Asm ile yazilmiş Kodun Mantigi
Başlatan M_B, 03 Haziran 2015, 11:55:46
M_B
Merhabalar;
https://www.picproje.org/index.php/topic,55627.120.html (RGB P6 Panel icin  )
Linkteki konu icin araştırma yapıyorum. Arduino ile yazılmış kodun icerisinde tarama ve veri gönderme kısmı olarak alt kısımdaki asm komutları kullanılmış
burda adam ne yapmak istemiş
  tock = SCLKPORT;
  tick = tock | sclkpin;
#define pew asm volatile(                 \
      "ld  __tmp_reg__, %a[ptr]+"    "\n\t"   \
      "out %[data]    , __tmp_reg__" "\n\t"   \
      "out %[clk]     , %[tick]"     "\n\t"   \
      "out %[clk]     , %[tock]"     "\n"     \
      :: [ptr]  "e" (ptr),                    \
         [data] "I" (_SFR_IO_ADDR(DATAPORT)), \
         [clk]  "I" (_SFR_IO_ADDR(SCLKPORT)), \
         [tick] "r" (tick),                   \
         [tock] "r" (tock));
Kodun tamamı:
// -------------------- Interrupt handler stuff --------------------
ISR(TIMER1_OVF_vect, ISR_BLOCK) { // ISR_BLOCK important -- see notes later
  activePanel->updateDisplay();   // Call refresh func for active display
  TIFR1 |= TOV1;                  // Clear Timer1 interrupt flag
#define CALLOVERHEAD 60   // Actual value measured = 56
#define LOOPTIME     200  // Actual value measured = 188
void RGBmatrixPanel::updateDisplay(void) {
  uint8_t  i, tick, tock, *ptr;
  uint16_t t, duration;
  *oeport  |= oepin;
  *latport |= latpin;
  t = (nRows > 8) ? LOOPTIME : (LOOPTIME * 2);
  duration = ((t + CALLOVERHEAD * 2) << plane) - CALLOVERHEAD;
  if(++plane >= nPlanes) {      // Advance plane counter.  Maxed out?
    plane = 0;                  // Yes, reset to plane 0, and
    if(++row >= nRows) {        // advance row counter.  Maxed out?
      row     = 0;              // Yes, reset row counter, then...
      if(swapflag == true) {    // Swap front/back buffers if requested
        backindex = 1 - backindex;
        swapflag  = false;
      buffptr = matrixbuff[1-backindex]; // Reset into front buffer
  } else if(plane == 1) {
    // Plane 0 was loaded on prior interrupt invocation and is about to
    // latch now, so update the row address lines before we do that:
    if(row & 0x1)   *addraport |=  addrapin;
    else            *addraport &= ~addrapin;
    if(row & 0x2)   *addrbport |=  addrbpin;
    else            *addrbport &= ~addrbpin;
    if(row & 0x4)   *addrcport |=  addrcpin;
    else            *addrcport &= ~addrcpin;
    if(nRows > 8) {
      if(row & 0x8) *addrdport |=  addrdpin;
      else          *addrdport &= ~addrdpin;
  // buffptr, being 'volatile' type, doesn't take well to optimization.
  // A local register copy can speed some things up:
  ptr = (uint8_t *)buffptr;
  ICR1      = duration; // Set interval for next interrupt
  TCNT1     = 0;        // Restart interrupt timer
  *oeport  &= ~oepin;   // Re-enable output
  *latport &= ~latpin;  // Latch down
  tock = SCLKPORT;
  if(plane > 0) {
         [tock] "r" (tock));
    // Loop is unrolled for speed:
    pew pew pew pew pew pew pew pew
      if (WIDTH == 64) {
    buffptr = ptr; //+= 32;
  } else {
    for(i=0; i<WIDTH; i++) {
      DATAPORT =
        ( ptr[i]    << 6)         |
        ((ptr[i+WIDTH] << 4) & 0x30) |
        ((ptr[i+WIDTH*2] << 2) & 0x0C);
      SCLKPORT = tick; // Clock lo
      SCLKPORT = tock; // Clock hi
Datayı adresinden oku ve adresi 1 artır
Datayı porttan çık.
Clk 1 yap.
Clk 0 yap.
Yaptığı iş bu.
M_B
Alıntı yapılan: z - 03 Haziran 2015, 12:07:44
Datayı porttan çık.
Clk 1 yap.
Clk 0 yap.
Yaptığı iş bu.
Teşekkür ederim z hocam;
