Ynt: MikroC arm ile lm35 sensöründen I2C veri yolu ile veri okuyup ve yazan lcd
Başlatan Serhad, 17 Aralık 2015, 17:05:18
Serhad
unsigned olculen=0;
long  toplam=0;
float milivolt=0, sicaklik=0, ortalama=0;
char i=0, txt[15];
// Software I2C connections
sbit Soft_I2C_Scl_Output    at GPIOD_ODR.B3;
sbit Soft_I2C_Scl_Input     at GPIOD_IDR.B3;
sbit Soft_I2C_Sda_Output    at GPIOD_ODR.B4;
sbit Soft_I2C_Sda_Input     at GPIOD_IDR.B4;
// End Software I2C connections
// LCD module connections
sbit LCD_RS   at GPIOE_ODR.B8;
sbit LCD_EN   at GPIOE_ODR.B10;
sbit LCD_D4   at GPIOE_ODR.B4;
sbit LCD_D5   at GPIOE_ODR.B5;
sbit LCD_D6   at GPIOE_ODR.B6;
sbit LCD_D7   at GPIOE_ODR.B7;
// End LCD module connections
void Write_Temparature()
Soft_I2C_Start();      // Issue start signal
  Soft_I2C_Write(0xA2);  // Address
  Soft_I2C_Write(0);     // Start from address 0
  Soft_I2C_Write(0);     // Write 0 to configuration memory location (enable counting)
sicaklik=Soft_I2c_Write(1)  ;
Soft_I2C_Stop();
void Read_Temparature()
  Soft_I2C_Write(0x00);              // Start from address
  Soft_I2C_Start();               // Issue repeated start signal
  Soft_I2C_Write(0xA3);           // Address  for reading R/W=1
sicaklik =Soft_I2C_Read(1);
Soft_I2C_Stop();                // Issue stop signal
void Transform_Temperature()
          GPIO_Digital_Output(&GPIOE_BASE, _GPIO_PINMASK_9);     //9. Pin şaseye çekiliyor
      GPIOE_ODR.B9=0;
      ADC1_Init();
      ADC_Set_Input_Channel(_ADC_CHANNEL_12);
      while(1)
        for(i=0;i<100;i++)
        olculen=ADC1_Get_Sample(12);
        toplam+=olculen;
      ortalama=toplam/100.0;
      toplam=0;
      milivolt=ortalama*3000.0/4095;
      sicaklik=milivolt/10;
      FloatToStr(sicaklik,txt);
      if(sicaklik>=1)
      Lcd_Chr(1,10,txt[0]);
      Lcd_Chr_CP(txt[1]);
      Lcd_Chr_CP(txt[2]);
      Lcd_Chr_CP(txt[3]);
      Lcd_Chr_CP(txt[4]);
      Lcd_Chr_CP('C');
      if(sicaklik<1)
      Lcd_Chr(1,10,'0');
      Lcd_Chr_CP('.');
     Lcd_Chr_CP(txt[0]);
     Lcd_Chr_CP(txt[2]);
      Lcd_Chr_CP(txt[3]);
       Lcd_Chr_CP('C');
void main()
      Soft_I2C_Init();
      Lcd_Init();
      Lcd_Cmd(_LCD_CLEAR);
      Lcd_Cmd(_LCD_CURSOR_OFF);
      Lcd_Out(1,1,"Sicaklik=");
while(1)
     Transform_Temperature();
     Write_Temparature();
     Read_Temparature();
mesaj birleştirme:: 18 Aralık 2015, 07:07:22
Merhaba arkadaşlar paylaştığım bu kod ta LCD ekranda sıcaklığı göremiyorum rica etsem yanlış düzeltmem için yardımcı olabilir misiniz..
mesaj birleştirme:: 17 Aralık 2015, 18:50:17
2x16 LCD modülü düşünerek yapmaya çalıştım.
Yardımlarınız için şimdiden teşekkür ederim.
