ds18b20 tavsiye
Başlatan styx75, 15 Mart 2014, 12:51:28
styx75
selam arkadaşlar
aşağıdaki programı yazdım..tecrübeli arkadaşlar eksik yada falıkları nelerdedir tavsiyelerini yazarsa sevinirim
program çalışmaktadır..
pause 200
TRISB  = 0
TRISA  = %11111
LOW PORTB.7
SYMBOL SEC=PORTA.0
SYMBOL A =PORTA.1
SYMBOL E =PORTA.2
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 4
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 5
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
  DQ var PORTA.3
  deger var word
  derece var word
  SET VAR BYTE
  TOL VAR BYTE
  SC VAR BYTE
  CMCON=7
  SC=0
  READ 0,TOL
  READ 5,SET
  LCDOUT $FE,$48, 3, 3, 0,0, 0, 0, 0, 0
  PAUSE 50
  ILK:
  LCDOUT $FE,$01," BOYLER"
  LCDOUT $FE ,$C0,"SET"," ",#SET,1,"C"
  PAUSE 500
  LCDOUT $FE,$01
  PAUSE 500
  PAUSE 500
  LCDOUT $FE ,$C0,"TOLR"," ",#TOL,1,"C"
  PAUSE 500
  LCDOUT $FE,$01
  PAUSE 500
  PAUSE 1000
'-anadongu-----
  LCDOUT $FE ,$C0,"BASLIYOR"
  PAUSE 3000
basla:
  IF DERECE<=SET-TOL THEN HIGH PORTB.7
  IF DERECE>=SET THEN LOW PORTB.7
  IF SEC=0 THEN GOSUB AYAR
  WHILE SEC=0
  WEND
  PAUSE 10
  GOSUB OKUMA
  GOTO BASLA
'-OKUMA ALT PROG----
OKUMA:
  owout dq, 1,[$CC, $44]
  pause 20
  owout dq, 1,[$CC, $BE]
  owin DQ, 0, [deger.lowbyte, deger.highbyte]
  DERECE=DEGER/16
  LCDOUT $FE ,$C0,"  ", DEC DERECE,1,"C"
  RETURN
'-AYAR ALT PROG-----
  AYAR:
  SC=0
  SC=SC+1
  GOSUB SETD
'-SETD ALT PROG-----
  SETD:
  SETD1:
  LOW PORTB.7
  IF A=0 THEN SET=SET+1
  PAUSE 150
  IF SET>99 THEN SET=1
  IF A=0 THEN GOTO SETD1
  WRITE 5,SET
  SETD2:
  IF E=0 THEN SET=SET-1
  PAUSE 150
  IF SET<1 THEN SET=99
  IF E=0 THEN GOTO SETD2
  WRITE 5,SET
  IF SEC=0 THEN SC=SC+1
  WHILE SEC=0
  WEND
  IF SC=2 THEN GOSUB TL
  IF SC=1 THEN GOTO SETD
'-TOL ALT PROGRAMI----
  TL:
  TLT:
  LOW PORTB.7
  IF A=0 THEN TOL=TOL+1
  PAUSE 150
  IF TOL>15 THEN TOL=1
  IF A=0 THEN GOTO TLT
  WRITE 0,TOL
  TLT1:
  IF E=0 THEN TOL=TOL-1
  PAUSE 150
  IF TOL<1 THEN TOL=15
  IF E=0 THEN GOTO TLT1
  WRITE 0,TOL
  WHILE SEC=0
  WEND
  PAUSE 5
  IF SC=3 THEN GOTO ILK
  IF SC=2 THEN GOTO TL
  END
EFESU
