STM32FCUBEMX ADC YAPILANDIRMAK
Başlatan sadogan, 06 Şubat 2016, 12:49:12
sadogan
#include "stm32f0xx_hal.h"
/* USER CODE BEGIN Includes */
#include <stdio.h>
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
ADC_HandleTypeDef hadc;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_ADC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
	uint32_t adc_val;
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_ADC_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
	HAL_ADC_PollForConversion(&hadc,10);
	adc_val=HAL_ADC_GetValue(&hadc);
  /* USER CODE BEGIN 3 */
	sprintf(lcdbuf1,"ADC:%X        ",adc_val);
	LcdWrite(lcdbuf1,lcdbuf2,lcdbuf3,lcdbuf4);
	  HAL_Delay(500);
	//		HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5);
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSI14;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSI14State = RCC_HSI14_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.HSI14CalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL12;
  RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* ADC init function */
  ADC_ChannelConfTypeDef sConfig;
    /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC;
  hadc.Init.Resolution = ADC_RESOLUTION12b;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = DISABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = DISABLE;
  hadc.Init.Overrun = OVR_DATA_PRESERVED;
  HAL_ADC_Init(&hadc);
    /**Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
  HAL_ADC_ConfigChannel(&hadc, &sConfig);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
     PA2   ------> USART2_TX
     PA3   ------> USART2_RX
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __GPIOC_CLK_ENABLE();
  __GPIOF_CLK_ENABLE();
  __GPIOA_CLK_ENABLE();
  /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = B1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : USART_TX_Pin USART_RX_Pin */
  GPIO_InitStruct.Pin = USART_TX_Pin|USART_RX_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
  GPIO_InitStruct.Alternate = GPIO_AF1_USART2;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /*Configure GPIO pin : LD2_Pin */
  GPIO_InitStruct.Pin = LD2_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  HAL_GPIO_Init(LD2_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
STM32F030 Nucleo board da , AN0 analog giriş olarak seçip bu girişe bağlı pot dan gelen gerilimi ölçmek istiyorum.
Ama sürekli 0 okuyorum.
STM32cubemx in üretiği kodlar bunlar.
JKramer
Bir yerde aşağıdakine benzer fonksiyon olması lazım. Ben kod üretirken ayrı ayrı üretilsin dediğimden adc.c dosyası içinde oluyor:
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
  if(hadc->Instance==ADC1)
  /* USER CODE BEGIN ADC1_MspInit 0 */
  /* USER CODE END ADC1_MspInit 0 */
    /* Peripheral clock enable */
    __ADC1_CLK_ENABLE();
    /**ADC GPIO Configuration
    PA4     ------> ADC_IN4
    PA5     ------> ADC_IN5
    GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_5;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    /* Peripheral DMA init*/
    hdma_adc.Instance = DMA1_Channel1;
    hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
    hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
    hdma_adc.Init.Mode = DMA_CIRCULAR;
    hdma_adc.Init.Priority = DMA_PRIORITY_MEDIUM;
    HAL_DMA_Init(&hdma_adc);
    __HAL_LINKDMA(hadc,DMA_Handle,hdma_adc);
  /* USER CODE BEGIN ADC1_MspInit 1 */
  /* USER CODE END ADC1_MspInit 1 */
sadogan
stm32f0xx_hal.c icerisinde var.
    PA0     ------> ADC_IN0
    GPIO_InitStruct.Pin = GPIO_PIN_0;
Cemre.
Hocam donanımda bir hata olma ihtimali var mı? POT bozuk olabilir mi ya da? Gözden kaçabiliyor bazen.
sadogan
Benimde aklıma geldi.
Mbed ile denedim sorunsuz çalıştı.
Cemre.
Hocam MspInit kodunuzda hata var sanırım. IN0'dan okumak istiyorum demişsiniz ancak onu değil de IN4 ve 5'i Analog tanımlamışsınız. CubeMX böyle bir hata yapmadı bende, stm32F4Disco için.
sadogan
JKramer paylaştığı koda öyle,benim paylaştığım kod da AN0 da
JKramer
Yok, o benim koyduğum kod. Bu arada debug'dan (watch) bakıyorsunuz değil mi?
Ek: Sizin kodda HAL_ADC_Start() yok sanırım.
Alıntı Yap(++) ADC conversion by polling:
          (+++) Activate the ADC peripheral and start conversions
                using function HAL_ADC_Start()
          (+++) Wait for ADC conversion completion
                using function HAL_ADC_PollForConversion()
          (+++) Retrieve conversion results
                using function HAL_ADC_GetValue()
          (+++) Stop conversion and disable the ADC peripheral
                using function HAL_ADC_Stop()
sadogan
HAL_ADC_Start(&hadc);
	HAL_ADC_Stop(&hadc);
Değişen bir şey yok. hala 0 okuyorum.
Biryerde hatam var ama bulamadım.
Cemre.
Evet hocam haklısınız yanlış görmüşüm.
JKramer
HAL_ADC_Start ve HAL_ADC_PollForConversion fonksiyonları HAL_StatusTypeDef döndürüyor, bunları kontrol edebilirsiniz. 10 ms timeout az geliyordur belki.
e-design
hal kütüphanesinde DMA kullanmadan birden fazla kanalı nasıl okuyabiliriz.
örn: ADC1 üzerinde pin 3 ve pin 4 üzerindeki 2 adet potun değerini okuyacağız ?
