) (239 - (x))
#endif
#ifdef LANDSCAPE_FLIP
#define HORIZ_DIRECTION 0x30
#define VERT_DIRECTION  0x38
#define MAPPED_X(x, y) (x)
#define MAPPED_Y(x, y) (y)
#endif
/** @defgroup STM32F4_DISCOVERY_LCD_Exported_Constants
 * @brief Uncomment the line below if you want to use user defined Delay function
 *        (for precise timing), otherwise default _delay_ function defined within
 *         this driver is used (less precise timing).
/* #define USE_Delay */
#ifdef USE_Delay
#include "main.h"
  #define _delay_     Delay  /* !< User can provide more timing precise _delay_ function
                                   (with 10ms time base), using SysTick for example */
#else
  #define _delay_     delay      /* !< Default _delay_ function with less precise timing */
#endif
  * @brief  LCD color
#define LCD_COLOR_CUSTOM(r,g,b) ((b%32) + ((g%32) << 5) + ((r%32) << 10)) //convert 24->16bits
#define LCD_COLOR_WHITE          0xFFFF
#define LCD_COLOR_BLACK          0x0000
#define LCD_COLOR_GREY           0xF7DE
#define LCD_COLOR_BLUE           0x001F
#define LCD_COLOR_BLUE2          0x051F
#define LCD_COLOR_RED            0xF800
#define LCD_COLOR_MAGENTA        0xF81F
#define LCD_COLOR_GREEN          0x07E0
#define LCD_COLOR_CYAN           0x7FFF
#define LCD_COLOR_YELLOW         0xFFE0
#define White		         LCD_COLOR_WHITE
#define Black		         LCD_COLOR_BLACK
#define Red		         LCD_COLOR_RED
#define Blue		         LCD_COLOR_BLUE
#define Green		         LCD_COLOR_GREEN
#define Cyan                     LCD_COLOR_CYAN
  * @brief  LCD Lines depending on the chosen fonts.
#define LCD_LINE_0               LINE(0)
#define LCD_LINE_1               LINE(1)
#define LCD_LINE_2               LINE(2)
#define LCD_LINE_3               LINE(3)
#define LCD_LINE_4               LINE(4)
#define LCD_LINE_5               LINE(5)
#define LCD_LINE_6               LINE(6)
#define LCD_LINE_7               LINE(7)
#define LCD_LINE_8               LINE(8)
#define LCD_LINE_9               LINE(9)
#define LCD_LINE_10              LINE(10)
#define LCD_LINE_11              LINE(11)
#define LCD_LINE_12              LINE(12)
#define LCD_LINE_13              LINE(13)
#define LCD_LINE_14              LINE(14)
#define LCD_LINE_15              LINE(15)
#define LCD_LINE_16              LINE(16)
#define LCD_LINE_17              LINE(17)
#define LCD_LINE_18              LINE(18)
#define LCD_LINE_19              LINE(19)
#define LCD_LINE_20              LINE(20)
#define LCD_LINE_21              LINE(21)
#define LCD_LINE_22              LINE(22)
#define LCD_LINE_23              LINE(23)
#define LCD_LINE_24              LINE(24)
#define LCD_LINE_25              LINE(25)
#define LCD_LINE_26              LINE(26)
#define LCD_LINE_27              LINE(27)
#define LCD_LINE_28              LINE(28)
#define LCD_LINE_29              LINE(29)
#define Line0                    LCD_LINE_0
#define Line1                    LCD_LINE_1
#define Line2                    LCD_LINE_2
#define Line3                    LCD_LINE_3
#define Line4                    LCD_LINE_4
#define Line5                    LCD_LINE_5
#define Line6                    LCD_LINE_6
#define Line7                    LCD_LINE_7
#define Line8                    LCD_LINE_8
#define Line9                    LCD_LINE_9
  * @brief LCD default font
#define LCD_DEFAULT_FONT         Font16x24
  * @brief  LCD Direction
#define LCD_DIR_HORIZONTAL       0x0000
#define LCD_DIR_VERTICAL         0x0001
  * @brief  LCD Size (Width and Height)
#define LCD_PIXEL_WIDTH          800
#define LCD_PIXEL_HEIGHT         480
/** @defgroup STM32F4_DISCOVERY_LCD_Exported_Macros
#define ASSEMBLE_RGB(R ,G, B)    ((((R)& 0xF8) << 8) | (((G) & 0xFC) << 3) | (((B) & 0xF8) >> 3))
/** @defgroup STM32F4_DISCOVERY_LCD_Exported_Functions
/** @defgroup
void LCD_DeInit(void);
void STM32f4_Discovery_LCD_Init(void);
void LCD_RGB_Test(void);
void LCD_SetColors(__IO uint16_t _TextColor, __IO uint16_t _BackColor);
void LCD_GetColors(__IO uint16_t *_TextColor, __IO uint16_t *_BackColor);
void LCD_SetTextColor(__IO uint16_t Color);
void LCD_SetBackColor(__IO uint16_t Color);
void LCD_ClearLine(uint16_t Line);
void LCD_Clear(uint16_t Color);
void LCD_SetCursor(uint16_t Xpos, uint16_t Ypos);
void LCD_DrawChar(uint16_t Xpos, uint16_t Ypos, const uint16_t *c);
void LCD_DisplayChar(uint16_t Line, uint16_t Column, uint8_t Ascii);
void LCD_DisplayChars(uint16_t Line, uint16_t Column, uint8_t *ptr);
void LCD_SetFont(sFONT *fonts);
sFONT *LCD_GetFont(void);
void LCD_DisplayStringLine(uint16_t Line, uint8_t *ptr);
void LCD_SetDisplayWindow(uint16_t Xpos, uint16_t Ypos, uint16_t Height, uint16_t Width);
void LCD_WindowModeDisable(void);
void LCD_DrawLine(uint16_t Xpos, uint16_t Ypos, uint16_t Length, uint8_t Direction);
void LCD_DrawRect(uint16_t Xpos, uint16_t Ypos, uint8_t Height, uint16_t Width);
