STM32F103 mini board
Başlatan baran123, 13 Kasım 2015, 22:35:34
baran123
Elimde bu karttan var stlink ile programlama yapıyorum fakat HSE ile 72 Mhz de çalıştıracak config dosyasını oluşturamadım.Sanırım bu yüzden aşağıda ki kod çalışmıyor.Gerekli ayarları nasıl yapacağım ?
system_stm32f10x.c
  * @file    system_stm32f10x.c
  * @author  MCD Application Team
  * @version V3.1.2
  * @date    09/28/2009
  * @brief   CMSIS Cortex-M3 Device Peripheral Access Layer System Source File.
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2009 STMicroelectronics</center></h2>
/** @addtogroup CMSIS
/** @addtogroup stm32f10x_system
/** @addtogroup STM32F10x_System_Private_Includes
#include "stm32f10x.h"
/** @addtogroup STM32F10x_System_Private_TypesDefinitions
/** @addtogroup STM32F10x_System_Private_Defines
#define SYSCLK_FREQ_HSE    8000000
/* #define SYSCLK_FREQ_24MHz  24000000 */
/* #define SYSCLK_FREQ_36MHz  36000000 */
/* #define SYSCLK_FREQ_48MHz  48000000 */
/* #define SYSCLK_FREQ_56MHz  56000000 */
/* #define SYSCLK_FREQ_72MHz  72000000 */
*  Clock Definitions
#ifdef SYSCLK_FREQ_HSE
  uint32_t SystemCoreClock         = SYSCLK_FREQ_HSE;        /*!< System Clock Frequency (Core Clock) */
//  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_HSE;        /*!< System clock                        */
//  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_HSE;        /*!< AHB System bus speed                */
//  const uint32_t SystemFrequency_APB1Clk = SYSCLK_FREQ_HSE;        /*!< APB Peripheral bus 1 (low)  speed   */
//  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_HSE;        /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_24MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_24MHz;      /*!< System Clock Frequency (Core Clock) */
//  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_24MHz;      /*!< System clock                        */
//  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_24MHz;      /*!< AHB System bus speed                */
//  const uint32_t SystemFrequency_APB1Clk = SYSCLK_FREQ_24MHz;      /*!< APB Peripheral bus 1 (low)  speed   */
//  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_24MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_36MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_36MHz;      /*!< System Clock Frequency (Core Clock) */
//  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_36MHz;      /*!< System clock                        */
//  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_36MHz;      /*!< AHB System bus speed                */
//  const uint32_t SystemFrequency_APB1Clk = SYSCLK_FREQ_36MHz;      /*!< APB Peripheral bus 1 (low)  speed   */
//  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_36MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_48MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_48MHz;      /*!< System Clock Frequency (Core Clock) */
//  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_48MHz;      /*!< System clock                        */
//  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_48MHz;      /*!< AHB System bus speed                */
//  const uint32_t SystemFrequency_APB1Clk = (SYSCLK_FREQ_48MHz/2);  /*!< APB Peripheral bus 1 (low)  speed   */
//  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_48MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_56MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_56MHz;      /*!< System Clock Frequency (Core Clock) */
//  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_56MHz;      /*!< System clock                        */
//  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_56MHz;      /*!< AHB System bus speed                */
//  const uint32_t SystemFrequency_APB1Clk = (SYSCLK_FREQ_56MHz/2);  /*!< APB Peripheral bus 1 (low)  speed   */
//  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_56MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_72MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_72MHz;      /*!< System Clock Frequency (Core Clock) */
//  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_72MHz;      /*!< System clock                        */
//  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_72MHz;      /*!< AHB System bus speed                */
//  const uint32_t SystemFrequency_APB1Clk = (SYSCLK_FREQ_72MHz/2);  /*!< APB Peripheral bus 1 (low)  speed   */
//  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_72MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#else /*!< HSI Selected as System Clock source */
  uint32_t SystemCoreClock         = HSI_Value;              /*!< System Clock Frequency (Core Clock) */
//  const uint32_t SystemFrequency_SysClk  = HSI_Value;              /*!< System clock                        */
//  const uint32_t SystemFrequency_AHBClk  = HSI_Value;              /*!< AHB System bus speed                */
//  const uint32_t SystemFrequency_APB1Clk = HSI_Value;              /*!< APB Peripheral bus 1 (low)  speed   */
//  const uint32_t SystemFrequency_APB2Clk = HSI_Value;              /*!< APB Peripheral bus 2 (high) speed   */
#endif
/** @addtogroup STM32F10x_System_Private_FunctionPrototypes
static void SetSysClock(void);
  static void SetSysClockToHSE(void);
  static void SetSysClockTo24(void);
  static void SetSysClockTo36(void);
  static void SetSysClockTo48(void);
  static void SetSysClockTo56(void);
  static void SetSysClockTo72(void);
#endif
#ifdef DATA_IN_ExtSRAM
  static void SystemInit_ExtMemCtl(void);
#endif /* DATA_IN_ExtSRAM */
/** @addtogroup STM32F10x_System_Private_Functions
  * @brief  Setup the microcontroller system
  *         Initialize the Embedded Flash Interface, the PLL and update the SystemFrequency variable.
