Illegal opcode sorunu
Başlatan NecmiGurbuz, 10 Ocak 2015, 02:09:47
NecmiGurbuz
Tris lerden sonraki İllegal opcode sorununu çözemedim. Açıkcası pekte anlamıyorum bu işlerden :S.
Yardım ederseniz memnun olurum.
MPLAB IDE v 8.15a
Pbp3
PIC16f877
Teşekkürler.
TRISA =11111100
TRISC =11111111
TRISE =11100000
TRISD =0
TRISB =0
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 3
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 2
DEFINE LCD_RWREG PORTB
DEFINE LCD_RWBIT 5
DEFINE LCD_LINES 2
DEFINE LCD_BITS 8
PAUSE 500 : PORTB.5 =0
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
OKUNAN VAR BYTE
ADCON1=%00000000
BASLA:
LCDOUT $FE, $80, " ADC "
LCDOUT $FE, $C0, "UYGULAMA "
   IF PORTC.0 = 0 THEN LM35
   IF PORTC.1 = 0 THEN POT1
   IF PORTC.2 = 0 THEN LDR
   IF PORTC.3 = 0 THEN POT2
   IF PORTC.4 = 0 THEN POT3
   IF PORTC.5 = 0 THEN NTC
   GOTO BASLA
LM35:
WHILE PORTC.0 = 0 : WEND
ADCIN 0, OKUNAN
LCDOUT $FE, 1
LCDOUT $FE, $C0, "LM35= ", DEC OKUNAN
PAUSE 1000
GOTO BASLA
POT1:
WHILE PORTC.1 = 0 : WEND
ADCIN 1, OKUNAN
LCDOUT $FE, 1
LCDOUT $FE, $C0, "1.POT= " , DEC OKUNAN
PAUSE 1000
GOTO BASLA
LDR:
WHILE PORTC.2 = 0 : WEND
ADCIN 2, OKUNAN
LCDOUT $FE, 1
LCDOUT $FE , $C0, "LDR= ", DEC OKUNAN
PAUSE 1000
GOTO BASLA
POT2:
WHILE PORTC.3 = 0 : WEND
ADCIN 3, OKUNAN
LCDOUT $FE, 1
LCDOUT $FE, $C0, "2. POT= ", DEC OKUNAN
PAUSE 1000
GOTO BASLA
POT3:
WHILE PORTC.4 = 0 : WEND
ADCIN 5, OKUNAN
LCDOUT $FE, 1
LCDOUT $FE, $C0, "3. POT= ", DEC OKUNAN
PAUSE 1000
GOTO BASLA
NTC:
WHILE PORTC.5 = 0 : WEND
ADCIN 6, OKUNAN
LCDOUT $FE, 1
LCDOUT $FE, $C0, "NTC= ", DEC OKUNAN
PAUSE 1000
GOTO BASLA
END
Error[122]   C:\USERS\U15.ASM 18 : Illegal opcode (LCD_DREG)
Error[122]   C:\USERS\\U15.ASM 19 : Illegal opcode (LCD_DBIT)
Error[122]   C:\USERS\\U15.ASM 20 : Illegal opcode (LCD_RSREG)
Error[122]   C:\USERS\\U15.ASM 21 : Illegal opcode (LCD_RSBIT)
Error[122]   C:\USERS\U15.ASM 22 : Illegal opcode (LCD_EREG)
Error[122]   C:\USERS\U15.ASM 23 : Illegal opcode (LCD_EBIT)
Error[122]   C:\USERS\\U15.ASM 24 : Illegal opcode (LCD_RWREG)
Error[122]   C:\USERS\\U15.ASM 25 : Illegal opcode (LCD_RWBIT)
Error[122]   C:\USERS\\U15.ASM 26 : Illegal opcode (LCD_LINES)
Error[122]   C:\USERS\U15.ASM 27 : Illegal opcode (LCD_BITS)
Error[108]   C:\USERS\U15.ASM 28 : Illegal character (5)
Error[122]   C:\USERS\U15.ASM 29 : Illegal opcode (ADC_BITS)
Error[122]   C:\USERS\U15.ASM 30 : Illegal opcode (ADC_CLOCK)
Error[122]   C:\USERS\U15.ASM 31 : Illegal opcode (ADC_SAMPLEUS)
Error[122]   C:\USERS\U15.ASM 32 : Illegal opcode (VAR)
Error[128]   C:\USERS\\U15.ASM 33 : Missing argument(s)
Error[108]   C:\USERS\\U15.ASM 36 : Illegal character ($)
Error[108]   C:\USERS\\U15.ASM 37 : Illegal character ($)
Error[113]   C:\USERS\U15.ASM 38 : Symbol not previously defined (PORTC.0)
Error[108]   C:\USERS\\U15.ASM 38 : Illegal character (=)
Warning[212] C:\USERS\U15.ASM 92 : Expected (ENDIF)
ido2323
DEFINE LCD_DBIT 0
DEFINE LCD_RSBIT 3
DEFINE LCD_EBIT 2
DEFINE LCD_RWBIT 5
DEFINE LCD_LINES 2
DEFINE LCD_BITS 8
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 3
yukarıdaki şekilde tanımlama yapamassın belki port tanımlamasını şöyle yapabilirsin
#define LCD_DREG PORTD   PORTD,0
yada değişken tanımlayacaksan önce
LCD_RSREG_PORTB    equ   20h;
sonra
#define LCD_RSREG_PORTB    kolon_ind  yapabilirsin.
NecmiGurbuz
Öncelile cevap için teşekkür ederim.
Dediğiniz gibi tanımların başına # işareti koyunca düzeldi.
Error[108]   CU15.ASM 34 : Illegal character (5)
Error[122]   C:SAMPLES\U15.ASM 39 : Illegal opcode (VAR)
Error[108]   C:\ 43 : Illegal character ($)
Error[108]   C:\ 44 : Illegal character ($)
Error[113]   C:\ 45 : Symbol not previously defined (PORTC.0)
Error[108]   C:\ : Illegal character (=)
Warning[212] C:\99 : Expected (ENDIF)
kaldı hata olarak .
ido2323
Error[108]   CU15.ASM 34 : Illegal character (5)  ; 5 ekleme
Error[122]   C:SAMPLES\U15.ASM 39 : Illegal opcode (VAR); VAR tanımsız ve ya başka yerde kullanılıyor.
Error[108]   C:\ 43 : Illegal character ($); '$' işaretini kullanamassın başka dene
Error[108]   C:\ 44 : Illegal character ($); '$' işaretini kullanamassın başka dene
Error[113]   C:\ 45 : Symbol not previously defined (PORTC.0) ;PORTC,0 olacak nokta değil virgül
Error[108]   C:\ : Illegal character (=) ;'=' işaretini kullanamassın başka dene
Warning[212] C:\99 : Expected (ENDIF) ENDIF gerekiyor.