void LCD_DrawCircle(uint16_t Xpos, uint16_t Ypos, uint16_t Radius);
void LCD_DrawMonoPict(const uint32_t *Pict);
void LCD_WriteBMP(uint32_t BmpAddress);
void LCD_DrawUniLine(uint16_t x1, uint16_t y1, uint16_t x2, uint16_t y2);
void LCD_DrawFullRect(uint16_t Xpos, uint16_t Ypos, uint16_t Width, uint16_t Height);
void LCD_DrawFullCircle(uint16_t Xpos, uint16_t Ypos, uint16_t Radius);
void LCD_PolyLine(pPoint Points, uint16_t PointCount);
void LCD_PolyLineRelative(pPoint Points, uint16_t PointCount);
void LCD_ClosedPolyLine(pPoint Points, uint16_t PointCount);
void LCD_ClosedPolyLineRelative(pPoint Points, uint16_t PointCount);
void LCD_FillPolyLine(pPoint Points, uint16_t PointCount);
/** @defgroup
void LCD_WriteReg(uint8_t LCD_Reg, uint16_t LCD_RegValue);
uint16_t LCD_ReadReg(uint8_t LCD_Reg);
void LCD_WriteRAM_Prepare(void);
void LCD_WriteRAM(uint16_t RGB_Code);
uint16_t LCD_ReadRAM(void);
void LCD_PowerOn(void);
void LCD_DisplayOn(void);
void LCD_DisplayOff(void);
/** @defgroup
void LCD_CtrlLinesConfig(void);
void LCD_FSMCConfig(void);
#ifdef __cplusplus
#endif
#endif /* __STM32F4_DISCOVERY_LCD_H */
/*********** Portions COPYRIGHT 2012 Embest Tech. Co., Ltd.*****END OF FILE****/
LCD.c
[code]
  * @file    stm324xg_discovery_lcd.c
  * @version V1.0.0
  * @brief   This file includes the LCD driver for AM-240320L8TNQW00H (LCD_ILI9320)
  *          and AM240320D5TOQW01H (LCD_ILI9325) Liquid Crystal Display Modules
  *          of STM324xG-EVAL evaluation board(MB786) RevB.
  * @attention
  * @file    stm32f4_discovery_lcd.c
  * @author  CMP Team
  * @version V1.0.0
  * @brief   LCD LOW_LEVEL Drive
  * @attention
#include "stm32f4_discovery.h"
#include "lcd.h"
#include "fonts.c"
/** @defgroup stm32f4_discovery_LCD
  * @brief This file includes the LCD driver for (LCDSSD2119)
/** @defgroup stm32f4_discovery_LCD_Private_TypesDef
/** @defgroup stm32f4_discovery_LCD_Private define
#define LCD_RST_PIN                  (GPIO_Pin_3)
#define LCD_RST_PORT                 (GPIOD)
#define LCD_PWM_PIN                  (GPIO_Pin_13)
#define LCD_PWM_PORT                 (GPIOD)
/* Note: LCD /CS is NE1 - Bank 1 of NOR/SRAM Bank 1~4 */
#define  LCD_BASE_Data               ((u32)(0x60000000|0x00100000))
#define  LCD_BASE_Addr               ((u32)(0x60000000|0x00000000))
#define  LCD_CMD                     (*(vu16 *)LCD_BASE_Addr)
#define  LCD_Data                    (*(vu16 *)LCD_BASE_Data)
#define MAX_POLY_CORNERS             200
#define POLY_Y(Z)                    ((int32_t)((Points + Z)->X))
#define POLY_X(Z)                    ((int32_t)((Points + Z)->Y))
/** @defgroup stm32f4_discovery_LCD_Private_Macros
#define ABS(X)  ((X) > 0 ? (X) : -(X))
/** @defgroup stm32f4_discovery_LCD_Private_Variables
static sFONT *LCD_Currentfonts;
  /* Global variables to set the written text color */
static __IO uint16_t TextColor = 0x0000, BackColor = 0xFFFF;
/** @defgroup stm32f4_discovery_LCD_Private_FunctionPrototypes
#ifndef USE_Delay
static void delay(__IO uint32_t nCount);
#endif /* USE_Delay*/
static void PutPixel(int16_t x, int16_t y);
static void LCD_PolyLineRelativeClosed(pPoint Points, uint16_t PointCount, uint16_t Closed);
  * @brief  LCD Default FSMC Init
  * @param  None
  * @retval None
  /*!< LCD Display Off */
  LCD_DisplayOff();
  /* BANK 3 (of NOR/SRAM Bank 1~4) is disabled */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE);
  /*!< LCD_SPI DeInit */
  FSMC_NORSRAMDeInit(FSMC_Bank1_NORSRAM3);
/*-- GPIO Configuration ------------------------------------------------------*/
  /* SRAM Data lines configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
                                GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_MCO);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
                                GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
                                GPIO_Pin_15;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource11 , GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource12 , GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource13 , GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource14 , GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource15 , GPIO_AF_MCO);
  /* SRAM Address lines configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |
                                GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 |
  GPIO_Init(GPIOF, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource0, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource1, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource2, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource3, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource4, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource5, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource12, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource13, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource14, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource15, GPIO_AF_MCO);