  * @note   This function should be used only after reset.
  * @param  None
  * @retval None
void SystemInit (void)
  /* Reset the RCC clock configuration to the default reset state(for debug purpose) */
  /* Set HSION bit */
  RCC->CR |= (uint32_t)0x00000001;
  /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
#ifndef STM32F10X_CL
  RCC->CFGR &= (uint32_t)0xF8FF0000;
#else
  RCC->CFGR &= (uint32_t)0xF0FF0000;
#endif /* STM32F10X_CL */
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= (uint32_t)0xFEF6FFFF;
  /* Reset HSEBYP bit */
  RCC->CR &= (uint32_t)0xFFFBFFFF;
  /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */
  RCC->CFGR &= (uint32_t)0xFF80FFFF;
  /* Disable all interrupts and clear pending bits  */
  RCC->CIR = 0x009F0000;
#else
  /* Reset PLL2ON and PLL3ON bits */
  RCC->CR &= (uint32_t)0xEBFFFFFF;
  RCC->CIR = 0x00FF0000;
  /* Reset CFGR2 register */
  RCC->CFGR2 = 0x00000000;
  /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
  /* Configure the Flash Latency cycles and enable prefetch buffer */
  SetSysClock();
#ifdef STM32F10X_HD
    SystemInit_ExtMemCtl();
#endif /* STM32F10X_HD */
  * @brief  Update SystemCoreClock according to Clock Register Values
  * @note   None
  * @param  None
  * @retval None
void SystemCoreClockUpdate (void){
  /* NEEDS TO BE IMPLEMENTED */
  * @brief  Configures the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers.
  * @param  None
  * @retval None
  SetSysClockToHSE();
  SetSysClockTo24();
  SetSysClockTo36();
  SetSysClockTo48();
  SetSysClockTo56();
  SetSysClockTo72();
#endif
 /* If none of the define above is enabled, the HSI is used as System clock
    source (default after reset) */
  * @brief  Setup the external memory controller.
  * @param  None
  * @retval None
  *         Called in startup_stm32f10x_xx.s/.c before jump to main.
  * 	      This function configures the external SRAM mounted on STM3210E-EVAL
  *         board (STM32 High density devices). This SRAM will be used as program
  *         data memory (including heap and stack).
  * @param  None
  * @retval None
/*!< FSMC Bank1 NOR/SRAM3 is used for the STM3210E-EVAL, if another Bank is
  required, then adjust the Register Addresses */
  /* Enable FSMC clock */
  RCC->AHBENR = 0x00000114;
  /* Enable GPIOD, GPIOE, GPIOF and GPIOG clocks */
  RCC->APB2ENR = 0x000001E0;
/* ---------------  SRAM Data lines, NOE and NWE configuration ---------------*/
/*----------------  SRAM Address lines configuration -------------------------*/
/*----------------  NOE and NWE configuration --------------------------------*/
/*----------------  NE3 configuration ----------------------------------------*/
/*----------------  NBL0, NBL1 configuration ---------------------------------*/
  GPIOD->CRL = 0x44BB44BB;
  GPIOD->CRH = 0xBBBBBBBB;
  GPIOE->CRL = 0xB44444BB;
  GPIOE->CRH = 0xBBBBBBBB;
  GPIOF->CRL = 0x44BBBBBB;
  GPIOF->CRH = 0xBBBB4444;
  GPIOG->CRL = 0x44BBBBBB;
  GPIOG->CRH = 0x44444B44;
/*----------------  FSMC Configuration ---------------------------------------*/
/*----------------  Enable FSMC Bank1_SRAM Bank ------------------------------*/
  FSMC_Bank1->BTCR[4] = 0x00001011;
  FSMC_Bank1->BTCR[5] = 0x00000200;
  * @brief  Selects HSE as System clock source and configure HCLK, PCLK2
  *          and PCLK1 prescalers.
