XTEA şifre kırma, key bulma
Başlatan esensoy, 09 Nisan 2014, 12:21:12
Bitcoin VHDL ile yazılmış sha-256 örneği ilginiz çekebilir RAM kullanımı yüksek olduğundan dolayı içinde RAM blok miktarı FPGA seçilmesinde fayda var.
-- Copyright (C) 2010 Arif Endro Nugroho
-- All rights reserved.
-- Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
-- 1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
-- 2. Redistributions in binary form must reproduce the above copyright   notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
-- THIS SOFTWARE IS PROVIDED BY ARIF ENDRO NUGROHO "AS IS" AND ANY EXPRESS
-- OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
-- WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
-- DISCLAIMED. IN NO EVENT SHALL ARIF ENDRO NUGROHO BE LIABLE FOR ANY
-- DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
-- DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
-- OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
-- HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
-- STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
-- ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-- POSSIBILITY OF SUCH DAMAGE.
-- End Of License.
-- MaxMessage  <= 2^64 bits
-- BlockSize   ==  512 bits
-- WordSize    ==   32 bits
-- MDigestSize ==  256 bits
-- Security    ==  128 bits
-- SHLnx  = (x<<n)
-- SHRnx  = (x>>n)
-- ROTRnx = (x>>n) or (x<<w-n)
-- ROTLnx = (x<<n) or (x>>w-n)
-- f0 = ((x and y) xor (not(x) and z))              --   Ch(x,y,z)
-- f1 = ((x and y) xor (x and z)  xor (y and z)     --  Maj(x,y,z)
-- f2 = ROTR  2(x) xor ROTR 13(x) xor ROTR 22(x)    --   Sigma0(x)
-- f3 = ROTR  6(x) xor ROTR 11(x) xor ROTR 25(x)    --   Sigma1(x)
-- f4 = ROTR  7(x) xor ROTR 18(x) xor SHR   3(x)    --   Tetha0(x)
-- f5 = ROTR 17(x) xor ROTR 19(x) xor SHR  10(x)    --   Tetha1(x)
-- h0 = 0x6a09e667
-- h1 = 0xbb67ae85
-- h2 = 0x3c6ef372
-- h3 = 0xa54ff53a
-- h4 = 0x510e527f
-- h5 = 0x9b05688c
-- h6 = 0x1f83d9ab
-- h7 = 0x5be0cd19
-- k[0-63] looks like better implemented in ROM file
--         with 32 bit in each contants it would take
--         64 x 32 bit storage which equal to
--            2048 bit ROM
-- Step 1
-- W(t) = M(t)                                                  0 <= t <=  15 -- we need 16x32 (512) bit registers
-- W(t) = f5(W(t-2)) + W(t-7) + f4(W(t-15)) + W(t-16);         16 <= t <=  79
-- W    = f5(W(  1)) + W(  6) + f4(W(  14)) + W(  15);         16 <= t <=  79
-- Step 2
-- a = h0; b = h1; c = h2; d = h3; e = h4; f = h5; g = h6; h = h7;
-- Step 3
-- for t 0 step 1 to 63 do
-- T1= h + f3(e) + f0(e, f, g) + k(t) + W(t)
-- T2=     f2(a) + f1(a, b, c)
-- h = g
-- g = f
-- f = e
-- e = d + T1
-- d = c
-- c = b
-- b = a
-- a = T1 + T2
-- Step 4
-- H0 = a + h0;
-- H1 = b + h1;
-- H2 = c + h2;
-- H3 = d + h3;
-- H4 = e + H4;
-- H5 = f + H5;
-- H6 = g + H6;
-- H7 = h + H7;
--  31 63 95 127 159 191 223 255 287 319 351 383 415 447 479 511
-- 0 32 64 96 128 160 192 224 256 288 320 352 384 416 448 480 512
--    0  1  2   3   4   5   6   7   8   9   a   b   c   d   e   f
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity sha256 is
  port(
  m                : in  bit_vector ( 31 downto 0); -- 32 bit data path require 16 clock to load all 512 bits of each block
  init             : in  bit;                       --    initial message
  ld               : in  bit;                       --    load signal
  md               : out bit_vector ( 31 downto 0); --    5 clock after active valid signal is the message hash result
--probe
--a_prb            : out bit_vector ( 31 downto 0);
--b_prb            : out bit_vector ( 31 downto 0);
--c_prb            : out bit_vector ( 31 downto 0);
--d_prb            : out bit_vector ( 31 downto 0);
--e_prb            : out bit_vector ( 31 downto 0);
--f_prb            : out bit_vector ( 31 downto 0);
--g_prb            : out bit_vector ( 31 downto 0);
--h_prb            : out bit_vector ( 31 downto 0);
--k_prb            : out bit_vector ( 31 downto 0);
--w_prb            : out bit_vector ( 31 downto 0);
--ctr2p            : out bit_vector (  3 downto 0);
--ctr3p            : out bit_vector (  5 downto 0);
--sc_pr            : out bit_vector (  1 downto 0);
--probe
  v                : out bit;                       --    hash output valid signal one clock advance
  clk              : in  bit;                       --    master clock signal
  rst              : in  bit                        --    master reset signal
end sha256;
architecture phy of sha256 is
  component c4b
    port (
    cnt            : out bit_vector (  3 downto 0);
    clk            : in  bit;
    rst            : in  bit
  end component;
  component c6b
    port (
    cnt            : out bit_vector (  5 downto 0);
    clk            : in  bit;
    rst            : in  bit
  end component;
  component romk
    port (
    addr           : in  bit_vector (  5 downto 0);
    k              : out bit_vector ( 31 downto 0)
  end component;
  signal   ih      :     bit_vector ( 31 downto 0);
  signal   h0      :     bit_vector ( 31 downto 0);
  signal   h1      :     bit_vector ( 31 downto 0);
  signal   h2      :     bit_vector ( 31 downto 0);
  signal   h3      :     bit_vector ( 31 downto 0);
  signal   h4      :     bit_vector ( 31 downto 0);
  signal   h5      :     bit_vector ( 31 downto 0);
  signal   h6      :     bit_vector ( 31 downto 0);
  signal   h7      :     bit_vector ( 31 downto 0);
  signal   k       :     bit_vector ( 31 downto 0);
  signal   im      :     bit_vector ( 31 downto 0);
  signal   iw      :     bit_vector ( 31 downto 0);
  signal   w       :     bit_vector ( 31 downto 0); -- current working register
  signal   w0      :     bit_vector (511 downto 0); -- working register 1
  signal   a       :     bit_vector ( 31 downto 0); -- a register
  signal   b       :     bit_vector ( 31 downto 0); -- b register
  signal   c       :     bit_vector ( 31 downto 0); -- c register
  signal   d       :     bit_vector ( 31 downto 0); -- d register
  signal   e       :     bit_vector ( 31 downto 0); -- e register
  signal   f       :     bit_vector ( 31 downto 0); -- f register
  signal   g       :     bit_vector ( 31 downto 0); -- g register
  signal   h       :     bit_vector ( 31 downto 0); -- h register
  signal   f0      :     bit_vector ( 31 downto 0);
  signal   f1      :     bit_vector ( 31 downto 0);
  signal   f2      :     bit_vector ( 31 downto 0);
  signal   f3      :     bit_vector ( 31 downto 0);
  signal   f4      :     bit_vector ( 31 downto 0);
  signal   f5      :     bit_vector ( 31 downto 0);
  signal   ctr2    :     bit_vector (  3 downto 0); --  4  bit counter (zero to  16)
  signal   ctr2_rst:     bit;
  signal   ctr3    :     bit_vector (  5 downto 0); --  6  bit counter (zero to  64)
  signal   ctr3_rst:     bit;
  signal   vld     :     bit;
  signal   nld     :     bit;
  signal   ild     :     bit;
  signal   ild_rst :     bit;
begin
  ct2              : c4b
  port map (
  cnt              => ctr2,
  clk              => clk,
  rst              => ctr2_rst
  ct3              : c6b
  port map (
  cnt              => ctr3,
  clk              => clk,
  rst              => ctr3_rst
  rom0             : romk
  port map (
  addr             => ctr3,
  k                => k
--probe signal
--a_prb            <= a;
--b_prb            <= b;
--c_prb            <= c;
--d_prb            <= d;
--e_prb            <= e;
--f_prb            <= e;
--g_prb            <= e;
--h_prb            <= e;
--k_prb            <= k;
--w_prb            <= w;
--ctr2p            <= ctr2;
--ctr3p            <= ctr3;
--probe signal
--persistent connection
--f0               == ((x and y) xor (not(x) and z))                      -- f0(e, f, g)
