stm32f103rb harici kesme
Başlatan handybest06, 20 Aralık 2013, 17:50:33
handybest06
Merhaba stm32f103rb harici kesmeyi öğrenmeye çalışıyorum.Çalışan kodda harici kesme RA0 ile yapılmış.Ben bunu RA1 ile yapmayı denedim ama işin içinden çıkamadım.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32f10x_gpio.h"
#include "stm32f10x_rcc.h"
#include "stm32f10x_usart.h"
#include "stm32f10x_exti.h"
#include "misc.h"
#include "hardware.h"
#include "usart.h"
#include <stdio.h>
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
const char menu[] =
   "\n\r"
   "*********************** MINI-STM32***********************\n\r"
   "*-------------------------------------------------------*\n\r";
/* Private function prototypes -----------------------------------------------*/
void GPIO_Configuration(void);
void NVIC_Configuration(void);
uint8_t KEY_Scan(void);
void Delay(uint16_t time);
/* Private functions ---------------------------------------------------------*/
EXTI_InitTypeDef EXTI_InitStructure;
** º¯ÊıÃû³Æ: main
** ¹¦ÄÜÃèÊö: Ö÷º¯ÊıÈë¿Ú
** ×÷  ¡¡Õß: Dream
** ÈÕ¡¡  ÆÚ: 2010Äê12ÔÂ17ÈÕ
int main(void)
//	uint8_t key;			//¶¨ÒåÒ»¸ö¼üÖµ
	SystemInit();	   		//ÅäÖÃϵͳʱÖÓ72M(°üÀ¨clock, PLL and Flash configuration)
	GPIO_Configuration();	// Òı½ÅÅäÖÃ
	NVIC_Configuration();	//ϵͳÖжÏÅäÖÃ
	USART_Configuration();	//Ò첽ͨĞųõʼ»¯
	USART_Send_Str(menu);
  	/* Connect Key Button EXTI Line to Key Button GPIO Pin */
  	GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource1);
  	/* Configure Key Button EXTI Line to generate an interrupt on falling edge */
  	EXTI_InitStructure.EXTI_Line = EXTI_Line1;			  //ÍⲿÖжÏ0
  	EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;	   	  //ÖжÏģʽ
  	EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;	  //ϽµÑزúÉúÖжÏ
  	EXTI_InitStructure.EXTI_LineCmd = ENABLE;				  //ʹÄÜÖжÏÏß0ÉÏÖжÏ
  	EXTI_Init(&EXTI_InitStructure);
  	while (1)
		LED2 =!LED2;
		Delay(5000);
** º¯ÊıÃû³Æ: GPIO_Configuration
** ¹¦ÄÜÃèÊö: ÅäÖÃIO¿Ú
** ×÷  ¡¡Õß: Dream
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1
							, ENABLE);	// ʹÄܶ˿ÚʱÖÓ£¬ÖØÒª£¡£¡£¡
	/* ÅäÖà LED1¡¢LED2Òı½ÅµÄ¹¦ÄÜ *********************/
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
  	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;		//ͨÓÃÍÆÍìÊä³öģʽ
  	GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;		//Êä³ö×î´óƵÂÊΪ50MHz
  	GPIO_Init(GPIOA, &GPIO_InitStructure);					//³õʼ»¯PA2¡¢PA3
	/* ÅäÖà KEY1¡¢KEY2Òı½ÅµÄ¹¦ÄÜ *********************/
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
  	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;			//ÉÏÀ­ÊäÈëģʽ
  	GPIO_Init(GPIOA, &GPIO_InitStructure);					//³õʼ»¯PA0¡¢PA1
   	/* ÅäÖÃ USART1 Tx (PA9) */
  	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;	 		//¸´ÓÿªÂ©Êä³öģʽ
  	/* ÅäÖÃ USART1 Rx (PA10)  */
  	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;	//¸¡¿ÕÊäÈëģʽ
** º¯ÊıÃû³Æ: KEY_Scan
** ¹¦ÄÜÃèÊö: °´¼ü´¦Àíº¯Êı
				0£¬Ã»ÓĞÈκΰ´¼ü°´ÏÂ	  1£¬KEY1°´Ï
				 2£¬KEY2°´Ï
** ×÷  ¡¡Õß: Dream
	static uint8_t KEY_UP=1;	//°´¼ü°´ËÉ¿ª±êÖ¾
	if(KEY_UP&&(KEY1==0||KEY2==0))
		Delay(10);				//È¥¶¶¶¯
		KEY_UP=0;
		if(KEY1==0)return 1;
		else if(KEY2==0)return 2;
	}else if(KEY1==1&&KEY2==1)KEY_UP=1;
	return 0;					//ÎŞ°´¼ü°´ÏÂ
** º¯ÊıÃû³Æ: Delay
** ¹¦ÄÜÃèÊö: ÑÓʱһ¶Îʱ¼ä
				time <65536;
** ×÷  ¡¡Õß: Dream
	uint16_t i,j;
	for(i=time;i>0;i--)
		for(j=500;j>0;j--);
** º¯ÊıÃû³Æ: NVIC_Configuration
** ¹¦ÄÜÃèÊö: ϵͳÖжϹÜÀí
** ×÷  ¡¡Õß: Dream
	   NVIC_InitTypeDef NVIC_InitStructure;
	    NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
	    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
	    NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn;
	    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
	    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
	    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
	    NVIC_Init(&NVIC_InitStructure);
** º¯ÊıÃû³Æ: EXTI0_IRQHandler
** ¹¦ÄÜÃèÊö: ÍⲿÖжÏ0½øÈë¿Ú
				´¦ÀíÖжϺ¯Êı
** ×÷  ¡¡Õß: Dream
void EXTI0_IRQHandler(void)
  	if(EXTI_GetITStatus(EXTI_Line1) != RESET)
		Delay(50); //ÑÓʱȡÏû¶¶
			LED1 =!LED1; //LED1·­×ª
    	EXTI_ClearITPendingBit(EXTI_Line1);	 //Çå³ıLINE13ÉϵÄÖжϱê־λ
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
** End of File
Örnek kodda yaptığım değişiklikler
GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);   ->   GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource1);
EXTI_InitStructure.EXTI_Line = EXTI_Line0;     ->    EXTI_InitStructure.EXTI_Line = EXTI_Line1; yaptım.
NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;   ->  NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn;
ve kesmedeki EXTI_Line0 ' ları EXTI_Line1 yaptım.Ama bi türlü çalışmıyor.
magnetron
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
AFIO clock'u enable ettin mi ? kodlarda göremedim
handybest06
@magnetron Baktığım örnekler AFIO kullanmamış.Ama bi değişiklik olmadı.
@muhittin hocam bu konuyu bakarkan ilk önce sizin örneklerle karşılaştırarak yapmaya çalıştım.Ama sizin örneğinizde de PA0 kullanılmıştı.
Sorunu çözdüm sıkıntı kesme fonksiyon adından kaynaklanıyormuş.
void EXTI0_IRQHandler(void)    ->   void EXTI1_IRQHandler(void)
sorunu düzeltti.