  * @param  None
  * @retval None
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSEStartUp_TimeOut));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer */
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    /* Flash 0 wait state */
    FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
#else
    if (HSE_Value <= 24000000)
      FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    /* PCLK1 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
    /* Select HSE as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_HSE;
    /* Wait till HSE is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x04)
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
    /* Go to infinite loop */
    while (1)
  * @brief  Sets System clock frequency to 24MHz and configure HCLK, PCLK2
  * @param  None
  * @retval None
  /* Enable HSE */
  do
    StartUpCounter++;
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    /* PCLK1 = HCLK */
#ifdef STM32F10X_CL
    /* Configure PLLs ------------------------------------------------------*/
    /* PLL configuration: PLLCLK = PREDIV1 * 6 = 24 MHz */
    RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
                            RCC_CFGR_PLLMULL6);
    /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
    /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 10 = 4 MHz */
    RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
                              RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
    RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
                             RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV10);
    /* Enable PLL2 */
    RCC->CR |= RCC_CR_PLL2ON;
    /* Wait till PLL2 is ready */
    while((RCC->CR & RCC_CR_PLL2RDY) == 0)
#else
    /*  PLL configuration:  = (HSE / 2) * 6 = 24 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL6);
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
    while (1)
  * @brief  Sets System clock frequency to 36MHz and configure HCLK, PCLK2
  * @param  None
  * @retval None
  /* Enable HSE */
  do
    StartUpCounter++;
    /* Flash 1 wait state */
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    /* PCLK1 = HCLK */
#ifdef STM32F10X_CL
    /* PLL configuration: PLLCLK = PREDIV1 * 9 = 36 MHz */
                            RCC_CFGR_PLLMULL9);
	/*!< PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
    /* Enable PLL2 */
#else
    /*  PLL configuration: PLLCLK = (HSE / 2) * 9 = 36 MHz */
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL9);
    /* Enable PLL */
    while (1)
  * @brief  Sets System clock frequency to 48MHz and configure HCLK, PCLK2
  * @param  None
  * @retval None
  /* Enable HSE */
  do
    StartUpCounter++;
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    /* PCLK1 = HCLK/2 */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
#ifdef STM32F10X_CL
    /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
                             RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
    /* Enable PLL2 */
    /* PLL configuration: PLLCLK = PREDIV1 * 6 = 48 MHz */
                            RCC_CFGR_PLLMULL6);
#else
    /*  PLL configuration: PLLCLK = HSE * 6 = 48 MHz */
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
    /* Enable PLL */
    while (1)
  * @brief  Sets System clock frequency to 56MHz and configure HCLK, PCLK2
  * @param  None
  * @retval None
  /* Enable HSE */
  do
    StartUpCounter++;
    /* Flash 2 wait state */
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
#ifdef STM32F10X_CL
    /* Enable PLL2 */
    /* PLL configuration: PLLCLK = PREDIV1 * 7 = 56 MHz */
                            RCC_CFGR_PLLMULL7);
#else
    /* PLL configuration: PLLCLK = HSE * 7 = 56 MHz */
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL7);
    /* Enable PLL */
    while (1)
  * @brief  Sets System clock frequency to 72MHz and configure HCLK, PCLK2
  * @param  None
  * @retval None
  /* Enable HSE */
  do
    StartUpCounter++;
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
#ifdef STM32F10X_CL
    /* Enable PLL2 */
    /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
                            RCC_CFGR_PLLMULL9);
#else
    /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
                                        RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
    /* Enable PLL */
    while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
code
* File Name        : main.c
* Description      :
* Additional Information :
#include "stm32f10x_conf.h"
void Init_RCC(void);
void Init_GPIO(void);
void Init_ADC(void);
* Function Name  : main
* Description    :
* Input          : void
* Return         : int
int main(void)
    Init_RCC();
    Init_GPIO();
    Init_ADC();
    GPIO_SetBits(GPIOC, GPIO_Pin_13);
    while(1)
* Function Name  : Init_RCC
* Description    :
* Input          : void
* Return         : void
void Init_RCC(void)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
* Function Name  : Init_GPIO
* Description    :
* Input          : void
* Return         : void
    GPIO_InitTypeDef    GPIO_InitStructure;
    GPIO_InitStructure.GPIO_Mode    = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Pin     = GPIO_Pin_13;
    GPIO_InitStructure.GPIO_Speed   = GPIO_Speed_50MHz;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
* Function Name  : Init_ADC
* Description    :
* Input          : void
* Return         : void
void Init_ADC(void)
BurakSeki
SystemInit();
fonksiyonu eksik ondan olabilir.
robomaster
Soruya soru ile katkım olmaz ama kiti nereden aldınız.
Ben doğrudan STM32F103VE için kullandığım system_stm32f10x.c dosyasını kullandım bir problem olmadı.
baran123
Alıntı yapılan: robomaster - 13 Kasım 2015, 22:46:41
Direnc den :)
Alıntı yapılan: Mucit23 - 13 Kasım 2015, 22:56:27
Pine bağlı ledde sorun varmış direk pinden alınca problem olmadı.
mesaj birleştirme:: 13 Kasım 2015, 23:00:37
Bu arada benim ayarlarımda problem varmı ?Clock ayarları doğrumu?
LED lerin Eksisi pinlere bağlı. Ledin çalışması için sıfır vermen gerekir. Şemayı incele
baran123
Kitin şemasını bulamadım.Gönderebilir misin ?
baran123
Tamamdır.Teşekkür ederim. :)
Gökhan BEKEN
Cubemx ile stm32f103'lerden senin çipin aynısını seç
sonra aşağıdaki gibi ayarla:
