MCP41010 PIC16f877a dijital pot örnek kod uygulaması
Başlatan ergunbt, 22 Ağustos 2015, 15:41:45
ergunbt
Merhaba arkadaşlar. Bugün araştırıp kodlarını yazdıgım dijital pot devresinin kodlarını işinize yarar diye sizlere sunuyorum. Umarım işinize yarar. İyi günler dilerim..
'*  Name    : mcp41010.BAS                                      *
'*  Author  : [ergunbt]                                         *
'*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
'*  Date    : 22.08.2015                                        *
'*  Notes   : mcp41010 dijital pot uygalaması                   *
Device=16F877A
XTAL = 4
TRISA=%111111
ALL_DIGITAL = True
Symbol YUKARI= PORTA.0
Symbol ASAGI= PORTA.1
Symbol MODE= PORTA.2
Symbol CS10 = PORTB.3 ' CHIP SEÇ
Symbol CS20 = PORTB.4 ' CHIP SEÇ
Symbol CS30 = PORTB.5 ' CHIP SEÇ
Symbol CS40 = PORTB.6 ' CHIP SEÇ
Output CS10 ' CS10 ÇIKISINI AYARLA
Output CS20 ' CS20 ÇIKISINI AYARLA
Output CS30 ' CS30 ÇIKISINI AYARLA
Output CS40 ' CS40 ÇIKISINI AYARLA
Symbol SCK = PORTC.3	' CLOCK PINI
Symbol SI = PORTC.4	' DATA IN PINI
Symbol SO = PORTC.5	' DATA OUT PINI
Dim POT1 As Byte
Dim POT2 As Byte
Dim POT3 As Byte
Dim POT4 As Byte
Dim MOD As Byte
MOD=0
LOOP:
If MODE=0 Then
While MODE=0 :Wend
MOD=MOD+1
If MOD=4 Then  MOD=0
EndIf
If MOD=0 Then
If YUKARI=0 Then
While YUKARI=0 :Wend
POT1=POT1+10
If POT1>255 Then POT1=0
EndIf
If ASAGI=0 Then
While ASAGI=0 :Wend
POT1=POT1-10
If POT1<5 Then POT1=0
EndIf
EndIf
If MOD=1 Then
If YUKARI=0 Then
POT2=POT2+10
If POT2>255 Then POT2=0
EndIf
If ASAGI=0 Then
While ASAGI=0 :Wend
POT2=POT2-10
If POT2<5 Then POT2=0
EndIf
EndIf
If MOD=2 Then
If YUKARI=0 Then
POT3=POT3+10
If POT3>255 Then POT3=0
EndIf
If ASAGI=0 Then
While ASAGI=0 :Wend
POT3=POT3-10
If POT3<5 Then POT3=0
EndIf
EndIf
If MOD=3 Then
If YUKARI=0 Then
POT4=POT4+10
If POT4>255 Then POT4=0
EndIf
If ASAGI=0 Then
While ASAGI=0 :Wend
POT4=POT4-10
If POT4<5 Then POT4=0
EndIf
EndIf
GoSub POT_YAZ ' DİJİTAL PORTA YAZ
GoTo LOOP
POT_YAZ:
CS10=0 ' AKTIF
CS20=0 ' AKTIF
CS30=0 ' AKTIF
CS40=0 ' AKTIF
SHOut SI, SCK, msbfirst, [$11,POT1]
CS10=1
CS10=0
CS10=1
SHOut SI, SCK, msbfirst, [$11,POT2]
CS20=1
CS20=0
CS20=1
SHOut SI, SCK, msbfirst, [$11,POT3]
CS30=1
CS30=0
CS30=1
SHOut SI, SCK, msbfirst, [$11,POT4]
CS40=1
CS40=0
CS40=1
Return
End