  f0               <= ((e and f) xor (not(e) and g));
--f1               == ((x and y) xor (x and z) xor (y and z)              -- f1(a, b, c)
  f1               <= ((a and b) xor (a and c) xor (b and c));
--f2               == ROTR  2(x)  xor ROTR 13(x) xor ROTR 22(x)           -- f2(a)
  f2               <= (a (  1 downto   0) & a ( 31 downto   2)) xor
      (a ( 12 downto   0) & a ( 31 downto  13)) xor
      (a ( 21 downto   0) & a ( 31 downto  22));
--f3               == ROTR  6(x)  xor ROTR 11(x) xor ROTR 25(x)           -- f3(e)
  f3               <= (e (  5 downto   0) & e ( 31 downto   6)) xor
      (e ( 10 downto   0) & e ( 31 downto  11)) xor
      (e ( 24 downto   0) & e ( 31 downto  25));
--f4               == ROTR  7(x)  xor ROTR 18(x) xor SHR   3(x)           -- w0(479 downto 448)
  f4               <= (w0(454 downto 448) & w0(479 downto 455)) xor
                      (w0(465 downto 448) & w0(479 downto 466)) xor
                      (B"000"             & w0(479 downto 451));
--f5               == ROTR 17(x)  xor ROTR 19(x) xor SHR  10(x)           -- w0( 63 downto  32)
  f5               <= (w0( 48 downto  32) & w0( 63 downto  49)) xor
                      (w0( 50 downto  32) & w0( 63 downto  51)) xor
      (B"0000000000"      & w0( 63 downto  42));
  with ctr2( 2 downto 0) select -- omit bit 4
  ih               <= h0                                      when B"000",
                      h1                                      when B"001",
                      h2                                      when B"010",
                      h3                                      when B"011",
                      h4                                      when B"100",
                      h5                                      when B"101",
                      h6                                      when B"110",
                      h7                                      when B"111";
--W                == f5(W(  1)) + W(  6)             + f4(W(  14)) + W(  15);             16 <= t <=  79
--iw               <= f5         + w0(223 downto 192) + f4          + w0(511 downto 480); -- FIXME this adder is very costly and NOT A PORTABLE CODE
  iw               <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(f5)) + unsigned(to_stdlogicvector(w0(223 downto 192))) + unsigned(to_stdlogicvector(f4)) + unsigned(to_stdlogicvector(w0(511 downto 480))) ));
  process (clk)
  begin
    if ((clk = '1') and clk'event) then
      if    (rst = '1') then
        w          <= (others => '0');
        w0         <= (others => '0');
      elsif (nld = '1') then                                              -- 0 <= t <= 15 first 512 bit block
        w          <=              im;
  w0(511 downto 0) <= (w0(479 downto  0) & im);
        w          <=  iw( 31 downto   0)                      ;
  w0(511 downto 0) <= (w0(479 downto   0) & iw( 31 downto   0));
      end if;
    end if;
  end process;
  process (clk)
  begin
      if (rst = '1') then
        ild        <=  '0';
nld        <=  '0';
im         <= (others => '0');
        ild        <=  nld;
nld        <=   ld;
im         <=    m;
      end if;
    end if;
  end process;
  process (clk)
  begin
      if ((ild_rst or rst) = '1') then
        vld        <=  '0';
      elsif (ctr3 = B"111111") then
        vld        <=  '1';
        vld        <=  '0';
      end if;
    end if;
  end process;
  ild_rst          <= (ild xor ld) and ld;
--ctr2_rst         <=  ild_rst     or rst or vld or (ctr2 = B"0111");     -- set to count to  7 (  8 clock)
  ctr2_rst         <=  ild_rst     or rst or vld or not(ctr2(3) or not(ctr2(2)) or not(ctr2(1)) or not(ctr2(0)));
  ctr3_rst         <=  ild_rst     or rst;-- (ctr3 = B"010011");          -- set to count to 63 ( 64 clock)
  process (clk)
  begin
      if (init = '1'or (rst = '1') then
