haberleşme sorun
Başlatan barut, 19 Aralık 2013, 22:23:33
barut
alıcı
#include <16f877.h>
#use delay(CLOCK=4000000)
#use fast_io(b)
#fuses XT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP,NOWDT
#use rs232 (baud=9600, xmit=PIN_C6, RCV=PIN_C7, parity=N, stop=1)
char temp=0;
#INT_RDA
void seri_kesme()
disable_interrupts(INT_RDA);
temp=getc();
void main()
set_tris_b(0x00);
output_b(0x00);
output_a(0x00);
enable_interrupts(GLOBAL);
while(true)
enable_interrupts(int_rda);
if(temp=='S')
temp=0X00;
output_bit(PIN_B0,1);
output_bit(PIN_B1,1);
output_bit(PIN_B2,1);
output_bit(PIN_B3,1);
if(temp=='A')
temp=0X00;
output_bit(PIN_B0,0);
output_bit(PIN_B1,0);
output_bit(PIN_B2,0);
output_bit(PIN_B3,0);
verici
#include <16f877.h>
#use fast_io(b)
#use fast_io(a)
void main()
set_tris_a(0x03);
set_tris_b(0x00);
output_b(0);
putc(0x55);
putc(0x55);
putc(0x55);
putc(0x55);
putc(0x55);
putc(0x00);
putc(0x00);
putc(0x00);
putc(0x00);
putc(0x00);
putc(0xFF);
putc(0xFF);
putc(0xFF);
putc(0xFF);
putc(0xFF);
while(true)
if(input(pin_a0))
putc('S');
output_high(pin_b0);
if(input(pin_a1))
putc('A');
output_high(pin_b1);
udea nın rf modulunu kullanıyorum.Devre pratikte çalımıyor önerisi olan var mı acaba?
jrcapa
Uyandırma kodlarını putc('S') ve putc('A) komutlarından hemen önce göndermelisin ki data gönderildiği anda alıcı uyanık vaziyette olsun.
esensoy
Mesela;
#include <16f877.h>
#use fast_io(b)
#use fast_io(a)
void gonder(int veri);
void main()
set_tris_a(0x03);
set_tris_b(0x00);
output_b(0);
while(true)
if(input(pin_a0))
gonder('S');
if(input(pin_a1))
gonder('A');
void gonder(int veri){
putc(0x55);
putc(0x55);
putc(0x55);
putc(0x55);
putc(0x55);
putc(0x00);
putc(0x00);
putc(0x00);
putc(0x00);
putc(0x00);
putc(0xFF);
putc(0xFF);
putc(0xFF);
putc(0xFF);
putc(0xFF);
putc(veri);
barut
int veri mi yazmalıyım char veri mi
esensoy
#include <16f877.h>
#use fast_io(b)
char temp=0;
#INT_RDA
void seri_kesme(){
temp=getc();
void main()
set_tris_b(0x00);
output_b(0x00);
output_a(0x00);
while(true)
if(temp=='S')
temp=0X00;
if(temp=='A')
temp=0X00;
bu kodun çalışması lazım, çalışmaz ise dosyalarını yükle, kendi pc mde bakayım
esensoy
1 virtual terminal baud rate ini 9600 e ayarlamışsın, 1200 e çevirdim,
2 isiste piclerin hızlarını 1MHz olarak bırakmışsın, 4MHz yaptım,
3 use rs232 satırına bits=8 yazmamışsın, bu sebepten sanırım ilk gönderilen 0x55 karşıya 0x25 olarak gidiyordu, bits=8 yazınca düzeldi,
4 0x55 ten sonra 00 ve FF neden gönderiyorsun? 434 benzeri rf alıcı vericiler için gerek yok diye biliyorum,
genel değişiklikler yaptım, simulasyon çalışıyor,
http://s3.dosya.tc/server15/lNcmTE/f8771200.rar.html
barut
Devre gerçekte çalışmıyor.alıcı taraftaki ledler sürekli yanıp sonuyor.
engineer42
iki gün önce benzer sorun yaşadım.. microdenetleyicinin dahili osilatörünü kullanarak dene.. kristalde sorun olabilir
tigris
haberleşme hızın 9600 bu rf için çok yüksek olabilir buna benzer bir projeyi piyasadaki çin malı rf modüller ile yapmıştım ve hızı 1200 olarak ayarlamıştım.
diğer arkadaşların dediği gibi uyandırma ve senkonazisyon verilerini  her veriyi göndermeden önce göndermelisin ki alıcı kendini hazırlasın.