                                GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_Init(GPIOG, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource0, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource1, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource2, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource3, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource4, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource5, GPIO_AF_MCO);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource11, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource12, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource13, GPIO_AF_MCO);
  /* NOE and NWE configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 |GPIO_Pin_5;
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource4, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource5, GPIO_AF_MCO);
  /* NE3 configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_PinAFConfig(GPIOG, GPIO_PinSource12, GPIO_AF_MCO);
  /* NBL0, NBL1 configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource0, GPIO_AF_MCO);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource1, GPIO_AF_MCO);
  * @brief  Configures LCD Control lines (FSMC Pins) in alternate function mode.
  * @param  None
  * @retval None
  /* Enable GPIOB, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE |
                         RCC_AHB1Periph_GPIOF, ENABLE);
  /* SRAM Data lines,  NOE and NWE configuration */
                                GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15 |
                                GPIO_Pin_4 |GPIO_Pin_5;;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
                                GPIO_Pin_15;
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource11 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource12 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource13 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource14 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource15 , GPIO_AF_FSMC);
  /* SRAM Address lines configuration LCD-DC */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource3, GPIO_AF_FSMC);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  /* LCD RST configuration */
  GPIO_InitStructure.GPIO_Pin = LCD_RST_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  GPIO_Init(LCD_RST_PORT, &GPIO_InitStructure);
   /* LCD pwm configuration */
  GPIO_InitStructure.GPIO_Pin = LCD_PWM_PIN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_25MHz;
  GPIO_Init(LCD_PWM_PORT, &GPIO_InitStructure);
  GPIO_SetBits(LCD_PWM_PORT, LCD_PWM_PIN);
  * @brief  Configures the Parallel interface (FSMC) for LCD(Parallel mode)
  * @param  None
  * @retval None
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
   LCD_CMD=(0x002A);
   LCD_Data=(x1>>8);
   LCD_Data=(x1&0x00ff);
   LCD_Data=(x2>>8);
   LCD_Data=(x2&0x00ff);
    LCD_CMD=(0x002b);
   LCD_Data=(y1>>8);
   LCD_Data=(y1&0x00ff);
   LCD_Data=(y2>>8);
   LCD_Data=(y2&0x00ff);
   LCD_CMD=(0x002c);
  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  p;
  /* Enable FSMC clock */
  RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
/*-- FSMC Configuration ------------------------------------------------------*/
/*----------------------- SRAM Bank 1 ----------------------------------------*/
  /* FSMC_Bank1_NORSRAM4 configuration */
/* p.FSMC_AddressSetupTime = 1;
  p.FSMC_AddressHoldTime = 0;
  p.FSMC_DataSetupTime = 9;
  p.FSMC_BusTurnAroundDuration = 0;
  p.FSMC_CLKDivision = 0;
  p.FSMC_DataLatency = 0;
  p.FSMC_AccessMode = FSMC_AccessMode_A;*/
  /* Color LCD configuration ------------------------------------
     LCD configured as follow:
        - Data/Address MUX = Disable
        - Memory Type = SRAM
        - Data Width = 16bit
        - Write Operation = Enable
        - Extended Mode = Enable
        - Asynchronous Wait = Disable */
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;*/
       p.FSMC_AddressSetupTime=2; // want 2 :
    p.FSMC_DataSetupTime=5;  // keep
    p.FSMC_AccessMode=FSMC_AccessMode_B/*FSMC_AccessMode_A*/; // B? This is how he does it in ili9325
    p.FSMC_CLKDivision=1; //  ?
    p.FSMC_DataLatency=0;
    p.FSMC_BusTurnAroundDuration=0;
    p.FSMC_AddressHoldTime=0;
// ip.nitialise how the FSMC will work and then enable it
    FSMC_NORSRAMInitStructure.FSMC_Bank=FSMC_Bank1_NORSRAM1; // keep
    FSMC_NORSRAMInitStructure.FSMC_DataAddressMux=FSMC_DataAddressMux_Disable; // keep
    FSMC_NORSRAMInitStructure.FSMC_MemoryType=FSMC_MemoryType_SRAM; // keep
    FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth=FSMC_MemoryDataWidth_16b; // make 8 bit?
    FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode=FSMC_BurstAccessMode_Disable; // keep
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity=FSMC_WaitSignalPolarity_Low;  // keep
    FSMC_NORSRAMInitStructure.FSMC_WrapMode=FSMC_WrapMode_Disable;  // keep
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive=FSMC_WaitSignalActive_BeforeWaitState; // keep
    FSMC_NORSRAMInitStructure.FSMC_WriteOperation=FSMC_WriteOperation_Enable; // keep
    FSMC_NORSRAMInitStructure.FSMC_WaitSignal=FSMC_WaitSignal_Disable; // keep
    FSMC_NORSRAMInitStructure.FSMC_ExtendedMode=FSMC_ExtendedMode_Disable; // keep
    FSMC_NORSRAMInitStructure.FSMC_WriteBurst=FSMC_WriteBurst_Disable; // keep
    FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct=&p;
    FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct=&p;
    FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable; // keep
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
  /* Enable FSMC NOR/SRAM Bank1 */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
  * @brief  LCD Init.
  * @retval None
  unsigned long ulCount;
   int  HDP=799;
int  HT=928;
int  HPS=46;
int  LPS=15;
char   HPW=48;
int  VDP=479;
int  VT=525;
int  VPS=16;
int  FPS=8;
char   VPW=16;
  /* Configure the LCD Control pins */
  LCD_CtrlLinesConfig();
  /* Configure the FSMC Parallel interface */
  LCD_FSMCConfig();
  _delay_(5);
  /* Reset LCD */
  GPIO_ResetBits(LCD_RST_PORT, LCD_RST_PIN);
  _delay_(10);
  GPIO_SetBits(LCD_RST_PORT, LCD_RST_PIN);
   LCD_CMD = (0x00E2);   //PLL multiplier, set PLL clock to 120M
   LCD_Data = (0x0023);       //N=0x36 for 6.5M, 0x23 for 10M crystal
   LCD_Data = (0x0002);
   LCD_Data = (0x0004);
   LCD_CMD = (0x00E0);  // PLL enable
   LCD_Data = (0x0001);
   _delay_(10);
   LCD_CMD = (0x00E0);
   LCD_Data = (0x0003);
   _delay_(50);
   LCD_CMD = (0x0001);  // software reset
   _delay_(50);
   LCD_CMD = (0x00E6);   //PLL setting for PCLK, depends on resolution
   LCD_Data = (0x00ff);
   LCD_CMD = (0x00B0);   //LCD SPECIFICATION
   LCD_Data = (0x0027);
   LCD_Data = (0x0000);
   LCD_Data = ((HDP>>8)&0X00FF);  //Set HDP
   LCD_Data = (HDP&0X00FF);
    LCD_Data = ((VDP>>8)&0X00FF);  //Set VDP
   LCD_Data = (VDP&0X00FF);
   LCD_CMD = (0x00B4);   //HSYNC
   LCD_Data = ((HT>>8)&0X00FF);  //Set HT
   LCD_Data = (HT&0X00FF);
   LCD_Data = ((HPS>>8)&0X00FF);  //Set HPS
   LCD_Data = (HPS&0X00FF);
   LCD_Data = (HPW);            //Set HPW
   LCD_Data = ((LPS>>8)&0X00FF);  //Set HPS
   LCD_Data = (LPS&0X00FF);
   LCD_CMD = (0x00B6);   //VSYNC
   LCD_Data = ((VT>>8)&0X00FF);   //Set VT
   LCD_Data = (VT&0X00FF);
   LCD_Data = ((VPS>>8)&0X00FF);  //Set VPS
   LCD_Data = (VPS&0X00FF);
   LCD_Data = (VPW);            //Set VPW
   LCD_Data = ((FPS>>8)&0X00FF);  //Set FPS
   LCD_Data = (FPS&0X00FF);
   LCD_CMD = (0x0036); //rotation
   LCD_CMD = (0x00F0); //pixel data interface
   _delay_(50);
   LCD_CMD = (0x0029); //display on
//   LCD_CMD = (0x00d0);
   //LCD_Data = (0x000d);
   Address_set(0,0,799,479);
  for(ulCount = 0; ulCount < (LCD_PIXEL_WIDTH * LCD_PIXEL_HEIGHT); ulCount++)
    LCD_WriteRAM(0x0000);
  LCD_SetFont(&LCD_DEFAULT_FONT);
  * @brief  Sets the cursor position.