        h0         <= X"6a09e667";
        h1         <= X"bb67ae85";
        h2         <= X"3c6ef372";
        h3         <= X"a54ff53a";
        h4         <= X"510e527f";
        h5         <= X"9b05688c";
        h6         <= X"1f83d9ab";
        h7         <= X"5be0cd19";
      elsif (vld = '1') then -- FIXME this adder is very costly and NOT A PORTABLE CODE
        h0         <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(a)) + unsigned(to_stdlogicvector(h0)) ));
        h1         <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(b)) + unsigned(to_stdlogicvector(h1)) ));
        h2         <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(c)) + unsigned(to_stdlogicvector(h2)) ));
        h3         <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(d)) + unsigned(to_stdlogicvector(h3)) ));
        h4         <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(e)) + unsigned(to_stdlogicvector(h4)) ));
        h5         <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(f)) + unsigned(to_stdlogicvector(h5)) ));
        h6         <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(g)) + unsigned(to_stdlogicvector(h6)) ));
        h7         <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(h)) + unsigned(to_stdlogicvector(h7)) ));
--      h0         <=      a + h0;
--      h1         <=      b + h1;
--      h2         <=      c + h2;
--      h3         <=      d + h3;
--      h4         <=      e + h4;
--      h5         <=      f + h5;
--      h6         <=      g + h6;
--      h7         <=      h + h7;
      end if;
    end if;
  end process;
  process (clk)
  begin
        a          <= h0;
        b          <= h1;
        c          <= h2;
        d          <= h3;
        e          <= h4;
        f          <= h5;
        g          <= h6;
        h          <= h7;
       else -- FIXME this adder is very costly and NOT A PORTABLE CODE
--      T1         == h + f3(e) + f0(e, f, g) + k(t) + W(t)
--      T2         ==     f2(a) + f1(a, b, c)
        h          <=  g;
        g          <=  f;
        f          <=  e;
-- e          <=  d +          T1        ;
--      e          <=  d + h + f3 + f0 + k + w;
        e          <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(d)) + unsigned(to_stdlogicvector(h)) + unsigned(to_stdlogicvector(f3)) + unsigned(to_stdlogicvector(f0)) + unsigned(to_stdlogicvector(k)) + unsigned(to_stdlogicvector(w)) ));
        d          <=  c;
        c          <=  b;
        b          <=  a;
-- a          <=             T1           +    T2  ;
--      a          <=      h + f3 + f0 + k + w + f2 + f1;
        a          <= to_bitvector(std_logic_vector( unsigned(to_stdlogicvector(h)) + unsigned(to_stdlogicvector(f3)) + unsigned(to_stdlogicvector(f0)) + unsigned(to_stdlogicvector(k)) + unsigned(to_stdlogicvector(w))  + unsigned(to_stdlogicvector(f2)) + unsigned(to_stdlogicvector(f1)) ));
      end if;
    end if;
  end process;
  md               <=  ih;
  v                <=  vld;
end phy;
kutahyaspor
key içeriğinin 16 haneli ve sadece rakamlardan oluştuğunu varsayalım. (ben olsam mutlaka harf, nokta, virgül vs. kullanırdım)
10000000000000000 farklı keyimiz var.
saniyede 10000000 key deneyebildiğimizi varsayalım (elinizde kesin bir rakam varsa ona göre hesaplanır.)
10000000  x 60 x 60 x 24 x 365 = 315360000000000  bir yılda bu kadar key deneyebiliriz.
bu da yaklaşık 30 yıl eder.  harf ve ascii karakter kullanılmadığını da bilmiyoruz. elde keyin içeriğine dair başka bir ipucu olmadığı sürece, bence bu işlem imkansız.
kolay gelsin.
esensoy
Alıntı yapılan: kutahyaspor - 10 Nisan 2014, 08:57:00
kolay gelsin.
Bu algoritmayı n parçaya bölsem ve bir program oluştursam,
Nette de desem ki ey nvidia cudaminer lar, bu programı çalıştırın bitcoinden kazandığınızın x katını vereceğim size,
Kaç kişi bulurum??
