How to Enable SDO2 PIC18F26K22
Başlatan buntger, 14 Şubat 2016, 22:34:53
buntger
Hello,
I am using this code to enable SDO2 (PORTB.3) pin.24 (PIC 18F26K22) , but does not work.
For SPI Display.
Something is missing or something is wrong with the code.
Code Active SPI (SDO2)
  SSP2CON1=         %00000001          ' Clock FOSC/16 '%
  Symbol SSP2EN     = SSP2CON1.5     ' SSP Enable bit
  Symbol CKP2       = SSP2CON1.4     ' Clock Polarity Select
  Symbol SMP2       = SSP2STAT.7     ' Data input sample bit
  Symbol CKE2       = SSP2STAT.6     ' Clock Edge Select bit
  Symbol BF2        = SSP2STAT.0     ' buffer full status bit 1 = buffer full
  Symbol SSP2IF     = PIR3.7         ' Synchronous Serial Port Interrupt Flag Bit
  OSCCON=   %01110000                      ' HFINTOSC – (16 MHz)'%
THX
Karamel
Are you able to send any code from spi2 to outside? Could you check it with any logic analyzer? if it is okay, your lcd configurations or anything has a problem. if it is not okay, you must solve opening spi2 unit correctly.
Best Regards,
Karamel
kantirici
it must be digital I/O. Did you make it ?
buntger
Hello,
My question is that if the code is good for the open MSSP2 Pic 18F26K22 PortB.
For now, it does not work.
New Code: (does not work.)
  SSP2CON1=         %00100001          ' Clock FOSC/16 '%
 TRISB=   %00000000                 'All PortB Outs
THX.
Karamel
Nope. kantirici mentor has said that you must define digital i-o these pins of port. Actually, i have worked with picmicrocontrollers for very short times but i can remember that these family must be had a ADCON e.t registers. Thus, you must arrange this register for digital io selections.
You can also ask your questions which are about pic basic pro or pic microcontrollers to @Maxim mentor
Good luck.
buntger
Hi Karamel,
The PortB already enabled I / O digital.
THX.
buntger
Hi,
(But Code does not work)...
The "Amicus18_SPI.inc" there as two parts for SPI1 and SPI2.
with "OpenSI2()" Selecting the DSO2 (SPI2).
I have also tried all the pSyncMode, pBusMode, pSmpPhase... Nothing..!!
I have included this:
Include "Amicus18_SPI.inc"
OpenSPI2 (SMPEND, MODE_00, SPI_FOSC_16)
Code OpenSPI2 (only):
$ifndef __SPI_INC_
$define __SPI_INC_
' SPI peripheral library for Amicus18
$define SMPEND        %10000000          ' Input data sample at end of data out
$define SMPMID        %00000000          ' Input data sample at middle of data out
$define MODE_00       %00000000          ' Setting for SPI bus Mode 0,0
$define MODE_01       %00000001          ' Setting for SPI bus Mode 0,1
$define MODE_10       %00000010          ' Setting for SPI bus Mode 1,0
$define MODE_11       %00000011          ' Setting for SPI bus Mode 1,1
' SSPCON1 Register
$define SSPENB        %00100000          ' Enable serial port and configures SCK, SDO, SDI
$define SPI_FOSC_4    %00000000          ' SPI Master mode, clock = Fosc/4
$define SPI_FOSC_16   %00000001          ' SPI Master mode, clock = Fosc/16
$define SPI_FOSC_64   %00000010          ' SPI Master mode, clock = Fosc/64
$define SPI_FOSC_TMR2 %00000011          ' SPI Master mode, clock = TMR2 output/2
$define SLV_SSON      %00000100          ' SPI Slave mode, /SS pin control enabled
$define SLV_SSOFF     %00000101          ' SPI Slave mode, /SS pin control disabled
' Amicus18 Revision 2
$if (_device = _18F26K22)
' CloseSPI2
$define CloseSPI2() SSP2CON1 = SSP2CON1 & $DF
' DataReadySPI2: Test if SSP2BUF register is full