  * @param  Xpos: specifies the X position.
  * @param  Ypos: specifies the Y position.
  * @retval None
  /* Set the X address of the display cursor.*/
//  LCD_WriteReg(SSD2119_X_RAM_ADDR_REG, Xpos);
  /* Set the Y address of the display cursor.*/
  //LCD_WriteReg(SSD2119_Y_RAM_ADDR_REG, Ypos);
   uint16_t x2 = 799;
   uint16_t y2 = 479;
   LCD_CMD=(0x002A);
   LCD_Data=(Xpos>>8);
   LCD_Data=(Xpos&0x00ff);
   LCD_Data=(x2>>8);
    LCD_CMD=(0x002b);
   LCD_Data=(Ypos>>8);
   LCD_Data=(Ypos&0x00ff);
   LCD_Data=(y2>>8);
   LCD_CMD=(0x002c);
  * @brief  Writes to the selected LCD register.
  * @param  LCD_Reg: address of the selected register.
  * @param  LCD_RegValue: value to write to the selected register.
  * @retval None
  /* Write 16-bit Index, then Write Reg */
  LCD_CMD = LCD_Reg;
  /* Write 16-bit Reg */
  LCD_Data = LCD_RegValue;
  * @brief  Reads the selected LCD Register.
  * @retval LCD Register Value.
  /* Write 16-bit Index (then Read Reg) */
  LCD_CMD = LCD_Reg;
  /* Read 16-bit Reg */
  return (LCD_Data);
  * @brief  Prepare to write to the LCD RAM.
  * @param  None
  * @retval None
   //LCD_CMD = SSD2119_RAM_DATA_REG;
   LCD_CMD = 0x2c;
  * @brief  Writes to the LCD RAM.
  * @param  RGB_Code: the pixel color in RGB mode (5-6-5).
  * @retval None
  /* Write 16-bit GRAM Reg */
  LCD_Data = RGB_Code;
  * @brief  Reads the LCD RAM.
  * @param  None
  * @retval LCD RAM Value.
//  LCD_CMD = SSD2119_RAM_DATA_REG; /* Select GRAM Reg */
  return LCD_Data;
  * @brief  Test LCD Display
  * @retval None
  uint32_t index;
  LCD_SetCursor(0x00, 0x00);
  LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
   /* R */
  for(index = 0; index < (LCD_PIXEL_HEIGHT*LCD_PIXEL_WIDTH)/3; index++)
    LCD_Data = LCD_COLOR_RED;
  /* G */
  for(;index < 2*(LCD_PIXEL_HEIGHT*LCD_PIXEL_WIDTH)/3; index++)
    LCD_Data = LCD_COLOR_GREEN;
   /* B */
  for(; index < LCD_PIXEL_HEIGHT*LCD_PIXEL_WIDTH; index++)
    LCD_Data = LCD_COLOR_BLUE;
  * @brief  Sets the LCD Text and Background colors.
  * @param  _TextColor: specifies the Text Color.
  * @param  _BackColor: specifies the Background Color.
  * @retval None
  TextColor = _TextColor;
  BackColor = _BackColor;
  * @brief  Gets the LCD Text and Background colors.
  * @param  _TextColor: pointer to the variable that will contain the Text
            Color.
  * @param  _BackColor: pointer to the variable that will contain the Background
            Color.
  * @retval None
  *_TextColor = TextColor; *_BackColor = BackColor;
  * @brief  Sets the Text color.
  * @param  Color: specifies the Text color code RGB(5-6-5).
  * @retval None
  TextColor = Color;
  * @brief  Sets the Background color.
  * @param  Color: specifies the Background color code RGB(5-6-5).
  * @retval None
  BackColor = Color;
LCD_DisplayOff
LCD_DisplayOn
  * @brief  Sets the Text Font.
  * @param  fonts: specifies the font to be used.
  * @retval None
  LCD_Currentfonts = fonts;
  * @brief  Gets the Text Font.
  * @param  None.
  * @retval the used font.
  return LCD_Currentfonts;
  * @brief  Clears the selected line.
  * @param  Line: the Line to be cleared.
  *   This parameter can be one of the following values:
  *     @arg Linex: where x can be 0..n
  * @retval None
  uint16_t refcolumn = 0;
  do {
       /* Display one character on LCD */
    LCD_DisplayChar(Line, refcolumn, ' ');
    /* Decrement the column position by 16 */
    refcolumn += LCD_Currentfonts->Width;
  } while (refcolumn < LCD_PIXEL_WIDTH);
  * @brief  Clears the hole LCD.
  * @param  Color: the color of the background.
  * @retval None
  uint32_t index = 0;
  //LCD_SetCursor(0x00, 0x00);
  //LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
  for(index = 0; index < LCD_PIXEL_HEIGHT*LCD_PIXEL_WIDTH; index++)
    LCD_Data = Color;
  * @brief  Displays a pixel.