Ya da desem ki hadi xtea şifre kırıp caka satacağız, voltran ı oluşturalım, kaç kişi gelir?
Ben sizin ya da sizden önce bana "imkansız" demişlerin laflarına zaten kulak asmıyorum da, umarım bu örnekler düşünce sisteminizi açmaya yardımcı olur,
@esensoy  eğer bu işi FPGA ile yapacaksan elimde ki kartlardan (Cyclone IV EP4C10F17CN8) birini senin bu işin için kullanabilirim.
http://imageshack.com/a/img42/8643/4gwx.jpg
esensoy
Hocam eldeki pcleri karıştırırken köşede duran laptopta cuda uyumlu 310M ekran kartı olduğunu farkettim,
https://developer.nvidia.com/cuda-gpus
Bu sayfada Compute Capability olarak 1.2 vermiş, anlaşılıyor ki deneme amaçlı kullanılabilir,
Kodu vhdl ya da verilog a çabukça çevirebilecek kadar iyi olmadığımı düşünüyorum, biraz vakit alacak,
CUDA lar ise bildiğin C ile çalışıyor, o sebepten önceliğim ekran kartında denemek,
Nezaketiniz için yine de teşekkür ederim, FPGA tarafını da denemeye kalkarsam mutlaka iletişime geçerim sizinle,
bu işler için AMD(ATI) kartlar daha çok tercih ediliyor.  paralel işlem üniteleri Nvidia GPUlardan daha fazla.  OpenCL  ile progam geliştiriyorlar.
1 adet GTX580, 1 adet Radeon HD5450 de var.
programda GPU yu mutlaka termal olarak izleyin cudaminer çalışırken ortalama 80C GPU sıcaklığı görüyorum. bir müddetsonra kasadan jet türbini gibi ses gelmeye başlıyor. :)
muuzoo
Alıntı yapılan: MC_Skywalker - 10 Nisan 2014, 10:38:24
Hocam soyle bir duzeltme yapmak istiyorum Amd kartlardaki paralel islem unitelerinin fazla olmasi yuzunden degil de bit bazlı işlemleri daha kisa surede yapmasindan kaynakli bir fark var. Yoksa nvidia nin da 3000 civarinda cekirdek iceren kartlari da var.
Aslinda tum mesele kodunuzun ekran karti mimarisine gore ne olcude iyi yazildigina bagli. Ayni isi yapan 2 kod arasinda 20-30 katlik farklar gorebilirsiniz.
Bunun bariz bir ornegi cuda miner mesela eski versiyonu ile 100k-105k hash aldiginiz karttan sadece yazilimla 190k hash almaya basliyorsunuz. İster Amd olsun ister nvidia , kodun nasil yazildigi onemli.
benim okuduğum bir forumda böyle bir beyanda bulunmuşlar. konuyu tekrar araştırayım.
birde kullandığınız havuz önemli.  Cuda miner GTX580 için 200-256Kh değer gösterirken, havuzun gösterdiği değer 180-190Kh görünüyor.
speak48
kim hangi programla neiçin şifrelemiş
hex codu nerde kullanılacak
hex codu bootmu ediliyor yoksa direct flashamı yazılıyor.
birazdaha bilgi işleri kolaylaştırır.
peki şifresiz kısmını nerden biliyorsunuz.
speak48
70k ya 10core pipeline koydum zorlasam 15 sığar.
100 mhzde her 2 clokta bir şifre dener  saniyede 500*10^6 tane şifre dener
ama bu bile süreyi pek düşüremedi 1000 yıllar alacak.
https://www.mediafire.com/?4dr1vd4pz20vcd3
10K sığan versionu var ise boştaki karta denemek için yüklerim. (Cyclone IV EP4C10F17CN8)
speak48
tek bir core pipeline16round 5k.
ayrıca tek core la ne bulucan.
tek core saniyede 50M şifre dener
Elektroemre
@esensoy hocam var mı bir gelişme?  :)
speak48
siz parayı dökün
bulun bana
en büyük fpga serisinden 1000-2000 tane falan
olacak gelişmeyi söyliyelim
