I2C iletişim problemi
Başlatan constantine33, 30 Mart 2016, 23:04:15
constantine33
I2C ile iki tane pic16f877a arasında iletişim yapmaya çalışıyorum ama başaramadım. Bir pic master diğeri de slave modunda çalışıyor. Kodda bir hata olabilir mi?
Master PIC
#include <16f877a.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,LVP,NOPUT,NOWRT,DEBUG,NOCPD
#use delay(CLOCK=20M, CRYSTAL=20M)
#use fast_io(b)
#use I2C(MASTER,FAST, SCL=PIN_C3, SDA=PIN_C4, FORCE_HW)
int dataout = 250;
void main()
   set_tris_b(0x00);
   output_b(0x00);
   i2c_start();
   i2c_write(0xa0);
   i2c_write(1);
   i2c_write(dataout);
   i2c_stop();
   delay_ms(100);
Slave PIC
#use fast_io(b)
#use i2c(SLAVE, FAST, SCL=PIN_C3, SDA=PIN_C4, address=0xA0, FORCE_HW)
int state;
int address;
int buffer[0x03];
#INT_SSP
void ssp_interupt ()
   state = i2c_isr_state();
   if(state < 0x80)                 //master is sending data
   if(state == 0)
   if(state == 1)                   //first received byte is address
      address = i2c_read();
   if(state == 2)                   //second received byte is data
      buffer[address] = i2c_read();
   if(state == 0x80)                //master is requesting data
      i2c_write (buffer[address]);  //send requested data
void main()
   set_tris_b(0x00);
   output_b(0x00);
   enable_interrupts(INT_SSP);
   enable_interrupts(GLOBAL);
   buffer[0x02] = 240;
   while(TRUE)
     if (address ==  1)
         output_high(pin_b0);