  * @param  x: pixel x.
  * @param  y: pixel y.
  * @retval None
  if(x < 0 || x > LCD_PIXEL_WIDTH-1 || y < 0 || y > LCD_PIXEL_HEIGHT-1)
    return;
  LCD_DrawLine(x, y, 1, LCD_DIR_HORIZONTAL);
  * @brief  Draws a character on LCD.
  * @param  Xpos: the Line where to display the character shape.
  * @param  Ypos: start column address.
  * @param  c: pointer to the character data.
  * @retval None
  uint32_t index = 0, i = 0;
  uint16_t  Xaddress = 0;
  Xaddress = Xpos;
  LCD_SetCursor(Ypos, Xaddress);
  for(index = 0; index < LCD_Currentfonts->Height; index++)
    for(i = 0; i < LCD_Currentfonts->Width; i++)
      if((((c[index] & ((0x80 << ((LCD_Currentfonts->Width / 12 ) * 8 ) ) >> i)) == 0x00) &&(LCD_Currentfonts->Width <= 12))||
        (((c[index] & (0x1 << i)) == 0x00)&&(LCD_Currentfonts->Width > 12 )))
        LCD_WriteRAM(BackColor);
        LCD_WriteRAM(TextColor);
    Xaddress++;
  * @brief  Displays one character (16dots width, 24dots height).
  * @param  Line: the Line where to display the character shape .
  *     @arg Linex: where x can be 0..9
  * @param  Column: start column address.
  * @param  Ascii: character ascii code, must be between 0x20 and 0x7E.
  * @retval None
  Ascii -= 32;
  LCD_DrawChar(Line, Column, &LCD_Currentfonts->table[Ascii * LCD_Currentfonts->Height]);
void LCD_DisplayChars(uint16_t Line, uint16_t Column, uint8_t *ptr){
   uint16_t refcolumn = Column;
  while (*ptr != 0)
         LCD_DisplayChar(Line, refcolumn, *ptr);
            if (refcolumn >= LCD_PIXEL_WIDTH) {
               break;
      ptr++;
  * @brief  Displays a maximum of 20 char on the LCD.
  * @param  *ptr: pointer to string to display on LCD.
  * @retval None
  /* Send the string character by character on lCD */
  while (*ptr != 0)
      break;
    /* Point on the next character */
    ptr++;
  * @brief  Sets a display window
  * @param  Xpos: specifies the X bottom left position.
  * @param  Ypos: specifies the Y bottom left position.
  * @param  Height: display window width.
  * @param  Width: display window Height.
  * @retval None
void LCD_SetDisplayWindow(uint16_t Xpos, uint16_t Ypos, uint16_t width, uint16_t Height)
  uint32_t value = 0;
  LCD_WriteReg(SSD2119_H_RAM_START_REG, Xpos);
  if ((Xpos+width) >= LCD_PIXEL_WIDTH) {
    LCD_WriteReg(SSD2119_H_RAM_END_REG, LCD_PIXEL_WIDTH-1);
  } else {
    LCD_WriteReg(SSD2119_H_RAM_END_REG, Xpos+width);
  if ((Ypos+Height) >= LCD_PIXEL_HEIGHT) {
    value = (LCD_PIXEL_HEIGHT-1) << 8;
  } else {
    value = (Ypos+Height) << 8;
  value |= Xpos;
  LCD_WriteReg(SSD2119_V_RAM_POS_REG, value);
  LCD_SetCursor(Xpos, Ypos);
  * @brief  Disables LCD Window mode.
  * @param  None
  * @retval None
#if 0
  LCD_SetDisplayWindow(239, 0x13F, 240, 320);
  LCD_WriteReg(LCD_REG_3, 0x1018);
#endif
  * @brief  Displays a line.
  * @param Length: line length.
  * @param Direction: line direction.
  *   This parameter can be one of the following values: Vertical or Horizontal.
  * @retval None
  uint32_t i = 0;
  if(Direction == LCD_DIR_HORIZONTAL)
    for(i = 0; i < Length; i++)
      Ypos++;
  * @brief  Displays a rectangle.
  * @param  Height: display rectangle height.
  * @param  Width: display rectangle width.
  * @retval None
  LCD_DrawLine(Xpos, Ypos, Width, LCD_DIR_VERTICAL);
  LCD_DrawLine((Xpos + Height-1), Ypos, Width, LCD_DIR_VERTICAL);
  LCD_DrawLine(Xpos, Ypos, Height, LCD_DIR_HORIZONTAL);
  LCD_DrawLine(Xpos, (Ypos + Width), Height, LCD_DIR_HORIZONTAL);
  * @brief  Displays a circle.