$define DataReadySPI2() SSP2STATbits_BF
' Macro Name    : OpenSPI2
' Return Value  : None
' Parameters    : SSP2 peripheral setup values
' Notes         : Sets up the SSP2 module for master or slave operation
' Syntax OpenSPI2 pSyncMode , pBusMode , pSmpPhase
$define OpenSPI2(pSyncMode,pBusMode,pSmpPhase) _OpenSPI2 pSyncMode, pBusMode, pSmpPhase
_OpenSPI2 Macro- pSyncMode, pBusMode, pSmpPhase
    SSP2STAT = SSP2STAT & $3F       ' Power on state
    SSP2CON1 = $00                  ' Power on state
    #if(pSyncMode != 0)
        Movlw (pSyncMode)
        Iorwf SSP2CON1,f            ' Select serial mode
    #endif
    #if(pSmpPhase != 0)
        Movlw (pSmpPhase)
        Iorwf SSP2STAT,f            ' Select data input sample phase
    #endif
    #if(pBusMode == 0)              ' SPI bus mode 0,0
        SSP2STATbits_CKE = 1        ' Data transmitted on rising edge
    #endif
    #if(pBusMode == 2)              ' SPI bus mode 1,0
        SSP2STATbits_CKE = 1        ' Data transmitted on falling edge
        SSP2CON1bits_CKP = 1        ' Clock idle state high
    #endif
    #if(pBusMode == 3)              ' SPI bus mode 1,1
    #endif
    #if(pSyncMode == 4)             ' Slave mode with /SS enable
      TRISB.1 = 1                   ' Define clock pin as input
      TRISB.0 = 1                   ' Define /SS2 pin as input
    #endif
    #if(pSyncMode == 5)             ' Slave mode without /SS enable
    #else                           ' Master mode, define clock pin as output
      TRISB.1 = 0                   ' Define clock pin as output
    #endif
    TRISB.2 = 1                     ' Define SDI pin as input
    TRISB.3 = 0                     ' Define SDO pin as output
    SSP2CON1.5 = 1                  ' Enable synchronous serial port
Endm
' Macro Name     : WriteSPI2
' Return Value   : Input data can be picked up by reading SSP2BUF straight after the WriteSPI2 macro
' Parameter      : Single 8-bit variable for SPI2 bus.
' Description    : Write a single byte (8-bits) to the SPI2 bus.
$define WriteSPI2(pDataOut) '
    WREG = pDataOut '
    _WriteSPI2
_WriteSPI2 Macro-
    GoSub __WriteSPI2
Endm
#ifMacro- _WriteSPI2
__WriteSPI2:
    SSP2STATbits_BF = 0             ' Empty the SSP2BUF buffer flags
    PIR3bits_SSP2IF = 0             ' Clear the interrupt flag
    SSP2BUF = WREG                  ' Place the data to send into SSP2BUF
    Btfss PIR3bits_SSP2IF           ' \
    Bra $ - 2                       ' / Wait until cycle complete
    WREG = SSP2BUF                  ' Read SSP2BUF into WREG
    Return
#endIfMacro-
' Macro Name    : ReadSPI2
' Return Value  : Contents of SSP2BUF register
' Parameters    : None
' Description   : Read byte\s from the SPI2 bus.
$define ReadSPI2() _ReadSPI2
_ReadSPI2 Macro- '\Byte
    GoSub __ReadSPI2
    Return_Wreg
Endm
#ifMacro- _ReadSPI2
__ReadSPI2:
    WREG = SSP2BUF                  ' Empty the SSP2BUF buffer and clear flags
    PIR3bits_SSP2IF = 0             ' Clear interrupt flag
    SSP2BUF = $FF                   ' Initiate bus cycle
    WREG = SSPBUF                   ' Read SSP2BUF into WREG
    Return
#endIfMacro-
$define SPI2_Write(pDataOut) WriteSPI2(pDataOut)
$define SPI2_Read() ReadSPI2()
$define SPI2_Open(pSyncMode,pBusMode,pSmpPhase) OpenSPI2(pSyncMode,pBusMode,pSmpPhase)
$define SPI2_DataReady() SSP2STATbits_BF
$define SPI2_Close() SSP2CON1 = SSP2CON1 & $DF
$endif
_SPI_MAIN_:
$endif
THX.
