uart transmitter
Başlatan ido2323, 25 Mayıs 2015, 16:44:54
ido2323
Hayırlı akşamlar 9600 bps hızda, gönderici şekilde, 55 sayısını göndermeye çalışıyorum acaba eksik bir şey mi var? 8 mhz
#include "p18F4550.inc"
; CONFIG1L
  CONFIG  PLLDIV = 1            ; PLL Prescaler Selection bits (No prescale (4 MHz oscillator input drives PLL directly))
  CONFIG  CPUDIV = OSC1_PLL2    ; System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
  CONFIG  USBDIV = 1            ; USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
; CONFIG1H
  CONFIG  FOSC = HS         ; Oscillator Selection bits (EC oscillator, CLKO function on RA6 (EC))
  CONFIG  FCMEN = OFF           ; Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
  CONFIG  IESO = OFF            ; Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
; CONFIG2L
  CONFIG  PWRT = OFF            ; Power-up Timer Enable bit (PWRT disabled)
  CONFIG  BOR = ON              ; Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
  CONFIG  BORV = 3              ; Brown-out Reset Voltage bits (Minimum setting)
  CONFIG  VREGEN = OFF          ; USB Voltage Regulator Enable bit (USB voltage regulator disabled)
; CONFIG2H
  CONFIG  WDT = ON              ; Watchdog Timer Enable bit (WDT enabled)
  CONFIG  WDTPS = 32768         ; Watchdog Timer Postscale Select bits (1:32768)
; CONFIG3H
  CONFIG  CCP2MX = ON           ; CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
  CONFIG  PBADEN = ON           ; PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
  CONFIG  LPT1OSC = OFF         ; Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
  CONFIG  MCLRE = ON            ; MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
; CONFIG4L
  CONFIG  STVREN = ON           ; Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
  CONFIG  LVP = ON              ; Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
  CONFIG  ICPRT = OFF           ; Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
  CONFIG  XINST = OFF           ; Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
; CONFIG5L
  CONFIG  CP0 = OFF             ; Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
  CONFIG  CP1 = OFF             ; Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
  CONFIG  CP2 = OFF             ; Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
  CONFIG  CP3 = OFF             ; Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
; CONFIG5H
  CONFIG  CPB = OFF             ; Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
  CONFIG  CPD = OFF             ; Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
; CONFIG6L
  CONFIG  WRT0 = OFF            ; Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
  CONFIG  WRT1 = OFF            ; Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
  CONFIG  WRT2 = OFF            ; Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
  CONFIG  WRT3 = OFF            ; Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
; CONFIG6H
  CONFIG  WRTC = OFF            ; Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
  CONFIG  WRTB = OFF            ; Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
  CONFIG  WRTD = OFF            ; Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
; CONFIG7L
  CONFIG  EBTR0 = OFF           ; Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
  CONFIG  EBTR1 = OFF           ; Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
  CONFIG  EBTR2 = OFF           ; Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
  CONFIG  EBTR3 = OFF           ; Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
; CONFIG7H
  CONFIG  EBTRB = OFF           ; Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
ORG     0X0000            ; ba?lang?ç vektörü
clrf    PCLATH            ; pc sayac?n?n ;yüksek bitini s?f?rla
goto    main              ; ana programa ;dallan
ORG     0X0020
main
CLRF PORTC
MOVLW 0X00
MOVWF TRISC
; baud rate speed 96000, asekron,
movlw b'10000000'
movwf RCSTA
movlw b'00000000'
movwf TXSTA
movlw b'00000000'
movwf BAUDCON
MOVLW D'12' ;WE WILL USE 9600bps
MOVWF SPBRGH ;BAUD AT 8MHZ
asd
clrf TXREG
;bcf TXSTA,5
movlw h'55'
movwf TXREG
bsf TXSTA,5
goto asd
end
Seri port gönderme sistemin epey yanlış. Datasheet bölüm 20.2.1'de maddeler halinde verilen prosedürü uygula. Ayrıca 20.0'ın başındaki bilgileri de oku. Seri port bacaklarının TRIS bitleri 1 olmalı (ikisinin de).
Genel olarak, ayarları yaptığında TX modülü açık olmalı. Bundan sonra tekrardan aç kapa yapılmaz. Gönderilecek olan veri TXREG'e yüklenir, göndermenin bitip bitmediği kesme bayrağına veya TSR ile ilgili bite bakılarak belirlenir. Gönderme bitmeden, veya TXREG dolu iken tekrardan yükleme yapılmaz (ki sen programda bunu yapıyorsun hiç beklemeden). TXREG clrf ile sıfırlanmaz, tabi eğer amacın 0 göndermek değilse. Yeni değer doğrudan TXREG'e yüklenir.