  * @param  Radius
  * @retval None
  int32_t  D;/* Decision Variable */
  uint32_t  CurX;/* Current X Value */
  uint32_t  CurY;/* Current Y Value */
  D = 3 - (Radius << 1);
  CurX = 0;
  CurY = Radius;
  while (CurX <= CurY)
    LCD_SetCursor(Xpos + CurX, Ypos + CurY);
    LCD_SetCursor(Xpos + CurX, Ypos - CurY);
    LCD_SetCursor(Xpos - CurX, Ypos + CurY);
    LCD_SetCursor(Xpos - CurX, Ypos - CurY);
    LCD_SetCursor(Xpos + CurY, Ypos + CurX);
    LCD_SetCursor(Xpos + CurY, Ypos - CurX);
    LCD_SetCursor(Xpos - CurY, Ypos + CurX);
    LCD_SetCursor(Xpos - CurY, Ypos - CurX);
    if (D < 0)
      D += (CurX << 2) + 6;
      D += ((CurX - CurY) << 2) + 10;
      CurY--;
    CurX++;
  * @brief  Displays a mono-color picture.
  * @param  Pict: pointer to the picture array.
  * @retval None
  LCD_SetCursor(0, (LCD_PIXEL_WIDTH - 1));
  for(index = 0; index < 2400; index++)
    for(i = 0; i < 32; i++)
      if((Pict[index] & (1 << i)) == 0x00)
  * @brief  Displays a bitmap picture loaded in the internal Flash.
  * @param  BmpAddress: Bmp picture address in the internal Flash.
  * @retval None
  uint32_t index = 0, size = 0;
//   LCD_SetCursor(0,0);
      LCD_CMD = 0x0036;
   LCD_Data = 0x0080;//4
//   Address_set(0,0,799,479);
   LCD_SetCursor(0,0);
  /* Read bitmap size */
  size = *(__IO uint16_t *) (BmpAddress + 2);
  size |= (*(__IO uint16_t *) (BmpAddress + 4)) << 16;
  /* Get bitmap data address offset */
  index = *(__IO uint16_t *) (BmpAddress + 10);
  index |= (*(__IO uint16_t *) (BmpAddress + 12)) << 16;
  size = (size - index)/2;
  BmpAddress += index;
  /* Set entrypoint and derection for bmp*/
// LCD_WriteReg(SSD2119_ENTRY_MODE_REG , ENTRY_MODE_BMP );
//  LCD_WriteRAM_Prepare();
  for(index = 0; index < size; index++)
    LCD_WriteRAM(*(__IO uint16_t *)BmpAddress);
    BmpAddress += 2;
  /* Set GRAM write direction and BGR = 1 */
  /* I/D = 01 (Horizontal : increment, Vertical : decrement) */
  /* AM = 1 (address is updated in vertical writing direction) */
// LCD_WriteReg(LCD_REG_3, 0x1018);
         LCD_CMD = 0x0036;
   LCD_Data = 0x0000;
  * @brief  Displays a full rectangle.
  * @param  Height: rectangle height.
  * @param  Width: rectangle width.
  * @retval None
  LCD_SetTextColor(TextColor);
  LCD_DrawLine(Xpos, Ypos, Width, LCD_DIR_HORIZONTAL);
  LCD_DrawLine(Xpos, (Ypos+Height), Width, LCD_DIR_HORIZONTAL);
  LCD_DrawLine(Xpos, Ypos, Height, LCD_DIR_VERTICAL);
  LCD_DrawLine((Xpos+Width-1), Ypos, Height, LCD_DIR_VERTICAL);
  Height--;
  Ypos++;
  LCD_SetTextColor(BackColor);
  while(Height--)
    LCD_DrawLine(Xpos, Ypos++, Width, LCD_DIR_HORIZONTAL);
  * @brief  Displays a full circle.
  * @param  Radius
  * @retval None
  int32_t  D;    /* Decision Variable */
  CurX = 0;
  CurY = Radius;
    if(CurY > 0)
      LCD_DrawLine(Xpos - CurX, Ypos + CurY, 2*CurY, LCD_DIR_HORIZONTAL);
      LCD_DrawLine(Xpos + CurX, Ypos + CurY, 2*CurY, LCD_DIR_HORIZONTAL);
    if(CurX > 0)
      LCD_DrawLine(Xpos - CurY, Ypos + CurX, 2*CurX, LCD_DIR_HORIZONTAL);
      LCD_DrawLine(Xpos + CurY, Ypos + CurX, 2*CurX, LCD_DIR_HORIZONTAL);
    if (D < 0)
      CurY--;
    CurX++;
  LCD_DrawCircle(Xpos, Ypos, Radius);
  * @brief  Displays an uni-line (between two points).
  * @param  x1: specifies the point 1 x position.
  * @param  y1: specifies the point 1 y position.
  * @param  x2: specifies the point 2 x position.
  * @param  y2: specifies the point 2 y position.
