kod değişikliği
Başlatan fatefate420, 17 Aralık 2013, 18:13:27
fatefate420
ekteki dosyada bulunan program 12f615 için yazılmış bunu 12f675 e çevirme şansımız varmıdır
piclerle ilgili çok fazla bilgim yok daha yeni başlıyorum sayılır yardımcı olabiliseniz sevinirim
list       F=inhx8m, P=12F615, R=hex, N=0
#include  P12F615.inc; PIC definitions
 __config _BOR_ON & _IOSCFS_8MHZ & _CP_OFF & _MCLRE_ON & _PWRTE_OFF & _WDT_OFF & _INTOSCIO
 Errorlevel -302, -224     ; switches off Message [302]: Register in operand not in bank 0.
; Definitions -------------------------------------------------------------
#define OutputPin porta,0
#define ToggleSelect porta,5
#define SensitivitySelect porta,4
#define PreviousButtonState Flags,0
; RAM preserved -----------------------------------------------------------
	cblock 0x40
		WaitCounter,WaitCounter2
		PassArg1,PassArg2
		PassArg3,PassArg4
		Press_Threshold_H,Press_Threshold_L
		Release_Threshold_H,Release_Threshold_L
		Flags
	endc
; Conastants --------------------------------------------------------------
GLPressHysteresis_H			=		b'00000001'		;High sensitivity
GLPressHysteresis_L			=		b'00000010'		;High sensitivity
GLReleaseHysteresis_H		=		b'00000001'		;High sensitivity
GLReleaseHysteresis_L		=		b'00000000'		;High sensitivity
GLPressHysteresis_H_2		=		b'00000001'		;Low sensitivity
GLPressHysteresis_L_2		=		b'00001110'		;Low sensitivity
GLReleaseHysteresis_H_2		=		b'00000001'		;Low sensitivity
GLReleaseHysteresis_L_2		=		b'00001000'		;Low sensitivity
; Program Memory ----------------------------------------------------------
                org     0
                goto    Init
; Interrupt Service Routine -----------------------------------------------
                org     4               ; ISR beginning
; Microcontroller initialization
Init
				include myInitilization.inc	;Include the PIC Initialization routine
; Main Program ------------------------------------------------------------
Start
				;TRIS setup
				bank1					;Go to bank 1
				movlw b'11111010'		;
				movwf TRISA				;Set the port pin types of the RA
				bank0					;Go to bank 0
				bcf OutputPin
				MOVLW b'11100111'
				option
				bsf cmcon0,CMON			;Enable comparator
				bcf cmcon0,CMPOL		;Logic is inverted
				bcf cmcon0,COUT			;
				bsf cmcon0,CMOE			;Output to COUT pin
				bsf cmcon0,CMR			;V+ driven to Vref
				bcf cmcon0,CMCH			;V- driven to channel 0
				bcf CMCON1,T1ACS		;Timer 1 Clock Source is Instruction Clock (FOSC\4)
				bcf CMCON1,CMHYS		;Comparator Hysteresis disabled
				bsf CMCON1,T1GSS		;Timer 1 Gate Source is T1G pin (pin should be configured as digital input)
				bcf CMCON1,CMSYNC		;Output is asynchronous
				movlw b'00010000'
				movwf vrcon
				;Set the press threshold
				call wait250msec
				call wait250msec
				call wait250msec
				call wait250msec			;Wait for frequency to become stable
				call GetFrequencyCount
				movlw GLPressHysteresis_H_2
				btfsc SensitivitySelect
				subwf passarg1,w			;Sub from count HIGH the HIGH byte of Press Thresshold
				movwf Press_Threshold_H		;And save it to memory
				movlw GLPressHysteresis_L_2
				subwf passarg2,w			;Sub from count LOW the LOW byte of Press Thresshold
				movwf Press_Threshold_L		;And save it to memory
				;Set the release threshold
				movlw GLReleaseHysteresis_H_2
				subwf passarg1,w			;Sub from count HIGH the HIGH byte of Release Thresshold
				movwf Release_Threshold_H	;And save it to memory
				movlw GLReleaseHysteresis_L_2
				subwf passarg2,w			;Sub from count LOW the LOW byte of Release Thresshold
				movwf Release_Threshold_L	;And save it to memory
MainLoop
				;Check if pressed
				movf passarg2,w
				movwf passarg4				;Save Prescaller Count
				movf passarg1,w
				movwf passarg3				;Save TMR0 Count
				movf Press_Threshold_L,w
				subwf passarg2,w			; R= Prescaller - LOW threshold
				btfss carry
				decf passarg1,f				;If R < 0, decrease passarg1 (TMR0 count)
				movf Press_Threshold_H,w
				subwf passarg1,w			; R= TMR0 - HIGH threshold
				btfsc carry
				goto IsNotPressed			;If R < 0, Button is NOT Pressed
											;Else is pressed
				btfss ToggleSelect			;If ToggleSelect is LOW (pushbutton action)
				goto ActivateOutput			;Then just activate output
				btfsc PreviousButtonState	;Else, check if previous state was RELEASED
				goto PressReleaseCheckDone	;If not, then do nothing
											;If WAS released...
				bsf PreviousButtonState		;Update previous state
				movlw b'00000001'
				xorwf PORTA,f				;Toggle output
				call wait100msec			;and wait 100msec
ActivateOutput
				bsf OutputPin
IsNotPressed	;Check if released
				movf passarg3,w
				movwf passarg1				;Restore TMR0 Count
				movf Release_Threshold_L,w
				btfss carry
				decf passarg1,f				;If R < 0, decrease passarg3 (TMR0 count)
				movf Release_Threshold_H,w
				btfss carry
				goto PressReleaseCheckDone	;If R > 0, Button is NOT Released
											;Else is released
				bcf OutputPin				;Then deactivate output
				bcf PreviousButtonState		;else (Toggle) do not deactivate it
				goto MainLoop
GetFrequencyCount
				;This sub returns PassArg1:PassArg2 as the TMR0:Prescaller count
				clrf passarg1
				movlw d'44' 				; Set the maximum prescaller value
				movwf passarg2				; to start decreasing (max 43+1)
				clrf tmr0
				call wait10msec
				call wait10msec
				call wait10msec
				call wait10msec
				call wait10msec
				call wait10msec
				movf tmr0,w
				movwf passarg1
				MOVLW b'11000111'	;Tmr0 source is Fosc/4
				option
GetPrescallerValue
				decF passarg2,f				;1
				MOVF tmr0,w					;1
				XORWF passarg1,w			;1
				BTFSC status,z				;1
				GOTO GetPrescallerValue		;2 = total 6 instruction cycles
				;So, it prescaller is 0 (min), we can measure (ceil)255/6=43
				MOVLW b'11100111'			;Tmr0 source is T0CKI
				option
				return
				include mSecDelays8MHz.inc
Fins
                end             ; end of program
bu satırlarda P =12f675
p12F675.inc
olarak değiştir,
mplab da program nasıl derlenir öğren,
mplabta bu programı derle,
isis biliyorsan simulasyonda dene,
ama 615 ile 675 arasındaki farklara bakman lazım
programda 615 in neleri kullanılmışsa
port timer vs. register lar
bunların yeni kullanacağın picdede aynı olması lazım
yoksa kodları ona göre düzenlemen gerekir.