  * @retval None
  int16_t deltax = 0, deltay = 0, x = 0, y = 0, xinc1 = 0, xinc2 = 0,
  yinc1 = 0, yinc2 = 0, den = 0, num = 0, numadd = 0, numpixels = 0,
  curpixel = 0;
  deltax = ABS(x2 - x1);        /* The difference between the x's *
Mnemonic
teşekkür ederim
ancak banada ssd1963 için olan gerekli
Kaanx
Arkadaşlar SsD1289 a kodları uyarladım fakat yatay eksende çizdiremedik dikey olarak çiziyor suan horizontal ve vertical değişimi nasıl yapabilirim fikri olan var mı ?
Alıntı yapılan: Kaanx - 16 Ekim 2013, 17:19:18
Hocam neden direk ssd1289 kütüphanesi kullanmıyorsunuz?
Kaanx
Hocam en baştan ben uyarlamaya çalıştım daha sonra anladım ki aynı komutlar var .h da direk kullanmaya basladım uyarladım demem yukarıda uyarlamam gerekiyor demiştim ya o yuzden öyle dedim yani.
ekrana çizdirdiğim fonksiyonalr sunlar hocam
audiogr.h
#ifndef __STM32F4_AUDIOGR_H
#define __STM32F4_AUDIOGR_H
#ifdef __cplusplus
 extern "C" {
#endif
#include "lcd.h"
#define WIDTH 15
#define GREENc 80
#define YELLOWc 120
#define REDc 170
#define HARDC 0xff
#define SOFTC 0x1f
#define SOFTTOP 10
void drawBar(uint16_t Xpos, uint16_t Height, uint16_t MHeight);
#ifdef __cplusplus
#endif
audiogr.c
#include <stdio.h>
#include "lcd.h"
#include "audiogr.h"
#include "delay.h"
void drawBar(const uint16_t Xpos, const uint16_t Height, const uint16_t MHeight){
	uint16_t Ypos = 0;
	uint8_t Wd = 0;
	uint8_t Cr = 0, Cg = 0, Cb = 0;
	for(Ypos = 0; Ypos < Height && Ypos < 240; Ypos++){
		Delay(50);
		Delay(50);
		if(Ypos > REDc) Cr = 0, Cg = 0, Cb = 0;
		if(Ypos < REDc) Cr = HARDC, Cg = 0, Cb = 0;
		if(Ypos < YELLOWc) Cr = HARDC, Cg = HARDC, Cb = 0;
		if(Ypos < GREENc) Cr = 0, Cg = HARDC, Cb = 0;
		for(Wd = 0; Wd < WIDTH; Wd++){
				LCD_WriteRAM(ASSEMBLE_RGB(Cr ,Cg, Cb));Delay(15);
	for(Ypos = Ypos; Ypos < MHeight && Ypos < 240; Ypos++){
	LCD_SetCursor(Xpos, Ypos);Delay(25);
		LCD_WriteRAM_Prepare();Delay(25);
		/*-----2.çizdirme yöntemi-------*/
		/*if(Ypos > REDc) Cr = 0, Cg = 0, Cb = 0;
		if(Ypos < REDc ) Cr = SOFTC, Cg = 0, Cb = 0;
		if(Ypos < YELLOWc) Cr = SOFTC, Cg = SOFTC, Cb = 0;
		if(Ypos < GREENc) Cr = 0, Cg = SOFTC, Cb = 0;
		if(Ypos < MHeight - SOFTTOP) Cr = 0, Cg = 0, Cb = 0;*/
		/*-------3. çizdirme yöntemi------- */
		/*if(Ypos > RED) Cr = 0, Cg = 0, Cb = 0;
		if(Ypos < RED ) Cr = 0, Cg = 0, Cb = SOFTC;
		if(Ypos < YELLOW) Cr = 0, Cg = 0, Cb = SOFTC;
		if(Ypos < GREEN) Cr = 0, Cg = 0, Cb = SOFTC;
	while(Ypos <= 240){
				LCD_WriteRAM(ASSEMBLE_RGB(0,0,0));
		Ypos++;
Xpos ve Ypos değiştirdim fakat bi işe yaramadı Y ekseninde bişiler olustu ama yine X de çizdirdi yani her iki eksende olustu hocam. Eğer değişiklik yapmazsam yukarıdaki kod x ekseninde güzel çizdiriyor bar ları
Kaanx
Hocam sonuc böyle 2 ayrı foto da göstermeye calsıtım Y eksenine gecemiyorum gecıyor fakat çizgi olusuyor sadece
Hocam çizim yaptıgım fonksiyonu tekrar veriyorum birisi yardım eder belki :)
audiogr.h
#ifdef __cplusplus
 extern "C" {
#endif
#include "lcd.h"
#define WIDTH 15
#define GREENc 80
#define YELLOWc 120
#define REDc 170
#define HARDC 0xff
#define SOFTC 0x1f
#define SOFTTOP 10
void drawBar(uint16_t Ypos, uint16_t Height, uint16_t MHeight);
#ifdef __cplusplus
#endif
#include <stdio.h>
#include "lcd.h"
#include "delay.h"
	uint16_t Ypos = 0;
	uint8_t Wd = 0;
		Delay(50);
		Delay(50);
	while(Ypos <= 240){
		Ypos++;
